[MOD] One eXtreme Sound Enhancer [v20] [SENSE/AOSP/MIUI] [23.09.2012]
Page 1 sur 5 1, 2, 3, 4, 5  Suivant
Message par colonel59 le Mar 5 Juin 2012 - 23:43
Le mot du Senior Member ZeroInfinity :
"Salut tout le monde, je vous présente le One eXtreme Sound Enhancer."
Fonctionnalités :
-System Wide (No need to press anything, it will be working as soon as your device boots up)
-Maximum Audio Re-sampling (Re-Sampling sound to 48kHz!)
-DPS Manager V3
-AudioFX DSP Widget [Removed in AOSP/AOKP]
-Massively Improved overall sound
-Improved Beats Audio Effect
-Louder, Clearer vocals in the background
-100% FULLY ACTIVATED ALSA MODULES AND DRIVERS! (SPECIFICALLY COMPILED FOR TLV320AIC3008) (TEGRA 3 ONE X ONLY)
-Sony xLOUD Engine ("xLOUD Experience – audio filter technology from Sony" Speaker volume enhancement and prevents distortion in headphones)
-More Powerful Drums
-Walkman Sound Enhancement Features (Clear Audio)
-Walkman Music Player
-MusicBox v3 - By lyapota
Installation
1) Télécharger le fichier ZIP et déplacer-le sur votre téléphone à la racine de la carte SD.
2) Redémarrer en Recovery
3) Faîtes un Backup de votre rom avant de flasher le fichier ZIP
4) Faîtes un Wipe Cache Partition + Wipe Dalvik Cache
5) Flashez le fichier ZIP et redémarrez.
23 septembre 2012 - v20 :
- Added some audio goodies that were only in EndeavorU 0.96.401.2 base
- Removed ALSA in addon options, wil be installed automatically with correct files when you choose your phone model
- Fixed all UUID errors, now all of them are matching to the corresponding effects
- Modified audio_effects.conf
- Updated ALSA libraries, added loads of new alsa libraries and bin files and added some more alsa related build.prop lines (EPIC SOUND!!!)
- Added some misc audio libraries
- Some audio stuff from Sense 4.5 JellyBean ROM
- Using Rezound beatsbass and beatscorehtc libraries for more bass and "pumping" effect.
- Deleted MusicBox (Install from main thread in xda instead)
Anciennes versions :
23 septembre 2012 - v19 :
- Fixed audio_effects.conf
- Fixed equalizers
- Fixed ClearAudio
- Updated asound.so from leaked sense 4.5
- Updated libsrsfx from leaked sense 4.5
- updated audio_policy and audio.primary to sense 4.5
- updated soundfx files to sense 4.5
- updated Rezound Beats Audio to Sense 4.5 Beats Audio
- Re-Organised AROMA Installer
02 septembre 2012 - v18 - Rezound Edition :
- Updates Beats Audio to leaked One XL 2.29 ROM Beats Audio (Thanks to memAllocatoR)
- Updates to some ALSA files
- More clean up done
- af.resampling.quality modified to 255 instead of 5 (Special thanks to aznrice2k4)
- new audio tweaks for build.prop
- Added MusicBox v3 by lyapota (Comes with Normal, ViperX and Coredroid versions)
- Fixed no sound for AOSP/AOKP Evita users
- Other minor fixes and changes
18 août 2012 - v17.5 - Rezound Edition :
-Moved all xLOUD files into addon folder
-Modified script a bit
18 août 2012 - v17 - Rezound Edition :
-Cleaned useless libs and files from the mod (Thanks to sebastiaan15 for pointing that out)
-Now Fully Compatible with (AT&T) HTC One XL (Thanks to BreatheHT for testing)
-Smaller file size
-All ALSA Content used from early leaked test rom 0.96.401.2
-100% fully activated ALSA Modules, drivers etc. (Please do NOT steal these..)
-about 10%-20% clearer sound then on v16
12 août 2012 - v16 - Rezound Edition :
-Removed Beats Notify App in AOSP version (No effect, just for display)
-Added Sony Walkman Music player in AROMA
-Replaced a few libs with walkman ones giving even more clarity to voice, bass and treble
-Fixed audio_effects.conf, no errors at all!
-New Audio Tweak: Audio Fluence Mode, "Broadway" (rather then "Endfire"), basically it fully activates alsa modules and gives more clarity to the sound.
-Merged Maximum audio re-sampling Add-On with Audio Fluence Mode together in AROMA
-New device check before installation to avoid incompatibility with other phones (Thanks to MemAllocatoR for helping me)
06 août 2012 - v15 - Rezound Edition :
-Updated libs
-Walkman sound enhancements in full effect!
