[Soft] ROM Toolbox Pro v4.0.5 [PAYANT]
Message par nexus35 le Ven 4 Nov 2011 - 13:48
VRAIMENT SUPER APPLICATION: lien market: https://market.android.com/details?id=com.jrummy.liberty.toolboxpro
ROM Toolbox combines all the great root apps all tied up into one monster app with a beautiful and user-friendly interface.
This app requires root permission.
FEATURE LIST:
==== TOOLS ====
-- ROM Manager --
☆ Install full ROMs and other zips from a growing list of ROMs
☆ Create, manage and restore nandroid backups
☆ Wipe data, cache, dalvik-cache, battery stats
☆ Install a ROM from your SD card
-- App Manager --
☆ Batch backup & restore
☆ Automatically backup apps when they are installed
☆ Automatically delete backups when uninstalled (off by default)
☆ Send backups via gmail/email or dropbox
☆ Sort backups by already installed, same as installed, older versions, etc.
☆ Backup/restore app data
☆ Backup/restore Android Market link
☆ Task manager
☆ View memory usage
☆ Show/hide different processes
☆ Automated batch uninstaller
☆ E-mail your apps to friends
☆ Share with other applications which accept text (SMS, facebook, google reader, etc...)
☆ Move *any* user app to the SD card
☆ Freeze/Defrost system & user apps
☆ Market Doctor (Link *any* app to the Android Market)
☆ Break market links
☆ Clean up dalvik-cache
☆ Zipalign all apks
☆ Fix permissions on all apps
☆ Wipe data or cache for apps
☆ Force close apps
-- Root File Browser --
☆ Access the whole of android's file system (including the elusive data folder!).
☆ Batch copy/paste, zip, tar, delete, move any file or folder
☆ Change file permissions and ownership
☆ View, edit and share files
☆ Add new files & folders in any directory
-- Scripter --
☆ Create and run scripts as root
☆ Download & run new scripts from an ever-growing list
-- Ad Blocker --
☆ Choose to block ads, porn, casino & risky sites
☆ Add new sites to the hosts file
☆ Use custom IP
-- Configure Apps2SD --
☆ Select the default install location for apps
==== INTERFACE ====
-- Font Installer --
☆ Install custom fonts to your whole device from a list of over 150
☆ Set fonts as favorites and send them to friends
-- Boot Animation Installer --
☆ Install custom boot animations from over 100+
☆ Preview boot animations
☆ Backup & preview your current boot animation
-- Battery Icon Changer --
☆ Change your battery icons in the status bar to a custom one from a list of 150+
-- Boot Logo Changer --
☆ Change your boot logo (splash screen) for supported phones
-- Theme Chooser Themes --
☆ View a list of themes for the CM7 theme chooser
==== PERFORMANCE ====
-- CPU Sliders --
☆ SetCPU and scaling governor
☆ Apply cpu at boot
☆ View cpu info
-- Build.prop Tweaks --
☆ Easily edit your build.prop
☆ Change lcd density, improve battery life, increase performance
-- Auto Memomory Manager --
☆ Set minfree values and select from presets
☆ Apply minfree at boot
-- SD Boost --
☆ Increase the speed of your SD card
-- Sysctl Tweaks --
☆ Easily modify sysctl values
What's in this version:
-App Manager fixes
-Bookmark and fixes for root browser
-UI modifications
-Force close fixes
nexus35
ROMs : super fast & famous
Re: [Soft] ROM Toolbox Pro v4.0.5 [PAYANT]
Message par Snipper-Ice le Ven 4 Nov 2011 - 17:44
Salut.
Merci du partage mais :
=> merci de traduire
=> mise en page s'il te plait, ce n'est pas bien compliqué, surtout avec le script automatique : [FORUM] Comment présenter les Jeux/Softs/ROMs publiés sur ce forum?
Merci d'avance !
: : Nougat / EMUI5
Message par Karting06 le Ven 4 Nov 2011 - 17:44
C'est gentil de vouloir aider. Sauf que bon, la mise en page n'est pas super. Tu aurais pu traduire je trouve Wink
EDIT: Snipp' est plus rapide :/
Karting06
Maitre
Maitre
Appareil secondaire : GOOGLE Nexus 7 (2013)
: : HD2 + One V (Stock) + TF700T
http://vanweereld.be
Message par iciTeLLuRiaN le Mar 8 Nov 2011 - 13:30
Attention toute fois conflit avec d'autre appli du still System Tuner ...... ils ne s'aiment pas trop les uns les autres surtout si on leurs demande la même chose (tweak)
iciTeLLuRiaN
Appareil principal : SM-G925 F
ROMs : Carbone HD
Appareil secondaire : One M9 / M8 /M7 / X [...] / Ma
: : Ouya / Nexus Player / Nvidia Shield
