Page 1 sur 22 1, 2, 3 ... 11 ... 22  Suivant
Message par Mendicant Bias le Dim 6 Oct 2013 - 19:53
Le mot du créateur de la rom "Soloilmeglio" :
"Je vous présente la rom X-Note pour le Samsung Galaxy Note 3 compatible SM-N9005 uniquement."
Détails :
-  Deodexed busybox
-  Autorooting Kernel with init.d support by @Angelom (thanks mate)
-  Zipalign new applications at boot and db optimize
-  Knox free (there is still some knox file but erasing it cause instability ... I'm doing more tests)
-  Almost all apps are in place, updated and installed as data application... Google Maps replaced with older version (faster for me)
-  Modded settings with many additional options "X-Note special settings"
-  All application can be easy selected to have in floating window. Credits @xperiacle and his great application (linked in settings)
-  Sound boost mod made by @nowy57 and modified by me to have whole louder speaker audio also in call (pay attention with volume because note 3 speaker have a poor quality)
-  customized some UI sound
-  Fixed spen pointer position
-  Xposed framework
-  Xposed per app density (set many options for each app included dpi density)
-  @Wanam Xposed module that include multiwindow app selector (other features not tested yet)
-  Call recording xposed module
-  No mms conversion xposed module
-  disabled infinite scrolling in launcher (I like more)
-  Enabled all rotation degree included upside down
-  Fully themed notification panel, status bar, circle battery, framework, dialer, application icons etc. (See screenshots)
-  Enabled secondary symbols on stock samsung keyboard
-  Camera with shutter sound on/off option
-  Browser with exit option
-  Unlocked lockscreen torch option
-  Unlocked call and message block settings
-  Sms will display sent time instead off received time
-  Unlimited contacts join
-  Greenify app
-  Segoe UI extra font available (nice!) + ifont app.
-  Cpu spy linked in settings
-  Advanced reboot menu (in settings)
-  Additional camera effects available by default
-  editor video, sketch book mobile, stranslator available by default (no need to download it)
-  more to come
Images et Vidéos
Installation
Pré-requis :
- Avoir installé la rom stock Android 4.4.2 [ROM 4.4.2][SM-N9005] Pre-Release Rom Stock Samsung Android KitKat 4.4.2 [XXUENA6]
Installation :
1) Important : Faîtes un Backup EFS (IMEI) via ce tuto [OUTIL][SM-N9005] Backup et Restore EFS (IMEI) pour le SGNIII
2) Démarrez dans le Recovery custom CWM Android KitKat 4.4.2 en maintenant les touches "Volume +", "Power" et "Home" et vérifiez que vous avez la dernière version via ce Regroupement.
3) Faîtes un NANDROID Backup via le Recovery en allant dans "Backup et Restore/Backup" ou "Backup et Restore/Backup to External SD".
4) Faites le "Wipe Data Factory Reset", "Wipe Cache Partition" et dans "Advanced", le "Wipe Dalvik Cache" via le Recovery.
5) Ensuite flashez la ROM.
6) Enfin redémarre et amusez-vous  Very Happy
Activer le débogage USB :
1) Aller dans "Paramètres/Général/A propos de l'appareil".
2) Tapez 7 fois sur "Numéro de version", un message apparaîtra en disant que "le mode développeur a été activé"
3) Allez dans "Paramètres/Général" et vous verrez au-dessus de "A propos de l'appareil" le nouveau menu "Options de développement".
4) Allez dans ce menu et vous allez pouvoir activer le débogage USB cheers
@mike_du_51 a écrit:Pour ceux qui, comme moi, n'ont pas de bol, et qui ne peuvent pas sur la v20 mettre un verrouillage par code pin, modèle ou signature (ca reste bloqué sur 'glissement'), voici comment corriger le problème :
- Installer root explorer (dispo sur play store)
- Ouvrir root explorer et cliquer sur le bouton r/w en haut à gauche pour avoir les droits en écriture.
- Se rendre dans le dossier 'system'.
- Faire un clic long sur le fichier build.prop et choisir 'ouvrir avec' puis 'éditeur de texte'.
- dans ce fichier  :
Rechercher
security.mdpp=None
Et le remplacer par
#security.mdpp=None
Rechercher
security.mdpp.result=None
Et le remplacer par
#security.mdpp.result=None
Rechercher
ro.security.mdpp.ux=Enabled
Et le remplacer par
ro.security.mdpp.ux=Disabled
- Utiliser ensuite la touche 'retour' du smartphone et confirmer l'enregistrement du fichier.
