[ROM 2.3.5 / SENSE 3] [28.08.2011] Cool3D Sense 3.0 SagaS
+8
jepsboubou
alpacino3012
Gill
doudou2106
lacjm
db77
zouhir
weelo57
12 participants
description[ROM 2.3.5 / SENSE 3] [28.08.2011] Cool3D Sense 3.0 SagaS Empty[ROM 2.3.5 / SENSE 3] [28.08.2011] Cool3D Sense 3.0 SagaS
[ROM 2.3.5 / SENSE 3] Cool3D Sense 3.0 SagaS
Voici un rom cuisinée par Coolexe (xda developpers) basé sur une release  officielle android 2.3.5 avec sense 3 du HTC Desire S .
cette rom a été porter par capychimp (RCteam) mais modifier par Coolexe avec l'aide de nombreux developpeurs de xda.
Radio recommandée : la dernière si possible (RIL également)
[ROM 2.3.5 / SENSE 3] [28.08.2011] Cool3D Sense 3.0 SagaS 2011-016[ROM 2.3.5 / SENSE 3] [28.08.2011] Cool3D Sense 3.0 SagaS 2011-017[ROM 2.3.5 / SENSE 3] [28.08.2011] Cool3D Sense 3.0 SagaS 2011-018[ROM 2.3.5 / SENSE 3] [28.08.2011] Cool3D Sense 3.0 SagaS 2011-019[ROM 2.3.5 / SENSE 3] [28.08.2011] Cool3D Sense 3.0 SagaS Cap20113
Cool3D SagaS v3 :
* All Widgets Fixed
* Optimized apk's for More RAM & Speed
* New EXT4 ALIGNMENT Script for more speed
* Phone.apk reboot fix
* New v3 RAM Tweaks (thx to Juwe11)
* Some More Tweaks (thx knzo)
Cool3D SagaS v2 :
* New Kernel Unity_v5 (thx m-deejay)
* USB Mount Fix
* New Market v3.1.3
* Phone Reboot Fix When Ending Calls
* HtcMusic.apk Fix *Working Dolby, SRS & Equalizer* (thx to lyapota)
* Missing widgets Added
* Ereader Added (buggy one)
* Polaris office Added
* BT Fix
* FM Radio Fix
* CRT Removed due to Auto brightness issue[/I][/QUOTE]
Cool3D Saga S v1b :
* USB Mount Fix
* New Market v3.1.3
* HtcMusic.apk Fix *Working SRS & Equalizer, Dolby Still Buggy* (thx to lyapota)
* Missing widgets FIX
* Ereader Added
Initial release :
* Officially Leaked Android 2.3.5 with Sense 3.0 For HTC Desire S WVGA Screen (Base thx to goapk)
* All Partitions System, Data & cache mount as ext4 Inserted of yaff2 (Boot Time Decreased) *NEW
* Full Multi Tasking with 250MB RAM on First boot *NEW
* Ext4 File system with Alignment 6952 TAP Benchmark *NEW
* Cache Partition Mount as Re-writable *Now u can save ur data on cache partition too* *NEW
* UNITY V4 kernel (thx m-deejay)
* CRT & Advanced Power Menu (thx to Capy)
* Andrev_oc Demon with Daemon Controller v2.11.apk
* Screen state scaling Customizable...
...................screen on - ondemand 254-1152 MHz.
...................screen off - conservative 254-384.0 MHz.
* RAM Tweaks (thx to Juwe11)
* Speed tweaks with Smoothness patch
* Rom Optimized for Speed & Stability
* Busybox 1.19.0, Root, Superuser
* Automatic ZipAlign by Wes Garner, slightly adjusted by ROBO
* Updated APNs to Cyanogens big list (over 1300 providers)
* All HTC Themes, Widgets & Addons
* Host file symlink to data partition for easier update
* Customizable Bootanimation and downanimation
* Some Hidden bloat-ware removed
* AND MUCH MORE.
* Languages supported: WWE
Known Bugs:
USB Mount & Video Recording..
Flash Unity_v5 Kernel for solving USB Mount issue... (A big thx to mdeejay)
>>> Cool3D SagaS v1 (Full Wipe Recommendé): http://coolexe.dataninja.net/DHD/3DSagaS/
(md5sum-2f0ec4bd1faad1634ad6d0bb0622bc5)
http://www.multiupload.com/J4OPQR6CF0
>>> Cool3D SagaS v1a ( c'est un patch pour résoudre les bugs usb et reboot du téléphone après un appel )  http://coolexe.dataninja.net/DHD/3DSagaS/
>>> Cool3D SagaS v1b (http://coolexe.dataninja.net/DHD/3DSagaS/)
>>> Cool3D SagaS v2  (http://coolexe.dataninja.net/DHD/3DSagaS/)
>>> Cool3D SagaS v3  (http://www.multiupload.com/1TD827LF2S)
FULL WIPE RECOMMANDER POUR LA V3
description[ROM 2.3.5 / SENSE 3] [28.08.2011] Cool3D Sense 3.0 SagaS EmptyRe: [ROM 2.3.5 / SENSE 3] [28.08.2011] Cool3D Sense 3.0 SagaS
impeccable merci je l installe maintenant
ok le problèmes usb est réglé après l'installation du kernel de mdeejay Wink
pareille que rcmix problème quand on appelle le téléphone bug apart ca la rom et super fluide gestionnaire de tache 320 memoire libre domage
Et le problème du téléphone qui reboote en fin d'appel ? Il est réglé aussi avec le kernel V5 ?
a bonne nouvelle je la garde alors
non la pas encore résolu, un dev lui as conseiller de ixer le problème avec un apk venant d'une autres rom donc affaires a suivres mais je pense que sa seras résolu sous peu Wink
Ok, yapluka ...
Pour régler le problème de l'enregistrement video, ouvrir le camescope, aller dans menu et désactiver enregistrement stereo et la video fonctionne!
wep yapluka smile lol
oui oui mais a quoi sa sert d'enregistrer des vidéos sans son lol .. vaut mieux attendre que sa soit vraiment fixer lol
g est mal compris je penser que le problème état résolu avec le kernel v5. c etait une question
Il y a du son mais pas stéréo.....essaye le et tu verras s'il y en a...lolll...moi je l'ai essayé et il y a du son [ROM 2.3.5 / SENSE 3] [28.08.2011] Cool3D Sense 3.0 SagaS 2325459160
franchement bonne rom dommage pour le problème d appelle
problème du phone corrige avec un apk http://www.multiupload.com/HYMJ9HVHPU xda
tu as appliquer le patch ?? c'es fonctionnel ?
@weelo : peux-tu ajouter l'apk qui corrige ce problème dans le premier post ?
jais essayer de l installer impossible a installer comment on fait svp
quelqu'un a essayer de faire reconnaitre son bluetooth? moi il ne le reconnais pas?
impossible a installer faut patienter un peux quil nous dise comment fair
zouhir tu as root explore r?? si ou copy l'apk dans le fichier sysem/app et reboot ton tel .. pour voir ce que sa donne
je les fait problème de permission
c est bizare sur xda il di utilise root explorer pour apk sa marche pas chez moi g est un problème de permission
Alors il te faut un autre root explorer cherche un qui as pour icones un casier bleu.. tu trouve sa sur internet .. je te l'aurai bien donner mais je suis sur mon portable ....alors trouve sur internet via ton telephone .. et une fois telecharger tu lance l'installation et la tu n'auras plus de soucis de permissions.. si tu n'y arrive pas dit moi le et je le trouverais pr toi .
bon je laisse tomber root explorer me di maintenant. you cannot paste here because the file system is read only. merci quamem weelo57
