[ROM JB SENSE5][4.2.2][OTA][Xposed]MagioROM R6.2 - extreme performance, 0% Lag, Battery HTC ONE X+
Message par bzhmobile le Lun 26 Aoû 2013 - 22:51
Nous devons cette Rom à Grinder19
Enjoy...
This is my first Rom many of you will know me as a advanced themer for viper Roms. Please be patient with me I'm still learning a lot
I will have 2 versions of my Rom available soon as I get a new laptop. I will have stock Rom and stock inverted Rom with dark backgrounds and white text
  • rebased to 2.18.401.2
  • Sense 5
  • Android Jellybean 4.2.2
Installation
Faire un backup dans le recovery, puis copier le contenu de Sd interne sur votre PC...
1. Télécharger la Rom. Extraire le boot.img qui est dans le Zip de la Rom, puis le flasher en mode fastboot (fastboot flash boot boot.img) ou avec Kernel Flasher
2. Copier le zip sur la "Sd card/mémoire interne" de votre HOX+
3. Booter dans le Recovery (TWRP 2.3.1.0 suggéré. )
3. Wiper les caches et le system , factory reset (ce qui effacera vos datas mais pas le contenu de la SD)
4. lancer l'installation .
Rebooter  Phone and Enjoy ...
Un backup est à faire dans le recovery avant l'installation...
R6.2: OTA
  • Enabled init.d scripts by default
    Fixed WiFi hotspot
    Added latest myhub files and configuration. You can find myhub under settings
R6: Full Rom
  • Completely stripped rom down and rebuilt it from the ground up.
    new APM(thanks @tr1gg3r84),
    New systemUI with animated background support(thanks @richamondoUK for fixing background issue)
    New performance tweaks giving the best performance yet
    New Battery performance tweaks giving best battery performance(you may need to calibrate battery)
    credits PurePerformances X & to zeppelinrox for his default.prop of V6
    ImbaWind for his parts of Adrenaline Engine
    idcrisis for his CrossBreeder
    nicolassp for his S1_Optimize
    (Ive used their work as a basis then improved on the concept solely for this rom)
    Viper4android included (thanks @ViPER520 and @zhuhang)
    Longpress back to kill mod(thanks @imagiox1)
    Now able to select dark Theme from this installer
    myHUB included providing access to mods and themes thanks microsmile(will be available in next OTA)
    New bootanimation thanks to @venomtester
    many many more improvements.
    I notice small error I left superuser app in Rom so it will ask you to install binary don't allow it and go into supersu app instead go to settings and tap remove other super user apps and reboot. If supersu not installed then install from playstore do that then make the app a system app in settings
Rom Update
MagioROM_OTA_R6.2.zip - 8.98 MB
Rom Update
Magiorom_Xplus_R6.zip - 995.08 MB - Full Wipe optional unless coming from another Rom
sur Xda
ROM SENSE5 JB 4.2.2 OTA MagioROM R4 HTC ONE X+ genmob @Gen_mob
Réserved Wink
Re: [ROM JB SENSE5][4.2.2][OTA][Xposed]MagioROM R6.2 - extreme performance, 0% Lag, Battery HTC ONE X+
Message par bzhmobile le Dim 5 Jan 2014 - 23:05
Post1 mis à jour Wink
