[ROM][WWE|GER|FRA|ITA|NLD] |Mar 15| Energy™-.¸¸.·´¯ 6.5|21916 / 6.5.X|29017 * Sense 2021
+35
golgote25
xp_98
smilt
Sejay
psykho_
backchich
bga1373
dakbes
tibidul
bigbrutus97
philippeb
akhekaton
captainsam
twedie
cnsprtnr
Dandy-
Twipeep
fc160955@skynet.be
kurohebi
Z80
benoitdu37
rod
Euskadia
marcopolo_22
alan42
ARM
bonzai
NERVEUX
Guiky
Dougi
onthenight
39 participants
description[ROM][WWE|GER|FRA|ITA|NLD] |Mar 15| Energy™-.¸¸.·´¯ 6.5|21916 / 6.5.X|29017 * Sense 2021 Empty[ROM][WWE|GER|FRA|ITA|NLD] |Mar 15| Energy™-.¸¸.·´¯ 6.5|21916 / 6.5.X|29017 * Sense 2021
Energy Series
[ROM][WWE|GER|FRA|ITA|NLD] |Mar 15| Energy™-.¸¸.·´¯ 6.5|21916 / 6.5.X|29017 * Sense 2021 EnergyROM_Collection
Welcome to the "EnergyROM" thread !
For easier updates you can always check the website for energyroms at http://www.energyroms.com
This development thread is for my "Energy" custom firmware series for the HTC Touch HD2 (Leo) device.
I build my ROMs with four main goals.
•Eye candy ( I want my ROM to look great and for it to all flow together nicely)
•Speed !!!
•Smoothness, consistency and good aesthetics
•Stability through private beta testing before public release
I preconfigure a lot of things in my ROM, because when I flash it on my phone, I want it ready to go. So, expect the backlight to be set at the maximum brightness, the ringtone, sms/email and other notifications to already be set. Doing it this way, makes for a nice ROM that's ready out of the box.
This ROM is compatible with all HD2 devices manufactured by HTC.
If you're an advanced user and know what you want already, jump directly to post #2 and download what build you'll like to install.
If you're a beginner, read on as there's a few things you need to do first.
•You need to install a modified "SPL" on your device that allows installation of custom ROMs such as this one. It's called a "Hard SPL" and it's in of these stickies at the top of this forum (not this thread!).
•You need to install a compatible "radio" firmware that works with this ROM. The radios that work with this ROM all have ".50" in their name.
If you have a TMobile USA branded device, then you don't need to flash a "radio". The ROM will work just fine with it. However, if you own an asian or european HD2 then you NEED to flash a .50 radio.
I RECOMMEND FLASHING RADIO 2.07.50 or 2.12.50 ! 2.07 can be downloaded here: > CLICK <.
After you install the correct radio, go on to post #2 and download the ROM of your choice. There's always a choice of 2 (sometimes 3) builds for each "flavor" of the ROM. Looking at the download folders you'll see:
•A 21916 Build which is the most reliable and bug free release. It has the Start menu button at the top left corner. This build uses the same stock system that came with your device. This is usually the fastest and most stable build, but it's also the least fancy
•A 29007 Build that's the latest in Microsoft's development with the Start menu button at the bottom left corner and big softkeys, making it all very "finger friendly". These builds reflect the latest cutting edge technology from Microsoft. Most people choose this build... Why else would you install a custom ROM ?
After flashing the ROM, please read the FAQ in post 4, and maybe even the links to the individual modifications for each ROM in post 2 (such as "Cookie", "GTX" etc). It will help you get more familiar with which one and will greatly reduce the initial learning curve.
The current build numbers and date can be seen in the title of this thread. I usually update the ROMs every few days, as new builds come down the pipe.
I recommend learning to backup your settings with either Sashimi or UC (User Customization), or the built in "Settings Exporter" in the Tools folder. Backing up with SPB Backup or similar products, is NOT recommended, as they tend to backup the previous release's registry/file bugs as well!
BEFORE YOU DOWNLOAD AND FLASH ANY OF THESE ROMS, MAKE SURE YOUR RADIO VERSION IS AT LEAST 2.07.50 (not 51! any .50 version should be okay) , OR YOUR PHONE WILL NOT BOOTUP AFTER YOU FLASH !
