[ROM 2.3.4 / SENSE 3][17-08-2011]RCMix3d 234 v2.5 [First android 2.3.4 incl. sense3.0 on dhd][OC]
Page 1 sur 3 1, 2, 3  Suivant
Message par Gill le Sam 13 Aoû 2011 - 15:25
[ROM 2.3.4 / SENSE 3]RCMix3d 234 v2.5 [First android 2.3.4 incl. sense3.0 on dhd][OC]
RCMix3d 234
Hello Flashmaniacs
For those who don't know RCTeam, we have been around since htc Magic (sapphire) we were on Hero Desire DesireHD, and made roms like the first sense 3 on desire HD, aria to hero and sapphire, we do stock roms, but we are strong on ports, the real cooking, everyone can throw something on a ruu and release a rom, we enjoy the fun of making something run on the phone that was not meant to.
Cette ROM est basée sur le RUU Pyramid HTC android 2.3.4 build 1.45.401.2
Ceci est le fruit d'un gros travail dans l'équipe avec samuel2706, QD2DC and RCTeam (robocik, klquicksall et capychimp)
RC Team présente
Features:
Base - RUU Pyramid HTC android 2.3.4 build 1.45.401.2
Deodexed
Kernel: RCMix3D
Extra quicksettings
Busybox, Root, Superuser...
ES file explorer
Langages supportés: Arabic - WWE
v2.5
Wifi fixed again
gallery changed back to pyramid android 2.3.4 (fixed effects)
Inspire4g full phone identity
v2.3
crt readded
keyboard slide in animation
last resizing
rom optimized by coolexe huge thx there buddy
ext4 aligment by coolexe
other tweaks and fixes
auto detection of inspire phones, for audio gps and such by coolexe
updated su
3D homescreen option added
v2.2
widgets fixed after mistake on sizing
watch app should work now
videos in app drawer
other sizing
v2.1
resized new widgets
cam fixed (thanks to sam)
phone identity should be right now
v2.0
wwe 1.45.401.2 (thx baadnewz)
wifi dhcp fixed (thx LorD ClockaN )
friendstream widget displays correct
email widget displays correct
v1.0
Added advanced power menu
crt and all the usual things
Deodexed
Working Trends widget, not seen before on sense 3 dhd
Initial release
BUGS:
USB mount (use auto mount from market, or reboot with cable connected, rerun setup and internal usb mount app will work, must be done each time you need to mount) or find unity beta kernel, once source is released we can add the fix to rcmix kernel
FULL WIPE requis!
>>> RcMix3D 234 v2.5
Gill
Re: [ROM 2.3.4 / SENSE 3][17-08-2011]RCMix3d 234 v2.5 [First android 2.3.4 incl. sense3.0 on dhd][OC]
Gracieusement proposé par cells224: Wink
theme de sergio disponible pour cette rom:
BlueManiacs Captures d'écran
Theme BlueManiacsHD for RCMix234 2.5
Gill
Réservé... Very Happy
Gill
Message par Erosennin le Sam 13 Aoû 2011 - 18:51
Merci pour le partage Wink
Erosennin
ROMs : à modifier
Message par o3e b6d le Sam 13 Aoû 2011 - 20:34
quelqu'un pourrait faire un retour sur cette rom ?
o3e b6d
ROMs : inconnu
Message par Gill le Dim 14 Aoû 2011 - 0:43
Post 1 à jour. Wink
RCMix3d 234 v2.0
Gill
Message par phil34 le Dim 14 Aoû 2011 - 14:40
Je télécharge et je test.
phil34
Maitre
Maitre
Appareil principal : GALAXY Note 4
ROMs : N910FXXU1DPB1
Message par Erosennin le Dim 14 Aoû 2011 - 14:42
Cette rom est passée en v2.2 Wink
Erosennin
ROMs : à modifier
Message par phil34 le Dim 14 Aoû 2011 - 14:46
[Vous devez être inscrit et connecté pour voir ce lien] a écrit:Cette rom est passée en v2.2 Wink
Merci pour l'info je DL la V2.2
phil34
Maitre
Maitre
Message par Gill le Dim 14 Aoû 2011 - 15:14
Post 1 à jour. Wink
Gill
Message par o3e b6d le Dim 14 Aoû 2011 - 17:16
j’attends le retour avec impatience smile
même si je sais que la virtuous unity seras ma première installation sur le htc XD
o3e b6d
ROMs : inconnu
Message par phil34 le Dim 14 Aoû 2011 - 22:38
Premier retour,
Après un full wipe 1.4 ext4 ,instalation de la rom ok.
L'animation de démarrage est sympa, ce qui laissait l"espoir d'avoir une rom skinnée, ben non .....
Pas de freeze ni de bug à signaler, en tout cas pour l'instant.
