[ROM 4.3.1][GROUPER/TILAPIA] OmniROM [ALPHA/Nightly][18.11.2013]
Message par Primokorn le Ven 18 Oct 2013 - 9:34
OmniROM
C'est quoi OmniROM ?
=> Découverte de OmniROM : un nouveau monde pour les ROMs Custom
GROUPER
omni-4.3.1-20131108-grouper-NIGHTLY-230600.zip - 141.65 MB
tilapia
omni-4.3.1-20131024-tilapia-NIGHTLY-175957.zip - 138.41 MB
GAPPS:
gapps43.zip - 101.29 MB
SuperUser a flashé si vous n'avez pas le root. Problème qui sera corrigé dans les prochains jours : Superuser
Installation
  1. Téléchargez la ROM
  2. Redémarrez dans le recovery custom
  3. Faites un Wipe data + dalvik cache
  4. Faites un Format System
  5. Flashez la ROM
  6. Faites un Wipe cache et Dalvik cache
  7. Redémarrez normalement
  8. Enjoy Very Happy
Images
Changelog
08/11/13
    Add SED_INPLACE macro - based on squashed
    Revert "Fix warning caused by disabled asserts causing unused variables."
    libstagefright: support for disabling buffer metadata
    Change CloneFunctionInto to always clone Argument attributes induvidually,
    Label /data/misc/media and allow mediaserver access to it.
    Initial drop of uapi mips headers.
    systrace: remove the use of a Python 2.7 function
    Set ro.config.low_ram=true when AVD has <= 512M of RAM
    Updated boot animation from kevinrocksman (http://goo.gl/w1tjAP)
    Some SELinux specific CTS tests.
    Network Speed indicator
    Implement CBC record splitting.
24/10/13
    Overlay support for legacy camera libs
    init.rc: Fix init.custom.rc reference
    AppOps: Add more operations in app ops settings.
    Add following operations in app ops settings.
    -- Wifi enable/disable
    -- Bluetooth enable/disable
    -- Mobile data enable/disable
    releasetools: support more partitions and different fstab types
    Merge tag 'android-4.3.1_r1' into HEAD
    frameworks: base: add storage_sd_dock_card string
    [1/3] base: add support for adb over network"
    Dashclock: Allow customizing alarm intent
    Dashclock: Prepopulate extension list with weather, gmail, next alarm …
    Dashclock: Handle ACTION_CANCEL in swipe dismiss code. Fixes issue 465.
    srec: Fix srec using new AudioRecord API
    DSPManager: Save and load presets from external storage
    OmniGears: notification lights - support for devices without multi-color led
    SEPolicy: Confine all app domains, but make them permissive for now.
    SEPolicy: Confine bluetooth app.
    SEPolicy: Move unconfined domains out of permissive mode.
    SEPolicy: tools: update lengths from int to size_t
    [2/3] settings: add support for adb over network" into android
    Settings: notification lights - fix for devices without leds"
    legacy OMX: use local flags
    Fix target parser"
    Fixed issues with SUdaemon now u can flash SuperSU and Root Acces work
    [1/2] base: volume panel styles and tweaks
    [3/3] Omni: add support for adb over network
    Revert "V8: enable no-pic compiling option"
    Apollo: strings: App is called 'Music' in the launcher
    [2/2] settings: volume tweaks
    SEPolicy: sysfs_devices_system_cpu should be a sysfs_type
    Update SDK prebuilt: layoutlib-api.jar.
    Revert:[2/2] settings: volume tweaks
    Revert: [2/3] settings: add support for adb over network
19/10/13
    Add more info while flashing
    Add Omni Version
    add CPU info overlay
    fixes on stability
    New bootanimation for the project
    "Fix target parser"
    "Update libandroid.so for API9 .. API18"
    "Add libm_hard to system lib list"
    "legacy OMX: squashed commit for mmparser"
    performancecontrol: fix layout derp and enabled battery info
    libnativehelper: "Remove jniGetNonMovableArrayElements."
    omnigears: cleanup missed whitespace problem
    [2/4] omnigears: custom brightness support
    re-implemented [WIP] Multiwindow
    settings: fixed NPE when non slide security is selected
    [3/4] settings: custom brightness support"
NOTE: For now this proyect have issues with SuperUSER I Working to fix this problem
Sorry for the inconvenience!.
