[SAMSUNG GALAXY NOTE2][ROM Kitkat 4.4.2][GT-N7100][NI1]Dr.Ketan Custom ROMV14 [SGN2]
+24
bidibull
rjimi
djedje31
guilsx
ikhor13
VTR
@joan62
jfh777
tata54
Odym
blackpanther
AKASHIK
flo90
joyfrag
geebee
renderay78
cheikhjamal
flicman78
yougyoh
trob
k88
bibou59
28 participants
description[SAMSUNG GALAXY NOTE2][ROM Kitkat 4.4.2][GT-N7100][NI1]Dr.Ketan Custom ROMV14 [SGN2]  Empty[SAMSUNG GALAXY NOTE2][ROM Kitkat 4.4.2][GT-N7100][NI1]Dr.Ketan Custom ROMV14 [SGN2]
[SAMSUNG GALAXY NOTE2][ROM Kitkat 4.4.2][GT-N7100][NI1]Dr.Ketan Custom ROMV14 [SGN2]  Attachment
Le mot du créateur de la rom "Dr.ketan" :
"Je vous présente la rom Dr.Ketan's Custom ROM pour le Samsung Galaxy Note 2 compatible GT-N7100 uniquement."
Détails :
Base : N7100XXUFNI1(Base)_N7100ODDFNI1(CSC)_N7100DDUFND1( modem) Deodexed Deknoxed Pre rooted
MultiTool functions :
Apart from ROM flasher you can use ROM file as utility too
-Inbuilt Aroma file manager in case anything go wrong while playing device with different mods, you can manage to explore device from recovery
-EFS Backup/Restore
-Customized Bloatware remover, select only app you don't want.(including Knox)
-CSC features
-Build prop tweaks.
-LockScreen Password cleaner
-GPS changer (select according your location)
-Theme changer
S5 Features/Applications
  • Air wakeup
  • Ultra power saving mod - Power saving +, UPSM,Emergency mod
  • Toolbox - 10 application can be edit
  • Phone app with popup notification and status information option.
  • Lockscreen Unlock effect -
    1. Particle
    2. Stone skipping
    3. water color
    4. Ripple
    5. Light effect - Blue Flame/Blue light/blue ring/green ring/white lightening/yellow flame
    6. Oil paint
    7. Blind
  • Launcher
  • Accuweather Widget
  • Browser
  • SecMMS - MMS issue fixed
  • Kids Mod
  • Memo
  • NOTE 3 Features :
  • Air command
  • Smart Scroll
  • Smart Pause
  • Story Album
  • One Hand for All screen
  • Writing buddy (direct Input)
  • PEN Window
  • Action Memo
  • Scrap booker
  • ScreenShot
  • S Finder
  • S note with attachment option like chart, map, video, YouTube,scrap book
  • S suggest
  • S finder
  • ScrapBook
  • Gallery
  • Sketch Book
  • Magazine
  • Dr.Ketan Utilities
    You can access this by Setting-device-DrKetan ROM Extra OR from App drawer. This utility requires plug in called Secure setting. It should auto install while flashing ROM. you should check in app drawer, if it is missing then you should download from play store.(you can find it here in post #5 too.)
    This application is built-in Dr.Ketan's Custom ROM. This application divided in four menu. Also note that you needs to install plug-in to work this app. On opening of app it will direct to play store to install plug in if your device lacking it.
    1.Toggles - As name suggest here in this menu you will have many Toggles which you can use to activate/Deactivate services.
    Single tap on icon to activate, Long click on icon to deactivate
    Incoming Call Record - This will record all incoming calls. File will be saved in IntSD/Sounds/ folder. (If you dont have this folder then manually create it.)
    Outgoing Call Record - This will record all Outgoing calls. File will be saved in IntSD/Sounds/ folder. (If you dont have this folder then manually create it.)
    Auto GPS - Will Auto On/Off GPS with some commonly GPS using app
    Auto Wifi - Auto switch off wifi if no active connection more than 10min
    Auto Bluetooth - Auto switch off bluetooth if not actively paired more than 10min
    Smart Network - Switch off data connection with 30sec of screen off, Auto ON with screen ON
    Media scanner - To turn On/Off media scanner
    Torch - Activate flash light with shaking of device with screen (home/Lock) ON
    LogIn security - silently capture image is multiple failed attempt to unlock device,pic stored in IntSD/DCIM/DrKetan_utilities/
Installation
1) Démarrez dans le CWM Recovery en maintenant les touches "Volume +", "Power" et "Home".
