description[ROM 2.3.5 / SENSE 3.5] Virtuous Affinity 2.05.0 based on Runnymede [30.01.12] Empty[ROM 2.3.5 / SENSE 3.5] Virtuous Affinity 2.05.0 based on Runnymede [30.01.12]
Virtuous Affinity is based on an official shipping release for Runnymede from HTC (1.05.401.4).
The entire ROM is brand new, taking no application or framework components from any prior releases.
Features
Based on the official Runnymede shipping ROM (1.05.401.4).
Ported for full functionality on each supported devices. Additional device support is being added regularly.
Heavily optimized for fluid performance and usability.
Overclocked kernels with numerous additional kernel modules.
Built-in screen state frequency scaling (1.2Ghz-245MHz/ondemand screen-on, 806Mhz-245Mz/conservative screen-off), via custom built Virtuous_OC C daemon.
Trackpad wake support (DesireZ/G2 and MT4G only).
WiFi calling (T-Mobile USA only).
Fully functional device hardware, including wifi, bluetooth, camera, camcorder, etc.
Market-sourced applications (Gmail, Maps, Voice, etc) automatically installed on first boot into /data/app for easy removal.
Bloatware and unnecessary applications removed.
[ROM 2.3.5 / SENSE 3.5] Virtuous Affinity 2.05.0 based on Runnymede [30.01.12] Screen10[ROM 2.3.5 / SENSE 3.5] Virtuous Affinity 2.05.0 based on Runnymede [30.01.12] Screen11
Changelog for Virtuous Affinity 1.48.0
New Features
Added tweak for setting different Auto Brightness levels
Added tweak for disabling Recent Apps
Added tweak for disabling Quick Settings
Added tweak for choosing wake up buttons (Power, Volume up, Volume down and Trackpad)
Added tweak for enabling screen-on when new SMS arrives
Added more schemes to the Softkey Backlight tweak
you can now disable the backlight for the capacitive buttons too
Enabled SIP over 3G
Removed Updater Service (useless for custom roms)
Updated Market to 3.4.4
Updated all apps to latest market version
Bug Fixes
Fixed panorama mode of camera
Fixed Saga rmt_storage error
Spoiler :
http://goo-inside.me/roms/VirtuousTeam/multi/affinity/rom/virtuous_affinity-2.05.0.zip
http://virtuous.prp2.com/android/multi/affinity/rom/virtuous_affinity-2.05.0.zip
http://bit.ly/w5C3iR
Faire un Full Wipe manuel avant l'installation!
(Ne pas utiliser les zips: FULL_WIPE_1.5_EXT4 ou FULL_WIPE_1.4 ou FULL_WIPE_1.3)
installation:
1. Faire un full wipe* (voir ci-dessous)
2. Flasher la ROM
3. Redémarrer.
* Full Wipe:
(ClockworkMod Recovery EXT4requis)
Dans le Recovery, faire:
- Advanced/Wipe dalvik cache
- Mounts and storage/format cache
- Mounts and storage/format sytem
- Mounts and storage/format data
- Wipe data/factory reset
description[ROM 2.3.5 / SENSE 3.5] Virtuous Affinity 2.05.0 based on Runnymede [30.01.12] EmptyRe: [ROM 2.3.5 / SENSE 3.5] Virtuous Affinity 2.05.0 based on Runnymede [30.01.12]
apparemment beaucoup de déçu, pas énormément de rajout dans les paramètres rapides, pas de mod beats audio.
je viens de l'installée et voici quelques petits retours:
- le beats audio marche mais il fait fermer l'application musique plusierus fois avant de s'activer (donc pas terrible)
- pas de paramétrage des paramètres rapides possible, par exemple il y a un raccourcis pour aller dans parametres pour activer le wifi
- je ne sais pas si cela est lié à la rom mais le market ne veut plus m'installer d'applis car il me dis que la mémoire du téléphone est pleine alors qu'il me reste 680Mo d'après les parametres :/ alors que je peux restaurer les applis avec titanium
sinon pour les points positifs Very Happy :
- la rom est super réactive et fluide pour moi (sans mods installés ni paramétrage de l'OC)
- le sense 3.5 est sympa!
je vais essayer de reflasher le ROM pour voir si j'ai toujours ce probleme de mémoire
edit: après un nouveau flash tout semble marcher au niveau de la mémoire. la ROM est encore plus fluide que la première fois Very Happy
Version 1.48 dispo.
Je ne fais pas plus, pas d'internet maison pour l'instant.
Post 1 à jour Wink
je viens de l'installer et pour l'instant tout va bien Wink
Rom flashée et tout est nickel maintenant
Merci! [ROM 2.3.5 / SENSE 3.5] Virtuous Affinity 2.05.0 based on Runnymede [30.01.12] 750705
Des image stp .... koma031
Mise à jour Wink
Merci, çà fait un bout de temps que je n'ai pas flasher mon incredibleS smile
Bug Fixes
çà veut dire quoi exactement ? Que les problèmes cités sont fixés ou bien que ce sont des bugs ?
Sinon, je ne comprends pas Saga rmt storage error ?
Sinon, je le découvrirai par moi-même après l'installation smile
did
