[SGN3][ROM 4.4.2][SM-N9005] [ZHUENH4] Omega v22.1 Samsung Galaxy Note3
Page 1 sur 9 1, 2, 3, 4, 5, 6, 7, 8, 9  Suivant
Message par Mendicant Bias le Sam 5 Oct 2013 - 8:36
Le mot du créateur de la rom "::indie::" :
"Je vous présente la rom Omega pour le Samsung Galaxy Note 3 compatible SM-N9005 uniquement."
Fonctionnalités :
- Based on firmware ZHUENH4 Android 4.4.2 (Date: 20/08/2014)
Omega Kernel - Sources
Build from Samsung sources KK Update 7
Build with stock ARM toolchain 4.7
Governors:
Dancedance
Intelidemand
Lionheart
Smartmax
I/O schedulers:
Fifo
Fiops
Simple
V(R)
Zen
Ramdisk XXUENC2
Selinux status set to Permissive
ExFAt sdcard support
busybox
init.d support
Insecure
Adb Insecure
*Stock kernel as an option to aroma installer
Features:
csc multi set to EUR
Busybox
Aroma Installer
Installation is fully customizable by user and there is options to install everything or remove all Bloatware
aroma installer now has the option to remove more then 700 mb of almost 100 bloatware apps, widgets and services
Option to full wipe from aroma installer
Option to Remove all Bloatware from aroma installer
Option to install or not all Omega addon apps from aroma installer
Wipe cache partition automatic before roms installation
Wipe Dalvik Cache automatic during installation
Wipe preloaded partition automatic before roms installation
Wipe System automatic before roms installation
Omegas Emblem Bootanimation by our artist anbech
Omegas Emblem Shutdown animation by our artist anbech
OmegaDroid Kit Kat Wallpapers by our artist Jorq1H
Applications developed by Omegas Team (bartito & indie):
Omega Files by indie
OmegaDroid - The official application of www.omegadroid.co by indie
OmegaDroid Wallpapers application - Screenshot by indie
Task manager shortcut app by indie
Accounts Sync Profiler - xda thread for support & suggestions - Play Store link - by bartito
Backup manager for apps & data - xda thread for support & suggestions - Play Store link - by bartito
CPU Adjuster - xda thread for support & suggestions - Play Store link - by bartito
Notification Manager - xda thread for support & suggestions - Play Store link - by bartito
Recycle Bin - xda thread for support & suggestions - Play Store link - by bartito
Wireless Scheduler - xda thread for support & suggestions - Play Store link - by bartito
more to come ....
if someone wants to help with our app development, with beta testing, suggestions, translations and be part of our app dev team please sent me a pm.
Mods:
Omegas OGBatteryMod app with almost 60 battery mods - credits to OsamaGhareeb
Call Recorder
4-way reboot menu
Phone with no increasing ringtone
TW Launcher with scrolling wallpaper (can be disabled from Omega Files)
Hide sms from call logs
No sms to mms conversion
Unlimited contacts to sms - mms
sms/mms Backup - Restore
sms/mms Enable Group Messaging
Increased sms hour limit to 1000
Disable scrolling cache
Email with Exchange Security Disabled
All supported languages enabled
All supported languages for Samsung Keyboard enabled
Exit button to stock browser
Join more unlimited contacts in the contacts
Enable sub Symbols on Stock Samsung keyboard (available at Omega Files Free & Pro)
Camera shutter sound on-off
Kids mode ported form S4
Modded YouTube by rolle (can download videos) - available at Omega Files
build.prop tweaks
Addon applications:
Xposed Framework Installer by rovo89 - read more about Xposed here
Android Camera 4.4.2 with Photoshare
Android Keyboard 4.4.2 - available at Omega Files
Flash player Support
Dolphin Browser with Flashplayer support
Dolphin Browser Jet Pack
[url=https://play.google.com/store/search?q=Es File]Es File Explorer[/url]
Hide It Pro
ZArchiver
Hi-Q MP3 Recorder
Wanam Xposed
App Settings by Tungstwenty
MW Apps Manager
Pen Window Manager
Removed:
Knox
Boot sound
Charger Connection Sound
Stock Theme Changes:
Accuwheather widget transparent by indie
Omega Theme for aroma installer by our artist anbech
Bloatware :
You can remove all bloatware during Omegas installation
Rom is Deodexed + Rooted + Zipaligned
Images et Vidéos
Installation
Pré-requis :
- Avoir installé la rom stock Android 4.4.2 [ROM 4.4.2][SM-N9005] Pre-Release Rom Stock Samsung Android KitKat 4.4.2 [XXUENA6]
Installation :
1) Important : Faîtes un Backup EFS (IMEI) via ce tuto [OUTIL][SM-N9005] Backup et Restore EFS (IMEI) pour le SGNIII
2) Démarrez dans le Recovery custom CWM Android KitKat 4.4.2 en maintenant les touches "Volume +", "Power" et "Home" et vérifiez que vous avez la dernière version via ce Regroupement.
