[SOFT/TUTO] SETCPU : Utilitaire de gestion de CPU, fréquence, optmisation batterie, ... [Gratuit/Payant]
Page 11 sur 12 Précédent  1, 2, 3 ... , 10, 11, 12  Suivant
Re: [SOFT/TUTO] SETCPU : Utilitaire de gestion de CPU, fréquence, optmisation batterie, ... [Gratuit/Payant]
Message par DEDO le Sam 7 Mai 2011 - 22:30
alors deux possibilités
tu dézippes et l'apk est dedans
si c'est pas le cas tu changes l'extension du fichier par .apk (certain logiciels de download renomme les apk en zip) Wink
Message par Gill le Dim 8 Mai 2011 - 0:37
Il l'a dl chez XDA. (comme moi) Very Happy
Donc l'apk est dans le zip. Wink
Gill
Message par krisstian le Dim 8 Mai 2011 - 14:49
OK, vu
merci de votre aide
krisstian
ROMs : Viper
: : TF201
Message par Gill le Mer 8 Juin 2011 - 0:49
Je n'ai pas les droits pour mettre à jour le post 1. Wink
Changelog:
2.1.2 - Minor update. Adds a time of day based profile which will trigger based on a set time range. Fixes a bug with profiles and certain dual core kernels. Switched to the Android 3.0 SDK. Note that on some Tegra 2 kernels, scaling is completely controlled by the driver.
2.1.2.1 - Fixed a crash that occurred when updating from certain versions of the profiles database.
2.1.3 - Added perflock disabler support for HTC kernel 2.6.35.10 (in beta). Enhanced the Time in State readings in the System Info menu to include percentages. Removed WiFi permission until this feature is added to profiles. Fixed another database crash, and other bugfixes.
2.1.4 - Revamped Info tab UI. In portrait, clicking on an item in the Info tab will launch information on that category, and pressing back will return to the menu. In landscape, the content and the menu are split into two columns. Benchmarks are at the bottom. Added a chart for Time In State readings. Widget reliability fixes and optimizations. The main screen now indicates which kind of profile is currently active with an icon. Miscellaneous bugfixes and optimized performance.
setcpu_2.14.zip
setcpu_2.14.zip dans mon Dropbox
Gill
Message par Jedi.6 le Mer 8 Juin 2011 - 8:59
Post 1 a jour Wink
Message par BigPat le Mer 8 Juin 2011 - 9:01
Merci pour les infos et la maj Wink
C'est vraiment LE logiciel à avoir absolument.
Message par Jedi.6 le Mer 8 Juin 2011 - 9:03
rajout en post 1 du site de l'application : setcpu.com
Message par Superchocobo1 le Lun 27 Juin 2011 - 15:33
Bonjour à tous smile
Est-ce que quelqun'un pourrait m'aider à configurer setCPU afin d'obtenir une configuration pour économiser un maximum de batterie ? Car j'ai beau lire et relire le tuto je ne comprends pas grand chose
Merci d'avance.
Superchocobo1
ROMs : 1.44.163.3 FRE
Message par VM54 le Lun 27 Juin 2011 - 15:54
à la première utilisation, tu donnes les droits root, le logiciel va détecter les capacités du téléphone.
ensuite dans l'écran principal, tu peux changer la fréquence max et min du processeur. perso j'ai mis 1190 et non le max pour le HD2 (au lieu de 990 sans overclock). min = 245.
Les modes scaling permettent de définir des comportements plus ou moins réactif du téléphone notamment en sortie de veille mais cela peut se faire au détriment de la conso.
N'ayant pas le mode smartas, qui semble le mieux, je suis en conservative.
Ensuite dans profile, tu peux regler la frequence pour différentes situations.
Perso j'ai :
- batterie <20%, max 806
- temp > 42°, max 883
j'ai enlevé le screen off parceque ca laguait trop en sortie de de veille.
le mieux est de faire des essais et de voir ce qui convient le mieux à ton utilisation du téléphone.
ROMs : stock 4.19.118.9 S-Off
Message par Superchocobo1 le Lun 27 Juin 2011 - 16:09
Ok merci pour tes conseils je vais tester ta config ^^
Superchocobo1
Message par BigPat le Lun 27 Juin 2011 - 18:27
Ne pas oublier de cocher "Set on Boot"
Message par kokotchiii le Mar 28 Juin 2011 - 0:33
Bonsoir à tous !
Jai eu beau lire tout les posts je n'ai pas compris comment bien configurer setcpu . J'ai donc laissez les valeurs d'origines soit 1309 max et 245 min .
Quelles configuration allie Économie batterie en non utilisation et puissance quand nécessaire ?
kokotchiii
ROMs : Miui 2.3.5-a
: : Sensation 1.9
Message par Sony le Mar 28 Juin 2011 - 0:48
Mode interactive ou smartass si tu as avec un cpu max pas trop élévé... Wink
Message par Superchocobo1 le Mar 28 Juin 2011 - 10:30
Hello, alors j'ai utilisé la config de VM54 et ça n'a rien changé en une nuit je suis passé de 86% de batterie à 30%, je me demande si cela ne vient pas de la ROM ANDROID qui est installée sur la carte SD ?