-ALSA from 0.96 base
-Totally awesome improved beats audio
-clearer bass and voice
31 juillet 2012 - v14 - Sense et AOSP :
Rezound Edition:
-New Rezound Beats Audio libs (In leaked Rezound Base)
-New Walkman libs
-updated audio_effects
-Improved audio Quality
-Fixed Maximum Audio Re-Sampling
-Added Walkman Music Player In Installer
Normal :
-Reverted back to v1 Beats Audio and bass Libs (More Bass in v1)
26 juillet 2012 - v13 - Sense et AOSP :
-Updated some files
-you can now hear more higher frequencies clearly
-Added xLOUD Activation in AROMA
-Added a totally awesome, new, feature in AROMA: MAXIMUM AUDIO RE-SAMPLING!!!
-Maximum audio Re-Sampling, giving you the clearest sound and maximum quality Sampling Rate @ 48kHz instead of 41kHz
-Added Beat Notification for AOSP (FYI It is not the same as the Sense one.)
22 juillet 2012 - v12 :
SENSE :
-added a few new libs
-xLOUD FULLY WORKING! Very loud if you are using speaker
-updated walkman libs again
-tweaked beats audio, More Bass + clearer sound
AOSP :
-added new bin files activating beats
-Added Walkman player & Visualiser (FC)
18 juillet 2012 - v11.5 :
SENSE :
-Updated walkman sound effects libs
-Adapted audio.policy and audio.default to make the voice and bass much clearer and sounds much "lighter"
-updated xLOUD Engine
--Removed SRS (2 people voted against SRS) (this means the mod is more stable)
-Reverted Back to 2.05.401.2 base HtcSoundEnhancerSettings.apk (no headset option, just beats and no beats)
-Removed the modified framework
-Removed modded HtcBeatsNotify.apk
AOSP :
17 juillet 2012 - v11.0 :
SENSE :
-Improved Bass in Beats Audio
-Sound Enhancement Features From Walkman "Clear Audio Experience" :
-Sound Balance
-Improved Clear Bass
-Improved Clear Stereo
-Improved Surround Sound
-New libs improving bass and voice
-New Audio Filters
AOSP :
-Sound Balance
-Removed SRSPanel because it's very buggy
-New Audio Filters
08 juillet 2012 - v10.0 :
SENSE :
-Tweaked SRS again:
-Much More Bass
-Re-enabled Widesurround sound
-higher Bass frequencies.
-Pumping Bass Effect
-Enabled Hard-Limiter
-Modified Speaker Sound Quality
-new ALSA libs
-new SRS libs
-added mixer-paths (downmix related)
AOSP :
-new ALSA libs
-new SRS libs
-added mixer paths (Downmix Related)
-fixed SRS (forgot to add new lines to audio_effects.conf)
-Deleted AudioFX Widget (If you want to change equalizer use SRSPanel)
04 juillet 2012 - v9.5 - AOSP :
-Fixed Incompatibility with 3rd party music related apps
-Fixed SRS ??? (need confirmation)
-Beats is now enabled and is system wide
01 juillet 2012 - v9.0 :
SENSE Bêta :
-Updated ALSA libs
-Improved Speaker Sound Quality! smile
AOSP Bêta :
-1st Release of AOSP Version!
-Removed HtcSoundEnhancerSetting.apk
-Same changes in Sense 4.0 Release
-Added SRSPanel
-Added SRS Audio Filters
-Added SRS TruBass libs
29 juin 2012 - v8.7 :
-Added Downmix libs From Jelly Bean 4.1
-more clearer sound
-new soundbooster
-new filters
-other minor changes
27 juin 2012 - v8.6 :
-Fixed Overpowering Bass in SRS
-Removed WideSurround for SRS (Does not sound good)
-Tuned SRS again
24 juin 2012 - v8.5 :
- SRS Changes:
- Custom Tuned SRS Effect by me
- Reduced Bass in SRS (It was too loud)
- Disabled Limiters in SRS
- Little to None Distortion in SRS! Very Happy
- Sounds very close to the SRS from the EVO 3D or Sensation!
- Widened 3D Effect
- Added Wide Surround Sound in SRS
- SRS WOW HD Enabled
-Tiny modifications made to the framework (Bugs are still present)
SRS UPDATES :
-UPDATE 3: Trying some modifications to srs_global and srs_bypass, version 8.5 coming very soon...
-UPDATE 4: Focusing on making the SRS option enable the SRS effect and Dolby Enable the HTC 5.1 Effect.
-UPDATE 5: Tuning SRS Effect to my standards Very Happy
23 juin 2012 - v8.0 :
-Added DOLBY & SRS In Sound Enhancer Settings
-Improved Sound Quality ...again...
-ALL Equalizers (EXCEPT BEATS!) now activates SRS
BUG: This uses the old sound enhancer settings (The one with the headsets) and you cannot choose any other headset profiles except ibeats/urbeats, In the mean time, enjoy the SRS! Very Happy
SRS UPDATES :
-UPDATE 1 : SRS & DOLBY enabled in the sound enhancer setting as an option but does not change the sound.
