[ASTUCE] Montée sa carte microSD en mode stockage de masse USB
Message par cooks le Mar 26 Juin 2012 - 1:57
SGS3 Easy UMS v1.8
En me promenant sur le forum XDA j'ai trouver cette application qui m'est tres utile
Cette application va rendre la carte microSD externe de votre SGS3 disponible en tant que dispositif de stockage de masse USB. Jusqu'à présent, l'application s'exécute en appareil mobile
Images
- added support for third lun file, should work with GT-I9305 (Intl LTE version) now
Anciens Changelogs:
1.7
- fixed recognition failure if "mount" output contained "on" as the second column (e.g. Siyah kernels)
1.6
- fixed code so that it (hopefully!) works with recent CM10 versions again
- made some error messages clearer
- drop of "beta" name doesn't actually mean much by the way, but I think it looks a bit cleaner this way and does not make a difference
1.5beta
- added support for CM10 sd card paths (/mnt/external_sd and /mnt/sdcard1)
1.4beta
- added alternative method for users without s3c-usbgadget (may work on US versions)
v1.3beta
- rewrote the whole logic
- now opens Play Store entry of BusyBox if it is not yet installed
- notifies user if device seems to lack s3c-usbgadget module
- notifies user which apps are accessing the extSdCard
- generally better and more precise error messages
v1.2beta
- Automatically tries to unmount extSdCard before starting UMS mode. This will fail if some app is accessing it, so just wait or cancel that app if you know it and try again - possibly several times. This prevents the potential data loss with previous versions.
- It now checks the location of the extSdCard device. This should help with compabilty, e.g. for US versions.
- Added some log output and toasts (2s delay)
- Added link to this thread and version number in app
- It's a beta so please beware, but I think the worst probable thing that can happen is that it does not work (e.g. it does not start UMS if it cannot unmount the extSdCard).
- Dammit, the whole day is already over
v1.1
- Ajout d'une option pour revenir à MTP
v1.0
- Première édition
SGS3 Easy UMS v1.8
cooks
Appareil principal : Samsung Galaxy S8
ROMs : stock o
Re: [ASTUCE] Montée sa carte microSD en mode stockage de masse USB
Message par Sccip le Mar 26 Juin 2012 - 9:45
Merci du partage, excellente trouvaille
(Je remplace APP par ASTUCE en balise, car même si c'est une application qui permet de le faire, la recherche sera simplifiée)
Message par greatblue le Jeu 28 Juin 2012 - 9:22
Il était temps car c'est vraiment "suant" de copier des fichiers sur ce SGS3
greatblue
ROMs : HD REVOLUTION 7.04
Message par Sccip le Jeu 28 Juin 2012 - 10:08
Ah?? le MTP me convient très bien jusqu'à maintenant.
Message par loic95 le Mer 4 Juil 2012 - 10:39
@Sccip a écrit:Ah?? le MTP me convient très bien jusqu'à maintenant.
Pour copier des images de façon sélective, c'est un cauchemard.
loic95
Appareil principal : SAMSUNG Galaxy S6 Edge
ROMs : PDA:LLC/PHONE:LKB/CSC:LE5
: : 64 Gb Android M
http://thebreizhgeek.blogspot.fr/
Message par Sccip le Mer 4 Juil 2012 - 10:43
Pourquoi?
Message par loic95 le Mer 4 Juil 2012 - 11:22
@Sccip a écrit:Pourquoi?
Parce qu'en MTP, tu n'as pas l'aperçu de tes photos et que tu es obligé de les copier au préalable sur l'ordi.
Bon du coup, ça m'a motivé pour utiliser SGS3 Easy UMS et je viens de rooter mon terminal.
Y a pas à dire, SGS3 Toolkit et Odin, c'est du billard. Moi qui était ultra poltron avec le rootage (jamais fait sur mon DHD), c'est tellement bien foutu qu'on roote son tel en 5 minutes.
loic95
: : 64 Gb Android M
Message par Sccip le Mer 4 Juil 2012 - 11:29
@loic95 a écrit:Parce qu'en MTP, tu n'as pas l'aperçu de tes photos et que tu es obligé de les copier au préalable sur l'ordi.
Ah oui c'est vrai, j'avais même pas remarqué.
