description[TWEAK]  Zeus Mod v1.1.3 for GSM Devices- Reboot issue fixed/UOT compatible Empty[TWEAK] Zeus Mod v1.1.3 for GSM Devices- Reboot issue fixed/UOT compatible
If you don't know what the zeus mod is, here are some features:
- Super extended quicksettings
- Long Press "Evo 3D" to show recent apps bar, long press again to hide
- Short tap "Evo 3D" to show the quicksettings
- Long press on a Quicksetting to get linked to the menu if available
- Press on the volume icons in quicksettings to switch trough different volume settings (media/notifications/bluetooth/voice/alarm)
Here is a video from treve with a short show up:
[TWEAK]  Zeus Mod v1.1.3 for GSM Devices- Reboot issue fixed/UOT compatible 2011-10-09_01-22-49
[TWEAK]  Zeus Mod v1.1.3 for GSM Devices- Reboot issue fixed/UOT compatible 2011-10-09_01-24-20
Works only on deodexed Roms. Please make a backup, before flashing this. I'm not responsible for missing statusbars or bootloops
Buglist:
only white wifi icons in statusbar - nothing big: Explanation of bug
not UOT kitchen compatible
wrong gps icon in statusbar
wimax icon showing instead of normal wifi
reboot quick setting doesn't work
Changelog:
v1.1.3:
- fixed some ressource errors: should be UOT compatible now:
v1.1.2:
- made bar in quicksettings equal to the "Evo 3D" button
v1.1.1:
- fixed reboot quicksetting not working
v1.1.0:
- made button to reach recent apps/quicksettings more comfortable
v1.0.1:
- fixed wrong gps icon
- fixed wimax icon showing instead of normal wifi
v1.0.0.:
initial release
telechargement:v1.1.3/v1.1.2/v1.1.1
source:http://forum.xda-developers.com/showthread.php?t=1290382
description[TWEAK]  Zeus Mod v1.1.3 for GSM Devices- Reboot issue fixed/UOT compatible EmptyRe: [TWEAK] Zeus Mod v1.1.3 for GSM Devices- Reboot issue fixed/UOT compatible
Attention, ne fonctionne pas sur ROM stock.
sympa, merci du partage.
Rajout de l'info de Melchiah sur le post 1
Par contre est-ce que quelqu'un sait comment on peut ajouter le mode avion comme icône en plus dans les paramètres ?
Je voudrais savoir si quelqu'un a reussi a le modifier pour une rom stock 1.20. Car cela m'interresse beaucoup et je ne veux pas pour le moment avoir une rom custom car rien ne me tente. Merci.
post 1 mis a jour
Le mode avion est dedans !
la crypto's a ce quick setting... Very Happy
oui mais la 1.1.2 il faut la mettre a jour