IF YOU HAVE A TMOBILE USA DEVICE, THIS DOES NOT APPLY TO YOU AND YOU DO NOT NEED TO FLASH A NEW RADIO, BUT 2.07.50 IS STILL RECOMMENDED TO WORK BEST WITH THIS ROM.
[ROM][WWE|GER|FRA|ITA|NLD] |Mar 15| Energy™-.¸¸.·´¯ 6.5|21916 / 6.5.X|29017 * Sense 2021 EnergyROM_Energy
[ROM][WWE|GER|FRA|ITA|NLD] |Mar 15| Energy™-.¸¸.·´¯ 6.5|21916 / 6.5.X|29017 * Sense 2021 EnergyROM_xMas
[ROM][WWE|GER|FRA|ITA|NLD] |Mar 15| Energy™-.¸¸.·´¯ 6.5|21916 / 6.5.X|29017 * Sense 2021 EnergyROM_Dinik
[ROM][WWE|GER|FRA|ITA|NLD] |Mar 15| Energy™-.¸¸.·´¯ 6.5|21916 / 6.5.X|29017 * Sense 2021 EnergyROM_sencity
[ROM][WWE|GER|FRA|ITA|NLD] |Mar 15| Energy™-.¸¸.·´¯ 6.5|21916 / 6.5.X|29017 * Sense 2021 EnergyROM_TouchOfGlass
[ROM][WWE|GER|FRA|ITA|NLD] |Mar 15| Energy™-.¸¸.·´¯ 6.5|21916 / 6.5.X|29017 * Sense 2021 EnergyROM_GTX
description[ROM][WWE|GER|FRA|ITA|NLD] |Mar 15| Energy™-.¸¸.·´¯ 6.5|21916 / 6.5.X|29017 * Sense 2021 EmptyEnergy, NRG, nrg
March 15th, 2011
29017 Build
Some taskbar icons revised
Volume control issues on Rhodium solved
March 8th, 2011
29008 Build.
Java package updated
Some dialer revisions
Provisioning revisions for CDMA devices
.net errors with 28XXX build hopefully eliminated
etc...
February 12th, 2011[/center]
  • More packages updated from latest official Oboe ROM (list below)
"Album"="3_2_20203830_00"
"Calculator"="1_1_20211430_0"
"CommManager"="2_10_9_0"
"Contact_Picker"="1_0_20203822_00"
"Contact_Utility_Engine"="1_2_20202525_00"
"FM_Radio"="2_5_20211429_00"
"Full_Screen_Player"="1_8_20203830_00"
"HTCLockScreen"="2_0_20203825_00"
"Menu_Enhancement"="1_1_20203825_00"
"Message_Enhancement"="1_2_20222031_00"
"New_Contact_Card"="1_1_20211614_0"
"Notification_Enhancement"="3_5_20221926_00"
"Resource_Proxy"="1_0_20203824_00"
"SharedResource"="1_0_20203824_00"
"StartIconLoader"="2_5_20203822_0"
"Text_Selection"="1_0_20203825_00"
"USB_To_PC_Pop_Up"="2_3_20211825_00"
"Voice_Recorder"="2_0_20221721_0"
February 1st, 2011
  • Sense 2021 from latest official Oboe ROM (major update... Last Sense version was from November of last year)
  • By popular demand the 28XXX build was brought back
Energy/Anastasia/.Sensity/Touchofglass/GTX
[ROM][WWE|GER|FRA|ITA|NLD] |Mar 15| Energy™-.¸¸.·´¯ 6.5|21916 / 6.5.X|29017 * Sense 2021 Download_us [ROM][WWE|GER|FRA|ITA|NLD] |Mar 15| Energy™-.¸¸.·´¯ 6.5|21916 / 6.5.X|29017 * Sense 2021 Download_german [ROM][WWE|GER|FRA|ITA|NLD] |Mar 15| Energy™-.¸¸.·´¯ 6.5|21916 / 6.5.X|29017 * Sense 2021 Download_french [ROM][WWE|GER|FRA|ITA|NLD] |Mar 15| Energy™-.¸¸.·´¯ 6.5|21916 / 6.5.X|29017 * Sense 2021 Download_dutch [ROM][WWE|GER|FRA|ITA|NLD] |Mar 15| Energy™-.¸¸.·´¯ 6.5|21916 / 6.5.X|29017 * Sense 2021 Download_italian
Energy/Reference
MAxSense/Titanium
[ROM][WWE|GER|FRA|ITA|NLD] |Mar 15| Energy™-.¸¸.·´¯ 6.5|21916 / 6.5.X|29017 * Sense 2021 Download_plain
Click the following link for addons, XDA_UC help and various cabs specific to this ROM series
description[ROM][WWE|GER|FRA|ITA|NLD] |Mar 15| Energy™-.¸¸.·´¯ 6.5|21916 / 6.5.X|29017 * Sense 2021 EmptyRe: [ROM][WWE|GER|FRA|ITA|NLD] |Mar 15| Energy™-.¸¸.·´¯ 6.5|21916 / 6.5.X|29017 * Sense 2021
Bonsoir caramel,
Elle est de toi cette rom (enfin ces rom)?
