description[ROM 2.3][12.12.2010] Android 2.3 port from SDK for Dream (2708 kernel) Empty[ROM 2.3][12.12.2010] Android 2.3 port from SDK for Dream (2708 kernel)
Android 2.3 Port for HTC Dream
[ROM 2.3][12.12.2010] Android 2.3 port from SDK for Dream (2708 kernel) Descri10
Since people were asking for it, here is a quick port for the G1
Thanks and credits goes to :
-pershoot using his kernel boot-cm_2635.9_ds_32b_radio2708-oc-uv-xtra-ram-fp-120810
-seo using mostly his port for magic as base
I'm currently using the 14MB ram hack with radio 2.22.28.25 & hboot 1.33.0013d with CM6.1
If you are not you need to follow these steps first : 2708+ enabled kernel [14MB ram with radio 2.22.27.08/2.22.28.25 & hboot 1.33.0013d]
OR
you can always try to flash a non 2708 kernel from pershoot like boot-cm_2635.9_ds_32b-oc-uv-xtra-ram-fp-120810 after flashing this ROM but I have'nt tested it myself.
working : data/radio but like all other ports no mic
not working : mostly everything [ROM 2.3][12.12.2010] Android 2.3 port from SDK for Dream (2708 kernel) Wink
seo has wifi working on magic, I'm looking into his wpa_supplicant.exec script but changing wlan.ko and driver did'nt worked.
For wiping I suggest using Ohsaka SuperWipe as the update script does'nt wipe /data partition. [ROM 2.3][12.12.2010] Android 2.3 port from SDK for Dream (2708 kernel) Eek
[ROM 2.3][12.12.2010] Android 2.3 port from SDK for Dream (2708 kernel) Screen10
[ROM 2.3][12.12.2010] Android 2.3 port from SDK for Dream (2708 kernel) Attachment[ROM 2.3][12.12.2010] Android 2.3 port from SDK for Dream (2708 kernel) Attachment[ROM 2.3][12.12.2010] Android 2.3 port from SDK for Dream (2708 kernel) Attachment
[ROM 2.3][12.12.2010] Android 2.3 port from SDK for Dream (2708 kernel) Change10
Première release Wink
[ROM 2.3][12.12.2010] Android 2.3 port from SDK for Dream (2708 kernel) Telech10
Download link : here
[ROM 2.3][12.12.2010] Android 2.3 port from SDK for Dream (2708 kernel) Autres10
Aussi disponible dans la [ROM 2.3][12.12.2010] Android 2.3 port from SDK for Dream (2708 kernel) Yboourv Sinon, uploadez la Wink!
description[ROM 2.3][12.12.2010] Android 2.3 port from SDK for Dream (2708 kernel) EmptyRe: [ROM 2.3][12.12.2010] Android 2.3 port from SDK for Dream (2708 kernel)
Il y a l'android market d'installer sur cette rom ?
