[SOFT] HTC HUB pour tout le monde
Message par voileuxcool le Jeu 27 Jan 2011 - 22:38
Voiçi un lien pour avoir les HUB HTC sur n'importe quel appareil fonctionnant sous WP7 , HTC ou non .
You can download the rar's. They contain the xap. You can use any dev-unlocked device (also non-HTC). This was quite a reversing-adventure. I learned a lot.
This week, a lot of news are coming from the latest operating system from Microsoft. This time, XDA member Heathcliff74 has posted the xap files for using the HTC Hub on your Windows Phone 7 device. It needs to be dev-unlocked and will work also with non HTC devices.
The developer mentions that this is not the latest HTC Hub version, so it does not have included the live-tiles but should be added in future releases.
The file comes in two compressed parts and both need to be downloaded to the same folder and extract using WinRar or similar.
Did you find this useful? If so, please leave feedback
A few remarks:
- This is not the latest version of the HTC Hub. It does not have the live-tile. Maybe I'll update later.
- I had to rewrite some parts of the code. It all works 100% but I think it can be done better, so maybe I'll update that later.
- Note the about screen[/i]
Téléchargement / source : http://forum.xda-developers.com/showthread.php?t=923376
voileuxcool
Appareil principal : htc eye
ROMs : HTC
http://benmontagutfra89.wordpress.com/
Re: [SOFT] HTC HUB pour tout le monde
Message par Jedi.6 le Ven 28 Jan 2011 - 8:11
Nickel, merci de l'info
Message par icobi le Sam 29 Jan 2011 - 0:42
La météo marche bien mais on peut pas telecharger les applis de HTC, c'est surement normal, vous pouvez vous?
icobi
Message par dartagnan95 le Dim 30 Jan 2011 - 19:46
non hélas
dartagnan95
: : HTC Titan 7.8
Message par Caramel le Mar 12 Juil 2011 - 19:07
Il y a une MàJ aujourd'hui, mais incapable de trouver ce qu'elle apporte
Message par samanosuke37360 le Mar 12 Juil 2011 - 19:37
Est ce que la météo marche en LiveTiles ?
samanosuke37360
ROMs : 7.10.8773.98
: : 1.1.2.10
Message par poloche le Mar 12 Juil 2011 - 20:09
... Et sinon en français, ca donne quoi ??? Lool ... Un petit effort mon ami stp .. imagine on faisait les tuto en englais... :S la galère que ca pourrait être !
poloche
