[ROM CUSTOM 4.0.4 IMM76I][25/05/2012] OMEGA V4 *AOKP Build - 37*
Page 1 sur 3 1, 2, 3  Suivant
Message par Fid le Lun 7 Mai 2012 - 17:52
OMEGA
FRANCAIS DISPONIBLE
Android 4.0.4
Based on AOKP Build - 36
Built from scratch from AOKP Team & CM9 Teams source.
Rom is Deodexed + Rooted + Zipaligned
Inside Omega ◄AOKP► v4:
Based on AOKP Build-37
Modem: XXLPW
Kernel: Siyah-v3.2.6
Omega Files AOKP (kitchen application)
Theme Manager
Swype 3.26.92.39062 with all available languages (with download and update options and Dragon Go! addon)
Rom is call recorder ready - use your favorite call recorder program to record your calls (I use Total Recall Call Recorder)
ES File Explorer
Hi-Q MP3 Recorder
Home Switcher
ColorNote v3.8.6
Compass v3.0
ConvertPad v2.1.02
FasterFix v1.6.1
NoLed v5.2
Hide It Pro v2.9.2.1
MixZing Media Player v3.7.2
Tiny Flashlight + LED v4.9.1
Google Translate v2.3.1
any.do v2.03
Barcode Scanner
Sim Toolkit
DSPManager
Play Music
MIUI FileExplorer
Car Home by Google
Ice cream sandwich clock
Android Keyboard with many languages
Voice Command and Voice talk
Polaris Office
Hosts
Three Launchers included:
Apex
Nova
Trebuchet
Mods:
Instantaneous GPS Fixation
Camera mod, allows saving photos/videos to external sd card by D4rKn3sSyS - Available in Omega Files
YouTube modded by rolle (can download videos)
RemountSD by gundalbert - (mounts emmc to sdcard/external_sd - mass storage does not work with this change - only MTP)
Many Tweaks
Rom is no full Wipe - but full wipe is highly recommended
Installation:
Démarrer en Recovery
Faites une sauvegarde
Wipe data/factory reset (je le conseille vivement)
Flash Omega
Flash Gapps
Redemarrez
Appréciez !
changelog
New:
Kernel: SiyahKernel v3.2.6
Modem: XXLPW
Updates:
Apex Launcher v1.2.1
Nova Launcher v1.1.4
any.do v2.11
ColorNote v3.8.6
ES File Explorer v1.6.1.6
hosts
Rom is no full Wipe
Old changelog
Omega ◄AOKP► v3
Based on AOKP Build-36
New:
Theme Manager
Sim Toolkit
DSPManager
Play Music 4.1.513
Barcode Scanner v4.1
Updates:
Nova Launcher v1.1.3
NoLed v5.2.2
hosts
Removed:
CM9 Mucic player
Modded camera (you can add it from Omega Files)
Rom is no full Wipe
Changelog Omega v2.1 :
Based on AOKP Build-35
New:
Kernel: Siyah-v3.2.2
ColorNote v3.8.6
Compass v3.0
ConvertPad v2.1.02
FasterFix v1.6.1
NoLed v5.2
any.do v2.03
MIUI FileExplorer
Car Home by Google
Updates:
Es File explorer v1.6.1.5
hosts
Mods:
Tweaks
Removed:
CM9 Flashlight
changelog V2 :
New:
Modem: DXLP9
Kernel: Siyah-v3.2.1
Rom is now call recorder ready - use your favorite call recorder program to record your calls (I use Total Recall Call Recorder)
Many tweaks added
Updated:
Apex Launcher v1.1.1
Nova Launcher v1.1.2
hosts
Changelog Omega v1.0 :
Based on AOKP Milestone 5
Added:
Omega Files AOKP v0.1 (kitchen application)
ES File Explorer
Hi-Q MP3 Recorder
Home Switcher
Polaris Office
Hosts
Apex
Nova
Trebuchet
Mods:
Rom is Full Wipe
AOKP V4
VISIO DISPO AVEC TALK
Conso batterie : environ 2,5% / heure
SI PB AVEC MMS CHANGEZ VOS APN manuellement
PHOTOS
KITCHEN APPLICATION - CUSTOMIZEZ VOTRE ROM
Dans OMEGA FILES vous trouverez tous ce dont vous avez besoin pour customizer votre rom à votre convenance
INSTRUCTIONS
Vous devez avoir une connection internet
Parcourez OMEGA FILES et téléchargez les fichiers dont vous avez besoin
Les fichiers sont téléchargés dans SDCARD/DOWNLOAD
Installez vos fichiers
Pensez à faire un backup avant toute installations
Si vous nbe pouvez pas télécharger un fichier sur votre tèl, utilisez "download all files" (inclus dans toutes les rom omega)
CONTENUS
Boot Animations
Kernels
Keyboards
Mods
Modems
Programs
Fonts
Utilities
... et bien d'autres encore
CAPTURE
Fid
Appareil principal : SAMSUNG galaxy S6
ROMs : Tyranus
Appareil secondaire : Samsung galaxy S4
: : Pyrana V47
http://www.kanseikaratedoshotokan.com
Re: [ROM CUSTOM 4.0.4 IMM76I][25/05/2012] OMEGA V4 *AOKP Build - 37*
Message par Sccip le Lun 7 Mai 2012 - 21:42
Je te redis la même chose que dans l'autre post:
Merci du partage, en espérant que les tests soient concluants.
