[ROM 2.3.4 / Sense 2.1 & 3.0] [5 Août 2011] | HoneySense HD V.8.0 |
+32
Zaraki29
Ronhi11
taxi19240
sergentinho
travis75
jepsboubou
jejehtc
kain01
dadada72
Badboy_style972
mfredom
Optiimus
lonewolf83
_tristan_
nonoz1000
bqka94
C.B
orotex
Cyril28
Gill
Samuel2706
Volupia
bosschris
sumonino
Erosennin
gogy
sowan9
fuseur59
36 participants
description[ROM 2.3.4 / Sense 2.1 & 3.0] [5 Août 2011] | HoneySense HD V.8.0 | Empty[ROM 2.3.4 / Sense 2.1 & 3.0] [5 Août 2011] | HoneySense HD V.8.0 |
[ROM 2.3.4 / Sense 2.1 & 3.0]| HoneySense HD V.8.0 |
HoneySense HD Version 8.0
Fonctions :
Android 2.3.3 (Gingerbread) - OFFICIAL HTC RUU 2.50.405.2 (RELEASED 3.7.11)
Honeycomb themed LATER UPDATE!
Lee kernel: 3.2.0
Built with the latest GCC 4.5.2 tool-chain (2nd May 2011) 100% clean build
Available CPU Governors - Interactive, Smartass, SmartAss2, Conservative, Powersave, Performance & Userspace
SmoothAss CPU governor as default (245-1036MHz)
Max speed - screen off 499MHz
Max O/C 1.8GHz ("Nutter mode")
LeeDrOiD Optimal CPU table & VDD Levels
Brain Fuck CPU Scheduler as default (CFS optional)
VR I/O Scheduler as default (Deadline, Noop, SIO, BFQ V2.1 & CFQ Optional)
OpenVPN - CIFS - UTF8 - - EXT3 - EXT4 - JDB2
Audio boosts - 10% all outputs, 15% External speaker
WiFi Driver improvements & greater range
Rooted and Superuser added
Unsecured boot.img
Various tweaks for speed improvements
Battery calibration script (Thanks to the dev seo)
Multilingual ROM as all WWE are
Zipaligned @ system/app and data/app on boot
Fully de-odexed
init.d scripts (BusyBox run-parts) support
NANO text editor & sysro/sysrw commands support
EXT 4 VERSION
EXT 3 VERSION - for you non adventurous types (Coming soon)
Improved battery life, imagine a newer car vs the older car.. (Older car being STOCK ROM)
Includes support for customization and flash 2.50 mods ONLY over this release
Arabic and hebrew support find them in the addons section!
[ROM 2.3.4 / Sense 2.1 & 3.0] [5 Août 2011] | HoneySense HD V.8.0 | Headerjx
[ROM 2.3.4 / Sense 2.1 & 3.0] [5 Août 2011] | HoneySense HD V.8.0 | Newpicv
Derniers changements
1. Boot into recovery
2. Backup
3. Flash Honeysense HD EXT4 Full wipe
4. Flash Honeysense HD 7.8.0
5. Eat a donut of some variety - VERY IMPORTANT
DONE
Version 8.0
- Entire new rebuild
- Added 2 new speed scripts
- Completely Sense 2.1 now, if you want sense 3.0 use Honey3D
- EXT4 Mounted as usual
- Inspire 4G Script added flashes correct rils and settings when flashing ROM - - no inspire patch needed
- Added meatcase scripts
- Changed some drivers over for smoothness
- Changed the bootanimation to sense 2.1 version of honeysense
- Transparant clock
- Huge performance increase over all other updates we released
- Fixed resizing problems with quicksettings
- Rosie landscape enabled both portrait and landscape enabled
- Using latest Graphic Libs from latest ROM
- Using all updated drivers/libs
- Wifi driver extended to work on low ranges
- Fixed wifi driver error problem
- Uses latest leedroid CFS kernel
- Updated Daemon Script
- Updated theme
- New dock
- New icons
- New theme
- New EVERYTHING
- New speed scripts
- I Can't even remember what else i've done, It's all new.
Note:
This thing took me 50 hours to do. longest ever time spent on a rom for myself. i'm proud of myself, please comment and don't just swing by and use the rom, comment, rate, even send me flowers if you wish but most of all keep xda a friendly place to be.
Anciens changements Honeysense HD :
Dernière version Honeysense HD (Taille du fichier 239.2 MB --> v.8.0)
Honeysense HD FULL WIPE EXT4 (Taille du fichier 141.4 KB)
Dernière version Honeyunity HD (Taille du fichier 288.5 MB --> v.2.0)
Honeyunity HD FULL WIPE EXT4 (Taille du fichier 141.4 KB)
RIL_12.54.60.25_26.09.04.11_M2 (Taille du fichier 445.8 KB)
Source Sense
Source Unity
Dernière édition par migascalp le Sam 27 Juil 2013 - 16:31, édité 102 fois (Raison : Actualisation)
description[ROM 2.3.4 / Sense 2.1 & 3.0] [5 Août 2011] | HoneySense HD V.8.0 | EmptyRe: [ROM 2.3.4 / Sense 2.1 & 3.0] [5 Août 2011] | HoneySense HD V.8.0 |
Addons - Questions et réponses - Aide
Réparer le problème du Task Manager de la version 3.0
Pour réparer le problème de la Météo : (Toujours pas fixé)
Décochez les effets sonores dans les réglages de l'application Météo.
