[SOFT] GOTO : Lock alternatif pour android [Payant]
Message par Jedi.6 le Mer 11 Aoû 2010 - 10:50
GOTO
un lock alternatif pour non androidphones.
La particularité de celui la est qu'il permet depuis son ecran via un slide d'avoir accés soit :
- ses SMS
- l'historique de ces appels
- ses mails (pour le moment uniquement GMAIL)
- et bien sur déverrouillage
V1.20.1 : This was a minor release to address a few force close issues reported by users.
Added new GOTO Settings icon to set it apart from the GOTO app.
Fixed force close when missing a call from an unknown number.
Fixed force close caused by trying to launch an invalid custom app shortcut.
V1.20This release implements user suggestions for customization and addresses a few device specific issues. Specifically, we've resolved the issue with the alarm on HTC devices and added a workaround for the home key issue on Droid X devices.
Added customization of app shortcuts in settings so you can now choose which app you want shortcuts to launch when unlocking.
Added user preference for disabling the home key. This can be used as a workaround on the Droid X to resolve the home key issue. Open the GOTO Settings app and uncheck "Disable Home key" for now, we are investigating a more permanet solution.
Optimzied our graphics to reduce overall application size and memory footprint.
Fixed alarm issue on HTC devices, you can now turn off the alarm.
Adjusted hit area of thumb icon to reduce chance of unlocking to Messaging by accident.
Fixed bug where arrow on thumb icon was not dissappearing at times.
Fixed random crash bug that was reported by some users.
v1.15.1 This was a minor release to address a crash bug that was reported by users of the Samsung Vibrant phone.
Fixed force close related to alarm updating.
We've addressed customer concerns regarding security with our previous implementation of the background chooser. This has been moved out of the main UI into the new settings app which will also allow us to continue adding user settings and customizations based on your feedback.
You will now see two icons in your launcher, one for GOTO, and one for the GOTO Settings app:
V 1.15 Added the ability to crop when selecting the background image to maintain the aspect ratio and eliminate any image stretching.
Added new settings app to allow for more preferences and customizations.
Moved background settings menu from main UI into settings app, addressing security concerns.
Moved the owner name setting from main UI to settings app, addressing security concerns.
Added the ability to toggle unlock sound in the settings per user request.
Alarm bug fix to allow the alert UI to appear on top of GOTO for most devices (we are still working on the bug on the EVO and other HTC phones that don't use the Android alarm app).
Change in the way the app is started to prevent home screen from displaying when starting up from sleep.
V 1.12.1 This was a minor release to address a crash bug that was reported by users. We are currently working on a larger more comprehensive release that implements additional functionality and customer feedback.
Fixed force close related to image orientation check when choosing a background.
V 1.12 Fixed force close when choosing certain images as background.
Fixed bug where pattern unlock prompt would not display when running GOTO manually from launcher.
Disabled volume key sounds when screen is locked.
V 1.11 Added ability to set your own background (press Menu key).
Messaging shortcut now supports launching other messaging apps if installed.
Released to Android Markets in Australia, Canada, New Zealand, and the United Kingdom.
V 1.06 Disabled Home key.
Changed battery percentage to always display.
Fixed bug to improve battery usage.
V 1.05 Fixed force close when using 24-hour time format.
Fixed force close in weather updating.
Fixed bug that was causing battery drain.
Modified back key so it doesn't switch back to GOTO once you've unlocked.
Fixed contact names/pictures in notification previews for newer devices.
V 1.00 Initial release to Android market.
Re: [SOFT] GOTO : Lock alternatif pour android [Payant]
Message par Nico le Mer 11 Aoû 2010 - 13:53
pas mal comme lock,je vais essayer
par contre pour le changelog,il explique rien !
http://www.forum-htc-dev.net
Message par Jedi.6 le Mer 11 Aoû 2010 - 14:01
Mise à jour du post 1 avec le changelog Wink
Message par Invité le Jeu 12 Aoû 2010 - 12:02
Impossible a télécharger !!
Message par Jedi.6 le Jeu 12 Aoû 2010 - 12:09
même par la
Message par Invité le Jeu 12 Aoû 2010 - 12:31
Tous les liens de téléchargement renvoient vers le market et il est introuvable sur celui-ci !
Message par Nico le Jeu 12 Aoû 2010 - 13:03
@Jedi.6 a écrit:Mise à jour du post 1 avec le changelog Wink
beaucoup mieux le changelog
Message par Jedi.6 le Jeu 12 Aoû 2010 - 13:46
Comme il est encore en dev, il a du être momentanement supprimé.
Message par nekho69 le Jeu 12 Aoû 2010 - 13:53
Je l' avais testé et oublier car il avait plusieurs touche pour la sortie de veille (impossible de garder juste le trackball sur itanium froyo v1)
nekho69
ROMs : viper one
: : viper
Message par Jedi.6 le Jeu 12 Aoû 2010 - 14:44
exact, je ne l'utilise plus non plus a cause de ca Sad
en fait le trackball allume et se positionne sur l'ecran d'acceuil
le bouton home : déverrouille completement le telephone
Message par TonyKsh le Mar 1 Fév 2011 - 9:14
J'ai installé GOTO v1.33 sur mon HD2 mais le slide est plus petit que l'écran, avez vous une solution ? Merci
TonyKsh
: : Android CleanDroid v1.11