3) Faîtes un NANDROID Backup via le Recovery en allant dans "Backup et Restore/Backup" ou "Backup et Restore/Backup to External SD".
4) Faites le "Wipe Data Factory Reset", "Wipe Cache Partition" et dans "Advanced", le "Wipe Dalvik Cache" via le Recovery.
5) Ensuite flashez la ROM.
6) Redémarrez et configurez le premier setup (Choix de la langue, configuration du compte Samsung Google, ...)
7) Redémarrez dans le Recovery custom et flashez SuperSU
8) Enfin redémarre et amusez-vous  Very Happy
Activer le débogage USB :
1) Aller dans "Paramètres/Général/A propos de l'appareil".
2) Tapez 7 fois sur "Numéro de version", un message apparaîtra en disant que "le mode développeur a été activé"
3) Allez dans "Paramètres/Général" et vous verrez au-dessus de "A propos de l'appareil" le nouveau menu "Options de développement".
4) Allez dans ce menu et vous allez pouvoir activer le débogage USB cheers
Changelog
Omega v22.1 (05/10/2014):
Omega Kernel v1.3 - Sources
Build from Samsung sources KK Update 9
Governors:
Dancedance
Intelidemand
Lionheart
Smartmax
I/O schedulers:
Fifo
Fiops
Simple
V(R)
Zen
Ramdisk XXUFNG2
busybox
init.d support
Insecure
Adb Insecure
*Stock ZHUENH4 kernel as an option to aroma installer
Added:
Phone INFO ★Samsung★
Mods:
3minit Battery Mod Updated
Updated:
Samsung Galaxy Apps
Samsung IAP
Samsung Billing
ANT Radio Service
ANT Plugins Service
Bloomberg+
Dolphin Browser
Dropbox
ES File Explorer
Evernote
Flipboard
Google Drive
Play Games
Play Music
Play Newsstand
Hide It Pro
HP Print Service Plugin
Samsung WatchON
Wanam Xposed
All mods from previous Omega Kit Kat 4.4.2 versions added
Rom is No Full Wipe
Téléchargements
Omega v22.1 Android 4.4.2
Anciennes Versions:
Omega v22 Android 4.4.2
Omega v20 Android 4.4.2
Omega v16 Android 4.4.2
Torrent – Omega v16 Android 4.4.2
Omega v12 - Lien 1
Omega v12 - Lien 2 (Miroir)
Omega v10 - Lien 1
Omega v10 - Lien 2 (Miroir)
Omega v9 - Lien 1
Omega v9 - Lien 2 (Miroir)
Omega v8 - Lien 1
Omega v8 - Lien 2 (Miroir)
Omega v7.2 - Lien 1
Omega v7.2 - Lien 2 (Miroir)
Omega v7.1 - Lien 1
Omega v7.1 - Lien 2 (Miroir)
Omega v7.0 - Lien 1
Omega v7.0 - Lien 2 (Miroir)
Omega v6.0 - Lien 1
Omega v6.0 - Lien 2 (Miroir)
(MD5 : A7C06B1A2A24A9AE4DF38CB9E209E09F)
Omega v5.0 - Lien 1
Omega v5.0 - Lien 2 (Miroir)
(MD5 : 781B838A699F0B2CF166E9AA36E6C109)
Omega v4.0 - Lien 1
Omega v4.0 - Lien 2 (Miroir)
Omega v3.1 - Lien 1
Omega v3.1 - Lien 2 (Miroir)
(MD5 : b51e3c34261651ee1219d3e14bb86a16)
Omega v3 - Lien 1