17/10/13 Cooming soon
    "Use the uapi version of linux/auxvec.h"
    Flatten question statements into if/else statements"
    Initial drop of uapi aarch64 and common headers."
    core: set correct permission for init.d files"
    fix up adb to prefer /sbin/sh if it exists
    performancecontrol: fix layout for sw600
    performancetool: show core states
    Performance fixed ??? crashes?=????
    SecuritySettings: Fix crash when lockscreen is set to a secure mode
    Some SELinux specific CTS tests."
    add support for overriding build.prop settings. …
    FSTAB v2
    Electron Beam Fix
    Correctly advertise that the N7 has no hardware keys.
    Updated some SELinux policy
    Added SELinux in XPerience settings ops
    Multi-window -Patch set18 https://gerrit.omnirom.org/#/c/53/
    CircleBattery: Turn green when plugged in at 100%
    OTA update
    Re-add ARCH_ARM_HAVE_TLS_REGISTER for armv7
    fix STE_FM define brokeneness
    qcom_power: add TARGET_PROVIDES_POWERHAL
    Revert "Everyone has a TLS register."
    default: Use our own broadcom_libbt
    If dalvik wants ASCII casing, it needs to ask for it.
    Revert "Simplify OpenGL TLS access on ARM." …
    Phone: implement noise suppression for phone calls (2/2)
    external/webkit: use Cpu Upload path
    fmradio: port FMRadioSource to the new Proxy API …
    custom->omni
    Add testcase to demo how -mhard-float work in armeabi-v7a"
    Implement noise suppression for phone calls (1/2)" into androi
    libbt: Add support for board-specific configuration
    Builded with linaro 4.8.2 toolchain
16/10/13
    First alpha
Seigneur
Seigneur
Appareil secondaire : Nexus 5
: : AospExtended / MagiskSU
Re: [ROM 4.3.1][GROUPER/TILAPIA] OmniROM [ALPHA/Nightly][18.11.2013]
RESERVE
Seigneur
Seigneur
Message par ririck0 le Dim 20 Oct 2013 - 19:03
Merci pour la ROM, mais y a t'il le multi-fenêtre ?
ririck0
Message par Primokorn le Dim 20 Oct 2013 - 19:05
Normalement oui dans les dernières versions.
Seigneur
Seigneur
Message par Primokorn le Mar 29 Oct 2013 - 14:06
Mise à jour build du 24/10 :
  •  Overlay support for legacy camera libs
  • init.rc: Fix init.custom.rc reference
  • AppOps: Add more operations in app ops settings.
  • releasetools: support more partitions and different fstab types
  • Merge tag 'android-4.3.1_r1' into HEAD
  • frameworks: base: add storage_sd_dock_card string
  • [1/3] base: add support for adb over network"
  • Dashclock: Allow customizing alarm intent
  • Dashclock: Prepopulate extension list with weather, gmail, next alarm …
  • Dashclock: Handle ACTION_CANCEL in swipe dismiss code. Fixes issue 465.
  • srec: Fix srec using new AudioRecord API
  • DSPManager: Save and load presets from external storage
  • OmniGears: notification lights - support for devices without multi-color led
  • SEPolicy: Confine all app domains, but make them permissive for now.
  • SEPolicy: Confine bluetooth app.
  • SEPolicy: Move unconfined domains out of permissive mode.
  • SEPolicy: tools: update lengths from int to size_t
  • [2/3] settings: add support for adb over network" into android
  • Settings: notification lights - fix for devices without leds"
  • legacy OMX: use local flags
  • libstagefright: support for disabling buffer metadata
  • Fix target parser"
  • Fixed issues with SUdaemon now u can flash SuperSU and Root Acces work
  • [1/2] base: volume panel styles and tweaks
  • [3/3] Omni: add support for adb over network
  • Revert "V8: enable no-pic compiling option"
  • Apollo: strings: App is called 'Music' in the launcher
  • [2/2] settings: volume tweaks
  • SEPolicy: sysfs_devices_system_cpu should be a sysfs_type
  • Update SDK prebuilt: layoutlib-api.jar.
  • Revert:[2/2] settings: volume tweaks
  • Revert: [2/3] settings: add support for adb over network
Seigneur
Seigneur
Message par Primokorn le Lun 18 Nov 2013 - 11:01
Mise à jour
08/11/13
Seigneur
Seigneur
Message par Primokorn le Ven 6 Déc 2013 - 9:06
Changelog à suivre ici : Grouper - Tilapia
Seigneur
Seigneur