- Redémarrer le smartphone sans rien modifier d'autre.
- Se rendre dans les paramètres et configurer le verrouillage par code, modèle ou autre selon votre souhait.
Voila, le verrouillage fonctionne à nouveau correctement....   Wink
Changelog
Changelog X-Note v21:Changelog X-Note v21:
#Based on latest NJ2 Samsung N9005 firmware
#Deodexed, zipaligned, rooted, busybox
#Many apps moved to data partition to allow easy uninstall
#Changes in aroma
#most of our code is recoded to have smoothness and battery life
[X-NOTE app]
#totally rewritten X-Note control app... now the navigation is done with swipeable tabs.
when open the app the first page links to all tabs, the back key automatically redirect to first tab.
so you can swipe or navigate.
#New amazing theme (the old temes will be available in few time in OTA)
#300 fonts included
#face unlock feature
#Viper for android audio mod (aroma)
# New google applications (aroma)
#3 sound boost levels accessible with xnote app
#new 3D bootanimation + bootanimation switcher
#enable/disable music skip track and time control (xnote app)
[ADVANCED MULTIWINDOW]
#select any app in multiwindow mode with @xperiacle application (included)
#select any app in pen window mode with @xperiacle application (included)
#multi instance available for all apps
#4 window in the same screen available (X-Note app)
[MULTI DPI X-TRANSFORMER]
#X-Transformer feature: THE WHOLE ROM IS MULTI DPI available dentity:
- 480
- 450
- 420
- 390
- 360
- 330
- 300
- 290
- 289 (phablet notification panel)
+ custom density
- Air wake up
- LMT launcher (pie-gesture control)
- Cpu monitor
- Cpu Spy reborn (credits @Mirko ddd)
[TW LAUNCHER] (Xnote app)
#Theme manager
#Enable/disable infinite scrolling
#Enable/disable wallpaper scrolling
[SETTINGS]
#options in settings:
X-Transformer
X-note app
X-Reboot
#Enabled all hidden settings widgets
#Switch grid layout/tabs layout/list layout
[SCREEN]
#3 screen mode available
- black and white
- High contrast
- default
[Features MMS-SMS]
#Unlimited Contacts Joining, SMS/MMS Max Slide Count, Recipient Limit Messages Per Thread, Max Subject Length, Max Email Address Length.
#Disabled SMS To MMS Auto Conversion For Long Text
#Disabled SMS To MMS Auto Conversion For Emoji
#Save And Restore Text Messages Using The Messaging App
#Enabled Group Conversations In Stock Messaging App
#Messaging App Screen On/Off Toggle
#Messaging App Split-View Mode
[Features Lockscreen]
#Lockscreen Select AOSP - Samsung
#Ink effect custom color
[Features Power Menu]
#Power menu customizable
- Show/hide reboot menu title bar
- show/hide data mode
- show/hide airplane mode
- show/hide power off
- show/hide restart
- show/hide flashlight
- show/hide screenshot
- show/hide accessibility
- show/hide sound mode
# enable/disable home button
[Features Statusbar]
#6 system UI theme switchable with xnote app
# Double tap on status bar to turn off the screen + ability to
# Customized battery text style with the following options
text style
enable/disable Auto Color
Static Color selection
Charging Auto Color selection
Regular Auto Color selection
Medium Auto Color selection
Low Auto Color selection
# 100+ battery icons
# Show/hide Battery icon
# Show/hide Samsung Battery text
# Advanced Battery bar fully customizable
#Customized network Traffic Meter
# Traffic speedmeter - ability to change
Disabled
Outgoing
Incoming
Outgoing
# ability to autohide
# ability to change color
#Customized toggle
- ability to show/hide toggle status indicators (x-note app)
- ability to show/hide toggle text (xnote app)
- ability to change color of active toggles (x-note app)
- ability to change color of dim toggles (x-note app)
- ability to change color of OFF toggles (x-note app)
- ability to change color of toggle text (x-note app)
- ability to change color of active indicators (x-note app)
- ability to change color of dim indicators (x-note app)
- ability to change color of OFF indicators (x-note app)
#Additional toggles
- torch toggle
- X-Note toggle
- Xtransformer Toggle
- Shoot it toggle (dr. Ketan app)
- air command toggle
- enabled many hidden samsung toggle
#Customized Clock
- status bar clock right-center-hide
- status bar clock font selection - 5 fonts available
- enable/disable date near the status bar clock + small/big font selection
- uppercase/lowercase/normal font selection for status bar date if enabled
- 18 available date format: dd-mm-yyyy / EEEE-mm-dd-yyyy / etc.
