[SOFT] TorchButton 2.3 et l3v5y Flash Light 0.2 : Utiliser votre HD2 comme lampe !
+26
thibaulto
htc8062
fredfer
elodelu
onthenight
milmoul
VBNgo
Sullio
rockin
Damage inc
soudeur69
bugfx32
charlesmix
Archeun
macadam21
J-Seb
Hawk19
Lermitte
majdus
edouardpremier
Silouan
30 participants
description[SOFT] TorchButton 2.3 et l3v5y Flash Light 0.2 : Utiliser votre HD2 comme lampe ! Empty[SOFT] TorchButton 2.3 et l3v5y Flash Light 0.2 : Utiliser votre HD2 comme lampe !
Voici deux programmes permettant d'utiliser votre HD2 comme lampe torche.
TorchButton v2.3
[SOFT] TorchButton 2.3 et l3v5y Flash Light 0.2 : Utiliser votre HD2 comme lampe ! Descri10
Pour ceux qui ne connaissent pas cela permet d'utiliser les LEDs de l'APN comme lampe torche.
[SOFT] TorchButton 2.3 et l3v5y Flash Light 0.2 : Utiliser votre HD2 comme lampe ! Screen10
[SOFT] TorchButton 2.3 et l3v5y Flash Light 0.2 : Utiliser votre HD2 comme lampe ! Change10
Version 2.3
- Fix icons not showing in HTC Sense or WM 6.5 start menu when installed to Storage Card.
Version 2.2
- New icons for all TorchButton apps (thanks tnyynt!). These only work in WM6.5 and up. Older OS's will still see the old icons.
- Added registry setting to use bright setting in blink mode (see BlinkUsesBrightMode).
- Bright mode now has a seperate timeout, configurable in registry (see BrightModeTimeout).
- Added support for Samsung Omnia i9x0 devices (hopefully they all work). Thanks to raph/zemrwhite2/PaSSoA. Thanks to Chainfire for testing on his Omnia i900L.
- [edit] Shortcut names have changed. I found them nicer this way, no two-line icons. And the text is now also not cut-off when added as shortcut in the home screen.
- [edit] Improved handling of bright mode. It should stop immediately now when pressed again, instead of waiting for a 500ms interval. This makes BlinkUsesBrightMode possible combined with low intervals for blink mode.
- [edit] Soft-reset your phone after upgrading from an older version! Else the new icons will not show.
Version 2.1
- Bright mode is now support on the HTC HD2 (Leo).
- Added a one-time warning message when bright mode is used for the first time.
Version 2.0
- Initial version with support for the HTC HD2 (Leo) (bright mode is not supported on the Leo)
Version 1.x
- Support for the Touch Pro
[SOFT] TorchButton 2.3 et l3v5y Flash Light 0.2 : Utiliser votre HD2 comme lampe ! Telech10
Télécharger TorchButton v2.3.cab
[SOFT] TorchButton 2.3 et l3v5y Flash Light 0.2 : Utiliser votre HD2 comme lampe ! Autres10
------------------------------------------------- OU ---------------------------------------------------
Même principe...
[SOFT] TorchButton 2.3 et l3v5y Flash Light 0.2 : Utiliser votre HD2 comme lampe ! Flash210
0.2
Added morse
0.1
Initial release
Télécharger l3v5y Flash Light v0.2.cab
Lancer le programme :
> Une pression sur l'écran allume le flash
> Un double tap laisse le flash allumé jusqu'au prochain double tap
Simple, mais efficace
> Glissez de gauche à droite pour lancer le mode morse.
Aussi disponible dans la [SOFT] TorchButton 2.3 et l3v5y Flash Light 0.2 : Utiliser votre HD2 comme lampe ! Yboourv Sinon, uploadez le Wink!
description[SOFT] TorchButton 2.3 et l3v5y Flash Light 0.2 : Utiliser votre HD2 comme lampe ! EmptyRe: [SOFT] TorchButton 2.3 et l3v5y Flash Light 0.2 : Utiliser votre HD2 comme lampe !
