[ROM 4.2.2 / NO SENSE] PAC-man v22.3.0 | AIO | PA 3.0 | AOKP M1 | CM10.1 | AROMA
Page 1 sur 17 1, 2, 3 ... 9 ... 17  Suivant
Message par blackpanther le Dim 14 Oct 2012 - 0:44
Paranoid + Aokp + Cyanogen = PACman
Android 4.2.2, This ROM packs all the tweaks from the three super ROMs into one.
Why Choose Among ROMs , When You have All-In-One !!
Team:
blindndumb, szl.kiev, Randomblame
Very Happy Ce qui fonctionne:
:puce: Tout
Sad Ce qui ne fonctionne pas
:puce: Vidéo : Utiliser MX Player
:puce: Faites nous savoir ce qui pourrait ne pas fonctionner
Fonctionnalités:
  • CM10.1 - Syncd as of 24-02
  • PA 3.00 with PIE
  • AOKP 4.2.2 - Syncd as of 24-02
  • Multi devices - DS , DHD , IS
  • Ported from scratch
  • Fixed Audio Issues
  • Fixed Wi-Fi Issues
  • Fixed Bluetoth Issues
  • Fixed Data Issues
  • Fixed EGL Issues
  • Fixed Storage FC
  • Correct value for brightness & baacklight
  • Edited bools to match device requirements
  • Bluescreen before bootanimation has gone
  • Many more ...
Remerciements:
  • szl.kiev - For Making This Beautiful ROM
  • Randomblame - For Kernel
  • magic1977 - For Testing
  • CM, AOKP and PA Team Members
  • nissanskylinebam - For Signature
Appareils supportés:
Incredible S, Desire S , Desire HD
Images:
PAC-man v22.3.0 20/05/2013
  • Mise à jour avec CM [singhdd93]
  • Setting layout redone, New header for PAC In Black[blindndumb]
  • Dark Calculator[TRDS/kufikugel]
  • Statusbar auto collapse is back[g2usr]
  • Calendar now work on 960p[PA/beerbong]
  • Phone layouts for Tablet/Phablet UI[PA/beerbong]
  • Email FC Fixed[Sniper-]
  • Lockscreen shortcuts for now[Langes72]
  • CM's lockscreen slider shortcut is back[g2usr]
  • View PAC-man contributors in Settings > About phone
Anciennes versions:
## 22.1.0 -> 22.1.1
- Bluetooth finally fixed
- Pac-In-Black Toggle
- Initial LDPI Support
- updated AOKP Sources
- Fixed: navbar rings 90° rotate in landscape
- Lockscreen Theming support
- New Battery Styles
- AOKP Ribbon
- Added missing LDPI battery icons
- Lockscreen SOD Fixed
- Settings layout redone
- Minimal bootanimation
- Updated/Added Translations
- Moar minor updates
## 22.0.0 -> 22.1.0
- Changelog Feature [gs2usr]
- Fixed Quick Pulldown (Instant Tiles Pulldown) [gs2usr]
- Fixed back button will collapse statusbar [gs2usr]
- Toggle to disable Fullscrean Keyboard [OldDroid]
- Pie and Volume Toggle [OldDroid]
- Network Tile Updates [Nick0703]
- Latest PA and some CM Updates [OldDroid]
- Fixed FC's related to changing Navbar targets [xLaMbChOpSx]
- Added Option for Quicktile row Settings [gs2usr]
- Added QuietHours QuickSettings Tile [Nick0703]
- Added Hybrid QuickSettingsTile [OldDroid]
- Fixes on Settings & CleanUp [IvanBrazza & gs2usr]
- Added QuickSettingsModeTile [Nick0703]
- Updated PA sources to 3.15
- Resize text to fit on tile size adjusted [gs2usr]
- Choice to enable/disable CRT animation & at which orientation [kufikugel]
- Fixed PhabletUI NavBar in landscape [gs2usr]
- Brought sources inline with CM & PA sources [bluefa1con & szlkiev]
## 21.0.0 -> 22.0.0
- Brought Tiles inline with cm ones [Nick0703]
- Updated PIE Controls [blindndumb]
- Fix System UI crash when changing recent app key [bluefa1con]
- Notification Shortcuts & WiFi display (SlimRoms) [xLaMbChOpSx]
- Brought some things inline with cm source [bluefa1con]
- New BootAnimation (for most devices updated) [bluefa1con]
- Removed Tiny Gapps
- Various Device Updates
PAC-man v20.0.1 26/02/2013
  • Sources updated as of 24-02
  • Camera Fixed , Panorama Works !
  • Rotation Fixed
  • Reboot to recovery fixed
  • Audio Balance Fixed (Check It!)
  • Someone reported Alarm issue , Its working !
  • Various logcat issues fixed
  • Gapps removed from zip , Flash Manually !
