[SOFT] CO0KIE'S HOME TAB v1.8.5 : Un MUST pour personnaliser son home [Gratuit]
Page 1 sur 28 1, 2, 3 ... 14 ... 28  Suivant
Message par Zepiii le Dim 6 Juin 2010 - 21:42
CO0KIE'S HOME TAB
Un des softs qui a révolutionné le manila 2.5 ! Celui-ci permet de personaliser de manière très poussée le home du Sense. Avoir plus de raccourcis, changer d'horloges, réorganiser comme vous le souhaitez vos programmes favoris, ...
Bref, le must-have ultime qu'HTC aurait du faire il y'a bien longtemps Exclamation
A utiliser avec le CHT Editor déposé en poste 2, il permet de le configurer facilement...
Dans "Autres", vous trouverez des Add-Ons intéressants.
#v1.8.5
-[new] option for scrolling appointment and task lists
-[new] task improvements: counters, color options, option to display both start and due date
-[new] high quality wallpapers
-[new] taskbar and softkeybar skinning
-[new] wallpaper control quick links: previous, next, random wallpaper
-[new] compatible with manila_home 2016 (with manila_core 2015) (dev note: graphics files: 1b8f4bec_manila, 55b3bed2_manila, 710705ec_manila)
-[new] addon cab: alternative lockscreen for WM6.1 users (read the notes below) - thanks to Kenia1234 for testing this
-[new][dev] the analog clock has it's own mode9 and script file (mode9: 1E1A6CCD_manila, lua: 1EC5924B_manila)
-[change] weather animation on the lockscreen now plays even if weather is off on the home tab
-[change] music player (or any element) will no longer be loaded on startup if it's not visible on any layout
-[fixed] analog clock hand alignment (thanks to rat_2665)
-[fixed] wallpaper selection on WM6.1
-[fixed] VGA: all tabs wallpaper, add toggle menu, titlebar disappears
-[fixed] photos tab picture position for both VGA and WVGA
-[fixed] clock highlight getting stuck
-[fixed] tab change side swipe not responding after unlock
-[fixed] analog clock resize button shows in non-edit mode
-[fixed] quick links disappear in landscape
-[fixed] appointments/tasks slim header autohide
-[fixed] previous track button disabled image on manila 19xx (dev note: for skinned players 59B6BB1D_manila needs to be copied and renamed to 10B1B92F_manila)
-[fixed] white wallpaper when rotating with hdwall
-[fixed] test appointments don't show up sometimes
-[fixed] tasks sorting and range
-[fixed] if home menu was open when locking the unlock slider would be missing
-[fixed] slider bar appears on white menus with no tabs
-[fixed] phone toggle doesn't turn off if data was connected
-[fixed] weather animation freezes on comm switch
-[fixed] music info not updating
-[fixed] lockscreen bottom bar bug
-[fixed] uninstall problem on some ROMs
#v1.8.0
-[new] many lockscreen improvements
-[new] new quick link types: switches, notifications and misc
-[new] wallpaper controls: home, all tabs, lockscreen
-[new] wide scrolling home wallpaper
-[new] 4 home levels and landscape are customizable
-[new] tasks
-[new] new list control for appointments and tasks (unlimited item count)
-[new] anything will hide behind the expanded app/tasks list (not just quick links)
-[new] music player with 3 layouts
-[new] text color settings
-[new] analog clock is x-axis movable and resizable
-[speed] significant boost to quick links animation speed/smoothness
-[change] tab slider is now always visible on white submenus (related to retractable slider)
-[fixed] many lockscreen related problems
-[fixed] highlights that stick
-[fixed] second hand freezing
-[removed] animated wallpapers (not weather wallpapers, just the 3 animated ones)
#v1.7.1 - 18/04/2010
-[new] voicemail program link
-[new] notification support for more than 100 sms/mms/email
-[new] sun rays animation option
-[fixed] advanced layout menu not working
-[fixed] black bar in submenus
-[fixed] music problem with locker
-[fixed] full screen animation showing wrong weather
-[fixed] program selector in VGA
-[fixed] clock becomes rotated sometimes
-[fixed] weather hit area removed from no weather clock
-[fixed] page indicator shows up after unlock
-[fixed] retractable slider bugs
-[fixed] clock weather text overlap
-[removed] dim backlight option (using system setting instead)
-[removed] suspend timeout option (using system setting instead)
#v1.7 - 13/04/2010
-[new] moveable and customizable home items
-[new] 6 clock layouts (including analog)
-[new] 2 or 3 quick links rows in main view
