description[ROM] ROM JB 4.2.2 JDQ39 [CM10.1 + MiUi] Avatar ROM for LG Nexus 4 Empty[ROM] ROM JB 4.2.2 JDQ39 [CM10.1 + MiUi] Avatar ROM for LG Nexus 4
Vous aimez les Rom cyanogen 10.1? Vous aimez  la diversité des thèmes des Rom MIUI?
Alors cette Rom est faite pour vous!!!
La team Avatar à concoctée une Rom combinée entre la la base d'une Rom Cyanogen 10.1 et la large possibilité des différents thèmes d'une Rom MIUI!!
[ROM] ROM JB 4.2.2 JDQ39 [CM10.1 + MiUi] Avatar ROM for LG Nexus 4 Images11
•The platform for avatarrom is CM10.1. The following components are changed on top CM10.
•Status Bar•Toggles page to contain controls for toggles
•Fixed memory leaks
•Theme Chooser•Has an online theme server - head here and download cool MIUI converted themes.
•Changed the layout
•Added previews
•Bazooka Launcher (market link)•Own launcher which is an enhanced version of Trebuchet (you can download this at the end of this post)
•Enhanced theming by adding dockbar
•Preview mode to edit workspaces
•Messaging App•Changed message thread to make them themeable
•Boot Animation•A beautiful boot animation - will be made themeable in upcoming versions
•Settings•Changed statistics to point to Avatar statistics server
•OTA updater - you can check for updates to Avatar right from your device
•Changed to support Avatar ROMs
•Support for Gapps - download latest Gapps package as an OTA update
•Framework•Integrated with ACRA Error Reporter for system wide crashes
•Lockscreen•Changed to make them themeable
•Support for complex unlock gestures
https://s3.amazonaws.com/AvatarRom/JellyBean42/2.0b/cm-2.0b_98_20130226_mako.zip => ROM
https://s3.amazonaws.com/AvatarRom/JellyBean42/Gapps/gapps-jb-20121212-signed.zip => Gapps
-Téléchargez le fichier de votre choix et copiez le sur votre carte sd interne (/sdcard/)
-Redemarrez votre téléphone dans le recovery
-Faite un NANDROID BACKUP (via Rom Manager)
-Un wipe data / Factory Reset  et Wipe dalvik cache sont nécessaires
- chosse a zip from sd card=> selectionnez le fichier zip que vous venez de copier sur la carte sd interne
le site officiciel de la team Avatar http://www.avatarrom.com et le lien pour les rapports de bug  pour http://issues.avatarrom.com
description[ROM] ROM JB 4.2.2 JDQ39 [CM10.1 + MiUi] Avatar ROM for LG Nexus 4 EmptyRe: [ROM] ROM JB 4.2.2 JDQ39 [CM10.1 + MiUi] Avatar ROM for LG Nexus 4
merci d'avoir partagé la rom !!
je ne l'ai pas encore testée .. mais je déteste les thèmes qui sont présentés .. pensez-vous que l'on puisse les changer ?
Bien sur!!!
Il n'y à pas autant de thèmes possibles que sur une Rom Miui originale, mais entre 20 et 30, ce qui laisse pas mal de possibilité déjà.
Les mix sont aussi possible.
merci ^^