  • Updated kernel to 3.0.66(Desire S)
  • Updated kernel to latest by dla5244(Incredible S)
  • Hardware info updated
  • More Smooth and Better Battery
  • Many More !
PAC-man v20.0.0 25/02/2013
  • Première version basée sur JB 4.2.2
PACman v19.3 alpha 16/01/2013
  • Based on JT R31
  • Multi-Device Incredible S(Experimental) , Desire S , Desire HD , Inspire4G
  • Re-Written updater-script to support multiple device , One ROM for all devices
  • Updated kernel for all devices
  • Android 4.2 keyboard
  • Android 4.2 clock (If crashes , clear data)
  • Fixed paranoid slider
  • Fixed some permission
  • Added an "Automatically Connect" option for WiFi networks
  • Extended PreferenceActivity for title text on a single pane mode
  • Removed CM volume panel style
  • Removed CM kill app longpress back
  • Removed ParanoidPreferences.apk , Manually flash it from [Vous devez être inscrit et connecté pour voir ce lien] !
  • Syncd to CM10 as of 15 Jan
  • Experimental headphone audio fix (Please Test)
  • Battery Tweaks of BlindICE (Experimental)
  • Many more for sure ..
PACman v19.1 alpha 08/01/2013
  • Syncd CM10 for all latest changes
  • Remove buggy AOKP torch toggle
  • PAC default wallpaper
  • New bootanimation
  • Fix some lagging
  • Kernel Updated
  • Possible Audio Fix For ACE
  • Possible Battery Drain Fix
  • Cleaned Port , Ported again from scratch
  • More Changes ..
PACman v18 alpha 20/11/2012
  • Syncd to CM till date
  • AOKP Milestone 1 With Latest Nightly Fixes
  • PA 2.55
  • Fix for volume & music track using volume rocker button when display off (15 steps)
  • MMS CM10 base - AOKP style
  • SystemUI: Fix/Update Cog Circle battery mod
  • Add alpha settings to Circles lockscreen rings
  • Fix battery drain issue - Check Yourself
  • Reduce lag when after installed gapps and some apps under system partition.
  • AOKP: Circle unlock, New Circle Mod Battery, etc
  • Added 0% baterry fix
  • Updated and Changed CPU Freq table
  • Settings: Remove PA version, PA Logo activity, PA Circus
  • Settings: Add PAC version, PAC Logo Activity, PAC Circus
  • More for sure
  • Kernel
    - Jellytime R28 Kernel (Thanks Randomblame)
    - Patched to 3.0.XX
    - Various fixes in kernel
PACman v16.1 alpha 09/11/2012
  • AOKP Milestone 1
  • PA 2.53
  • Merged newer AOKP codes
  • Disable Vibrate on lockscreen
  • Toggles can be hidden(AOKP toggles only)
  • Clickable (short & long configurable) Clock and Calendar in the Notification Slider
  • Color Engine from PA
  • Per app color, latest PA invention, Let's you define navbar color, navbar glow color, navbar buttons color, and statusbar color on per app basis
  • Statusbar and navbar color (Independently from per app color, define default colors)
  • Statusbar transparency and navbar transparency are finally back (Navbar transparency is only enabled on launcher)
  • A lot of fixes to ParanoidPreferences
  • Fix SIM PIN issue
  • Home Button to unlock
  • CM File Explorer Added
  • Clock from Nexus 4 Dump
  • Front Camera - Fixed !
  • Android 4.2 Swype Keyboard from Nexus 4 Dump
  • Android 4.2 EMOJI Keyboard from Nexus 4 Dump
  • Possible bluetooth fix
  • Some build.prop tweaks
  • Updated egl and hw files
  • Port Clean up
  • More for sure !
  • Kernel
    - Jellytime R27 Kernel (Thanks Randomblame)
    - Patched to 3.0.50
PACman v15.0 alpha 27/10/2012
  • Syncd to CM as of 26 Oct
  • AOKP JB Build 5
  • PA 2.23
  • Fix Phablet statusbar gap
  • Fix Tab UI systembar height
  • Removed CM10 Weather
  • Wifi Hotspot Fixed
  • Possible fix of wifi random disconnect
  • Possible fix of Data over 3G, Now it works pretty well
  • Audio fixes
  • init.d script
    - For enable / disable S2W in Saga - Thanks nk111
    - zRam - nor sure if it works :p
  • Activated screen off animation, was disabled by default
  • Speaker issue fixed (Confirmed on Saga)
  • Video Recording Fix added from previous version
  • More bug fixes
  • Kernel
    - Jellytime R23 Kernel (Thanks Randomblame)
    - Patched to 3.0.48
    - Various audio/video bug fixes in kernel
    - More misc changes
PACman v14.1 alpha 16/10/2012
  • Video recording fixed
  • Audio volume issue for both devices fixed
  • framework fixes for wifi-hotspot, native still not working, try any app from market(>) Saga kernel from flinny 113 build
  • Ace kernel from Jellytime R20
  • More visual fixes
PACman v14.0 alpha 15/10/2012
  • Android Jellybean 4.1.2
  • Paranoid Android 2.21
  • ROM Control updated to changes till date
  • New Values for auto brightness
  • Backlit fully fixed
  • Storage FC fix included
  • Hopefully bluetooth restart solved
  • Kernel from Jellytime R19 for DHD(Ace)
  • Fernel from flinny 111 for DS(Saga)
  • Fixes in framework to match saga and ace configuration
  • Modded Bootanimation
  • Bluescreen before bootanimation still there, consider it a feature :P
  • More fixes here and there..
