[ROM DS_VERSION_7.A]DS 7a Froyo 2.2.1 sense
+7
skoblar
JUAN-TIAGO
BlackEco
pcmacactu
Karting06
dadou61
william61
11 participants
description[ROM DS_VERSION_7.A]DS 7a Froyo 2.2.1 sense Empty[ROM DS_VERSION_7.A]DS 7a Froyo 2.2.1 sense
DS_VERSION_7.A
[ROM DS_VERSION_7.A]DS 7a Froyo 2.2.1 sense Descri10
~#~What Ive done ~#~:
deodexed all files
Rooted
BusyBox installed
apps2sd
please use melvinchng tutorial to get full mb of the rom
xda
has custom bootanimation thanks to danny_jo
bash shell support
nano text edidtor installed
installed jacubs version 4.1 Kernal for oc
installed 4in1 boot (unsure of the creature)
Live wallpapers installed
created a few custom frameworks
installed gingerbread keyboard
Create a Custom Wallpaper
Add more languages ( not puting arabic in soz guys )
Changed the Market Theme
changed standered lockscreen thanks to Hewgballs
transparant notification background
edit the htc lockscreen
added opengl 1.1
new lockscreen
NEW BOOTANIMTION FUNNY MARIO LOL
~#~Thing Im still need to do:~#~
Create A Custom Bootanimation
Enable Jit Once some one A dev has fot it workin ( im not a programmer just having a play)
edit the standered lock screen so there a wallpaper as its see threw at the moment
If u wish to use any of danny jo's work like :
Cpu speed
Framework
They all work fine and ive had no trouble at the moment
~#~Ive created some frame work~#~
Please us the new petrol gauge belwo as the old one will mess up as its a old framework
# petrol gauge and new icons
http://www.megaupload.com/?d=MQGAMP8L
# oringal framework
http://www.megaupload.com/?d=I4W3V0UV
WILL ADD MORE WHEN I HAVE TIME
~#~Themed Market place~#~ Ive not created theses
Please remove the android market first with this Flashable Zip and install any of the ones below
At the bottom ov this thread
PendoBlueMarket
http://www.megaupload.com/?d=8FDRDCE7
NeonMarketLight
http://www.megaupload.com/?d=HVHTGH6G
NeonMarketBlueDARK
http://www.megaupload.com/?d=L0RO6D8C
NeonMarketBlack
http://www.megaupload.com/?d=5RT8WDZ6
~#~ Removing the android market theme and replacing standered ~#~
http://www.megaupload.com/?d=C4Z6W5ZN
if u wish to use any one else's work or software do at ur own risk
~#~Updates~#~
Remove Htc Apps and htc lockscreen et Install Adwlauncher and Animated Weatherpro and standered lock screen Extendedcontrols
http://www.megaupload.com/?d=W4QACIWA
please the lock screen is very basic please bear with me whilst i recieve help to amend it
LIst of apps that will be removed are ------- AdobeReader.apk/htccalendarwidgets.apk/Flickr.apk/Rosie.apk/HtcLocationPicker.apk/htcmailwidgets.apk/htcmsgwidgets.apk/NewsReader.apk/HtcTwitter.apk/HtcProfileswidegts.apk/HtcRingtoneWidgets.apk/com.htc.FMRadioWidget.apk/com.htc.FriendStreamWidget.apk/com.htc.MusicWidget.apk/com.htc.NewsReaderWidget.apk/Weather.apk/AlarmClock.apk/com.htc.StockWidget.apk/com.htc.TwitterWidget.apk/com.htc.WeatherWidget.apk/HtcAddProgramsWidget.apk/Stock.apk/htcbookmarkwidget.apk/com.htc.stockwidget.apk/Talk.apk/HtcClockWidget.apk/htccontactwidgets.apk/HtcFootprints.apk/HtcFootprintsWidget.apk/Rosie.apk/worldclock.apk
if u want me to remove any more apps i add them to the list but please wat eva u ask me to remove i cant tell wat it will affect
Remove Adwlauncher and Animated Weatherpro Extendedcontrols
et standered lockscreen and replace htc apps and lockscreen
http://www.megaupload.com/?d=EYI41K6D
Apps that will be removed are Adwlauncher.apk/Animatedweatherpro.apk/standered lock screen framework/ Extendedcontrols
~#~PLEASE IF THERE ANY BUGS PLEASE INFORM ME AND I WILL DO MY BEST TO AMEND THEM~#~
~#~Known bugs~#~......
