[ZIP / ROM 2.2.1] RAFDROID HD 4.2.0 [07.08.2011]
+87
xboxman18000
plexus
jimmy33
devil51
Lulucz
marus
Rusherman
AKASHIK
Pittyone
lolovtt
Dragon 548
gast
AxelNieza
ericp011
Batou_37
Magos
Erick
micky97115
alpin38
Hug le O
totolachance
croftman
Bédabou
Jedi30
spyoner971
aldai
funkyadelic
ejay36
emimat62
lopuma
kalhohan
doc jipeg
john59
anouarhozman
regtalou
fred89
Lolo78
laclys
jilou_86
migatt
Angefrance
M2o
elgringo116
toubabou
david54
babar27
Stephg
mathieu31770
seb31
lonewolf83
hou$$
masciou
mouximoux
didier13380
the wishmaster1
papaille44
Radh
Luigicube
Darkangel52
sbibif
seb_ff
voileuxcool
davidbourges18
raidmou
valentindu956
Davids777
Valais
Ricochet
darkvicious
Frakatchoo
yoga7862
gyzmocops
Erosennin
chrisdc91
Dragonlyon
punbb
tiiago
RuDy70
Allen
Thesalan
philippeb
psylooooo
blackpanther
Bamlot
91 participants
descriptionrafdroid hd - [ZIP / ROM 2.2.1] RAFDROID HD 4.2.0 [07.08.2011] Empty[ZIP / ROM 2.2.1] RAFDROID HD 4.2.0 [07.08.2011]
rafdroid hd - [ZIP / ROM 2.2.1] RAFDROID HD 4.2.0 [07.08.2011] Rafdroid_hd_logo
BE
ADVISED: THIS BUILD, CAUSE IT'S SIZE, WILL WORK ONLY WITH THIS METHOD OF
DATA2EXT EXCEPT FOR 1024 LEO WHERE IT WORK WITHOUT IT: JUST DONT CREATE
ANY EXT PARTITION ON YOUR SDCARD AND IT WILL NOT BE USED. IF YOU PUT AN
EXT PARTITION WILL BE AUTOMATICALLY USED ON BOOT
[/center]
rafdroid hd - [ZIP / ROM 2.2.1] RAFDROID HD 4.2.0 [07.08.2011] RafdroidHD
============ FEATURES ============
  • Deodexed and Zipaligned, not sqashfsed
  • RMNET / PPP
  • Multilanguage
  • Rooted (SU app + SU binaries)
  • AdFree
  • AutoAPNs
  • 5mpx camera with face recognition + 800*400 camcorder
  • HSDPA, GPS, Bluethoot, WiFi all working
  • % battery icon and status bar icons changed (use original framework-res.apk to go back to stock attached in 2nd post)
  • fonts changed (use original fonts to go back to stock attached in 2nd post)
  • Enhanced Shutdown Menu
  • WiFi MAC Fixed
  • Working HTC-SENSE.COM, HTC-HUB, HTC-LIKES
  • Working HTC Headsets using my kernel
  • Working notification LEDs
  • Working Streaming Video
  • Working Flash Player, No more browser crash
  • Support config.txt to tweak boot options
  • Modified shutdown android process to cleanly unmount data partition and avoid data corruption.
  • Fast, Fast, FAST!
Removed to fit in the 400mb system partition(you can download from market or use update zip in post #2)
AdobeReader.apk
Facebook.apk
GoogleMaps.apk
Quickoffice.apk
Street.apk
Talk.apk
Twitter.apk
YouTube.apk
============ WHAT IS WORKING ============
  • Everything except stock HTC Reader (removed)
============ WHAT IS NOT WORKING ============
  • No photo sharing in camera app
    If you choose to use a custom wifi mac, gps will not work.
4.2.0 - 07 AUG 11
I THINK THIS WILL MOSTLY BE THE LAST RELEASE OF THIS ROM
- Updated GPS libs (credits: tytung)
- Tweaked ril data (credits: jan-williem)
- Otpimized again all apks to improve speed
- Updated ad-free hosts
- Updated Market, Gmail, Flashplayer
- Fixed some typo in some part of codes
RAFDROID HD V4.2.0 -> DOWNLOAD HERE CWR
rafdroid hd - [ZIP / ROM 2.2.1] RAFDROID HD 4.2.0 [07.08.2011] Full_rafdroid_hd_ext_4r0f2
rafdroid hd - [ZIP / ROM 2.2.1] RAFDROID HD 4.2.0 [07.08.2011] Update_rafdroid_hd_ext_3r1
Lien XDA
descriptionrafdroid hd - [ZIP / ROM 2.2.1] RAFDROID HD 4.2.0 [07.08.2011] EmptyRe: [ZIP / ROM 2.2.1] RAFDROID HD 4.2.0 [07.08.2011]
Si quelqu'un pourrai me faire des screens ça serai sympa santa
Je vous fais profiter de mes retours
WIFI OK
Quadrant 1502 sans SetCPU
Téléphone OK
Super utilisateur fonctionne après installation de z4root
Quadrant 1994 avec setCPU à 1,5 ghz
Toujours pas de data après 3 reboot
Dans l'attente d'une release RMNET ...