PAC v13 alpha 10/10/2012
  • Default mode is phone
  • Kernel is from JellyTime R17.1, Thanks RB
  • WiFi Fixed
  • Network Fixed
  • Camera Fixed
  • USB Mass Storage Fixed
  • Fix contact custom ringtones
  • Fix Power menu reboot recovery
  • Latest CM10 fixes
  • Latest ROM Control
  • PA 2.18
  • AOKP JB Build 4
  • Syncd CM as of 10-10-12
  • Custom bootanimation, that you wont find :p,i mean the file
  • Changelog can be seen from Settings>About>View changelog
  • Many more fixes ...
:puce: La ROM
:puce: Fix
:puce: Gapps 4.2.2 du 01/03/2013
Dernière version JB 4.1.2:
:puce: La ROM
:puce: kangbang kernel 2.4 pour la correction du wifi
:puce: Paranoid Preferences
:puce: Google apps
Installation
Arrow Make Sure You're On The Latest 4EXT Recovery
Arrow Make A Backup
Arrow Wipe Data/Factory Reset In Recovery
Arrow Flash ROM And Follow Aroma Instructions
Arrow Flash Gapps
Arrow Reboot
Arrow ParanoidPreferences is included in ROM
Sources
blackpanther
Appareil principal : Huawei Mate 7 MT7-TL10
ROMs : Officiel Android 6.0 B571
Appareil secondaire : Asus Transformer TF300T
: : KatKiss - Nougatella #014
Re: [ROM 4.2.2 / NO SENSE] PAC-man v22.3.0 | AIO | PA 3.0 | AOKP M1 | CM10.1 | AROMA
blackpanther
Message par blackpanther le Dim 14 Oct 2012 - 0:45
Je suis en cours de test de cette ROM, elle est très très fluide !
blackpanther
Message par bzhmobile le Dim 14 Oct 2012 - 0:49
Elle fonctionne très bien dans sa version HD2 , donc sur DHD cela doit être perfect smile
Message par arnoldfitleist le Dim 14 Oct 2012 - 9:38
En phase de test aussi. Je très sympa à l'utilisation, énormément de personnalisations !
arnoldfitleist
ROMs : UNOFFICIAL CM10
: : iPad 3
Message par 4oohz le Dim 14 Oct 2012 - 10:11
cam photo mms gps ??? all work ?
I m looking again for a ICS ROM smile
please tell me smile
4oohz
Message par cmoha le Dim 14 Oct 2012 - 10:37
je me vais de ce pas tester cette rom,
qui me plais d'apparence pour ca personalisation.
je dirais en retour tout ce qui fonctione
je vous parlerais ou pas, alors, de ma satisfaction.
cmoha
Appareil principal : HTC One X
ROMs : Viper X 4.1.1
Appareil secondaire : nexus 7 (2013)
: : ROM stock
Message par blackpanther le Dim 14 Oct 2012 - 10:43
cam photo vidéo OK (lors de la prise de photo, celle-ci apparait en vert mais la photo est bonne dans la galerie)
wifi OK
Téléphone OK Very Happy
GPS OK fix rapide
MMS KO pour l'instant (je suis chez Free) je vais changer l'APN Free Mobile MMS par Free MMS et changer le MMSC par [Vous devez être inscrit et connecté pour voir ce lien] pour voir si c'est mieux !
blackpanther
Message par arnoldfitleist le Dim 14 Oct 2012 - 12:21
Petit retour rapide
je précise que c'es bien une JB et non ICS
Alors, petit soucis au niveau de l'icone météo sur le lockscreen. Il reste en point d'interrogation, alors qu'il capte bien le temps, le texte est bon.
J'ai eu un FC ce matin, j'écoutais de la musique en bluetooth et j'ai tenté d'envoyer un MMS et bim, FC.
MMS ne fonctionnent pas, pourtant les APN sont bons d'origine.
Le bluetooth a l'air de moins bien émettre que sur la UN CM10, petites coupures quand on éloigne du hp.
