C:\fastboot>adb push MIUI_Australia_OneX_JB_3.1.18.zip /tmp error: device not found
C:\fastboot>adb MIUI_Australia_OneX_JB_3_1_18.zip Android Debug Bridge version 1.0.29
-d - directs command to the only connected USB devic e returns an error if more than one USB device is present. -e - directs command to the only running emulator. returns an error if more than one emulator is r unning. -s - directs command to the USB device or emulator w ith the given serial number. Overrides ANDROID_SERI AL environment variable. -p - simple product name like 'sooner', or a relative/absolute path to a product out directory like 'out/target/product/sooner'.
If -p is not specified, the ANDROID_PRODUCT_OUT
environment variable is used, which must be an absolute path. devices - list all connected devices connect [:] - connect to a device via TCP/IP Port 5555 is used by default if no port number is specified. disconnect [[:]] - disconnect from a TCP/IP device. Port 5555 is used by default if no port number is specified. Using this command with no additional arguments
will disconnect from all connected TCP/IP devic es.
device commands: adb push - copy file/dir to device adb pull [] - copy file/dir from device adb sync [ ] - copy host->device only if changed (-l means list but don't copy) (see 'adb help all') adb shell - run remote shell interactively adb shell - run remote shell command adb emu - run emulator console command adb logcat [ ] - View device log adb forward - forward socket connections forward specs are one of: tcp: localabstract: localreserved: localfilesystem: dev: jdwp: (remote only) adb jdwp - list PIDs of processes hosting a JDWP transport
adb install [-l] [-r] [-s] - push this package file to the device and i nstall it ('-l' means forward-lock the app) ('-r' means reinstall the app, keeping its data ) ('-s' means install on SD card instead of inter nal storage) adb uninstall [-k] - remove this app package from the device ('-k' means keep the data and cache directories ) adb bugreport - return all information from the device that should be included in a bug report.
adb backup [-f ] [-apk|-noapk] [-shared|-noshared] [-all] [-system|-nosy stem] [] - write an archive of the device's data to . If no -f option is supplied then the data is wr itten to "backup.ab" in the current directory. (-apk|-noapk enable/disable backup of the .apks themselves in the archive; the default is noapk.) (-shared|-noshared enable/disable backup of the device's shared storage / SD card contents; the defau lt is noshared.) (-all means to back up all installed applicatio ns) (-system|-nosystem toggles whether -all automat ically includes system applications; the default is to inclu de system apps) ( is the list of applications to b e backed up. If the -all or -shared flags are passed, then t he package list is optional. Applications explicitly g iven on the command line will be included even if -nosys tem would ordinarily cause them to be omitted.)
adb restore - restore device contents from the backup archive
adb help - show this help message adb version - show version num
scripting: adb wait-for-device - block until device is online adb start-server - ensure that there is a server running adb kill-server - kill the server if it is running adb get-state - prints: offline | bootloader | device adb get-serialno - prints: adb status-window - continuously print device status for a specifie d device adb remount - remounts the /system partition on the device re ad-write adb reboot [bootloader|recovery] - reboots the device, optionally into the boo tloader or recovery program adb reboot-bootloader - reboots the device into the bootloader adb root - restarts the adbd daemon with root permissions adb usb - restarts the adbd daemon listening on USB adb tcpip - restarts the adbd daemon listening on TCP on th e specified port networking: adb ppp [parameters] - Run PPP over USB. Note: you should not automatically start a PPP connection. refers to the tty for PPP stream. Eg. dev:/dev/omap_csmi_tty1 [parameters] - Eg. defaultroute debug dump local notty usepeerdns
adb sync notes: adb sync [ ] can be interpreted in several ways:
- If is not specified, both /system and /data partitions will be u pdated.
- If it is "system" or "data", only the corresponding partition is updated.
environmental variables: ADB_TRACE - Print debug information. A comma separated list of the following values 1 or all, adb, sockets, packets, rwx, usb, sync , sysdeps, transport, jdwp ANDROID_SERIAL - The serial number to connect to. -s takes prior ity over this if given. ANDROID_LOG_TAGS - When used with the logcat option, only these de bug tags are printed.
"In my toolkit, under the extras section, press ADB Sideload a ROM. Press "Yes" when it asks you if you are in recovery. Then select the ROM you want to install. It will then sideload it to your phone and flash it."
dans ce thread: http://forum.xda-developers.com/showpost.php?p=35975366&postcount=4
Je vais faire un tuto pour ce qui sont grave en galère comme moi et qui pense que tout est perdu et qui pense que leur htc est RIP!
Merci Smoog, migascalp, doublefrag(mentation xd) et la team generation mobile pour les recherche effectué et les lien donné.... je...snifff ...je vous aime les gars....et c'est sincère ! MERCI
Je mettrai un tuto pour expliquer comment moi j'ai fait pour que ca marche! See ya!
Bonne nouvelles ! Je savais pas tu vois que TRWP gérait l'ADB lol... J'ai d'ailleurs répondu avec 4h de retard mdr... Content que tout refonctionne, et merci pour le tuto =)