-[new] notification icons
-[new] customizable lockscreen with 3 unlock modes
-[new] more than 3 quick links pages
-[new] retractable slider
-[new] parameter support for button program links
-[new] automatic VGA mode detection
-[new] added voicemail notification
-[changed] position of more appointments indicator arrow
-[changed] adjusted 3x3 quick links layout
-[fixed] exchange policies related issue
-[fixed] bug with appointment range set to 1
-[fixed] miscellaneous smaller bugs
#v1.6.1 - 07/03/2010
-[new] option to hide or auto hide appointments
-[new] added more appointments indicator for main view
-[fixed] call history related bugs (rounded edge, overlap)
-[fixed] date button now always shows month view in calendar tab
-[fixed] removed side scroll animation from animation level 0
-[fixed] corrected quick links scrolling in landscape
#v1.6 - 04/03/2010
-[new] 3x3 layout added and 5x5 repositioned slightly
-[new] reworked animations with 4 levels and an animation toolkit
-[new] dynamic notifications - autohide call history and quick links
-[new] up to 5 appointments in extended view, 2 in main view
-[new] enabled swiping between tabs from home
-[new] option to set the number of quick link pages
-[new] option to hide shortcut text and text background
-[new] option to hide page indicator
-[new] weather animatin on/off switch
-[new] localization support
-[new] setting for date, clock and weather buttons
-[new] option to set a custom operator name
-[fixed] leftmost and rightmost column sensitivity on 4x4 layout
-[fixed] wrong date for multiday appointments
-[fixed] quick links bug on up key / volume key
-[fixed] appointments now always update on home tab load
-[fixed] added back htc start menu shortcuts
-[fixed] unfinished animation before switching to remove/rearrange view
-[fixed] re-enabled operator logo
-[fixed] a few bugs in VGA mode
#v1.5.4 - 13/02/2010
-[fixed] crash on start up (thanks to caliban2)
-[fixed] crash on swiping
-[fixed] past/future appointment mix-up with 12-hour format
-[fixed] bug when dragging appointment across pages
-[fixed] default page reg setting
#v1.5 - 10/02/2010
-[new] 3 pages of quick links
-[new] 5x5 link layout
-[new] drag and drop to rearrange
-[new] dated appointment for more than 2 days
-[new] call history button
-[new] configurable alarm, call history and calendar buttons
-[new] basic VGA support
#v1.0.1 - 31/01/2010
-[fixed] clock distortion bug
-[changed] 16 links is now default
#v1.0 - 30/01/2010
-initial release
Sur la taverne :
Co0kie's HomeTab, Langage Pack, CHT Editor
Sur XDA :
http://forum.xda-developers.com/showthread.php?t=625483
Add-On :
L'INDISPENSABLE pour configurer Co0kie's Home Tab (Toujours mis à jour en même temps que la version de Co0kie's Home Tab)
[SOFT] CHT EDITOR : Editer facilement Co0kie's HomeTab [Gratuit]
[SOFT] CHTEDITOR : Configurez Co0kie's HomeTab [Gratuit] - Cookies Cookie C0okie C0okies Co0kie Co0kies home tab
CHTEditor
Configurer Co0kie's HomeTab disponible en poste 1.
Update 06-Jun-2010
Added support for new features in Co0kie's Home Tab, and some minor bug fixes.
Update 10-May-2010
Added multi-language support and import and export can now be done from command-line.
Update 19-Apr-2010
Fixed the export problem, so you can now export settings and create quicklinks for quick changes of your layouts.
Update 18-Apr-2010
A few options were added & removed from Co0kie's Home Tab, so the same options have been added/removed from the editor. Some logic has been put in place to make some of the controls context sensitive (you can't select too many pages for the different quicklink layouts, and you can't set a default page higher than the number of pages). I've also completely rewritten the import/export dialog, and have added the ability to run settings files directly, without opening the editor. This means you can have multiple layouts and switch between them by either running the settings files from a file explorer, running them from the start menu, or adding them as quicklinks.
Update 13-Apr-2010
The main changes have been in 2 parts. They have been driven by the big changes made to Co0kie's Home Tab, and I've switched the control set from the original Manila SDK controls to the new and improved Sense Interface SDK controls. There were also some minor bug-fixes and groundwork laid for future changes.
