[APPLICATION ANDROID - INDEX MODULES XPOSED] Centralisation des Modules Xposed Framework
Page 5 sur 23 Précédent  1, 2, 3, 4, 5, 6 ... 14 ... 23  Suivant
Re: [APPLICATION ANDROID - INDEX MODULES XPOSED] Centralisation des Modules Xposed Framework
Message par Primokorn le Dim 24 Nov 2013 - 16:30
Nouvelle bêta cheers
=> XposedInstaller_2.4-beta1.apk
Changelog :
Support for Android 4.4 (KitKat)
Significant performance improvements of the framework
Viewer for the debug.log in the installer
Check in the installer whether Xposed is actually active and working
rovo89 a écrit:In detail:
Xposed should now fully support KitKat. As mentioned, that wouldn't have been possible at this time without your support.
Modules should continue to work if they don't rely on AOSP internals that have changed in KitKat. One example: It seems that the battery icon is no longer an (animated) image, but a Java implementation. Obviously, any modules that try to replace the battery image will no longer work. The Xposed framework can't do anything here, the module needs to be rewritten. Therefore, if some of your modules don't work, please get in contact with the module author first. You will probably see an error in the new debug.log viewer in this case.
Xposed isn't compatible with ART, I can't say yet whether it will be in the future (will require a major rewrite if possible at all). As you would get into a bootloop if you try to combine Xposed+ART, Xposed automatically resets the choice to "Dalvik". If you want to test ART, you must uninstall the framework.
The performance improvements apply to the very core of Xposed, the method hooks, in all Android versions. In a test app developed by @exidler, the overhead per call used to be ~71 μs (= 0.071 ms) per call to a hooked method (with one empty callback handler) on my Galaxy S2. Now it's ~13 μs (= 0.013 ms). That's a relative improvement of factor ~5.5x. Thanks to @exidler for the research and several suggestions! I have sent a pre-beta to @kamso, who had reported lags with older versions. Now everything works fine for him. Anyway, I wouldn't say that Xposed had bad performance before. Keep in mind that we are talking about significantly less than a millisecond here.
The debug.log viewer should give a quick impression whether Xposed and modules could be loaded fine. It also includes options to save the log to SD card (so it's easier to transfer it to a PC etc.) and send it via mail.
The Xposed Installer now checks whether the latest version of the framework is active. If not (e.g. because it's not installed yet, you forgot to reboot or something in Xposed doesn't work), you will see a warning in the welcome screen and at the top of the module list.
Finally, there were some other minor improvements and fixes and new/updated translations.
Seigneur
Seigneur
Appareil secondaire : Nexus 5
: : AospExtended / MagiskSU
Message par Fredoah le Dim 24 Nov 2013 - 18:03
Fredoah
Seigneur
Seigneur
Appareil principal : N9005
ROMs : XXUGBOF1 (5.0)
: : De passage... ::
Message par Mendicant Bias le Dim 24 Nov 2013 - 23:49
:merci: pour l'info Primo
ROMs : Rom Stock
: : X-Note v10
Message par Primokorn le Mar 26 Nov 2013 - 9:17
26/11 => correction. App Settings manquait à l'appel, j'ai du le louper...
Le voici donc dans la liste "Autres"
  • App Settings par @Tungstwenty - Modifier les paramètres génériques (DPI, rotation, plein écran...) application par application. Sélectionner quelles applications sont lancer au démarrage du système.
Seigneur
Seigneur
Message par Fredoah le Mar 26 Nov 2013 - 10:43
Merci Wink
Fredoah
Seigneur
Seigneur
Message par jejehtc le Mer 27 Nov 2013 - 12:51
@Primo peux-tu m'expliqué ce qui faut faire pour ne plus avoir le message à l'installation du xposed
Mouting/system writablebachup of app_process ...etc
jejehtc
Appareil principal : Motorola Nexus 6
ROMs : Rom Stock
Appareil secondaire : HTC DESIRE
: : CM11
Message par HTCBatMan le Mer 27 Nov 2013 - 12:54
Bijour à toi,
Ben c'est juste une confirmation de l'installation, Xposed, il te raconte un peu ce qu'il a fait.
Mais si tu l'enlèves, ça changera quoi ???