#Customized Dropdown panel
- ability to change color and transparency of Droppanel
- custom image view selection (12 images) with transparency control
- cpu widget show/hide
# 10 KEYBOARDS available switchable with xnote app (new white keyboard)
# # # sure we've forgotten to mention some feature, sorry
X-Kernel V.3.0 - only for N9005
  • UPDATED TO LATEST SAMSUNG OFFICIAL SOURCES Opensource Update 9 NG2
    Close to stock for stability and best battery
    Selinux status = Permissive
    ExFAt support
    init.d support
    insecure & adb insecure
    Add swap support
    Add CIFS support
    Add NFS support
    Add NTFS support
    Add Xbox controller support
    Add cdrom option to UMS-lun-devices
    Add DriveDroid support
    USB: f_mass_storage: 2048 block size for cdrom devices
    USB: f_mass_storage: Added cdrom option to UMS-lun-devices
Credits Kernel:
Samsung for Official Source Code
Civato specially for the ramdisk
Faux123 Imoseyon DoomLord Yank555 Jovy23 Angelom TeamHacksung
Codeworkx Gokhanmoral Andreilux Simone201 Ktoonsez ptmr3
General Credits:
@xperiacle - for his great work
@Mirko ddd for the Control app Sources
@tamirda for additional power menu options
@dr.ketan for the two shoot-it app (free version)
@lidroid - for the superb coding of call recording
@Mythtrandyr - for the additional call recording code
@dsixda - For dsixda kitchen
@civato - for spen pointer tips
@Chainfire - For Superuser and a bunch of things
@rovo89 - For Xposed framework, for updates http://forum.xda-developers.com/show....php?t=1574401
@foreverloco for many AOSP theme PNG images
@DaOldMan for white samsung keyboard
@Tungstwenty - For Xposed Module (custom dpi density)
@OsamaGhareeb for battery mods
Please pm me if I forgot some Dev
Téléchargements
MD5: A5EE71FD2900F30178629874B44D9609
X-NOTE Build v21 sur Android File Host
Anciennes Versions:
X-NOTE Build v20 (N9005 NG1)
MD5: 5810A14FAAEE87991EA6F5A3E7A1B4C6
Android file host - ONLINE HERE
X-Note v18
MD5: 11C12E0370185CE6FAF44FD932DBD795
[*]MIROIR 1
MD5: 9605F3CD7940E232FF39B75312795C3E
X-Note v17
MIROIR 1,  MD5: 5A9B2926372A3EC11202171EE144D34C
X-Note v16
[url=http]MD5: 448BBD3FCEE3981B8A3788D65180E9C8
[/url]X-Note v15
MD5: DE9F65552E13C2349686B87198FD4A1E
X-Note v14
X-Note v13
(MD5 : D11F4BFAD920791B3B9158733355C4D4)
X-Note v12
(MD5 : 2639AB30F4B611AD9B56F305FF0B790E)
X-Note v11 - Lien 1
X-Note v11 - Lien 2 (Miroir)
(MD5 : B1049ADA0D4F167AFBA924755FD78491)
X-Note v10 - Lien 1
X-Note v10 - Lien 2 (Miroir)
(MD5 : F1525985392FBB945BD7103A20C6EFE0)
X-Note v9.0 - Lien 1
X-Note v9.0 - Lien 2 (Miroir)
(MD5 : 294A97B7C4F4BCBF385318B6176D9596)
X-Note v8.0 - Lien 1 + AOSP Thème
X-Note v8.0 - Lien 2 (Miroir)
(MD5 : F68B9165DE001CDCD8096FCCD545775B)
X-Note v7.0
(MD5 : 9EC11AE10CBE5399595C7B5874B069FD)
X-Note v6.0 - Lien 1
X-Note v6.0 - Lien 2 (Miroir)
(MD5 : E1FAD61A8C610ABD458457FF671E2947)
Pour ceux rencontrant des fast reboots en utilisant Google Music, Poweramp, ... vous devez flashez le "fix_poweramp_crash.zip" disponible en OTA à flasher via le Recovery.