Je pense retourner sous la un.cm10, malgré le problème de MMS (qui semble venir des roms JB pour l'opérateur free)
arnoldfitleist
: : iPad 3
Message par fff13 le Dim 14 Oct 2012 - 17:32
hello !
moi je n'arrive pas à l'installer ! ? je l'ai téléchargé, puis j'ai démarré en recovery.... est ce que je n'ai pas le dernier ext4 recovery ? Comment savoir et comment le mettre à jour ?
Merci pour les infos
NB je n'ai aucun problème pour installer les autres rom ics...
fff13
ROMs : sfr
Message par blackpanther le Dim 14 Oct 2012 - 17:36
@fff13,
Sois plus précis, à quelle étape es tu bloqué ?
blackpanther
Message par fff13 le Dim 14 Oct 2012 - 18:03
Dans le recovery au moment où je choisis le zip j'obtiens comme message :
finding update package
opening update package
E: Can't open /sdcard/Pacman..... .zip
(bad)
Installation aborded
Version du recovery :
1.003 beta 8
fff13
ROMs : sfr
Message par blackpanther le Dim 14 Oct 2012 - 18:21
Le ZIP est corrompu. Il faut le retelecharger.
Si tu peux ouvrir le ZIP sous windows alors il est correct.
blackpanther
Message par bzhmobile le Dim 14 Oct 2012 - 18:27
Le téléchargement est corrompu, il faut retélécharger...
Message par phidie le Dim 14 Oct 2012 - 18:29
Ça arrive quand on utilise un logiciel de téléchargement comme downthem all sur firefox.
Essayés de télécharger normalement.
phidie
ROMs : Ca change tout le temps..
Message par cmoha le Dim 14 Oct 2012 - 18:34
et un bon retour de ma part!
ca fait une tite journée que je tourne dessu et rien à déclarer, a par un ch'tio reboot dans l'aprèm.
bref rien de particulier pour le moment.
je reste avec PACman pour l'instant et on verra demain.
cmoha
: : ROM stock
Message par blackpanther le Dim 14 Oct 2012 - 18:37
moi j'ai eu 2 reboot, mais pour moi je n'ai pas trouvé mieux comme ROM sur JB ou ICS.
Que du bon pour l'instant
blackpanther
Message par db77 le Dim 14 Oct 2012 - 18:38
arnoldfitleist a écrit:Je pense retourner sous la un.cm10, malgré le problème de MMS (qui semble venir des roms JB pour l'opérateur free)
Arrête de dire ça !!!
J'ai installé la Unofficial et ai envoyé un MMS sans souci !!!
Et je te l'ai dit sur le topic concerné !!!
db77
ROMs : Android 7-Nitrogen
: : CM11 (4.4.4)
Message par fff13 le Dim 14 Oct 2012 - 20:01
OUi CA MARCHE !!! merci !!!!!
fff13
ROMs : sfr
Message par fff13 le Dim 14 Oct 2012 - 20:31
Quelle rom radio utilisez vous avec cette custom ?
fff13
ROMs : sfr
Message par cmoha le Dim 14 Oct 2012 - 20:55
fff13 a écrit:Quelle rom radio utilisez vous avec cette custom ?
cmoha
: : ROM stock
Message par blackpanther le Dim 14 Oct 2012 - 21:52
v 14 dispo, je mets à jour le post #1
EDIT:
Post #1 mis à jour
ROM et GAPPS à télécharger
Bon DL, moi c'est fait.
On passe à Android 4.1.2 donc FULL WIPE nécessaire !
blackpanther
Message par barjel le Dim 14 Oct 2012 - 22:10
et le Gapps-JB-20121012-JZO54K.zip (en ligne également sur le site blind) est-il le même que celui de ton lien ?
barjel
ROMs : ICS ou PACman
: : 4ext touch
Message par blackpanther le Dim 14 Oct 2012 - 22:12
Non il faut télécharger ROM et Gapps.
Cf. mon post mis à jour juste au dessus Very Happy
blackpanther
Message par barjel le Dim 14 Oct 2012 - 22:16
ok moi aussi je lance l'install (après fullwipe !)
edit1: pétard! incroyable... un mix incroyable qui permet une ultra personnalisation du téléphone... reste à voir ce que ça donne à l'usage mais pour l'instant je suis emballé car c'est vraiment ce que je cherche (aokp + paranoid! manque plus que cfx mais en fait cette association est du tonnerre !)
edit2: yahoooo !!! le mode tabletUi est fonctionnel à 200% même en 240dpi !
edit 3: arghhhh ! premier bug... la navbar ne s'affiche pas ! résolu en cochant tabletUI soft buttons dans système --> barre de navigation yesss ! mais seulement trois boutons de base... donc pas yessss complètement ! :
bon en tout cas pas de rebbot intempestif et bonne stabilité pour l'instant !
barjel
: : 4ext touch