Currently only on Adwlanucher
will not let u change lockscreen app in settings but will allows u to change on gallery.
in gallery ive create 5 new wallpapers but when u go into gallery it show the old wallpapers at the bottom but the new one at the top
[ROM DS_VERSION_7.A]DS 7a Froyo 2.2.1 sense Screen10
[ROM DS_VERSION_7.A]DS 7a Froyo 2.2.1 sense Snap20110206122238[ROM DS_VERSION_7.A]DS 7a Froyo 2.2.1 sense Mainpanol[ROM DS_VERSION_7.A]DS 7a Froyo 2.2.1 sense Systemk[ROM DS_VERSION_7.A]DS 7a Froyo 2.2.1 sense Linpack[ROM DS_VERSION_7.A]DS 7a Froyo 2.2.1 sense Cpubv[ROM DS_VERSION_7.A]DS 7a Froyo 2.2.1 sense Carpanol[ROM DS_VERSION_7.A]DS 7a Froyo 2.2.1 sense Marketr[ROM DS_VERSION_7.A]DS 7a Froyo 2.2.1 sense 4in1boot
[ROM DS_VERSION_7.A]DS 7a Froyo 2.2.1 sense Change10
Ds_Version_7.a
# Everythink the same as version 6 just changed Bootanimation
# changed the Bootanimation back to the Bios one
[ROM DS_VERSION_7.A]DS 7a Froyo 2.2.1 sense Telech10
[ROM DS_VERSION_7.A]DS 7a Froyo 2.2.1 sense Autres10
Aussi disponible dans la [ROM DS_VERSION_7.A]DS 7a Froyo 2.2.1 sense Yboourv Sinon, uploadez le Wink!
description[ROM DS_VERSION_7.A]DS 7a Froyo 2.2.1 sense EmptyRe: [ROM DS_VERSION_7.A]DS 7a Froyo 2.2.1 sense
Très très bonne rom, pas de bug ainsi que les vidéos plus fluide.
Au passage si vous en connaissez une en 2.3 autre que CM7 ou Openfire avec HTC sense merci de me le signaler Very Happy
Merci william
Je vais le tester ! Merci Wink
Bonjour à vous, voilà je suis intéressé par cette rom comment l'installer?
Je suis actuellement rooter et sos une rom cm7.
Merci à vous d'avance.
Salut !
Tu reboot en recovery, tu fais un Wipe data et puis "Install zip from sd-card" et là tu selectionnes le .zip !
ok merci
il n'y à pas besoin d'etre s-off? car je suis root mais je suis en s -on?
Euh bizarre ton truc.
Tu t'es rooter avec quel programme ? Alpha Rev X (Revolutionary), Unrevoked?
je suis imcapable de te dire comment j'ai fait cela fait 2 mois que je ne m'en sert plus mais j'ai le super utilisateur et rom manageur.
mais tu me conseille de faire quoi pour installer cette rom?
Pousse longtemps sur le bouton Power.
Puis sélectionne: Rédemarrage et puis Recovery. Et là, tu fais ce que je t'ai dit plus haut.
EDIT: 333 message ! Cool Wink
ok merci bien.
Voilà il te suffit de faire un full wipe puis tu l'installe, tu va voir elle est très bien et au moins tu va avoir sense Wink
Le S-off n'est pas obligatoire et le faite que tu soit s-on signifie sûrement que tu la rooté avec unrevoked en 2.1 il y a fort longtemps.
Merci william c'est bon je l'ai installé est ma copine est ravie de cette rom et oui c'est exact je l'est bien rooter avec unrevoked je vient de retrouver le tuto smile
c'est ce que j'avais dit Wink
oui merci à vous deux [ROM DS_VERSION_7.A]DS 7a Froyo 2.2.1 sense 2325459160
Ok c'est cool Wink
Bonjour! Je suis intéressé pour passer de WildPuzzle à cette ROM et je voudrais savoir si DS est meilleure que Wildpuzzle et si oui, qu'elles sont les différences.
Quand tu l'auras essayer, tu le sauras. Au pire, tu fais un back-up que tu restauras plus tard si tu le veux Wink
Ouais, je verrais par moi même. C'est juste que j'ai déjà flashé 3 fois mon tel aujourd'hui et que j'aimerais bien m'éviter encore deux ou trois flashages...
Tu peut flasher tu ne vas pas être déçu Wink
Nouveau sur le forum, j'ai actuellement un Wildfire en Rom CyanoGen mais Sence me manque.
MegaUpload étant fermé, avez vous d'autres liens pour télécharger cette Rom?
Slts
I don't know.
Y a ceci aussi http://forum.xda-developers.com/showthread.php?t=978197
bonsoir Karting06 Very Happy
je pense que tu as reçu mon mp
merci par avance