X-Note v5.1 - Lien 1
X-Note v5.1 - Lien 2 (Miroir)
(MD5 : 2D245FDED61F2420EC1907E4FCD187C2)
X-Note v5.0 - Lien 1
(MD5 : B1D7045987DEA21ED1A0F2A2F0BE6A7F)
X-Note v4.0 - Lien 1
%20X-NOTE%20construire%204.0%20N9005%20MJ6%20(r%C3%A9gion%20UNLOCKED)%20-%20Page%2085%20-%20xda-developers&txt=%3Cfont%3E%3Cfont%20class%3D%22%22%3E%20http%3A%2F%2Fsuperuser.cu.cc%2Fx-note%2F%3C%2Ffont%3E%3C%2Ffont%3E&jsonp=vglnk_jsonp_13836600036648]X-Note v4.0 - Lien 2 (Miroir)
(MD5 : 1FBE59C3C6028E0B9DC3B062C8ED728D)
[url=http://www.androidfilehost.com/?fid=23189362627840215]X-Note v3.0 - Lien 1
X-Note v3.0 - Lien 2 (Miroir)
(MD5 : CDDD6FAF379D4C3842151C02C2DDBC5D)
X-Note v2.0 [XXUBMJ1] - Lien 1
X-Note v2.0 [XXUBMJ1] - Lien 2 (Miroir)
X-Note v2.0 [XXUBMJ1] - Lien 3 (Miroir)
(MD5 : 52C4FC07B3E51030CF9526D2CB38DA16)
X-Note v1.0 + Update 1 (Launcher with 9 home screens and small build prop fix) + Update 2 (Fix samsung video player and uninstall Wanamxposed to avoid power button issue)
(MD5 : 6e85b2d4a1489ff41d26c94628ea3d4e)
[*]Source
Source sur Xda
ROMs : Rom Stock
: : X-Note v10
Rom Custom, Android 4.3, Samsung, Galaxy, Note 3, SM-N9005, X-Note, Thèmes
Thèmes
-Thèmes AOSP et Stock - XNote v7
ROMs : Rom Stock
: : X-Note v10
Re: [Samsung Galaxy Note3][ROM 4.4.2] X-NOTE Build v21 [NJ2] [20.11.14][SGN3][SM-N9005][TOPIC 3]
Message par Mendicant Bias le Lun 10 Mar 2014 - 0:37
ROMs : Rom Stock
: : X-Note v10
Message par Mendicant Bias le Lun 10 Mar 2014 - 0:38
L'ancien topic arrivant à 70 pages a été fermé.
Vous pouvez le retrouver ici
La suite est désormais sur ce nouveau sujet Very Happy
ROMs : Rom Stock
: : X-Note v10
Message par Mendicant Bias le Lun 10 Mar 2014 - 0:43
Topic mis à jour : Mise à jour du 09 mars 2014 - X-NOTE build 12.0 [NB7]
ROMs : Rom Stock
: : X-Note v10
Message par fright le Lun 10 Mar 2014 - 8:28
Hello les amis :-)
J'espère que vous allez bien?
Quand j'appuie longtemps sur le bouton home je n'ai plus accès au menu appli récentes...
Qqun peut me dire comment je peux corriger cela?
fright
Appareil principal : Samsung Galaxy S6 Edge +
ROMs : Official
Message par Alfy le Lun 10 Mar 2014 - 8:38
Salut.
Tu as utiliser un modèle complémentaire via Xposed installer ?
Si c'est le cas désactives les tous temporairement, redémarres et vois si ça a résolue ton problème.
Alfy
ROMs : Rom Stock+root+CWM
Message par fright le Lun 10 Mar 2014 - 9:00
Behn je pense effectivement....
J'ai tout desactivé et redémarré et c'est ok
fright
ROMs : Official
Message par davfunk le Lun 10 Mar 2014 - 9:02
Va faire un tour dans le GravityBox. Il y a tous les paramètres dedans.
Sinon, ce 12 cylindres en V elle tourne ou bien?
davfunk
Appareil principal : Samsung GN4
ROMs : X-Note V3
: : Galaxy Note 4
Message par fright le Lun 10 Mar 2014 - 9:29
Ok merci :-)
Sinon oui elle est parfaite.... elle ronronne tout va bien...
fright
ROMs : Official
Message par Mendicant Bias le Lun 10 Mar 2014 - 11:10
Bonjour tout le monde,
C'est clair cette v12 tourne parfaitement bien comme la v11.
ROMs : Rom Stock
: : X-Note v10
Message par fright le Lun 10 Mar 2014 - 11:26
J'ai un soucis avec ma gear... Je recois plus les notifs....