Superchocobo1
Message par kokotchiii le Mar 28 Juin 2011 - 11:14
Comment revenir au paramètre que javais avant setcpu car au final ma batterie se décharge plus vite ?merci
kokotchiii
ROMs : Miui 2.3.5-a
: : Sensation 1.9
Message par BigPat le Mar 28 Juin 2011 - 11:27
Tu désinstalles Setcpu
Message par Sir Darknar le Mar 2 Aoû 2011 - 13:13
J'aurais besoin de quelques conseils quant aux changements de fréquence de mon HTC Desire S (processeur 1Ghz), S-off, rooté et sous CoreDroid.
J'ai bien compris comment faire, mais je ne sais pas quoi augmenter ou baisser.
La plus grosse utilisation que je fais avec mon tel est l'écriture de SMS, Internet en Wi-fi et éventuellement des jeux.
Aussi ;
1/ Dois-je me mettre ondemand, interactive, userspace, performance (je ne pense pas), smartass ou conservative ?
2/ Pouvez-vous me donner les paramétrages idéals pour tous les profils ?
Si je vous demande ces services, c'est que je ne connais absolument rien dans le sujet, merci de votre compréhension.
Cordialement,
Sir Darknar.
Sir Darknar
ROMs : à remplir
Message par Sony le Mar 2 Aoû 2011 - 13:40
Mets smartass ou interactive pour que ça ne pompe pas trop de batterie...
Pas besoin de mettre tous les profils...
Maintenant, si tu lis les posts précédents tu pourras te faire une idée...On ne va pas répéter 100 fois la même chose...
Sinon, grosso modo, tu mets en paramétrage de base
Governor smartass ; fréquence minimum : ça dépend jusqu'à quelle fréquence tu peux baisser....Je ne mettrais pas la plus basse mais juste celle au-dessus...
Pour la fréquence max, overclocke légèrement (1100 ; 1200 environ)
Puis tu te crées un profil sleep mode en mettant en max et minimum l'avant dernière fréquence la plus basse...
Idem pour la température...Tu définies une témpérature max et tu mets des fréquences basses...
Après à toi de voir si tu as besoin des autres profils...Il faut faire des essais de toute manière...
Maintenant, n'overclocke jamais à fond ...
Et si tu veux plus de détails, lis les posts précédents...Wink
Message par Fredoah le Mer 3 Aoû 2011 - 0:35
v 2.2.4, suite à MAJ Market Wink
Fredoah
Seigneur
Seigneur
Appareil principal : N9005
ROMs : XXUGBOF1 (5.0)
: : De passage... ::
Message par VM54 le Dim 14 Aoû 2011 - 19:30
Le change log des dernieres version pour mettre à jour le post 1 :
2.2.0 - Added an "In Call" profile. Improved the Set on Boot safemode function by including a flashable zip that toggles SetCPU's safemode. Press menu on the main tab for more details. Added autodetect support for all Tegra 2 fakeShmoo kernels (ie. G2x). Added a "Voltage" tab for undervolting the CPU on fakeShmoo kernels, some custom Galaxy S kernels, and some Nexus S kernels. This is a full-fledged interface for undervolting these devices, and includes backing up and restoring and a Set on Boot checkbox. Improved the way SetCPU initially requests root. Various miscellaneous bugfixes.
2.2.1 - Fixed the voltage force close bug on some Galaxy S devices by adding undervolt support for older Galaxy S undervolt kernel patches. Added perflock disabler support for HTC kernel 2.6.35.9 (beta).
2.2.3 - Fixed an issue where the voltage menu displayed frequencies backwards on certain devices capable of voltage control. Added support for additional CPU temperature sensors.
2.2.4 - Improved support for the new MSM 8x60 devices (such as the HTC EVO 3D and Sensation).
[i]De plus, je suis suis surpris de retrouver le lien de téléchargement direct quand je lis ça sur XDA :
ROM developers: Please do not include SetCPU in your ROM. I appreciate the work you're doing, but link to this thread instead, and I'd really appreciate it if you mention that SetCPU is available on the Android Market.
The program is free here for XDA members. It costs 1.99 on the Android Market and available for purchase on the Amazon Appstore for users in the US.
[/i]
Message par th3skater le Lun 15 Aoû 2011 - 20:36
Merci ! Je cherche quelque chose dans ce style là justement !
th3skater
ROMs : CyanogenMod 7.0.3
: : Téléphone: Zte Star Trail
Message par th3skater le Lun 15 Aoû 2011 - 20:44
Dommage mon android n'est pas root !
th3skater
Message par Fredoah le Lun 15 Aoû 2011 - 20:46
Très surprenant, en effet VM54 Wink
Fredoah
Seigneur
Seigneur
[soft] Impossible d'éditer les profils SetCPU
Message par Dualias le Ven 28 Oct 2011 - 4:48
J'ai installé la dernière ROM Miui francisée et je voudrais accroître l'autonomie de mon DHD par le biais, entre autre, de SetCPU. Seulement, lorsque je lance l'appli (qui a les privilèges root), je peut choisir le scalling sur l'onglet Main mas il m'est impossible d'éditer la plage de fréquences CPU ni la priorité ni d'ailleurs les valeurs de température et le niveau de batterie pour les profils concernés...
J'ai bien coché enabled, quelqu'un aurait une idée d'où cela peut venir ?
Merci pour votre aide !
Dualias
ROMs : niarkMIUI 4.3.0
: : http://blog.dualias.com
Message par VM54 le Ven 28 Oct 2011 - 8:11
tu as peut être un kernel incompatible.