Merci pour le partage Bamlot Very Happy
Merci du partage , je l'ai deja installée depuis tout à l'heure mais pas encore testée Wink , pensez à mettre le dossier data dans la carte mémoire avant de lancer le installer.exe !
vous pouvez l'installer avec data 2g,3g ou 4g smile
encore une sacrée avancée ,,,
Mais alors il reste quoi sur la mémoire interne? On ne perd pas les avantages de la nand via ce procédé?
Bah la rom est sur la mémoire interne à la place du windows mobile mais le data de 1giga sur la SD c'est pour les applications , quand on regarde dans stockage et carte SD il y a 1Go de libre , ca marche un peu comme le data.img !
WIFI OK
Téléphone OK
Pour le data il faut créer les APN !
Ok,
J'essayerai ce soir avec les APN que j'ai trouvé ICI : http://forum.frandroid.com/topic/1406-configurations-operateurs-apn-internet-mmssms/page__p__22334#entry22334
en rentrant l'apn jai bien le h qui est apparu par contre si j'ouvre une page internet impossible de me connecter je ne vois pas quoi faire pour pouvoir me connecter sur le net
Dalut,
C'est quoi cette histoire de data svp ?
Moi j'aimerai bien avoir des screen rafdroid hd - [ZIP / ROM 2.2.1] RAFDROID HD 4.2.0 [07.08.2011] 281465
Hello all, installation sans problème avec DATA PACKAGE 1024MB configuration APN orange data fonctionnelle , OC avec Setcpu a 1536, 2150 sous Quadrant, pas encore tout tester mais pour le moment rom HD la plus complète et la plus rapide
Merci pour le partage, pour le moment très fluide, pas de soucis particuliers, il me reste à tester les data, mais comme ici la 3g ne passe pas, je verrais ça un peu plus tard, en tout cas, en WiFi, ça marche très bien...
Une ROM très complète, fluide et rapide, ce qui est rare pour une DHD. Coté design, j'aime bien la barre des taches colorée avec l'incrémentation du niveau de la batterie en 1%. Pas de voix robot, envoi SMS et MMS ok, ainsi que la réception...
Je précise que j'ai pris le Data 1Go.
Voilà si ce post peux orienter et en aider certains dans leur choix parmi toutes les ROM Nand dispo à ce jour, je les ai toutes testé, et pour le moment c'est celle qui correspond le plus à mes demandes...
bonjour
je voulais savoir si la cam hd 720p et apk tv fonctionne sur cette build
et d autre part je voulais savoir aussi si c est possible de transformer un .cab en .apk l'idée c est pour tomtom car je suis pas satisfait des gps android.
punbb
merci de passer par la section des présentations
c est a dir je comprend pas trop ta question pourtant j ai remplis mon profile y a autre chose a compléter
chrisdc91 a écrit:
bonjour
Non je viens de faire l'essai et toujours pas de cam hd720p, pour la TV je ne saurais te dire...
Pour ta demande sur le cab, non ce n'est pas possible pour la simple et bonne raison que ce sont deux OS totalement différents, à moins de passer par un émulateur pour le lire (ce qui te boufferait toute ta mémoire ainsi que le processeur), tu ne peux transformer un cab en apk. Par contre, en cherchant bien (google est ton ami) tu as d'autres GPS android très bon, du genre Igo qui est certainement bien meilleur que Tomtom sous winmo, et déjà présent sous android.
ton pseudo c'est pas "punbb"
ce message ne s'adresse pas à toi Wink
la tv marche pas sur cette rom
merci pour ta reponse Dragonlyon
excuse moi DEDO j avais pas vu dsl
bon j'ai reflasher la nand et remis le data 1go et tous est fonctionnel fluide une fois l'APN configuré reste plus qu 'à tester la batterie mais ca a l'air d'etre parfait.
edit :la TV ne fonctionne pas chez orange.
j'ai bien envie de ma laisser tenter par cette rom.
n'étant pas entièrement satisfait par la rom Gauner1986. (pas assez fluide et performance aux alentours de 1000 sur quadrant avec le Kernel 9.2)
Je vais flasher ce soir
dommage qu'il n'y ai pas de screen, tant pis ce sera la surprise.
Screen de la source xda.
rafdroid hd - [ZIP / ROM 2.2.1] RAFDROID HD 4.2.0 [07.08.2011] Rafdro10
