[NAND/NATIVESD][ROM JB][4.2.2][720p] NexusHD2-JellyBean-CM10.1 V2.7 FOR HD2
+54
rosierehtc
pas&isa
Alphomega
benoa
pcoolen
Flat-twin
ahu88
Darkshark07
ekassard
valoualiasdieu
nguyen18
Djjo
ratatouille75
zorville
mr-rob
aghumat
gregugc
AstraB
amarg
jfd70
frenesy
WILHOLIV
lapps
zigomar
eric.levillain
Lolo78
Ranarok
j323m13
bertgau
noumic
Atmosphere
kochanie
johnmarcus11
x-pOla-x
FlorentB49
Zab69
pimpe
skater
Koubiacz
miczl57
dj_epo
Fredoah
elsimbolo
nithwith
kevisann
powerbocker
vw-001
aldai
chinzo95
geogeo62
Chris30
58 participants
descriptionnativesd - [NAND/NATIVESD][ROM JB][4.2.2][720p] NexusHD2-JellyBean-CM10.1 V2.7 FOR HD2 Empty[NAND/NATIVESD][ROM JB][4.2.2][720p] NexusHD2-JellyBean-CM10.1 V2.7 FOR HD2
[ROM][4.2.2][720p] NexusHD2-JellyBean-CM10.1 V2.7
Retrouvez la version ICS ICI
Retrouvez la version JB 4.1 ICI
NexusHD2-JellyBean-CM10.1 is a stable and fast JellyBean ROM which is built from the CyanogenMod 10.1 source code and firstly provides native 720p video playback support for CM10.1 for HTC HD2.
  Include Android JellyBean 4.2.2 (JDQ39)
Include CyanogenMod 10.1 (CM-10.1)
Include htcleo-2.6.32 kernel: tytung_jellybean_r2
Include tytung's JellyBean CM10.1 ramdisk (initrd.gz).
Include the required proprietary binary files and the HD2-specific files.
Features:
All Android 4.2.2 features
All CM10.1 features
   Enhanced Power Menu w/ Reboot and Screenshot options, etc.
   Power Notification Widget
   Trebuchet Launcher
   T9 Dialer
   Keep app back button in Developer options
   Theme
   And more
All Google Apps including「Google Now」
Multi-Languages
Root, Superuser, su, busybox, etc.
AdFree hosts file
WiFi Ad-Hoc Network (credit: tytung)
Hardware Video Decoding (720p Video Playback via GPU) (credit: tytung)
Hardware Video Encoding (Video Recording via GPU) (credit: tytung)
HWA JB kernel (thanks Securecrt and Rick_1995)
HWUI deny app HwaSettings.apk and the framework patch (thanks royale1223)
NativeSD (thanks Securecrt and Xylograph)
DataOnEXT (thanks ph03n!x)
Pour accéder aux options Développeurs;
Aller dans les paramètres, infos de l'appareil (tout en bas des paramètres) puis tout en bas des infos logicielles
ce doit être n° de build et taper 7 fois dessus, vous aurez un message comme quoi vous êtes développeur maintenant   bounce
Images
nativesd - [NAND/NATIVESD][ROM JB][4.2.2][720p] NexusHD2-JellyBean-CM10.1 V2.7 FOR HD2 NexusHD2-JellyBean-CM10.1_with_Phone
Derniers changements
Spoiler :
Téléchargements
ROM: nativesd - [NAND/NATIVESD][ROM JB][4.2.2][720p] NexusHD2-JellyBean-CM10.1 V2.7 FOR HD2 Download [ltr]NexusHD2-JellyBean-CM10.1_V2.7.zip[/ltr]
(MD5sum: 1A40BCB543C2273D70A77877DD9769DC)
NexusHD2-JellyBean-CM10.1_V2.6.zip
 NativeSD Recovery v1.0 for NativeSD users.
Anciennes versions :
Installation
3 Types d'installation proposées dans l'Aroma:
  + NAND ; system@NAND, data@NAND, boot@NAND For TMoUS HD2 (LEO 1024) installation en Nand uniquement (peu place pour des applis personnelles
  +  NAND with DataOnEXT , system@NAND, data@EXT4, boot@NAND For EU/International HD2 (LEO 512), c'est à dire nos appareils, fonctionne bien la rom en Nand et les datas et applis sur la partition eXT4
  +  NativeSD (SD-EXT), system@EXT4, data@EXT4, boot@FAT32 , For high speed SD card . permet d'avoir une rom en Nand et une autre sur la SD...