Tu mets pour la radio 2.12.50 ! 2.07, moi j'ai 2.12.50.02_2 pour moi je dis c'est bon mais..... tu confirmes
Bon je suis une quiche dans la langue de Shakespeare, alors vive mon copain gogol mais bon sa qualité de traduction est moyenne quand même
Il y as des softs d'installé dedans ou c'est de base comme on peux l'avoir avec une rom officiel (mais optimisé je me doute bien)
Tu fais bien de me le dire, j'ai oublié la source [ROM][WWE|GER|FRA|ITA|NLD] |Mar 15| Energy™-.¸¸.·´¯ 6.5|21916 / 6.5.X|29017 * Sense 2021 803859
Ben là je sais sa qu'il y a comme application lol!
Elle m'as l'air très cette ROM
Il n'y à aucune ROM FR du 6 janvier
MErci pour les voeux.. CASPER... Very Happy
Salut, je cherche s'il existe un Cab l'appli pour la rotation écran intégrés dans la Rom Energy
"Rotate Screen (by clicking icon or by pushing down Send key)"
J'ai cherché, peut être mal, mais j'ai pas trouvé ! ^^
Salut, la ROM Fr va sortir ou pas à votre avis ?
elles sont en fr
Bonjour NERVEUX,
Pourrais tu passer par les présentations stp, Merci [ROM][WWE|GER|FRA|ITA|NLD] |Mar 15| Energy™-.¸¸.·´¯ 6.5|21916 / 6.5.X|29017 * Sense 2021 750705
bonsoir,
depuis que j'ai installer la rom energy MAxSense/Titanium, j'ai plus HTC quand je demare mon leo ca me gène pas trop.
ce qui me derrange c'est que je ne peut plus faire un Task29 ni changer ma rom radio.
le HSPL 2 ou 3 passe, et la j'ai tous remis d'origine sfr (rom et spl).
une idée serai la bienvenue mercri
bonsoir, je viens d'installer la rom energy 21916. Sense2.5. FRA.Cookie. 2.0.DinikGlass et je la trouve excellent, mais je n'arrive pas à faire fonctionner Skype. Avec vous une solution? merci d'avance et longue vie à HTC-DEV.
ARM a écrit:
bonsoir,
depuis que j'ai installer la rom energy MAxSense/Titanium, j'ai plus HTC quand je demarre mon leo ca me gène pas trop.
la je dit n'importe quoi, la soluce c'est HSPL et tous passe.
ces sa posé des questions sens chercher sur le forum.
Salut alan42,
Skype pour winmo c'est fini!
clubic.com a écrit:
Skype retire ses logiciels pour Windows Mobile
Publiée par Guillaume Belfiore le Jeudi 25 Fevrier 2010
téléphonez gratuitement : skype logo
Le leader du marché de la voix sur IP Skype vient de mettre fin au téléchargement de ses logiciels Skype Lite et Skype pour Windows Mobile. Sur la FAQ du site officiel l'équipe explique ainsi : « nous avons choisi de retirer Skype Lite et Skype pour Windows Mobile parce que nous voulons offrir à nos nouveaux clients une nouvelle version améliorée ».
La version pour Windows Mobile devrait ainsi s'aligner sur celle de l'iPhone qui est disponible depuis peu sur Symbian. Avec une ergonomie repensée elle simplifie la possibilité d'effectuer des appels depuis le client Skype vers un autre utilisateur du logiciel. Les mobinautes ayant déjà téléchargé l'une des deux versions du logiciel peuvent cependant continuer à l'utiliser jusqu'à la fin 2010.
