description[ROM 4.3.1] CM10.2 : CyanogenMod 10.2 sur Samsung Galaxy Ace 2 [29.01.2014] Empty[ROM 4.3.1] CM10.2 : CyanogenMod 10.2 sur Samsung Galaxy Ace 2 [29.01.2014]
Pré-requis
Il est recommandé de flasher au préalable la ROM Stock MG2.
Avoir ce recovery : [JB] CWM Recovery 6
Installation
  1. Démarrez le recovery
  2. Faites un NANDROID BACKUP
  3. Faites un WIPE DATA
  4. Flashez la ROM puis les GApps
  5. Redémarrez
Téléchargements
• CLIQUEZ ICI ( GT-I8160 ) - Mirrors
• CLIQUEZ ICI ( GT-I8160P )
Busg connus
- Bluetooth (lié au kernel)
Derniers changements
23/01 :
    CM sources update
    Removed buggy multi-user support
    Updated translations in Ace 2 settings
    Updated P verison too
2014:
19/01 :
    CM sources update
    Kernel updated to 3.0.101
    Added abyssplug governor
    Removed ondemandq governor
    Fixed data download/upload arrows
    Updated GT-I8160P version too
04/01 :
    CM sources update
    GPS Improved
    Added support for 3 buttons headphones - Thanks to @PolishVodka
    Uploaded GT-I8160P version too
01/01 :
    CM sources update
    Notification sound is not late anymore
    Fixed apollo skip song when notification comes + DSP FC
    SD card can be safetly removed
    Swap storages option in advanced settings - Thanks to @e_c
    Updated GT-I8160P version too ( Not available to download )
2013:
27/12 :
    CM sources update
25/12 :
    CM sources update
    GT-I8160P Version ( NFC )
08/12 :
    CM sources update
    Fixed USB mass storage problems
    Problems with 2g/3g toggle fixed
06/12 :
    CM sources update
    GPS fully fixed
    Fixed 2G/3G toggle FC
29/11 :
    CM sources update
    Fixed problems for other screen driver
26/11 :
    CM sources update
    Improved GPS
24/11 :
    CM sources update
    Better Bootanimation look
    Improved mass storage
    Fixed cpu freq settings apps
    More Camera features
18/11 :
    CM sources update
    STABILITY FIX - No more random reboots - Thanks to percy-g2 and munjeni
    Fixed Low-Incall - Thanks to h3llrais3r
    Fixed bluetooth settings
    Removed USBdisk
    Enabled KSM - Improved RAM management
    Adb in recovery is working now
    Build power.montblanc.so from sources
    Not mounting preload as swap anymore
12/11 :
    CM sources update
    Fix signal bar problems
10/11 :
    CM sources update
    Fix mic and sound problems from last version
    RIL improvements
    Faster screenshoot taking
    Surfaceflinger improvements
    Fstab updated - Fixed sdcard problems
    Mounting preload as swap partition
    Swipe recovery function
    Fix blackscreen bugs on S6D27A1 driver
    SELinux disabled ( enabled Audit only )
04/11 :
    CM sources update
    Fixed 2G/3G toggle - Thanks to Macław Team
    Sound glitches should be fixed now
    OndemandQ governor added
    SIO and ZEN io schedulers
    Fixed BT tethering
    Build should be more stable
    Problems for users with other screen driver should be resolved
    Deleted buggy MultiWindow for now
31/10 :
    CM sources update
    Fixed CRT-Off Screen animation
    Devices with other screen driver now shouldn't have problems with booting
    Fixed Random Reboots (Maybe - need more tests)
29/10 :
    CM sources update
    Testing MultiWindow
Autres infos
Le 1er démarrage prend du temps, au moisn 5min
Appuyez 5 fois sur "numéro de build" dans "A propos" pour avoir les options de développement
La première connexion WiFi peut prendre du temps
N'utilisez pas le kernel RoXSel pour le moment (attendez la v3)
description[ROM 4.3.1] CM10.2 : CyanogenMod 10.2 sur Samsung Galaxy Ace 2 [29.01.2014] EmptyCM10.2 Galaxy Ace2, Cyanogen Galaxy Ace 2, rom aosp ace II
RESERVE
description[ROM 4.3.1] CM10.2 : CyanogenMod 10.2 sur Samsung Galaxy Ace 2 [29.01.2014] EmptyRe: [ROM 4.3.1] CM10.2 : CyanogenMod 10.2 sur Samsung Galaxy Ace 2 [29.01.2014]
Mise à jour dont :
• 2 modèles supportés
• réduction des problèmes