Update 04-Mar-2010
Fixed issues with exporting and importing settings and quicklinks and added support for new features in Co0kie's Home Tab v1.6. Exports from an earlier version will not be able to be imported into this version, but this will not be the case with later version of this application. I know it's a pain, and I'm sorry, but the problem has been resolved for future versions.
Update 21-Feb-2010
Fixed a problem where selecting an app from the application list did not assign it correctly.
Update 21-Feb-2010
I've added a folder treeview for exporting and importing settings, rather than saving them to the root of the storage card, which didn't always work.
Update 20-Feb-2010
I've changed the application picker for the alarm, calendar and call history applications.
It's now a list of everything in your start menu, rather than the standard .Net open file dialog, which is somewhat lacking.
I've also fixed the "Number of days to look ahead", which wasn't updating, despite the value being changed and stored succesfully.
http://forum.xda-developers.com/showthread.php?t=633590
Re: [SOFT] CO0KIE'S HOME TAB v1.8.5 : Un MUST pour personnaliser son home [Gratuit]
Message par Zepiii le Dim 6 Juin 2010 - 21:45
Réservé au cas où.
Message par rschris le Dim 6 Juin 2010 - 23:05
Je l'essaie sur mon TP2, en attendant que mon Desire revienne. Et ben franchement, déjà que la 1.7.1.1 que j'avais sur le Leo déchirait, celle-là, elle me fait presque regretter WM !
Contrairement à Max Sense, qui est définitivement mal pensé et compliqué.
Le CHT 1.8 est une merveille, totalement personnalisable, de la folie furieuse. En plus de mon Desire, je sens que je vais garder un WM tiens !
rschris
: : MIUI rom 1.1.28
Message par carlintech le Lun 7 Juin 2010 - 1:13
je suis dégouter il plante sur la rom de bichon simple problème d'implantation mais bon il est entrain dans sortir une nouvel version avec cookie's installer........... malgré tout je l'est tester et il est mortel j'hallucine de l'évolution proposer sur le HD2 si vous comparer un HD2 d'origine a celui équiper d'une bonne rom (BichOn; NetDrg) avec cookie's v1.8 c'est hallucinant HD2Powaaa
carlintech
ROMs : Shooter Beats v 1.7
: : revolver 3.9.5
Message par Atmosphere le Lun 7 Juin 2010 - 1:35
j'ai aussi installe et teste et c'est effectivement mortel....
a regretter de ne pas avoir un ecran plus grand tant on peut afficher de chose...
Par contre, quelques petits soucis avec S2U2 : je n'utilise pas le lock de Co0kieMonster mais celui de S2U2 et parois S2U2 me demande de faire un sof reset car il semble penser que le lock de WM 6.5 est active....
J'ai aussi un probleme d'affichage de la date, l'heure et les alarmes: parfois rien n'est affiche.... je vais voir sur le post de Co0kie si ces problèmes sont deja références...
Mais bon, a part cela, la version 1.8.0 apporte beaucoup de belles choses... c'est a se demander si HTC ne devrait pas integrer CHT dans le Sense...
Atmosphere
ROMs : NexusHD2-JellyBean-4.3.2-
Message par Gill le Lun 7 Juin 2010 - 1:43
Je ne vois pas trop pourquoi Zepii a mis les 2 add-ons (de la 1.7.1) pour ajouter les tâches et pour ajouter des widgets sur ce thread-ci.
C'est déjà inclus dans 1.8.
Même avec l'avertissement, ça n'a rien a voir sur ce thread. Ou alors fallait laisser tout dans le thread original.
Soyons clair!
Gill
Message par Goa46 le Lun 7 Juin 2010 - 5:43
Il faut desinstaller les versions précédentes ou on peut l'installer par dessus ?
Goa46
Message par Angelfun le Lun 7 Juin 2010 - 6:05
@Goa46 a écrit:Il faut desinstaller les versions précédentes ou on peut l'installer par dessus ?
Tu installe les cabs et il te prévient directement que les anciennes versions vont être supprimées...
Angelfun
Message par ll_ll le Lun 7 Juin 2010 - 6:58
Ou peut on personnaliser le PBanner du HDMini? (l'image, et la hauteur du slide)
ll_ll
ROMs : Androïd ICS 4.0.4
: : Ultimate Sense V7.0
Message par Zepiii le Lun 7 Juin 2010 - 7:36
@Gill a écrit:Je ne vois pas trop pourquoi Zepii a mis les 2 add-ons (de la 1.7.1) pour ajouter les tâches et pour ajouter des widgets sur ce thread-ci.