Message par Fid le Mar 8 Mai 2012 - 11:39
bounce
La nouvelle mouture OMEGA est en ligne !! ce n'est plus une ICS 4.0.3 mais bien une base de 4.0.4 !! basé sur ce qu'on peut trouver sur les NEXUS.
Après test, rom super fluide, stable et en FRANÇAIS comme toutes les OMEGA. Avec une utilisation normale : environ 50 sms, mail en push, quelques appels et surf 3G, la batterie (2000 mh pour ma part) tient très bien (environ 3 % / heure)
Toujours en cours de test pour vous donner le meilleur...
Pensez à faire un FULL WIPE car la base est totalement différente !!
enjoy
Fid
ROMs : Tyranus
: : Pyrana V47
Message par smobydick le Mar 8 Mai 2012 - 14:05
J'ai peur pour l'autonomie avec ma 1650mah !
smobydick
Appareil principal : HTC one m7
ROMs : stock android kit kat
Message par Fid le Mar 8 Mai 2012 - 14:08
@smobydick a écrit:J'ai peur pour l'autonomie avec ma 1650mah !
Tu peux y aller l'autonomie est plus que correcte
Fid
ROMs : Tyranus
: : Pyrana V47
Message par Angefrance le Mer 9 Mai 2012 - 11:33
Merci pour le partage,
Si j'ai bien compris, il faut installer le fichier téléchargé nommé "Omega_v1...." et ensuite installer le fichier nommé "gapps-ics..." et ensuite redemarrer ?
Merci d'avance,
Angefrance
Appareil principal : HTC ONE M7
ROMs : ARHD
Appareil secondaire : HTC HD2
Message par Fid le Mer 9 Mai 2012 - 12:57
Tout à fait
Fid
ROMs : Tyranus
: : Pyrana V47
Message par mnemonic le Ven 11 Mai 2012 - 10:34
euh question (peut être bête..désolé) : mais c'est quoi le "hosts" indiqué dans la description ?
mnemonic
Appareil principal : galaxy note 2 n7000
ROMs : stock 4.4.2
Appareil secondaire : HTC hd2
: : MIUI v1.8.12
Message par Fid le Sam 12 Mai 2012 - 10:11
@mnemonic a écrit:euh question (peut être bête..désolé) : mais c'est quoi le "hosts" indiqué dans la description ?
Tu parles de quoi ? AOKP ? d'abord il n'y a pas de question bête et AOKP est une alternative à CM9. Du coup une navigation plus fluide, plus flexible. C'est la nouvelle mouture qu'on peut trouver sur le galaxy nexus.
Après des tests super concluant, notamment à propos de la batterie qui tient très bien et tout le reste aussi d'ailleurs, je vous annonce l'arrivée prochaine de la V2.....
see you soon
Fid
ROMs : Tyranus
: : Pyrana V47
Message par seb69100 le Sam 12 Mai 2012 - 14:58
slt,
il s'agit d'un fichier host modifié qui t'évite d'avoir des pubs sur ton tph
seb69100
ROMs : Dorimanx
Message par Fid le Lun 14 Mai 2012 - 12:45
V2 en ligne !
Fid
ROMs : Tyranus
: : Pyrana V47
Message par Fonzie73 le Lun 14 Mai 2012 - 12:59
bonjiour , une petite question d'un débutant
Je suis en 4.0.3 NON rooté. Je peux installer cette rom ou je dois d'abord rooter mon tel ?
merciiiiii
Fonzie73
ROMs : 2.3.5 Ki3
Message par Fid le Lun 14 Mai 2012 - 13:02
Oui il faut roote le tel en suivant le tuto que tu trouveras facilement dans le forum. Bon courage et n'hésite pas si tu rencontre des pb
Fid
ROMs : Tyranus
: : Pyrana V47
Message par Fonzie73 le Lun 14 Mai 2012 - 13:09
Merci merci, mais je dois le rooter AVANT d'essayer d'installer cette ROM ?
je suis en LP7, c'est simple?
re merci
Fonzie73
ROMs : 2.3.5 Ki3
Message par Sccip le Lun 14 Mai 2012 - 13:24
Oui avant sinon tu ne peux pas installer.