2) Faîtes un NANDROID Backup via le Recovery en allant dans "Backup et Restore/Backup" ou "Backup et Restore/Backup to External SD".
3) Faîtes un Backup de votre EFS (Sauvegarde le numéro IMEI du téléphone) en suivant cette procédure suivante pour faire une sauvegarde manuelle Backup/Restore EFS (IMEI) pour le SGNII (Via le PC) ou en utilisant cette application GalaxSim Unlock disponible sur Google Play.
4) Allez dans "Mount and Storage" et choisissez "Format system" puis faites un "Wipe Data Factory Reset" (pas nécessaire si vous venez d'une version précédente de la Rom), "Wipe Cache Partition" et dans "Advanced" "Wipe Dalvik Cache".
5) Flashez la ROM, (redémarrez (et flashez les Gapps (Gapps 4.2.2), si jamais ils ne sont pas installés)
6) Amusez-vous  [SAMSUNG GALAXY NOTE2][ROM Kitkat 4.4.2][GT-N7100][NI1]Dr.Ketan Custom ROMV14 [SGN2]  Icon_biggrin
Images
[SAMSUNG GALAXY NOTE2][ROM Kitkat 4.4.2][GT-N7100][NI1]Dr.Ketan Custom ROMV14 [SGN2]  Attachment[SAMSUNG GALAXY NOTE2][ROM Kitkat 4.4.2][GT-N7100][NI1]Dr.Ketan Custom ROMV14 [SGN2]  Attachment
S5 SystemUi
S5 Settings style and 3D silver round Toggles
[SAMSUNG GALAXY NOTE2][ROM Kitkat 4.4.2][GT-N7100][NI1]Dr.Ketan Custom ROMV14 [SGN2]  Attachment[SAMSUNG GALAXY NOTE2][ROM Kitkat 4.4.2][GT-N7100][NI1]Dr.Ketan Custom ROMV14 [SGN2]  Attachment[SAMSUNG GALAXY NOTE2][ROM Kitkat 4.4.2][GT-N7100][NI1]Dr.Ketan Custom ROMV14 [SGN2]  Attachment
Que l'on doit à cheikhjamal smile
[SAMSUNG GALAXY NOTE2][ROM Kitkat 4.4.2][GT-N7100][NI1]Dr.Ketan Custom ROMV14 [SGN2]  49223520140613233047  [SAMSUNG GALAXY NOTE2][ROM Kitkat 4.4.2][GT-N7100][NI1]Dr.Ketan Custom ROMV14 [SGN2]  55877420140613234644
[SAMSUNG GALAXY NOTE2][ROM Kitkat 4.4.2][GT-N7100][NI1]Dr.Ketan Custom ROMV14 [SGN2]  60564020140613224147
Derniers changements
ChangeLog V13 & V14
V13 and V14 are same ROM except V14 is fixed for SystemUI FC when V13 users selecting transparent notification panel mod. If you are already on V13 then no needs to re download complete V14 ROM but can fix SystemUI FC (Happens only if you selected Transparent notification panel mod) by flashing small zip from here
All features of previous ROM as it is.
Based on same as v12 NI1 india
New features
   Torch Toggle (available for All 5 SystemUI)
   Dialer section in aroma with 5 dialer choice. System default is S5 (MultiDPI 320/240) 240DPI will have Androild L look - No key separation) Screenshot Here and Here
   -25% transparent key (Dialer will be full transparent but key is 25%) - MultiDPI
   -50% transparent key (Dialer will be full transparent but key is 50%) - MultiDPI
   -gray dialer - MultiDPI
   -N2 dialer - No multiDPI
   -N2 transparent dialer - No multiDPI
   Should be more smoother scrolling (Smali level tweak)
   snapbiz card - Start from Contact-menu key - Businesscard
   No more popout location agreement when toggle On location.