Message par Primokorn le Mer 27 Nov 2013 - 13:32
Je n'ai pas ce message en fait ^^
T'es sûr d'avoir pris la version bêta ? version 2.4 beta 1 | app_process 45 | XposedBridge.jar 40
Seigneur
Seigneur
Message par jejehtc le Mer 27 Nov 2013 - 14:18
oui j'ai la meme beta que toi
jejehtc
ROMs : Rom Stock
: : CM11
Message par Primokorn le Mer 27 Nov 2013 - 14:30
La réponse est LA. En gros, faut monter le système en écriture avant d'installer "app_process".
Ça sera corrigé à la prochaine bêta peut-être.
Seigneur
Seigneur
Message par jejehtc le Mer 27 Nov 2013 - 14:46
ok merci je testerai cela ce soir car la je suis au staff et la c'est chaud car fin de mois donc livraison à fond pour faire le chiffre.
jejehtc
ROMs : Rom Stock
: : CM11
Message par Primokorn le Mer 27 Nov 2013 - 14:55
On est avec toi Wink
A suivre sous peu, deux nouveaux modules : Phab7 et PerAppFonts.
EDIT
Ils sont disponibles Very Happy
Seigneur
Seigneur
Message par Primokorn le Jeu 28 Nov 2013 - 11:21
@jejehtc a écrit:ok merci je testerai cela ce soir car la je suis au staff et la c'est chaud car fin de mois donc livraison à fond pour faire le chiffre.
Alors ça marche ?
Sinon, fais ceci :
1. Ouvrez le Terminal Emulator
2. Tape : su
3. Puis : mount -o remount,rw /system
4. Ouvre à nouveau Xposed et l'installation/update devrait marcher
Seigneur
Seigneur
Message par jejehtc le Jeu 28 Nov 2013 - 12:53
Merci pour l'info car je voulais mettre le xposed + gravity box sur la cataclysm mais ça merde au niveau des toggles.
jejehtc
ROMs : Rom Stock
: : CM11
Message par Primokorn le Jeu 28 Nov 2013 - 13:34
Un petit nouveau pour aujourd'hui : Lockscreen Background
Seigneur
Seigneur
Message par Fredoah le Jeu 28 Nov 2013 - 14:08
Fredoah
Seigneur
Seigneur
Message par jejehtc le Jeu 28 Nov 2013 - 19:00
Xposed framework pour kitkat en beta 2 est sortie je vais tenter cette version sur ma Cataclysm
jejehtc
ROMs : Rom Stock
: : CM11
Message par Primokorn le Jeu 28 Nov 2013 - 21:30
Merci !
Seigneur
Seigneur
Message par Primokorn le Ven 29 Nov 2013 - 16:03
@Avis à ceux qui ont les dernières versions bêta et de préfèrent à ceux qui tournent sous KitKat
Est-ce que vous avez constatez une baisse de l'autonomie ?
EDIT
J'ai tout supprimé et je n'ai plus de problèmes... J'avais les modules suivants : GravityBox, XBlastTools, App Settings et XPrivacy. Est-ce que le problème venait des modules en général ou d'un seul, je ne sais pas.
Seigneur
Seigneur
Message par Primokorn le Ven 29 Nov 2013 - 21:06
Ajout :
YOUTUBE ADAWAY : Supprimer les publicités dans les vidéos YouTube
Seigneur
Seigneur
Message par Celine62110 le Sam 30 Nov 2013 - 9:21
Celine62110
ROMs : Rom inconnue
Message par Primokorn le Sam 30 Nov 2013 - 14:11
Version 2.4 finale du Xposed Installer : http://dl.xposed.info/latest.apk
Support for Android 4.4 (KitKat) in Dalvik mode (ART is not supported, see below)
Seigneur
Seigneur
Message par HTCBatMan le Sam 30 Nov 2013 - 15:08
Super merci de l'info !!!
Message par Primokorn le Mar 3 Déc 2013 - 13:35
3 nouveaux modules : Xposed StatusBar Mods, SpotifyAVRCP & KitKat Toast Backport
EDIT
Xposed Installer en 2.4.1
Seigneur
Seigneur
Message par HTCBatMan le Mar 3 Déc 2013 - 15:45
Okéy, je vais voir ça
Merci mister primo