Avant de flasher (partitions en 5/285/2, en Full, Mini 5/200/5
Pour une clean install MAGLDR, Attention à l'abus de Task29 Wink :
Pour une clean install CLK, Attention à l'abus de Task29 Wink :
Pour une installation en NativeSd en CLK :
Installation des nouvelles versions en NativeSd
+ Faire un backup de la carte SD sur votre PC
+ Télécharger le recovery suivant recovery_4EXT2.2.7_leo_sd.zip ou celui proposé par Tytung, décompresser le dossier 4EXTRecovery sur votre carte SD
+ booter dans le recovery en lançant clrcad.exe et haret.exe du dossier du recovery
+ dans advanced , partition Sdcard  (1024,0,yes) attention le formatage de la sd va effacer toutes les données
+ remettre la sauvegarde qui est sur le Pc sur votre carte, le dossier du recovery, le zip de la Rom (sans le décompresser)
+ choisir install zip, choose zip et sélectionner le zip de la rom. lors de l'installation choisir NativeSd
+ Rebooter et lancer la rom en laçant le clrcad.exe et haret.exe du dossier Nativesd sur votre carte
Trucs & Astuces
Sur NexusHD2 Android
Sur Xda
descriptionnativesd - [NAND/NATIVESD][ROM JB][4.2.2][720p] NexusHD2-JellyBean-CM10.1 V2.7 FOR HD2 EmptyRe: [NAND/NATIVESD][ROM JB][4.2.2][720p] NexusHD2-JellyBean-CM10.1 V2.7 FOR HD2
Réserved Wink
Vivement du 100% fonctionnel! cheers
Je ne l'ai pas encore testée...
Mais cela prend le bon chemin Wink
Salut !
rapide ,fluide ,mais pas de data ni de 3G,sinon nickel ,mais on va attendre un peu la suite....
Tu es en magldr ou en clk?
Est-ce que tu as vérifié les APN dans les paramètres, réseaux mobiles, nom des points d'accès?
Je suis en clk,
PPP/5/300/dataOnext et APN Free ok.
Après un coup d"œil sur XDA, apparemment je suis pas seul dans ce cas.
Ben alors il va falloir attendre que Tytung nous sorte un correctif ...
J'ai vu qu'il y avait une ligne à modifier dans build.prop, mettre tel quel :
ro.telephony.ril.v3=signalstrength,singlepdp,apptypesim
Et normalement Data et 3G ok.
Salut !
Moi j'ai "ro.telephony.ril.v3=signalstrengthgsmss,singlepdp,apptypesim"
Donc faut virer "gsmss" ,seulement root explo bug .....? pas moyen de faire une modif pour test...!,
j'ai rater un truc ou quoi ? Shocked
Pour le modifier il faut que modifies les droits en lecture/écriture du fichier...
, tu peux le faire avec ESexplorer. Pense à en faire une sauvegarde avant...
Ok! merci
Bon ,fichier modifié,mais le téléphone ne redémarre plus...
Je repasse de suite sur ICS 2.9a,
dommage ,elle était bien celle la...
bonjour,
j'ai le meme probleme, j'ai installé la rom jelly bean 4.2.2 sur mon htc hd2 mais je n'ai toujours pas de 3g et de data, pourtant j'ai mis les parametres apn indiqué sur le site free mobile. s'il faut juste modifier le fichiers build, je voudrais savoir comment on fait pour y acceder.
merci de votre aide.
Attention, ça ne marche pas à chaque fois, vois pour installer un explorateur tel "es file explorer", et après voir le tuto sur le forum.
Ne pas oublier de faire une sauvegarde dans le recovery avant.
EDIT : Voici un lien des "correctifs" pour cette rom : http://forum.xda-developers.com/wiki/FAQ_for_JellyBean_4.2.2_(CM10.1)_by_Tytung
La version 2.1 est sortie. Je teste.
Merci pour l'info Wink
Post1 mis à jour smile
Téléchargement en cours , flash ce soir ?
Possible d'installer la 2.1 par dessus la 1.4a comme une simple mise à jour (et ce sans perte de données ?)
Risqué car ce n'est pas la même base même si j'ai lu sur Xda que certains l'ont fait...
Fais un backup dans le recovery avant et essaye...
Je viens de terminer mon backup, je vais tester. Merci à toi.
Ah la la, dire que Android est facile, mais on se tire toujours un peu les cheveux lors d'une nouvelle installation Wink
Cela fait partie du plaisir smile
Voilà, version installée, data fonctionnel, un petit plantage sur firefox, peut-être un problème de surconsommation de mémoire... Mais comment savoir Sad
Le partage de connexion ne fonctionne pas, mais cela avait été dit smile
Le test antutu n'a rien donné, car il plante à 87% je retesterai demain.
C'est vraiment chouette les quelques nouvelles fonctions fournies dans cette nouvelle mouture.
Edit 25/04/13 :// le test antutu est de 3487, pratiquement idem à la version 1.4a avec une carte sd hyper rapide (633x 95mo)
je l'ai installée hier et je la trouve superbe ! pas de gros problèmes pour le moment,tout me semble fonctionnel ! :merci:
petite question, comment enlever la barre de navigation ? (home, retour, etc...) je trouve ça trop encombrant, je préfère me contenter des boutons physiques
Merci d'avance !!
