[Skin] OneX/OneXL - Sense 5 - APM - Icons Pack - % Battery - By LeSScro V3.5 (18/03/1013)
Message par Betrayal le Jeu 14 Mar 2013 - 9:35
Aroma tested on OrDroid 3.18 base ! Send Feedback for new base 3.18 !
Rom Compatibility :
MaXimus
JB Remix
ARHD
OrDroid
TrickDroid
Viper X 3.4.x
MOd Compatibility :
Lyapota MOd (% battery + Custom APM available in EXTRAS)
MemAllocator Mod (JB audio Enhancer - Full COmpatible
2013-03-18 Fixed issue with Lyapota 5.2 HEQS
Added support for Aroma lockscreen installation
2013-03.17 v4 is out
Support for ViperX (Me & Taieb partial work)
Fixed some issue during installation
New icons
Weather Support
2013-03-14 Fixed issue with lockscreen, added a new way to perform lockscreen install
Fixed issue with Skip function, you can now select every things you want and don't want... AWESOME
Fixed issue with EQS with Lyapota tips
Fixed various stuff in Aroma to make it more transparent
Added a pop up@ end of Aroma to remember you to like me on facebook and stay tuned about more stuff from me !!
2013-03-13 Support for ARHD + HTC Power Manager fully functional + New Prez
2013-03-13 v3.2 include Lyapota JB ModPack Support
• Fix APM with low brightness
• Fix wrong battery design
• Added Stock Battery design without % (on request)
• other minor Bug fixed, i hope...
2013-03-13 V3 is available
• include Deep Sense 5 integration
• Smokin901 - Sense 5 Lockscreen Beta
• New Base 3.18.x
2013-03-05 New battery % based on Dump of Sense 5
2013-03-04 added new wallpaper package @ download
2013-02-28 New Download link - support desktop and mobile
2013-02-27 Aroma Installer v2 - All in One with Lyapota support - Beta
2013-02-17 Added Flashable ZIP based On VRTheme Ported by Mwr666
2013-02-17 Added Aroma Installer in battery % - suport for Lyapota MOD
2013-02-16 Added APM Mod for Lyapota MOD - Specific download - Ported by Jarein95
2013-02-16 Initial Release
Version 4.1 - 18/03/2013
Betrayal
ROMs : stock - root
Re: [Skin] OneX/OneXL - Sense 5 - APM - Icons Pack - % Battery - By LeSScro V3.5 (18/03/1013)
[JB SENSE 4+ SKIN] Duru Skin v1.1 [12-03-2013]
12-03-2013
Duru Skin v1.1
changelog: 1x1 system widgets / minor changes
06-03-2013
Duru Skin v1.0
how to install:
1. Download and install the apk-file
2. Go to the skin picker and choose the skin
3. Reboot & enjoy
4. Share your screenshots!!!
[JB SENSE 4+ SKIN] Beauteous Skin v1.7 [04-03-2013]
03-03-2013
Beauteous Skin v1.7
- reworked productivity panel
- reworked strip panel with new icons
21-02-2013
Beauteous Skin v1.6
19-02-2013
Beauteous Skin v1.5
- folder background and shape
- Appdrawer and Navbar
- minor changes
changelog
09-02-2013
Beauteous Skin v1.3 - Dropbox download
- stok lock-ring
- dialer themed
- new Statusbar
- some backgrounds
01-02-2013
Beauteous Skin v1.2
- small corrections strip panel
- reworked Black Analog Clock (use the wooden one)
- minor corrections
29-01-2013
Beauteous Skin v1.1
- fixed calculator (use the wooden claculator)
- Black Analog Clock (use the wooden one)
- minor fixes
28-01-2013
Beauteous Skin v1.0
Betrayal
ROMs : stock - root
Message par Invité le Jeu 14 Mar 2013 - 17:43
:merci: pour le partage
Message par Betrayal le Jeu 14 Mar 2013 - 19:46
Update Page 1
Changelog
Betrayal
ROMs : stock - root
Message par Betrayal le Mer 20 Mar 2013 - 16:28
Update Page 1
Changelog
Betrayal
ROMs : stock - root
Message par Cochi le Sam 27 Avr 2013 - 12:55
J'ai un petit problème , après l'installation mon HOX reste bloqué sur le bootscreen.
Il y a une façon spécial de l'installer ?
Merci d'avance.
Cochi
ROMs : Rom Insertcoin V2.1.3 sense 6.0
: : Rom custom HDrevolution
