description[CUSTOM][4.3][I9505][10/11/2013] BATTERY KING v9.2 [XXUEMJ7] Empty[CUSTOM][4.3][I9505][10/11/2013] BATTERY KING v9.2 [XXUEMJ7]
BATTERY KING
Le mot du créateur de la rom "Batteryking" :
"Je vous présente la rom BATTERY KING pour le Samsung S4 I9505."
Détails :
I9505XXUEMJ7 Base
All Knox apks Removed
Removed CPU RENDERING, Full GPU RENDERING Enabled [Adreno 320]
Smooth Response [Lag free]
Enabled Secondary Keys/ Symbols [Samsung keyboard]
Tweaked AOSP Browser [No.1 Browser] with Working Google Bookmark Sync
Flash Support In next version
Quick GPS Lock
Minor Volume Gain [15%]
Long Press Menu Kill [Allowed apks only]
Enabled CRT OFF
Extended Power Menu
Removed Logging to File
100% Working init.d Support with Tweaks
AdFree In next version
ES Root|File Explorer[Old(classic) v1.6.2.4]
No MMS Conversion
Great Battery Life
Infinite SMS Recipient
Email Security Removed
Stock Dialer [Make and recieve 2 calls at one time] v4.9+ >>>Call Recording Enabled
Stock Contacts [Slide left/right to place call or send message]
All Bloatware Removed - S Voice, etc [Retained S Health, WatchON]
Removed Stock File Explorer, Calculator, Few More [Get your favourite & latest from Play Store]
Removed Location/Data Tracking apks [Latest can be installed from Play Store]
Stock Theme
Custom Kernel [Best kernel for battery life & stability]
Lite on RAM
Genie Widget
Removed Sounds Boot, Charger,etc
Working Root
With Busybox
All apks Zipaligned
All apks De-odexed
Much More Can`t Remember
Images et Vidéos
[CUSTOM][4.3][I9505][10/11/2013] BATTERY KING v9.2 [XXUEMJ7] 111
[CUSTOM][4.3][I9505][10/11/2013] BATTERY KING v9.2 [XXUEMJ7] 222
Installation
1) Démarrez dans le CWM Recovery en maintenant les touches "Volume +", "Power" et "Home".
2) Faîtes un NANDROID Backup via le Recovery en allant dans "Backup et Restore/Backup" ou "Backup et Restore/Backup to External SD".
3) Allez dans "Mount and Storage" et choisissez "Format system" puis faites un "Wipe Data Factory Reset" (pas nécessaire si vous venez d'une version précédente de la Rom), "Wipe Cache Partition" et dans "Advanced" "Wipe Dalvik Cache" ou cochez l'option "Full Wipe" lorsque vous êtes dans l’installeur Aroma.
4) Flashez la ROM et redémarrez.
5) Enfin amusez-vous  Very Happy
Changelog
10 novembre 2013 - v9.2 :
- XXUEMJ7[4.3] Base MD5: ---
- All Knox apks Removed
- New Stock Modified Kernel from talexop
- BK`s Restart Options Tweaked
- Removed more unnecessary apks and libs
- Make sure to flash xxuemj7 modem and wifi fix else bad wifi
Anciennes versions :
Spoiler :
Téléchargements
BATTERY KING v9.2 - Lien
Spoiler :
description[CUSTOM][4.3][I9505][10/11/2013] BATTERY KING v9.2 [XXUEMJ7] EmptySamsung, Galaxy S4, Battery King, Mods, Fix
Mods, Fix
-I9505_XXUBMGA_MODEM
-I9505_XXUBMGA_WIFI_FIX
-LTE_FIX
-CAMERA FIX
description[CUSTOM][4.3][I9505][10/11/2013] BATTERY KING v9.2 [XXUEMJ7] EmptyRe: [CUSTOM][4.3][I9505][10/11/2013] BATTERY KING v9.2 [XXUEMJ7]
Merci du partage cheers
Topic mis à jour : Mise à jour du 20 juillet 2013 - BATTERY KING v4.9 [XXUBMF8]
Topic mis à jour : Mise à jour du 29 juillet 2013 - BATTERY KING v5.0 [XXUBMGA]
Topic mis à jour : Mise à jour du 14 octobre 2013 - [ROM] I9505 XXUDMI1 | ...:::BATTERY KING:::... v8.2 | TWEAKED | SMOOTH | QUALITY
Topic mis à jour : Mise à jour du 09 novembre 2013 - BATTERY KING v9.2 | TWEAKED | SMOOTH | QUALITY [XXUEMJ7]