   Ink effect with finger
   Call/SMS block (second native support for phrase block in SMS) Setting-device-Call/Message block
   App Op native feature (Setting-device-Dr.Ketan ROM extra)
   360 Rotation - applied with smali level so it will follow rotation toggle settings - It was very inconvinient to have charging pin at lower end when playing device with device connected to charging point. Now you can rotate 180 degree and charging pin on Top)
   No increasing ring tone for S5 phone app also work along wth FSCID mod
   S5 gallery option in aroma -extra mod - You will lose pen air edit option (when you hover pen on gallery image and pressing button give option to edit/crop etc)
   Quickcommand short cut
Update fix
1.Floating msg app missing some option-fixed
2.Action memo have issue to not shown phone icon when you capture something from right side -fixed
3.work out done for long standing CSC feature incompatibility with wanam module. I have fixed smali level and now wanam xposed module CSC feature won't interfere with new other CSC feature
4.Floating msg stopped working issue fixed, no more activation requires.
5.3minit mod setting apk updated
6.Keyboard double space issue fixed.[
7.Ad free is to OFF by default, You can enable from Dr.Ketan Utility - Toggles
some tips for v14
-Torch Toggle start working after system loads7completely. So if it takes time to on just after boot, keep patience. Once system boot Complete it takes no time to on/off
-CSC features from wanam may not work, use csc features app from drawer / from aroma for csc features. Any csc features missing from wanam module let me know I will add it.
-there are two mods for no increase ring tone mod in aroma and both under mod section extra mod. Use later one (for S5 phone one) first option will do nothing (sorry for inconvenience)
N7100 NI1 Dr.Ketan Custom ROM V14
Miroir
MD5 : 50174F882BADE1FB154944D5FF0FD57B
add-ons :
Versions précédentes :
Autres infos
description[SAMSUNG GALAXY NOTE2][ROM Kitkat 4.4.2][GT-N7100][NI1]Dr.Ketan Custom ROMV14 [SGN2]  EmptyRe: [SAMSUNG GALAXY NOTE2][ROM Kitkat 4.4.2][GT-N7100][NI1]Dr.Ketan Custom ROMV14 [SGN2]
bonjour a tous
j'utilise cette rom depuis maintenant 1 semaine, rom parfaite sans fc (installe de la V1+V2+apps note3) bref que du bonheur !! j'utilise s-finder, pen windows, scratmachin et vraiment aucuns soucis (comparé aux autres roms en 4.3) mais aujourd'hui je viens d'avoir un petit soucis :
je démarre mon note 2 comme chaque matin, code pin, accès au bureau, tout ce passe nikel et la je remarque que dans la bar des botif il me dit : aucune sauvegarde veuillez selectionnez un compte ...... Bizarre .... je laisse de coté, je fais mes p'tite conneries habituels (info, meteo, facebook) et je décide d'envoyer un sms ..... donc, mes contacts, et la ...... plus aucuns contacts de présents ! plus accès au store, youtube !! obligé de remettre mon compte google ! l'avait disparu le bougre !!
quelqu'un a eu le même soucis ?
une soluce ?
sinon je n'ai qu'un petit bug : quand je clique dans paramètres - mon appareil - s-pen -options de détachement du stylet = écran noir ! et kill de l'application obligatoire ((je m'en fout je n'utilise pas cette option mais c'est juste pour préciser le bug et remonter l'info)
sinon je redis : rom parfaite ! pas de bug, FC, fluide, autonomie kernel stock raisonnable
merci de vos réponses
Bonjour Bibou,
Oui plusieurs personnes ont remontés ce bug sur différentes roms Android 4.3 où le compte Google avait sauté, disparu et qu'il fallait le reconfigurer.
Il semblerait que ce soit un bug sur la Leak mais rien de trop méchant.
Sinon pour l'autre bug, tu peux toujours essayé via le Recovery de faire un Wipe cache partition + wipe dalvik cache + fix permissions
merci pour ta réponse Mendi !
j'avais effectivement constaté ce bug du store sur toute les autres 4.3 mais celle la je n'avais pas ce soucis ..... il est apparu au bout de 5 jours .....
pour le s-pen je l'ai fait, j'ai même réinstaller en full wipe 2 fois .... mais pas grave je ne l'utilise pas ! ;-)
bonne soirée
Mais de rien Bibou,
Pour le bug du S-Pen il est connu et pour le moment pas de solution.
Bonne soirée à toi aussi
mise a jour en V3
http://d-h.st/3Vq
normalement avec cette V3 plus besoin de flasher des mods supplémentaires
Merci pour l'information Bibou.