Omega v3 - Lien 2 (Miroir)
(MD5 : 6fdd154b9155ab5ec4beda6748ea39c1)
Omega v2.3 - Lien 1
Omega v2.3 - Lien 2 (Miroir)
(MD5 : 0E317778BAB9D7D1B7E622AE5DA2A8C9)
Omega v2.2 - Lien 1
Omega v2.2 - Lien 2 (Miroir)
(MD5 : A74E585EA2CA9CBBB86DDB74C9B58922)
Omega v2.1 - Lien 1
Omega v2.1 - Lien 2 (Miroir)
(MD5 : 01C0006166824830BD940098C9E758F0)
Omega v2.0 - Lien 1
Omega v2.0 - Lien 2 (Miroir)
(MD5 : D0825FC851CB95F70623D0746204EA21)
ROMs : Rom Stock
: : X-Note v10
Rom Custom, Android 4.3, JellyBean, SM-N9005, Omega, Omega Files, Omega Graphics
Omega Files
-Omega Files - Application Google Play [GRATUIT]
-Omega Files Pro -  Application Google Play [PAYANT]
Omega Graphics
-Omega Graphics
ROMs : Rom Stock
: : X-Note v10
Rom Custom, Android 4.3, JellyBean, SM-N9005, Omega, Mods
ROMs : Rom Stock
: : X-Note v10
Re: [SGN3][ROM 4.4.2][SM-N9005] [ZHUENH4] Omega v22.1 Samsung Galaxy Note3
Message par Mendicant Bias le Sam 5 Oct 2013 - 8:37
Bonjour tout le monde,
C'est un grand jour, voici la première custom en ligne et non des moindre, la Omega pour le Note 3 cheers
Bon flash les amis Very Happy
ROMs : Rom Stock
: : X-Note v10
Message par BigPat le Sam 5 Oct 2013 - 8:54
Super nouvelle cheers
La 1ère custom.
Grrrrrrrrr je dois partir bosser Sad
Je vous laisse tester, mais ce soir, c'est mon tour
Bon flash les amis et faites-nous vos retours.
Message par aigle38 le Sam 5 Oct 2013 - 9:39
Bonjour à tous
Salut Mendi voilà une belle et grande ROM qui me fait pensé
à quelque chose .
Le téléchargement est pas encore dispo .
aigle38
ROMs : Echoe ROM V4
: : Samsung Galaxy Note 3
Message par davfunk le Sam 5 Oct 2013 - 10:32
Yes!!!
Je me lance. Merci.
Ça y est, les Custom arrivent!
Vu le nombre de fonction du Note 3, ça promet pour les Rom Custom.
davfunk
Appareil principal : Samsung GN4
ROMs : X-Note V3
: : Galaxy Note 4
Message par Mendicant Bias le Sam 5 Oct 2013 - 10:37
@Aigle : Si le lien de la rom Omega est déjà disponible sur Deposit Files ou via Torrent.
ROMs : Rom Stock
: : X-Note v10
Message par davfunk le Sam 5 Oct 2013 - 13:38
En cours de download...1.38 Gb
davfunk
ROMs : X-Note V3
: : Galaxy Note 4
Message par franzel le Sam 5 Oct 2013 - 13:43
Génial, est-ce que le exchange security dislabled est déjà présent ?
franzel
ROMs : Omega V1
Message par aigle38 le Sam 5 Oct 2013 - 13:44
Merci de nous faire un petit retour
Tu a CWM ou TWRP ?
aigle38
ROMs : Echoe ROM V4
Message par davfunk le Sam 5 Oct 2013 - 14:11
Moi j'ai CWM, mais il faut mettre impérativement TWRP?