Soyons clair!
L'astuce, c'est que j'avais préparé le thread le matin, étant au courant que la 1.8 allait sortir. Je savais pas encore les nouveautés...
Et comme hier, c'était la veille d'un examen, bah j'avais moins de temps le soir et j'ai pas eu le temps de tester l'application, mais j'ai quand même publier la mise à jour en adaptant à la bourrain en mettant ça.
Enfin, c'est corrigé.
Et let's go to the exam Laughing
PS : vidéo à jour aussi, ça a l'air ultra impressionnant... !
Message par Oudjat le Lun 7 Juin 2010 - 8:52
Énorme évolution du logiciel , merci pour le partage Zepiii.
ROMs : ViperOne V3.5
: : Htc One Max
Message par mania26 le Lun 7 Juin 2010 - 9:15
La v1.8 en 2 mots: magnifique et formidable !!! smile
mania26
ROMs : Orange
Message par teo le Lun 7 Juin 2010 - 9:39
Bonjour, personne n'a de problème avec HdWall ? Personnellement lorsque j'installe mon Wallpaper (hdwall) la barre du haut ok du bas ok par contre je suis obligé d'aller sélectionner mon fond d'écran, et cela provoque des décalages (avec barres du haut et du bas). De plus quand je relance mon Hd2 fond d'écran noir ? HELPPPPP
teo
: : NetDrg
http://bastiencollin.free.fr
Message par Nico le Lun 7 Juin 2010 - 9:54
je vais tester tout ça avec la dernière mouture de Nrgz
merci zepiii !
http://www.forum-htc-dev.net
Message par Melchiah le Lun 7 Juin 2010 - 9:55
Il faut sélectionner HDwall dans les options dans je ne sais plus quelle rubrique (misc je pense) de CHTEditor.
Moi ça marche comme ça.
Melchiah
: : A4TW BOA V5.2
Message par teo le Lun 7 Juin 2010 - 10:25
Merci Melchiah je vais chercher et je te tiens au courant. Merci Very Happy
teo
: : NetDrg
Message par teo le Lun 7 Juin 2010 - 10:48
Bon j'ai essayé j'ai bien trouvé l'option mais mon wallpaper est décalé par rapport à la bande du haut et du bas, une idée ?
teo
: : NetDrg
Message par Melchiah le Lun 7 Juin 2010 - 11:04
réinstalle ton hdwall, peut-être que ça marchera.
Cela ne doit pas marcher car tu as sélectionné un wallpaper avant.
Melchiah
: : A4TW BOA V5.2
Message par teo le Lun 7 Juin 2010 - 11:31
J'ai tout essayé, j'ai ré-installé mon wallpaper (hdwall), re-créé mon wallpaper mais cela ne change rien, toujours un décalage avec le bas et le haut ????????
teo
: : NetDrg
Message par PhilGood06 le Lun 7 Juin 2010 - 12:34
Merci pour la mise à jour Zepiii smile
PhilGood06
ROMs : Rom opérateur- And 2.3.4
Message par Bamlot le Lun 7 Juin 2010 - 12:38
Super Soft merci Zepiii Very Happy
Bamlot
Appareil principal : S7 EDGE
ROMs : Officiel
Message par Melchiah le Lun 7 Juin 2010 - 13:35
Franchement je l'adore encore plus cette 1.8 (pourtant j'aimais bien la 1.7.1)
Melchiah
: : A4TW BOA V5.2
Message par teo le Lun 7 Juin 2010 - 13:38
@Melchiah a écrit:Franchement je l'adore encore plus cette 1.8 (pourtant j'aimais bien la 1.7.1)
Tu es sur une rom officiel ? Peux tu me dire exactement comment tu as fait avec hdwall, là je vais péter un plomb j'ai tout essayé mais rien à faire. Je suis sur la dernière rom Energy (21905) du 06/06. Par avance merci pour ton aide
teo
: : NetDrg
Message par Melchiah le Lun 7 Juin 2010 - 13:42
Je suis toujours sur une officielle HTC.
Pour hdwall je n'ai rien fait.
J'ai installé CHT 1.8 et j'avais un wallpaper noir.
De ce fait, j'ai installé CHTEditor 1.8 et j'ai coché HDwall dans le miscellaneous settings puis mon wallpaper est revenu.
Mon HDwall était déjà installé auparavant.
Melchiah
: : A4TW BOA V5.2