-UPDATE 2 : Public BETA Testing available
17 juin 2012 - v7.0 :
- Improved Beats Audio
- New Audio Filters
- Fixed Crashing when using 3rd Party Music Apps
- Fixed AudioFX Widget
16 juin 2012 - v6.0 :
-Removed Apollo Music player and SRS Panel (no point keeping it since SRS is very unstable)
-Added back some files
-Updated libs
-Reduced Sound Popping/Crackling in speakers (still present in headphones)
-Other Minor Changes
14 juin 2012 - v5.0 :
- Removed Apollo Music Player + SRS Due to many bugs and being very unstable
- Updated some libs
- Cleaned up some files that were not needed
13 juin 2012 - v4.0 :
-Fixed SRS Panel
-Updated xLOUD
12 juin 2012 - v3.0 :
- Added MegaBass Mod (Improved Bass)
- Replaced libaudioeffect_jni.so with Sony xLOUD engine's one.
- Other minor changes and fixes...
09 juin 2012 - v2.0 :
- Reverted libasound.lib to stock
- added asound.conf (If you want to configure ALSA then edit this files to make changes)
- Replaced some libs from various devices
- Boosted Vocals in the backround
04 juin 2012 - v1.0 :
-Initial Release
One eXtreme Sound Enhancer v20
Rezound Edition:
One eXtream Sound Enhancer v17.5 (SENSE/AOSP/AOKP/MIUI) AROMA - Rezound Edition (Uses Beats Audio from HTC Rezound) (RECOMMENDED!)
One eXtream Sound Enhancer v17 (SENSE/AOSP/AOKP/MIUI) AROMA - Rezound Edition (Uses Beats Audio from HTC Rezound) (RECOMMENDED!)
One eXtream Sound Enhancer v16 (SENSE/AOSP/AOKP/MIUI) AROMA - Rezound Edition (Uses Beats Audio from HTC Rezound) (RECOMMENDED!)
One eXtream Sound Enhancer v15 (SENSE/AOSP/AOKP/MIUI) AROMA
Surhomme
Surhomme
ROMs : RD-MIUI JellyBean
: : MIUI FR v2.4.13
Re: [MOD] One eXtreme Sound Enhancer [v20] [SENSE/AOSP/MIUI] [23.09.2012]
Surhomme
Surhomme
: : MIUI FR v2.4.13
Message par colonel59 le Mar 5 Juin 2012 - 23:51
Traduction en français effectuée Very Happy
Surhomme
Surhomme
: : MIUI FR v2.4.13
Message par iciTeLLuRiaN le Jeu 7 Juin 2012 - 13:31
Quelqu'un a test ?
iciTeLLuRiaN
Appareil principal : SM-G925 F
ROMs : Carbone HD
Appareil secondaire : One M9 / M8 /M7 / X [...] / Ma
: : Ouya / Nexus Player / Nvidia Shield
Message par vic69 le Jeu 7 Juin 2012 - 17:30
Ne marche pas chez moi, je n'ai plus de reseau No
vic69
ROMs : Skydragon v12
Message par iciTeLLuRiaN le Jeu 7 Juin 2012 - 17:38
Bon ben la rèponse est donné
iciTeLLuRiaN
ROMs : Carbone HD
Message par colonel59 le Jeu 7 Juin 2012 - 17:40
Bonsoir Vic,
Tu l'as installé sur ta rom et tu n'as plus de réseau ?
Tu as essayé sur quelle rom ?
Tu as bien suivis la procédure pour l'installer ?
Surhomme
Surhomme
: : MIUI FR v2.4.13
Message par vic69 le Jeu 7 Juin 2012 - 18:13
Sur la rom de dougi. Quand je démarre il ne me demande plus le code pin et de plus je n'ai pas trouvé ou on pouvais le régler car il n'installe pas Apollo Music player.
Et oui j'ai bien fais tous les wipes. Je vais réésayer avec la nouvelle ROM de Dougi qui est en cours de téléchargement Wink
vic69
Message par colonel59 le Jeu 7 Juin 2012 - 19:53
Merci pour ton retour Vic.
Avant d'installer ce Mod sur la rom de Dougi, fais un Backup via le Recovery.
Ensuite, suit bien la procédure pour l'installer.
Par contre, je ne vois pas le rapport avec le faîtes que tu ne puisses plus mettre ton code PIN.