Il y a un mode dont l'icone est un doigt sur la flamme, il correspond à quoi ? parce que ca m'allume pas les led...
c'est normal c la PTT ça ne marche jamais Mort de Rire
[SOFT] TorchButton 2.3 et l3v5y Flash Light 0.2 : Utiliser votre HD2 comme lampe ! 595664 [SOFT] TorchButton 2.3 et l3v5y Flash Light 0.2 : Utiliser votre HD2 comme lampe ! 459461 cache
C'est un mode spécial Push-To-Torch spécifique à certains appareils AT&T.
Non utilisable pour nous Wink
Quelqu'un s'est aventuré à tester le mode bright? moi ca me met un message comme quoi ca va endommager l'appareil donc un peu retissant à tester.
Oui j'ai testé et cela fonctionne mais bon mieux vaut ne pas en abuser Wink
Sert à quoi ce mode ?
A avoir un éclairage encore plus puissant. Les LEDs sont poussés à fond
Effectivement vaut mieux pas en abuser alors
Ok, merci, je le trouve déjà assez puissant comme ça, je vais pas griller mes leds... [SOFT] TorchButton 2.3 et l3v5y Flash Light 0.2 : Utiliser votre HD2 comme lampe ! Icon_wink
[HS-VRAIMENT POURRI]
TorchButton, le nouveau bouton pour te torcher le cul !
Principe - Comment ça marche?
T'as plus de papier toilette, et t'as fini de chier?
Et bien appuie sur le bouton !
[SOFT] TorchButton 2.3 et l3v5y Flash Light 0.2 : Utiliser votre HD2 comme lampe ! 808734
[/HS-VRAIMENT POURRI]
Je vous conseille l3v5y Flash Light qui est très bien pensé :
>>> Ajout en poste 1
[SOFT] TorchButton 2.3 et l3v5y Flash Light 0.2 : Utiliser votre HD2 comme lampe ! 123544 Hum!
Ouai!
[SOFT] TorchButton 2.3 et l3v5y Flash Light 0.2 : Utiliser votre HD2 comme lampe ! Suspect Mais encore...
Quelque part ça peut être utile mais pas vraiment bon pour la batterie !
[SOFT] TorchButton 2.3 et l3v5y Flash Light 0.2 : Utiliser votre HD2 comme lampe ! Lol zepiii !
je vais tester le 2eme soft merci
ps: je vais enfin avoir le temps de bidouiller mon hd2 car en ce moment c'est tendu [SOFT] TorchButton 2.3 et l3v5y Flash Light 0.2 : Utiliser votre HD2 comme lampe ! Icon_biggrin
Je veux bien tester le 2e, mais le lien marche pas !
XDA est down pour le moment, sans plus Hawk19.
Ok... [SOFT] TorchButton 2.3 et l3v5y Flash Light 0.2 : Utiliser votre HD2 comme lampe ! Icon_wink
Sinon une nouvelle version de torch light est dispo ! [SOFT] TorchButton 2.3 et l3v5y Flash Light 0.2 : Utiliser votre HD2 comme lampe ! Icon_biggrin
Ben je ne comprends pas, j'ai les icônes tout moches, pourtant d'après le changelog de la 2.2 ça ne devrait pas être le cas...
Oui apparemment avec notre ROM 1.48 FRE les icônes restent anciennes... Sad
J'ai un problème avec l'installation.
Je l'avais, mais du jour au lendemain il ne marche plus.
Je l'ai déinstaller par le suppression de prog. Mais quand je tente de le re installer il me dis que cela a échoué Sad
Bonsoir!
MISE A JOURTorchButton 2.3
* Fix icons not showing in HTC Sense or WM 6.5 start menu when installed to Storage Card.
Maintenant nous aussi on a les belles icones Very Happy
>>>> ICI
je passe en 2.3 ! ^^
Ah bah tiens ooops j'ai oublié de faire la mise à jour du post pourtant cela fait quelques temps qu'elle est dispo cette version 2.3 !
Par contre jamais réussi à avoir les nouvelles icônes sur les ROM HTC Fr Sad
Si quelqu'un réussi faites moi signe Wink
Niquel, dis moi, tu peux mettre dans la plupart des post le N° de version, c'est bien mieux pour le suivi.
Merci d'avance !
je vais surement passer pour un chieur mais je trouve sa aussi rapide de lancer l'appareil photo et d'activer le flash continu que d'utiliser ce logiciel oO.