Quand j'essaie d'appeler qqn depuis la montre ca fonctionne donc elle est bien relié... et j'ai coché les notifs que je voulais dans l'appli gear... j'ai mis les notifs whats app, email, hangout... rien ne fonctionne vous savez de quoi ca vient? et je l'ai même réinitialisé bref je crois que j'ai tout fait...
Merci de vos aides
fright
ROMs : Official
Message par Mendicant Bias le Lun 10 Mar 2014 - 11:30
Bonjour Fright,
As tu essayé de redémarrer ta montre + le Note 3 ?
As-tu essayé de dissocier/reassocier la GEAR au Note 3 ?
Et surtout as tu bien coche dans GEAR Manager les notifications qui t'intéresse ?
ROMs : Rom Stock
: : X-Note v10
Message par Mahoni le Lun 10 Mar 2014 - 12:09
Bonjour à tous
Cette rom marche nickel à tous les points de vue,fluide,accroche reseau nickel enfin c'est du lourd
Je ferais un retour sur l'autonomie plus tard  cheers cheers
Mahoni
Appareil principal : GALAXY NOTE 4 910 F
ROMs : ROM DLS COI3
http://yoda.forumsactifs.com/
Message par fright le Lun 10 Mar 2014 - 13:42
Hello Mend :-)
Alors j'ai fait tout ça..... et en  effet quand je redémarre ca fonctionne 5 min et ça bloque de nouveau après....  et ca pour les notifs hangout et whats app que j'ai sélectionné par contre les emails je ne reçois aucune notifs même après redémarrage.... c'est comme si une appli bloquait la communication entre mon note 3 et la gear....Par contre quand je me téléphone ca fonctionne je reçois l'appel sur ma gear....
fright
ROMs : Official
Message par Mendicant Bias le Lun 10 Mar 2014 - 13:46
Re Fright,
Au début quand tu as installée la Xnote et que tu as connecté ta GEAR dessus tout fonctionné bien et sans problème ?
ROMs : Rom Stock
: : X-Note v10
Message par fright le Lun 10 Mar 2014 - 13:58
behn je l'ai installé hier et connecté ma gear ce matin donc non depuis le début ca ne fonctionne pas... c'est vraiment strange........
fright
ROMs : Official
Message par Mendicant Bias le Lun 10 Mar 2014 - 14:02
Sur la rom, qu'as-tu installé ? As-tu installé des mods, un autre thème ?
As-tu activé des modules du Xposed Framework ?
ROMs : Rom Stock
: : X-Note v10
Message par fright le Lun 10 Mar 2014 - 14:04
Non rien de spécial pour les thêmes et les modules j'avais kk gravity box mais j'ai tout desactivé....
fright
ROMs : Official
Message par Mendicant Bias le Lun 10 Mar 2014 - 14:09
Fais un NANDROID Backup de ta rom actuelle.
Ensuite fais un Full Wipe, reflash la rom et configure le premier setup, n'installe rien d'autre (Pas d'applications, ne restaure rien).
Juste après connecte ta GEAR sur la Xnote et lorsqu'il te le demandera fais une réinitialisation de la montre et non une restauration.
Quand c'est fait, fais quelques tests pour voir si ça corrige ton problème
ROMs : Rom Stock
: : X-Note v10
Message par ruan78 le Lun 10 Mar 2014 - 18:47
bonsoir
Je peux repasser de la xnote a la V7 sans probleme?
ruan78
ROMs : EVO_v7 4.4.2 BoBCaTROM
Message par Mendicant Bias le Lun 10 Mar 2014 - 18:58
Bonsoir Ruan,
Oui sans probleme, fais un Full Wipe avant
ROMs : Rom Stock
: : X-Note v10
Message par ruan78 le Lun 10 Mar 2014 - 19:30
bonsoir
Ok merci  Very Happy
Ps: le recovery de Philz n es pas compatible?
ruan78
Message par Mendicant Bias le Lun 10 Mar 2014 - 19:55
De rien Ruan smile,
Si le Philz Touch Recovery est compatible Android Kitkat 4.4.2
ROMs : Rom Stock
: : X-Note v10
Message par djadja le Lun 10 Mar 2014 - 20:31
Bonsoir peut on avoir le même son comme la rom bobCat
Dans le clavier
djadja
Appareil principal : galaxy s6 edge plus
ROMs : Stok Android 5.1.1
: : 5.1.1