davfunk
ROMs : X-Note V3
: : Galaxy Note 4
Message par aigle38 le Sam 5 Oct 2013 - 14:16
Oui mais pour le moment TWRP est pas opérationnel il y'a encore quelque soucis vaut mieux attendre .
aigle38
ROMs : Echoe ROM V4
Message par Froum le Sam 5 Oct 2013 - 14:46
Alors on y va ou pas ? *bave bave*
Nan parce qu'avec tout ça, j'ai toujours pas rooté la bête, moi, j'ai peur du méchant Knox, et du coup, il faut bien l'avouer, je suis en manque !
"bonjour, je m'appelle Froum, et je suis un flasheur, certes débutant, mais compulsif... "
" bonjour Froum !! " (all together)
Froum
ROMs : Stock - Rooté
Message par Mendicant Bias le Sam 5 Oct 2013 - 15:35
Normalement le CWM devrait fonctionner, il permettra au moins de flasher la rom.
Par contre pour le moment impossible de faire des NANDROID Backup avec lui.
Quelqu'un peut confirmer que le flash de la rom fonctionne avec le CWM ?
ROMs : Rom Stock
: : X-Note v10
Message par davfunk le Sam 5 Oct 2013 - 18:03
Bootloop pour moi.
Je vais essayer de remettre une rom d origine.
davfunk
ROMs : X-Note V3
: : Galaxy Note 4
Message par Mendicant Bias le Sam 5 Oct 2013 - 18:05
Davfunk tu utilises quel Recovery ?
As-tu bien fais tous les wipes ? As-tu vérifié le MD5 de la rom ?
Pas d'erreur pendant le flash ?
ROMs : Rom Stock
: : X-Note v10
Message par davfunk le Sam 5 Oct 2013 - 18:20
CWM + fais tous les wipe sauf que y a pas l option Format Preload.
L'install s'est pourtant faite sans pb.
davfunk
ROMs : X-Note V3
: : Galaxy Note 4
Message par Pepiito83 le Sam 5 Oct 2013 - 18:27
Format preload c'est pas dans advanced ??
Pepiito83
Appareil principal : Samsung Galaxy Note 4 Blanc SM
ROMs : Android 4.4.4
Message par Mendicant Bias le Sam 5 Oct 2013 - 18:29
Dans le CWM il n'y a pas de Format Preload.
Je vais l'enlever pour le moment.
@Davfunk : Enlève ta batterie et remet la, normalement ça devrait démarrer sur la rom.
Si ça ne fonctionne pas reflash et réessaye.
ROMs : Rom Stock
: : X-Note v10
Message par davfunk le Sam 5 Oct 2013 - 18:31
Non, il n'y est pas.
C'est bon j'ai pu remettre la rom d'origine avec OdinPc.
Par contre perdu le root.
On recommence tout...
EDIT : Rien a faire pour l'instant.
J'ai tout refais depuis le début (rom originale + Root + Rom Custom) et booloop.
J'abandonne pour l'instant. Vaux mieux attendre les amis.
davfunk
ROMs : X-Note V3
: : Galaxy Note 4
Message par micky387 le Sam 5 Oct 2013 - 19:04
il ne faut pas passé par CWM mais par TWRP,c'est lui le fautif.
Mais impossible de savoir si la version TMOBILe est sans dommage pour nos note3 francais...
micky387
ROMs : X-note
Message par Mendicant Bias le Sam 5 Oct 2013 - 19:30
Si quelqu'un veut tenter, il faut prendre cette version (A flasher via Odin PC) du TWRP recommandé par Indie le dev de la rom Omega.
ROMs : Rom Stock
: : X-Note v10
Message par micky387 le Sam 5 Oct 2013 - 19:36
oui c'est la version canadienne.
Si une ame charitable veux bien tenter un backup/restore pour voir si tous se passe bien....
micky387
ROMs : X-note
Message par franzel le Sam 5 Oct 2013 - 21:27
Bootloop pour moi aussi avec TWRP 2.6.3.2...
franzel
ROMs : Omega V1