Bonne accroche wifi, bluetooth (kit main libre voiture d"origine Toyota) et gps.
Copilot tourne bien ainsi que Localisation ( j'ai la licence)
La conso semble correcte (4ma) .Youtube ok.
Je vais la garder encore 24/48heures pour compléter le test, mais je ne la garderai pas , je retournerai sur Bichon V2.6 qui pour moi reste la meilleure rom sense actuellement.
eh bien un bug, je voulais me mettre un film sur la SD, mais après avoir connecté le cable, aucune reconnaissance de celui-ci et pas de propoisition de lecteur de disque(il reste en charge), y compris en manuel, via Parametre/Connexion PC, il ne reconnais pas la SD.
Pour les films Vplayer fonctionne bien mais avec ArcMédia il y a FC
phil34
Maitre
Maitre
Message par Volupia le Dim 14 Aoû 2011 - 22:59
Ton bug est cité dans le Post #1
- USB mount (use auto mount from market, or reboot with cable connected, rerun setup and internal usb mount app will work, must be done each time you need to mount)
Volupia
http://www.michelcoulon.fr
Message par Erosennin le Dim 14 Aoû 2011 - 23:18
Je viens de l'installer également, en cours de test, je ferai un retour demain !
Pour l'instant, tout à l'air de bien fonctionner.
Erosennin
ROMs : à modifier
Message par cells224 le Lun 15 Aoû 2011 - 3:55
[Vous devez être inscrit et connecté pour voir ce lien] a écrit:Ton bug est cité dans le Post #1
Usb fonctionne avec le kernel de MDJ 5, Unityv5
cells224
ROMs : RO
: : Officielle
Message par Gill le Lun 15 Aoû 2011 - 3:58
Oui. Cette Rom fonctionne avec les apports de l'équipe de la Virtuous, à qui ils piquent quand ils n'y arrivent pas. Wink
Gill
Message par db77 le Lun 15 Aoû 2011 - 8:33
[Vous devez être inscrit et connecté pour voir ce lien] a écrit: je retournerai sur Bichon V2.6 qui pour moi reste la meilleure rom sense actuellement.
HS-ON
Comme quoi, nous n'avons pas les mêmes DHD car j'ai quitté la Bichon 2.6 pour essayer la Virtuous Unity 1.31.0 car j'avais quelques soucis avec la Bichon dont j'étais pourtant très content.
Par exemple, Navigon me faisait des FC qu'il ne fait plus avec la Virtuous, mon DHD a freezé deux fois et rebooté en quinze jours et la deuxième fois en voiture alors que j'étais sous iGo (donc galère pour la route).
Bref, je teste la Virtuous qui a l'air de bien me convenir après avoir essayé la MIUI dont je n'aime pas le look iPhone.
HS-OFF
db77
ROMs : Android 7-Nitrogen
: : CM11 (4.4.4)
Message par Gill le Lun 15 Aoû 2011 - 16:00
Post 1 à jour. Wink
Gill
Message par hemess le Lun 15 Aoû 2011 - 18:48
bonjour ,
existe t'il des thèmes pour cette rom?
merci par avance.
hemess
ROMs : rom constucteur
: : [ROM 2.3.5 / SENSE 3.5][1
Message par Erosennin le Lun 15 Aoû 2011 - 19:38
Non il n'existe pas de thèmes pour l'instant !
Erosennin
ROMs : à modifier
Message par hemess le Lun 15 Aoû 2011 - 19:52
merci peut être plus tard ?
hemess
Message par Erosennin le Lun 15 Aoû 2011 - 20:04
Oui, pourquoi pas, quand la rom sera assez stable ^^
Erosennin
ROMs : à modifier
Message par Ronhi11 le Lun 15 Aoû 2011 - 22:12
[Vous devez être inscrit et connecté pour voir ce lien] a écrit:Je viens de l'installer également, en cours de test, je ferai un retour demain !
Alors l'Ermite pas net, quelle conclusion pour la rom ?
Ronhi11
ROMs : Pyrana KI4_ V7
: : Volé par effraction le 4/
Message par Erosennin le Lun 15 Aoû 2011 - 22:51
Bah là du coup, je suis passé en v2.3...Sinon tout roule bien pour l'instant, rom assez convaincante. Les bugs ont été résolus, manque que le truc du USB mais le kernel v5 de mdj résoud ça !
Erosennin
ROMs : à modifier
Message par Ronhi11 le Lun 15 Aoû 2011 - 23:50
Toi qui teste un peu tout par rapport à la vu ça donne quoi ? Et autonomie ça donne quoi surtout car la virtuous a une bonne autonomie en veille mais en utilisation, c'est la cata, ça fond à vu d'oeil !
Ronhi11