A voir si c'est lié
Surhomme
Surhomme
: : MIUI FR v2.4.13
Message par vic69 le Jeu 7 Juin 2012 - 20:38
J'avais fais un backup mais j'avais prévu de faire un full wipe pour la nouvelle rom de dougi Very Happy
Je ferais ça , pour faire un pti retour Rolling Eyes
Par contre je ne comprends pas trop ce que ça fais exactement ...?
vic69
Message par colonel59 le Jeu 7 Juin 2012 - 22:36
Ce mod permet d'améliorer le son avec diverses possibilités de personnalisation, il améliore Beats Audio et apporte plus d'effets, ....
Surhomme
Surhomme
: : MIUI FR v2.4.13
Message par vic69 le Ven 8 Juin 2012 - 12:56
Bon je viens de le réinstaller avec la dernière rom de dougi, ça fonctionne, j'avais du faire une mauvaise manipe Shocked
L'effet SRS n'apporte rien d'extraordinaire je trouve par contre l'effet beats est plus fort et c'est pas mal Very Happy
vic69
Message par colonel59 le Ven 8 Juin 2012 - 14:06
Bonjour Vic,
Merci pour ton retour, et content que ça fonctionne maintenant cheers
Jeanmarce a essayé et il approuve ce mod.
Je vais l'essayé aussi sur la rom de Dougi pour voir.
Surhomme
Surhomme
: : MIUI FR v2.4.13
Message par colonel59 le Sam 9 Juin 2012 - 23:45
Bonsoir tout le monde,
Topic mis à jour : Mise à jour du 09 mai 2012 - One eXtreme Sound Enhancer 2.0
Surhomme
Surhomme
: : MIUI FR v2.4.13
Message par jpfisa le Dim 10 Juin 2012 - 2:05
j'ai installer cette fonction,et bof
après quelques essais sa marche mieux sans avec mon casque.
basses déformés même avec beats désactivé.
les autre actions n'on pas plus d'intérêts que les fonction dance ...etc déjà présentes dans le lecteur
les lecteurs, origine et le nouveau se mélange les pédales un coup l'un s'ouvre un coup l'autre!!!!en appuyant sur la nouvelle icone
je suis sur ROM PkMn 5.0
j'ai effacer (restaurer sauvegarde)
jp
jpfisa
Appareil principal : Note 4
ROMs : origine + root
Appareil secondaire : Cube T9 + Minix neo X8 plus
Message par colonel59 le Mer 13 Juin 2012 - 22:20
Topic mis à jour : Mise à jour du 13 juin 2012 - One eXtreme Sound Enhancer 4.0
Surhomme
Surhomme
: : MIUI FR v2.4.13
Message par colonel59 le Jeu 14 Juin 2012 - 23:15
Topic mis à jour : Mise à jour du 14 juin 2012 - One eXtreme Sound Enhancer 5.0
Surhomme
Surhomme
: : MIUI FR v2.4.13
Message par colonel59 le Sam 16 Juin 2012 - 22:36
Topic mis à jour : Mise à jour du 16 juin 2012 - One eXtreme Sound Enhancer 6.0
Surhomme
Surhomme
: : MIUI FR v2.4.13
Message par colonel59 le Dim 17 Juin 2012 - 20:41
Topic mis à jour : Mise à jour du 17 juin 2012 - One eXtreme Sound Enhancer 7.0
Surhomme
Surhomme
: : MIUI FR v2.4.13
Message par ElRey le Lun 18 Juin 2012 - 8:52
A quand une compatibilité avec Cyanogen?
ElRey
ROMs : ARHD 6.0.0
Message par colonel59 le Lun 18 Juin 2012 - 10:32
Bonjour Elrey,
C'est peut-être compatible, as-tu essayé sur la rom que tu utilises ?
Surhomme
Surhomme
: : MIUI FR v2.4.13
Message par ElRey le Lun 18 Juin 2012 - 20:37
Ouais, ça met une FC pour le jeu de sons
ElRey
ROMs : ARHD 6.0.0
Message par colonel59 le Lun 18 Juin 2012 - 21:36
Bonsoir Elrey,
Tu as un Force Close sur quoi ? L'application ? Paramétrage ?
Essaye donc de faire un Wipe Cache Partition + WIpe Davlik Cache + Fix Permissions (deux ou trois à la suite) via le Recovery et reboot pour voir si ça corrige ton problème.
Surhomme
Surhomme
: : MIUI FR v2.4.13
Message par colonel59 le Sam 23 Juin 2012 - 22:11
Topic mis à jour : Mise à jour du 23 juin 2012 - One eXtreme Sound Enhancer V8.0 BETA [SRS ENABLED]
Surhomme
Surhomme
: : MIUI FR v2.4.13
Message par colonel59 le Dim 24 Juin 2012 - 21:00
Topic mis à jour : Mise à jour du 24 juin 2012 - One eXtreme Sound Enhancer V8.5 BETA[SRS ENABLED][HUGE UPDATE!]
Surhomme
Surhomme
: : MIUI FR v2.4.13
