description[MOD/THEME] 5UBZ3R0 0N3 V1.3.6 Empty[MOD/THEME] 5UBZ3R0 0N3 V1.3.6
5ubZ3r0 0N3 V1.3.6
Thème Subzero pour les adorateur de bleu sous Android 4.2.2 sense 5
[MOD/THEME] 5UBZ3R0 0N3 V1.3.6 V75
Encore :
1.3.6 : Ajout de compatibilité rom
1.3.4 : Ajout de plus d'icônes
1.3 : Fonctionne maintenant en base 4.2.2
1.2 : Quelque fixe et quelques icônes changé
1.1 : Fix de Prism.apk (HTC2Menu work)
Version 1.3.6 FULL THEME + addon son pour Trickdroid
Version 1.3.6 FULL THEME + addon son pour Venom (ViperOne)
Version 1.3.6 FULL THEME + addon son pour Renovate
Version 1.3.6 FULL THEME + addon son pour InsertCoin
Version 1.3.4 FULL THEME + addon son
Version 1.3 FULL THEME + addon son
Version 1.2 FULL THEME + addon Son
Version 1.1 FULL THEME + addon Son
FULL THEME sans addon
Version 1.0 FULL THEME + addon Son
INSTRUCTIONS
- Faite un BACKUP
- Télécharger et Flashé DarkOne (inverted sense)
- Flashé ce thème
- Enjoy =)
Pour la version Venom
For the Venom theme I had some trouble automatically changing some things due to the changes in the ROM because of the amazing tweaks they have added. HOWEVER, with some playing around you can make the missing changes in the Venom Tweaks. Things like the transparent notification drawer and the statusbar color can be adjusted directly in the ROM's tweaks. Pleas play around a bit and if you have issues let me know and I'll help.
Pour la version Renovate
WOW!!!! Well first off I have to say a HUGE thank you to the Renovate team, this ROM is amazing!! Secondly thank you soooo much for the beautiful theme! I have been working on themeing sense 5 for a while now and all of the things I couldn't edit or fix team renovate seems to have solved! All black and beautiful!
I have made a Renovate Version which basically adds everything I loved about my theme to the amazing built in renovate theme! and it's soooo awesome! I'm finally really really happy with the look of my device!
If you guys would like to try it out you can download it here: Renovate
THANKS AGAIN TEAM RENOVATE!!!
Pour la version InsertCoin
It works and themes everything but without a Black Theme for a base (Like DarkOne) some stuff is still white and some text is dark Grey on Black.... but if you want to try it out it's totally useable and looks pretty great: InsertCoin
Désolé pour l'absence de traduction, pour ce coup Google ne m'aide pas...
Source Xda
IMPORTANT : Ce thème est créé pour fonctionner avec le thème Dark / inverted Sense MOD FLASH Kiray1982 qu'il faudra d'abord  flashé avant le THEME 5UBZ3R0
DarkOne
description[MOD/THEME] 5UBZ3R0 0N3 V1.3.6 EmptyRe: [MOD/THEME] 5UBZ3R0 0N3 V1.3.6
:merci: pour le partage Wink
post 1 mis à jour ^^
il fonctionne sur android 4.1.2 ?
Oui tout à fait ! j'espère bientôt sur 4.2.2 aussi ^^
Mise à jour du post 1 en version 4.2.2 Wink
:merci: Wink
Je vais aller voir, comment il a fait sa soupe, et lui piquer quelques trucs, si ca me plait..
Maintenant que j'ai son accord Wink
Fait toi plaisir et si dans la foulé tu trouve les emplacements pour ce dont on a parler l'autre fois, partage Wink
J'ai marré son archive, c'est cool, il utilise vrtheme...
Plus facile comme ça ^^
Bon courage pour le travail à faire Wink
J'ai un trous de mémoire, rafraîchis moi, si je peut t'aider, ça sera avec plaisir...
Ah oui ça me reviens... Sur le calendrier ... Non?
Comme la dit dougi, c'est vrai que certaines icônes sont pas trop travaillées..
Juste un colorize de base,
Au début j'avais fait comme ça, mais maintenant, je passe plus d'une minute par icônes, baguette magique,zoom, détourage, modifs...
Ça prends plus de temps, mais le résultat est beaucoup mieux, q'un simple colorize..
ça c'est certain ^^
Oui le widget calendrier 1x4 qui est affreusement blanc et l'icône batterie du thème d'OPB's qui me plait pas trop, je préfère celle de la rom Rayglobe ^^
Post 1 mis à jour avec screens Wink
Super thème, moi qui aime le bleu je suis servi
cheers
Post 1 mis à jour
