[Kernel][GT-N710X] Note2Core V3.06- Standard, OC and Extreme [17.01.13]
+17
VTR
kakasupershow
Pepiito83
Samaye
yougyoh
Pow
virgo77
jejehtc
frenesistyle
jimmyproner
pantale
cscscs
306man
scofild
jackHD
GORA
21 participants
description[Kernel][GT-N710X] Note2Core V3.06- Standard, OC and Extreme [17.01.13] Empty[Kernel][GT-N710X] Note2Core V3.06- Standard, OC and Extreme [17.01.13]
Note2Core Kernel for Galaxy Note II N7100
About this kernel
This kernel is built from pure Samsung GT-N7100 source, with modifications and tweaks to provide the best user experience in reliability, performance and stability. Built upon my experience firstly with NoteCore and then HydraCore for the original Note, as many of you know, I strive for the best
There are 3 versions of each kernel, for the International standard Note II GT-N7100 and the International LTE model GT-N7105.
This kernel has all debuging removed - logcat, android log, kernel log, schedular log, etc etc all disabled. This is for performance reasons, so if you are a developer this kernel is probably not for you
Kernel Versions
There are three variants of the kernel for each device
STANDARD (STD) - 1.6ghz FSync() enabled
OVERCLOCK (OC) - 1.8ghz FSync() enabled
EXTREME (EX) - 1.8ghz FSync() disabled
The standard version, has no modifications to the processor clocks or voltages and can be considered a direct replacement for the stock kernel, and with FSync() enabled is completely stable
The OC kernel automatically scales up to 1.8ghz, with the proven voltages and stability from the perseus kernel (the same frequency table is used), and with FSync() enabled is completely stable
The EX kernel also scales to 1.8ghz, and has FSync() disabled. It offers by far the best possible performance. In rare circumstances you must be aware that this can lead to data corruption and the need to wipe / reflash a rom back to the phone. 99% of people will have no issues with this, as it has been extensively tested and proven on my previous kernel, but the risk is there. Dont go moaning to me if you lose your data and haven't got a nandroid backup!
- Built from official GT-N7100 sources
- 1.6 / 1.8ghz auto scaling
- Optimised VM memory settings, and global readahead
- Auto-rooting of any rom when flashed, even stock
- init.d script support
- CPU Voltage support through 3rd party apps
- Modified GPU DVFS utilisation steps for maximum GPU performance, far better than stock (this is NOT overclocking!)
- No logging / debugging of any kind for higher performance
- Decreased CPU frequency transition latency
- CRC32 slicing-by-8 algorithm
- SLUB allocator
- PEGASUSQ governor (default, others available)
- NOOP schedular, (default, others available)
- +50mb more free ram compared to all other kernels
- lots of other minor tweaks and changes
- ODIN TAR and CWM ZIPS available for all versions
- TouchWiz roms only
Pas de changelog disponible depuis la V2.10
Anciens changements :
Installation
1) Démarrez dans le CWM Recovery en maintenant les touches "Volume +", "Power" et "Home".
2) Faites un Wipe Cache Partition et dans "Advanced" Wipe Dalvik Cache
3) Flashez le kernel
4) Reboot system
Note2Core
description[Kernel][GT-N710X] Note2Core V3.06- Standard, OC and Extreme [17.01.13] EmptyRe: [Kernel][GT-N710X] Note2Core V3.06- Standard, OC and Extreme [17.01.13]
Un nouveau kernel à tester Very Happy
Une v1.01 est déjà en préparation.
Merci BigPat, tu m'as devancé, j'allais me lancer dans la conception des topics.
Même si c'est JackHD qui les as déniché, je sais qu'il est pris par une flémingite aiguë pour ce qui est de créer les topics . Mort de Rire
Par contre j'me lance sur le topic de la NEAK bounce
Ok je te laisse faire Very Happy
Arf... pas faut concernant ma "maladie", par contre si les kernels commencent à pleuvoir... on ne va plus où savoir donner de la tête, je suis sur celui que GORA doit nous présenter... et j'hésite à passer sur le Note2Core, mais en ayant lu certains retours sur XDA, me semble pas encore bien stable...
Tu as raison, c'est pas encore ça, mais tu vas voir, les maj de ce kernel vont pleuvoir.
Il va vite être au top ce kernel si ça se passe comme pour le GN.
Eh bien espérons qu'il en soit ainsi cheers Je n'ai pas gardé mon 1er Note assez longtemps pour testé tout cela.
Et Hop v1.01 Very Happy
Je l'avais dit, les maj vont pleuvoir.
Je mets à jour le post 1 dans la foulée.
Oki merki, m'en vais aller jeter un oeil ou deux Wink
bon ben testé la version de base,tout fonctionne sauf,ma carte sd 64 GO pas reconnus .......mince dommage........par contre ma carte 32 gO fonctionne nikel......
affraid bien mince... tu as fait des Wipe (cache & dalvik) avant de le flasher ?
oui je l ai refait 2fois.........rien a faire....
Et tu tourne sur quelle ROM ?
Ça serait plus simple si tout le monde mettait dans sa signature ROM + Kernel au minimum.
On gagnerait du temps.
Tu as bien flashé la V1.01.?
V1.02 en ligne
Post 1 mis à jour
v1.05 en ligne cheers
Post 1 mis à jour
Ah tiens cette fois tu l'as flashé... il est comme face ou RedPill (je sais c'est prématuré comme question), mais les 1ers opus n'étaient vraiment pas terribles Rolling Eyes
La V1.02 était pas mal du tout.
Là pour cette v1.05, je peux juste dire que tout est bon, reste à voir à l'usage.
J'ai aussi testé C+ et Orange TV, mais No
Bien cela provient des applications, as-tu été voir si sur le S3 en 4.1.2 c'était aussi la même chose avec celles-ci Wink
Oui, j'ai fouillé sur d'autres forums, même constatation, ça viendrait bien des applications.
Alors il faut faire pression, une pétition ou même une révolution afin qu'elles soient mises à jour Wink
J'ai suivi les conseils d'Oudjat et noté les 3 applications sur le PlayStore en précisant le bug.
De toute façon, ça se fera naturellement, lorsque les nouveaux téléphones sortiront avec Android 4.1.2 (ou plus), ils n'auront pas le choix.
D'ailleurs je me demande avec 4.2 ce que cela donne... vu que les 1ers Nexus 4 sont déjà dans la nature Wink
Alors installé depuis que BigPat nous a signalé sa mise en ligne et je dois dire que je trouve qu'il consomme plus en usage que les RedPill rev0.6 et 7, par contre en vieille cela à l'air d'être du kif-kif... ou c'est moi qui me fait des idées...
Aujourd’hui la conso a été très bonne pour moi avec ce kernel, je le garde. Very Happy