Notez qu'il est toujours possible de récupérer l'assistant d'installation depuis cette adresse, même si la page devrait bientôt être retirée du site Internet. L'on imagine que Skype souhaitera développer une version pour Windows Phone 7 tout en offrant une ergonomie similaire pour les utilisateurs de Windows Mobile 6.5.
Skype existe pour android, tu peux installer [ROM][WWE|GER|FRA|ITA|NLD] |Mar 15| Energy™-.¸¸.·´¯ 6.5|21916 / 6.5.X|29017 * Sense 2021 61393 en dual boot...
Bonsoir MarcoPolo, merci pour ta réponse, mais pour le moment, je ne suis pas encore au top pour mettre Android sur mon téléphone, il va falloir que je me plonge dans le forum afin de trouver la méthode et c'est pas gagné!, mais bon, il faudra que je prenne le temps. merci encore.
Empty Directory sur les Versions FR !
Possibilité de lien ou de re upload s'il vous pliiz ?
C'est fait Very Happy
Waouuuuuu ^^ Nickel la rapidité ^^
DeDo the king
bonjour à tous,
je suis sur Rom Energy depuis lontemps et je remarquais qu'avec ma rom radio 12. ..ect je captais plutot mal. En regardant sur xda j'ai vu que toutes les roms radio avec 50 étaient compatibles avec les roms Energy.
donc je suis passé sur la dernière en ligne sur le forum la 15....ect, depuis je n'ai que des problèmes.
des pertes de réseau tout le temps et dès que j'appui sur le bouton racrocher le téléphone se bloc sur un ecran noir impossible de réactiver l'écran.
je suis repassé sur rom officielle après un task29 puis la même chose pour revenir sur rom Energy mais le porblème est persistant. quelqu'un pourrait m'aider à trouver une solution.
si tu as flashé une rom officielle avant de revenir sur nrj ta radio a changée ,as tu remis celle qui marchait ?
Regarde aussi le retour des membres sur les radio
[Roms Radio] Liste des Rom Radio pour le HD2
enfin ce n'est peut être qu'une coincidence et ton souci serai ailleurs Wink
La Rom officiel que j'ai utilisé est 3.14.406.2
[ROM Radio_15.42.50.11U_2.15.50.14 et j'ai refait un task29 avant de repasser sur Energy.
Question au passage le task29 efface toutes les roms, système et radio, ou seulement la rom système?
Actuellement j'ai mis la rom Radio 2.14.50.09U, au niveau réseau tout est bon.
mais je concerve mon problème d'écran noir lorsque j'appui sur le bouton raccrocher.
Penses-tu que cela puisse être une défaillance matériel? [ROM][WWE|GER|FRA|ITA|NLD] |Mar 15| Energy™-.¸¸.·´¯ 6.5|21916 / 6.5.X|29017 * Sense 2021 123544
J'ai pris la Rom Maxsense et je voudrais savoir comment avoir la nouvelle interface du regroupement des sms svp.
Salut, c'est là, le forum qui roupille ? Very Happy
Bon, déjà,
En fait, précisément, ça dépend du contenu qui est flashé en même temps que le task29, mais fondamentalement, le task29 lui-même ne met à zéro que la ROM système.
Seulement, pour déclencher le processus sur certains appareils (comme le HD, par exemple), on passe par un RUU classique, et on touche aussi d'autres parties. Etant donné que la technique est transposable au HD2 (c'est pratique, ça permet de flasher autre chose en même temps), la réponse est donc : "ça dépend". Wink
Personnellement, j'ai eu l'occasion d'utiliser deux contenus distincts :
- Une ROM radio, justement, donc ça efface la ROM système et ça installe une ROM radio (évidemment)
- Un splash screen (le premier à s'afficher), qui est dans une zone protégée et doit se flasher séparément : ça met donc à zéro la ROM système et ça flashe cet écran d'accueil. L'avantage, c'est que c'est beaucoup plus rapide que la première solution...
ROM Energy 28244 récente ?
C'est précisément une des raisons pour lesquelles cette build m'énerve... Very Happy
ayant eu cette rom depuis un bail sur hd1
me voilà heureux possesseur d'un hd2 à présent, je suis heureux de voir voir les rom NRGZ sur hd2
top fluide, aucun souci, moi j'ai pas l'ecran noir en raccrochant
en revanche je ne trouves pas les versions sencity / touch of glass / gtx / etc... dans les téléchargmeents
