description[RECOVERY] TWRP 2.3.1 (TACTILE)(UNOFFICIAL) [24.10.2012] Empty[RECOVERY] TWRP 2.3.1 (TACTILE)(UNOFFICIAL) [24.10.2012]
TWRP 2.3.1 with on-screen keyboard! [2012-10-24]
Pour ceux que ça intéresse, voici un Recovery tactile développé par la team TWRP.
"Oui c'est vrai, TWRP 2.3.1 est sortit aujourd'hui !
Team Win Recovery Project 2.3.x, ou twrp2 pour être plus court, est un recovery custom a été crée pour une meilleure facilité d'utilisation.
Nous avons commencé de zéro en prenant comme base AOSP recovery et nous avons chargé des options standard pour le recovery, puis nous avons ajouté un grand nombres de nos propres fonctionnalités.
Fonctionnalités des touches :
-Touchscreen driven with real buttons and drag-to-scroll
-XML-based GUI that allows full customization of the layout – true theming!
-Settings are saved to the sdcard and persist through reboots
-Ability to choose which partitions to back up and which to restore
-Ability to choose to compress backups – now with pigz (multi-core processor support for faster compression times)
Qu'est-ce qu'il y a de nouveau dans la v2.3 :
CHANGELOG for 2.3.0.0:
-Rebased onto AOSP Jelly Bean source code
-Rewrote backup, restore, wipe, and mount code in C++ classes for easier maintenance going forward
NOTE: backups from prior versions of TWRP are still compatible with 2.3
-ADB sideload functionality from AOSP is included in 2.3, see this link for more info
-Re-wrote fix permissions entirely in C++ and runs in a few seconds instead of a few minutes (thanks to bigbiff)
-Improvements to zip finding in OpenRecoveryScript (should be a lot fewer GooManager automation issues)
-Faster boot times
-Added charging indicator while in recovery (only updates once every 60 seconds)
While this update may not bring a host of new must-have features, this update is a significant re-write of much of the core TWRP code. AOSP Jelly Bean recovery source moved to mostly C++ code and now all of the "TWRP" code is fully rewritten into C++ as well. Now that we've laid this groundwork, we're in a much better position to pull in future AOSP recovery updates as well as implementing more great new features.
Problèmes connus :
-CWM backups are not compatible - please make a fresh backup in TWRP as soon as you have flashed it
[RECOVERY] TWRP 2.3.1 (TACTILE)(UNOFFICIAL) [24.10.2012] Rasb10[RECOVERY] TWRP 2.3.1 (TACTILE)(UNOFFICIAL) [24.10.2012] Ao1310
Installation
1) Copiez le fichier ".img" dans votre dossier "fastboot" à la racine de votre disque C.
2) Puis flasher en fastboot en utilisant la commande :
fastboot flash recovery recovery.img
24 octobre 2012 - :
CHANGELOG for 2.3.1.0:
-Unmount system after boot to prevent some status 7 symlink failed errors on zip install
-USB Mass Storage code improvements
-Better handling of mounting storage during boot for some devices
-Fixed a problem with sizes of images (boot & recovery) after resetting defaults
-Fixed size errors during backup for some devices on recovery, etc.
-Fixed a problem with restoring backups when multiple archives were present
Anciennes versions :
Spoiler :
TWRP 2.3.1
Source 1
description[RECOVERY] TWRP 2.3.1 (TACTILE)(UNOFFICIAL) [24.10.2012] EmptyRe: [RECOVERY] TWRP 2.3.1 (TACTILE)(UNOFFICIAL) [24.10.2012]
Post1 mis à jour avec la version 2.3.1 Wink