Topic mis à jour : Mise à jour du 22 octobre 2013 - Dr.Ketan's Custom ROM Deodexed | Prerooted | ZipAligned | User Control V3
J'aurai une question sur cette rom, serait-il possible de la rendre compatible avec une tablette ?
Bonjour K88,
C'est-à-dire ?
Tu veux installer cette rom sur une tablette ?
Si oui alors non ce n'est pas possible ou alors faut demander au dev si il peut porter cette rom sur la tablette en question.
Quelle tablette possèdes-tu ?
Merci pour ta réponse, Galaxy note 10.1 et en voyant la rapidité des mises à jour android sur cette tablette je cherche par un autre moyen
De rien smile,
Malheureusement comme je le dis au-dessus tu ne peux pas installer une rom du Note 2 sur le Note 10.1.
Par contre, va voir dans la section du Note 10.1 sur le forum ou sur XDA pour trouver une rom équivalente tu auras plus de chance là-bas.
Merci je vais faire un tour sur XDA
De rien en espérant que tu trouveras ton bonheur là-bas.
Sinon fais un tour dans la section du Note 10.1 sur le forum ici
Topic mis à jour : Mise à jour du 11 novembre 2013 - Dr.Ketan's Custom ROM Deodexed Prerooted|ZipAligned|User Control
Hello à tous,
Première rom en 4.3 que j'installe, et je suis septique...
1ere installation en faisant bien sur un full wipe dans tous les sens : tout semble fonctionner sauf les applis qui ont besoin du root et qui mettent 1/4 heure à se lancer. Je lance Root Checker : il me signale que le système est très lent et 15 minutes plus tard, il mouline toujours.
Je me dis qu'il y a un problème quelque part, c'est reparti pour un formatage complet...
2e installation : cette fois, je commence par root Checker et tout baigne.
Je lance Go backup, il mouline 3 minutes, puis me dit que le téléphone n'est pas rooté...
Je revérifie, ba si, c'est rooté.
J'essaye d'installer la dernière version de xposed framework, impossible : sa mouline pendant 10 minutes et l'appli quitte toute seule.
Pour le reste, le téléphone réagit bien, c'est fluide, et pas d'autres bugs visiblement sauf l'impossibilité de classer les applis dans le mode multi fenêtres : je clique sur une appli, je la déplace dans la barre de gauche et c'est une autre qui apparaît.
Du coup, je me demande si je ne vais pas essayer une autre rom...
Bonsoir Trob,
As-tu bien flashé après la rom, le fix 2 V3 disponible dans le post 1 ?
[mode boulet]
j'avais pas vu ce fix, juste le deuxième ( APN_KeyBoard_videocall_popup_FIX.zip) Rolling Eyes  [SAMSUNG GALAXY NOTE2][ROM Kitkat 4.4.2][GT-N7100][NI1]Dr.Ketan Custom ROMV14 [SGN2]  808734
[/mode boulet]
je fais ça demain, merci Mendicant Wink
lol! Trob de rien smile
Je pense que le Fix 2 V3 devrait corriger ton soucis.
Et bien après installation du fix, cela n'a strictement rien changé : toujours les mêmes soucis concernant xposed framework ou Go Backup, et idem pour le classement des applis dans la barre du mode multi fenêtres.
D'ailleurs, le descriptif du fix ne mentionnait pas ces problèmes...
Bonjour Trob,
Alors là c'est bizarre que tu as ces soucis.
Essaye avec une autre rom, tu auras peut-être plus de chance.
Si je peux te conseil il semblerait d'après les retours que la rom DN3 soit la meilleure du moment.
Merci Mendicant, je vais regarder cette DN3 alors Wink
De rien camarade smile
Tu verras il y a de très bons retour sur cette rom.
Et une v3 est en préparation.
MISE A JOUR EN V5
[N7100 4.3]Dr.Ketan's Custom ROM Deodexed | Prerooted | ZipAligned | AROMA | Fully User controlled customization. V3 | Note3 Fs
Spoiler :
bon flash
[SAMSUNG GALAXY NOTE2][ROM Kitkat 4.4.2][GT-N7100][NI1]Dr.Ketan Custom ROMV14 [SGN2]  61393
