[ROM 2.3.5 / SENSE 3 - 3.5] GingerSense4 v1.3 - Sense4.0 feeling! [Fast & Stable]
+4
Poussinou
LudoA12
db77
SAVABACA
8 participants
description[ROM 2.3.5 / SENSE 3 - 3.5] GingerSense4 v1.3 - Sense4.0 feeling! [Fast & Stable] Empty[ROM 2.3.5 / SENSE 3 - 3.5] GingerSense4 v1.3 - Sense4.0 feeling! [Fast & Stable]
GingerSense4
[ROM 2.3.5 / SENSE 3 - 3.5] GingerSense4 v1.3 - Sense4.0 feeling! [Fast & Stable] Ginger10
Westito (developper): I can't find a proper ROM for me, so i created one (exactly two) and i share it with You! It has two versions. The first one based on Sense 3.5 with RcMix kernel and the secound one based on stock Sense 3.0 & stock kernel for the best battery life. I created from other ROMs described below and have a lot of work hours in it editing Xperia Launcher and build parts together
GingerSense4 Sense 3.5 Base
Features
•Based on MikRunny v1.01 (Sensation port)
•Kernel:RCMiX 12 or Unity v10
•Inspire 4G & Telus support
•Removed sense widgets
•Removed Facebook chat & MySketcher (cos always runs in background)
•Added Xplore, BMW, Reader, Flashplayer, AdFree, GPSStatus, OsMonitor, 4ext updater
•Percent (%) battery if need (optional, can select during installation)
•Excellent battery life (250-300 mA in use, 3-4 mA in sleep)
•Odex version
GingerSense4 Sense 3.0 Base
Features
•Supports only Desire HD
•Based on DHD WWE 3.12.405.1 Stock (by nitr00)
•Kernel: Stock
•Stock keyboard
•Odex version
•The best battery life! (can save 30% with this stock kernel!)
Sense widgets removed because you CAN'T use with non-sense launcher!
[center]
[ROM 2.3.5 / SENSE 3 - 3.5] GingerSense4 v1.3 - Sense4.0 feeling! [Fast & Stable] <a href=[ROM 2.3.5 / SENSE 3 - 3.5] GingerSense4 v1.3 - Sense4.0 feeling! [Fast & Stable] Captur11" />
v1.3 (only 3.5)
•Old/New kernel: RcMix v12 (only for DHD,Inspire4G) and Unity V10 (you can choose)
•FIXED: PlayStore and Downloads FC
•FIXED: Beats notify hide
•FIXED: Facebook, Gmail
Spoiler :
Sense 3.5 Base v1.3:
téléchargement
Sense 3.0 Base v1.1:
téléchargement
source
description[ROM 2.3.5 / SENSE 3 - 3.5] GingerSense4 v1.3 - Sense4.0 feeling! [Fast & Stable] EmptyRe: [ROM 2.3.5 / SENSE 3 - 3.5] GingerSense4 v1.3 - Sense4.0 feeling! [Fast & Stable]
réservé
réservé
[ROM 2.3.5 / SENSE 3 - 3.5] GingerSense4 v1.3 - Sense4.0 feeling! [Fast & Stable] 62793 y a plus qu'à attendre les retours [ROM 2.3.5 / SENSE 3 - 3.5] GingerSense4 v1.3 - Sense4.0 feeling! [Fast & Stable] 61393
Merci pour la présentation. Si tu peux faire apparaître le pseudo u créateur quelque part c'est encore mieux.
EDIT: J'ai supprimé les balise IMG qui étaient en trop et j'ai centré l'image.
Je viens de l'installer.
Alors 1ères impressions : très fluide, les animations des fenêtres et des icônes/widgets sont sympas, pas trouvé de bugs jusque-là mais c'est tout neuf.
Par contre il n'y a aucun widget HTC, uniquement celui de l'horloge. Moi il me faut celui des contacts ou ça va pas le faire Very Happy
Bin oui, c'est écrit dessus "removed sense widgets"
Bin oui je viens de voir ça, ce n'est pas le launcher Sense mais celui de l'Xperia (j'avais pas compris ça au départ), et on ne peut pas utiliser de widgets HTC autre part que sur Sense. Je comprends maintenant pourquoi y'a un dock à 5 icônes sur cette rom.
