[KERNEL] Linaro Kernel | r33 | 3.4.75| 4.4.2 | GCC 4.8.2 -O3 [Faux Sound [17.02.2014]
Message par Primokorn le Ven 15 Nov 2013 - 10:00
Linaro franco.Kernel
Kernel basé sur le Franco kernel avec les changements suivants :
- -O3 and other compiler optimizations
- Tweaks to make it compile with gcc 4.8.3
- Specific tweaks to make it fast with our Snapdragon 800
- Fixed some warning
- Removed some debug options
- Add Faux sound support, and Faux sound fixes
- Many slub, slab, slob allocators optimizations and fixes
- Mountpoints optimization
- Franco Audio patches not included for now, I prefer Faux solution, let's see in next builds
- Many fixes and optimization cherry-picked from Faux Hybrid, FuguMod, ElementalX, Bricked, Chaos, CM kernels
- Upstream with Linux kernel 3.4.x
- lz4 compressed kernel and RamDisk for faster boot (with lz4 r113)
- Added sweep2wake, doubletap2wake, sweep2sleep (from showp1984)
- s2w/dt2w: Powerkey toggle, Prevent touches during phone calls
- ExFat support
- Disabled secure adb on boot
- Minor fixes
Notes:
- You can find my own compiled toolchain, optimized for Cortex A15
- If you updated audio libs you have to revert back flashing old package in recovery (you can find it here)
- 0 - 17 versions are for android 4.4, 18+ version are for android 4.4.1 and 4.4.2
- s2w, dt2w, s2s+dt2w will cause an extra battery drain (2/3% per hour)
- s2s only will not cause any extra battery drain
- s2Boot folder is automatically created if there isn't one
Compatible avec l'application franco.Kernel Updater (FKU) / Faux Sound app / Nexus 5 gamma reverse engineering App / Touch Control App / Screen dimmer et fast charge
Téléchargements
MIRROR
• Couleurs stock
• Versions 0 à 17 pour Android 4.4. A partir de la version 18 c'est pour Android 4.4.1 et 4.4.2
Instructions boot image
Vous devez au préalable déverrouiller le bootloader et avoir le root : Rooter le Nexus 5 avec le CF-Auto-Root
  1. Redémarrez le téléphone dans le bootloader (téléphone éteint : VOLUME BAS + POWER)
  2. Connectez le téléphone à votre PC
  3. Ouvrez une invite de commandes depuis le dossier où vous avez fastboot et tapez :
    fastboot devices (pour vérifier la bonne connexion de votre téléphone)
    fastboot flash boot nom-de-l'image.img
  4. 3s après le flash est terminé. Faites VOLUME HAUT jusqu'à avoir l'option "START" en vert qui apparaît et validez avec POWER. (ou alors, toujours dans le cmd, faites fastboot reboot)
  5. Le téléphone redémarre, vous pouvez le déconnecter du PC.
  6. Enjoy cheers
Instructions zip
  1. Copiez le fichier .Zip sur votre téléphone
  2. Redémarrez dans votre recovery custom
  3. Flashez le kernel (pas besoin de wipe)
  4. Redémarrez normalement
Github - Source
S2W, DT2W, S2S:
Sweep2Wake:
in terminal emulator app type:
su
echo 1 > /sys/android_touch/sweep2wake
Set on boot: Create a file named s2w in /sdcard/s2Boot folder
DoubleTap2Wake
In terminal emulator app type:
su
echo 1 > /sys/android_touch/doubletap2wake
Set on boot: Create a file named dt in /sdcard/s2Boot folder
Sweep2Sleep
su
echo 1 > /sys/android_touch/s2w_s2sonly
Set on boot: Create 2 file named s2w and s2s in /sdcard/s2Boot folder
Re: [KERNEL] Linaro Kernel | r33 | 3.4.75| 4.4.2 | GCC 4.8.2 -O3 [Faux Sound [17.02.2014]
RESERVE
Message par Primokorn le Lun 18 Nov 2013 - 9:19
Mise à jour avec le kernel Franco r13
Message par Primokorn le Dim 8 Déc 2013 - 10:01
Mise à jour r19
Message par Primokorn le Mer 11 Déc 2013 - 11:08
Mise à jour r20
Message par Primokorn le Lun 16 Déc 2013 - 9:30
Mise à jour r21
Message par Primokorn le Mar 17 Déc 2013 - 14:54
Mise à jour r23
Message par Primokorn le Mar 24 Déc 2013 - 8:33
Mise à jour
Message par Primokorn le Ven 27 Déc 2013 - 11:12
r25 dispo
Message par Primokorn le Lun 17 Fév 2014 - 15:26
Mise à jour r33