Comme le dit Fid, suis un tuto et en cas de soucis postes là bas.
Message par Popovitch75 le Lun 14 Mai 2012 - 22:33
salut , je viens de mettre ta rom vraiment stylé mais j'ai un souci je n'es pas le google store , et je peux pas mettre mes compte google fb ect ... je peux mettre que pour email .
gmail ne fonctionne pas et je n'es pas de reseau activer Sad
Merciii
Popovitch75
ROMs : omega v26.1
Message par smobydick le Lun 14 Mai 2012 - 22:36
Question Importante pour moi : est ce qu'on peut recharger avec le support voiture avec ?? car avec les 4.0.3 officiel ou officieuse, mon tèl me dis "tension trop elevé chargement intérompu" en voiture cest vraiment galère. Aujourd'hui il me restait 2% de batterie vu que je n'arrive pas à recharger via chargeur cigare, alors que les version d'android antérieure marchent sans pb
smobydick
Message par Fid le Lun 14 Mai 2012 - 22:39
Salut
Je trouve ça bizarre car moi j'ai pu tout installer. Il y a juste les vpn que j'ai dû entrer manuellement.
Je vois ça je te tiens au jus. Je suppose que tu as fais tous les wipe et installer le gapps avant le reboot
Fid
ROMs : Tyranus
: : Pyrana V47
Message par Fid le Lun 14 Mai 2012 - 22:41
@smobydick a écrit:Question Importante pour moi : est ce qu'on peut recharger avec le support voiture avec ?? car avec les 4.0.3 officiel ou officieuse, mon tèl me dis "tension trop elevé chargement intérompu" en voiture cest vraiment galère. Aujourd'hui il me restait 2% de batterie vu que je n'arrive pas à recharger via chargeur cigare, alors que les version d'android antérieure marchent sans pb
Perso j'utilise en voiture et ça fonctionne
Fid
ROMs : Tyranus
: : Pyrana V47
Message par Popovitch75 le Lun 14 Mai 2012 - 22:45
@Fid a écrit:Salut
Bah j'ai mis ta rom sur carte sd et j'ai flasher via recovery directement ( en faisant tous les wipe avant bien sur smile ) et le gapps j'avais pas vu c'est peut etre pour ca je vais le faire la j'ai tellement l'habitude de le faire directement j'avais pas regarder xD
Mercii
Popovitch75
ROMs : omega v26.1
Message par Fid le Lun 14 Mai 2012 - 22:49
@Popovitch75 a écrit:
@Fid a écrit:Salut
Bah j'ai mis ta rom sur carte sd et j'ai flasher via recovery directement ( en faisant tous les wipe avant bien sur smile ) et le gapps c'est quoi ca ?
Mercii
Regardez bien dans mon descriptif de la rom il y a un lien après installer la rom il y a installer le gapps c'est un fichier à flasher obligatoirement dans le rénover avant de redémarrer.
Fid
ROMs : Tyranus
: : Pyrana V47
Message par Popovitch75 le Lun 14 Mai 2012 - 23:12
Ouais c'est bon ca marche smile merciiii a toi désolé encore j'avais pas vu ^^ en tout cas continue comme ca ta rom est tres belle smile
je voulais savoir le tethering ( AP) et le swagger c'est quoi?
Merciii
Popovitch75
ROMs : omega v26.1
Message par Fid le Mar 15 Mai 2012 - 8:27
@Popovitch75 a écrit:Ouais c'est bon ca marche smile merciiii a toi désolé encore j'avais pas vu ^^ en tout cas continue comme ca ta rom est tres belle smile
Merciii
Ah cool si ça marche comme quoi faut bien lire !! Pour le tethering, c'est ce qui te permet via le wi fi "d'attacher" un ordinateur portable par exemple pour que celui-ci se connecte via ton tel sur ton réseau 3 G. Pour le swagger, il ne sert à...pas grand chose en fait.
*La V2.1 arrive bientôt*
Fid
ROMs : Tyranus
: : Pyrana V47
Message par mnemonic le Mar 15 Mai 2012 - 16:12
Hey mais c'est quoi ce CWM avec cette rom ? on peut faire un dual boot ?? quelqu'un a déja essayé?? ça marche comment ?
mnemonic
ROMs : stock 4.4.2
: : MIUI v1.8.12
Message par Fid le Mar 15 Mai 2012 - 17:49
@mnemonic a écrit:Hey mais c'est quoi ce CWM avec cette rom ? on peut faire un dual boot ?? quelqu'un a déja essayé?? ça marche comment ?
Oui avec le kernel siyah on peut avoir le dual boot et non pas testé
Fid
ROMs : Tyranus
: : Pyrana V47