Bon, tant pis, avait l'air sympa comme rom mais je n'ai jamais trouvé un widget contact de qualité &équivalente à celui de Sense (notament pour la synchro des contacts Facebook) : retour à la xxxpachaxxx pour moi ....
@LudoA12, nom du dev ajouté. Merci Wink
Merci Wink
@Poussinou Il faut récupérer l'APK de HTC HUB
C'est quoi l'apk de Htc Hub ? J'ai pas compris ....
http://htc-touch-hd.1fr1.net/t60071-info-appli-htc-hub-de-htc-enfin-bien-fourni
Mais comme elle n'est pas sur le market, il faut l'extraire d'une rom, pas le temps là je vais bosser, si quelqu'un peut te la filer...
Ok merci, mais ça va pas me permettre de faire fonctionner des widgets HTC dans un launcher Xperia ça .... ou je n'ai pas compris ce que tu me proposais.
Ouep et en plus y'a pas les widgets HTC dans HTC HUB alors qu'ils y étaient avant.
Et je n'avais pas vu que c'était le launcher Xperia.
Bref, j'ai tout faux sur ce coup là rendeer
EDIT: Par contre, il parle qu'il a utilisé des roms à base de sense, une en sense 3 et et une en sense 3.5.
Donc je ne sais pas si au final on est sur une interface Xperia qui ressemble à Sense.
Ou si on est sur un vrai sense avec des morceaux de l'interface Xperia.
Pas le temps de tester, et puis pas trop envie de quitter ma XxXPACHAXxX qui me satisfait sur tous les points, si ce n'est la rosie barre qui n'a que 3 boutons au lieu de 5.
[ROM 2.3.5 / SENSE 3 - 3.5] GingerSense4 v1.3 - Sense4.0 feeling! [Fast & Stable] 69699
J'ai édité mon post du dessus Wink
Edit: Bon de ce que j'ai pu lire sur XDA, il va développer des widgets. Donc ceux de Sense sont bien incompatibles.
Du fait je reste sur ma XxXPACHAXxX [ROM 2.3.5 / SENSE 3 - 3.5] GingerSense4 v1.3 - Sense4.0 feeling! [Fast & Stable] 331128
C'est la 2ème solution car il y a tout le paramétrage de Sense dispo et que c'est bien des bases Sense 3.5 ou 3.0 ... n'empêche que y'a pas un seul widget HTC dans cette rom (à part l'horloge), c'est important de le noter pour les futurs utilisateurs.
Bin c'est noté Shocked puisque je te l'ai dit Very Happy
Il faudrait le faire ressortir en rouge par exemple.
Noté en rouge, voilou Wink
[ROM 2.3.5 / SENSE 3 - 3.5] GingerSense4 v1.3 - Sense4.0 feeling! [Fast & Stable] 56749
Mort de Rire
Oui je suis d'accord un des gros truc chiant sur les rom tiré d'xperia c'est au niveau des contacts, je n'ai toujours pas trouvé comment les lier à ceux de facebook.. Pour moi c'est juste pour les photo mais c'est le petit truc chiant ^^
Et bien que le widget horloge soit celui de sense, la météo derrière ne l'est pas si c'est comme sur la dhxperia..
Mais par contre c'est sur que le dock à 5 emplacements et où l'on peut faire des dossiers est quand même un gros avantage comparé à la rom de XxXPachaXxX..
Bien d'accord voisin (j'suis à la Part-Dieu Wink )
Bien le bonsoir voisin ^^
Si la rom de XxXPachaXxX me lasse je tenterais celle là quand même, mais je crois que tant qu'on aura pas la sortie officiel du sense 4 sur dhd rien ne sera vraiment top si on cherche du style sense 4.. Ca devrait plus tarder apparemment.. ^^
Pourquoi les widget sense ne peuvent être dispo que sur sense et les widgets xperia que sur du xperia ?
C'est impossible de prendre uniquement le stock du xperia et d'y mettre un style sense 4 tout en restant sur du sense 3.5 ?
Je sais que quand on est sur telle ou telle base on ne peut pas tout modifier, mais la dhxperia bien que sur une base xperia avait pas mal de truc sense dans ses versions de départ, style le répertoire et les appels par exemple ..
Bon après une journée d'essais , pas de bugs constatés.
Comme déjà cité plus haut les widgets sense ne sont pas présent et cela ressemble effectivementr à de l' Xpéria.
J'ai testé mais pas adopté