Si vous ne pouvez pas entrer dans l'application du tout, ou que cela ferme le processus avant que vous n'ayez de la chance, allez dans la liste de toutes les applications, et trouvez les deux applications suivantes :
HTC WEATHER SYNC PROVIDER
WEATHER PROVIDER
Nettoyez les données sur les deux, puis allez dans l'application météo, appuyez sur le bouton menu, dans les réglages et décochez les à partir de là.
Pour réparer le problème du GPS (Fixé à partir de la version 1.4)
Téléchargez Fasterfix dans le Market, j'imagine que vous avez rooté, acceptez juste et changez pour le lieu désiré.
Dernière édition par florian64190 le Ven 8 Juil 2011 - 15:26, édité 4 fois (Raison : Ajout (Task Manager))
description[ROM 2.3.4 / Sense 2.1 & 3.0] [5 Août 2011] | HoneySense HD V.8.0 | EmptyImages
Merci pour le partage Wink
merci pour le partage !!! Je testerai que dans quelque jours car je suis preneur lol. Je souhaite juste savoir si niveau autonomie sa tiens bien???
Merci d'avance !
Sony et Fuseur59 : De rien. smile
Merci d'avance !
Je l'ai que depuis 15h mais j'ai l'impression que l'autonomie est bonne, même meilleure que certaines autres Roms. L'interface est vraiment agréable et tout est vraiment très fluide, je n'ai remarqué aucuns lags, même lors de l'installation des applications. Donc, je la conseille. smile Je vais bientôt poster une autre Rom, je suis entrain de traduire. smile
C'est clair que l'interface est très sympa, juste dommage qu'il y'est pas le thème SMS du sense 3.0, il est bien mieux que celui d'avant smile
J'ai eu droit a des forces closes aussi quand j'ai mi le lockscreen météo, a chaque fois que je déverrouille bim force close :/
Merci pour le partage Very Happy
Sowan9 : De rien. smile Oui c'est vrai, mais ça viendra. smile
Regardes le Post 2. Wink
Merci du partage, c'est jolie Wink
Nico : De rien. smile Oui, c'est le Design qui a prit le dessus quand j'ai pris cette Rom. Very Happy
Le post 1 a été mit à jour (Version 1.4). smile
Dans la V.1.4 y'a toujours pas les SMS du sense 3 ?
Ou alors t'as oublier de le spécifier dans les nouveauté d'la version ?
Mercii !
Mercii !
Ça n'a pas été spécifié sur XDA. smile
salut les gens!
j'aimerais bien la tester pour voir se que sa donne mais je viens de mettre coredroide 6.5 qui formate en ext4, je peux faire une fullwipe et mettre cette rom directement par dessu?j'aurais pas de probleme particulier?
ça te coûte rien de faire un wipe ext4 et non ext3, puis tu passes sur cette rom,comme ça t'es rassuré Wink
okay je teste sa!
description[ROM 2.3.4 / Sense 2.1 & 3.0] [5 Août 2011] | HoneySense HD V.8.0 | EmptyMise à jour du Post 1
Post 1 à jour. smile
TRES BELLE ROM
fluide et pour le moment aucun bug
pour la conso je vais attendre quelque jours avant de donner avis
je voulais si je n'ai pas installé setcpu est ce que mon cpu tourne quand meme a plus de 1000mhz?
en tout cas bon boulot vraiment tres beau!!
Bonsoir, si tu n'as pas SetCPU, tu peux prendre autre chose comme CPU Master Free, qui est gratuit. Sans ce genre d'applications, tu resteras à 1 Ghz Max. smile
mise a jour 1.5
merci florian
j'ai installé set cpuet tout marche nickel
a part quelque FC en voulant installer certain widget tous va bien
@Sumonino : De rien. smile Les problèmes de FC pour la météo et les live Wallpapers sont corrigés dans la version 1.5.1. smile
Post 1 à jour ! smile
apres 1 jour de teste ,je trouve que l'autonomie est pas mal
par contre l'accroche reseau est moins bonne
il ya un decalage au niveau de l'heure (on dirait que l'heure se bloque )
puis se regle apres un petit temps de chargement comme si elle avait du mal a se regler
avec setcpu reglé sur 1600mhz j"obtiens un bench de 2200 et des brouettes!!!
Moi aussi, c'est assez bizarre en fait .. Mais la Rom est super fluide, alors qu'importe les tests ? Very Happy
PS : Je suis entrain de mettre la version 1.5.2, je traduis et je poste ! :p
EDIT : Post 1 à jour. smile
Je comprend pas ce que je dois télécharger la, la version 1.5 et ensuite la 1.5.2 Clean Rosie ou Honeycomb Rosie ?
merci ^^