Message par jackHD le Mer 4 Juil 2012 - 23:32
Euh juste pour info, il y a la version 1.2 qui est sortie Wink
jackHD
Seigneur
Seigneur
ROMs : SE: 8.10.14203.306
: : SE: 8.10.14219.341
Message par Sccip le Jeu 5 Juil 2012 - 12:30
Post 1 mis à jour.
Merci Jack
Message par Pyrana le Jeu 5 Juil 2012 - 12:46
Hi,
Fonctionne pas chez moi! où j'ai pas compris comment l'utiliser?
Pyrana
Cuist-AND
Cuist-AND
ROMs : HTU-0.4 Rom Pyrana
http://www.dis-ape.be
Message par jackHD le Jeu 5 Juil 2012 - 18:12
Essaie avec la dernière 1.2 beta 2 Wink
jackHD
Seigneur
Seigneur
Message par Pyrana le Jeu 5 Juil 2012 - 20:22
@jackHD a écrit:Essaie avec la dernière 1.2 beta 2 Wink
Hi,
Ben j'ai pris celle en page 1 du jour et cela ne fonctionne pas!!!
Pyrana
Cuist-AND
Cuist-AND
Message par jackHD le Jeu 5 Juil 2012 - 21:01
La dernière mouture sur XDA après c'est une version beta... donc suivant le kernel, d'ailleurs c'est bien stipulé que si l'on a un noyau personnalisé, il a vraiment besoin du module S3C-gadget Wink
jackHD
Seigneur
Seigneur
Message par jeremie0202 le Sam 21 Juil 2012 - 19:04
merci! et quels sont les kernels a part le siyah qui possedent le module s3c-gadget?
jeremie0202
Appareil principal : galaxy s7
ROMs : superman rom 1.12
Message par Invité le Lun 23 Juil 2012 - 5:52
Petite mise à jour sur XDA
v1.3beta
did.
Message par Sccip le Lun 23 Juil 2012 - 21:07
Merci Did.
Post 1 à jour.
Message par dam40 le Sam 17 Nov 2012 - 18:28
Bonjour a tous
Je l'ai téléchargé,elle est sur mon pc,
comment je fais pour la mettre sur le mobile ? Embarassed
Merci pour vos conseils
Bonne soirée !
dam40
ROMs : Rom inconnu
Message par Sccip le Mar 20 Nov 2012 - 15:46
Mise à jour en 1.8.
Une fois le fichier .apk sur ton pc, tu le transfère sur ton tèl et tu l'execute à partir d'un explorateur de fichier).
(Les sources inconnues doivent être autorisées dans les paramètres)
Message par dam40 le Mar 20 Nov 2012 - 16:33
Bonjour a tous
Merci Sccip pour ta réponse
J'ai téléchargé "SGS3-Easy-UMS-v1.8" mais je n'ai pas le fichier dont tu parles (.APK) No
Merci pour tes conseils
A+
dam40
ROMs : Rom inconnu
Message par Sccip le Mar 20 Nov 2012 - 17:33
C'est quoi l'extension de ton fichier téléchargé?
Message par dam40 le Mer 21 Nov 2012 - 14:00
Bonjour a tous !
voici ce que j'ai :
Merci pour tes conseils et bon après midi
dam40
ROMs : Rom inconnu
Message par Sccip le Mer 21 Nov 2012 - 14:39
Je pense que tu ne télécharge pas le fichier du post 1.
Si tu prends 1 des fichiers de la source citée, et si il est en .zip, renomme le en .apk et ça fonctionnera.
Lien direct de l'apk: http://dl.dropbox.com/u/22760184/android/sgs3-easy-ums/SGS3-Easy-UMS-v1.8.apk
Lien du zip à renommer: http://forum.xda-developers.com/attachment.php?attachmentid=1491770&d=1353257048
Message par dam40 le Mer 21 Nov 2012 - 17:31
Merci Sccip
J'avais telechargé le bon fichier,mais je l'avais dézippé au lieu de le renommer,je ne savais pas Embarassed
Merci pour ton aide et ta gentillesse,je me coucherai moins bete ce soir Laughing
Bonne fin journée
dam40
ROMs : Rom inconnu
Message par Sccip le Mer 21 Nov 2012 - 21:28
T'avais pas totalement tort, normalement les zips, il ne faut pas les renommer, ni les décompresser mais les installer par le recovery, sauf ceux là Wink
