[ROM 4.3]Android 4.3 avec CyanogenMod 10.2 pour le Motorola Defy (+) [31.10.2013]
Message par Primokorn le Jeu 31 Oct 2013 - 11:21
Téléchargements
Installation
Pour pouvoir flasher cette ROM, vous avez besoin du CWM 6.x ou le TWRP sinon l'installation sera un échec. ("STATUS 0 Installation aborted").
  1. Redémarrez dans le recovery
  2. Faites un BACKUP
  3. Faites un FULL WIPE
  4. Flashez la ROM puis les GApps
  5. Redémarrez
Changelog
30.07.13: First Build. Works almost all.
01.08.13: Fix "Unknown" bug. Fix 1% battery. Dialer included, VideoEditor removed.. Backup gapps disabled(to prevent reboots during install rom).
17.09.13: Focal Restored, Ability to OC GPU(without gui yet), added patch for Data, DefyParts, 720p rec(bugged), Support HWUI app, Minimum brightness 2, Wide poho added.
20.10.13:720p rec, Fix HWUI app, use thoemy wpa_supplicant, Call Recording, LTO support, many fixes and improvements in kernel, gpu 266mhz by default, Fix arrows that indicate upload/download activitiy at Wifi and mobile connections.
30.10.13: Fixes in kernel, Added two new options for ril "emptycallchanges" and"skipdatareg" (disabled by default), journal on ext enabled by default, fix reboots in recovery(not tested), updated twrp.
BT headset not fixed
Problems
Images
Autres infos
GPU Freqs:
266666666 = 266mhz OCed.
200000000
133333333
100000000
66666666
33333333
16666666
echo %freq% > /proc/gpu/max_rate
rom aosp defy, rom android 4.3 mototoral defy, CM10.2 defy, CM 10.2 defy+
RESERVE
