Halo; Movable and re sizable Halo window; Screenshot quick trash; Power menu QS tile (simple press to go into power dialog or long press to go into reboot dialog); Power menu added in navring targets; Non intrusive call; Navigation bar dimensions; Enable or disable navigation bar; Low battery warning options; Lockscreen see through with blur effect; Lockscreen PIN keypad shuffler; Lock before unlock (Show sliders before secure unlock); Extended QS options (3, 4 or 5 tiles per row + option to duplicate tiles in landscape mode); QS tiles custom colors and transparency with ribbon linked; Notification drawer custom background and transparency; Notifications row transparency; Custom clear all recents button (place it in any corner of the screen); RAM bar; Option to hide app's status bar notification icons; GPSTile from SlimRoms; TRDS from SlimRoms (Dark droid); TRDS tile; Status bar clock and date customization; OmniSwitch; Open source Google dialer and more; Configurable volume panel timeout;
• GApps :
Changelog
Build 6 - 16.02.14 - Several updates from CyanogenMod repositories (in line with all of them until February 16); - Open source Google dialer and more; - Configurable volume panel timeout;
Build 5 - 13.02.14 - Several updates from CyanogenMod repositories (in line with all of them until February 12); - Fix white background in dialer when TRDS is enable; - Fix icons overflowing status bar view in center clock and date layout; - Handle navbar heights correct on dpi changes (i'm including this because of a possible upcoming DPI changer feature!) ; - TRDS fix possible UI freeze on auto mode change;
Build 4 - 08.02.14 - Updates from CyanogenMod repositories; - Status bar clock and date customizations; *** Alignment: right or center clock *** AM/PM stye; *** Date font size; *** Date style; *** Date format; - OmniSwitch added into the build;
Build 3 - 04.02.14 - Updates from CyanogenMod repositories; - TRDS from SlimRoms (Dark droid); - TRDS tile; - TRDS new behavior: -> Switch theme *** manual *** On light condition; *** ON day time; - Dark Phone; - Dark Mms; - Dark Email; - Dark Contacts - Dark Gallery - Dark Keyboard; - Dark Calculator; - Quick unlock fixed;
Build 2 - 27.01.14 - Updates from CyanogenMod repositories; - QS tiles custom colors and transparency; - Ribbons transparency; - Notification drawer custom background and transparency; - Notifications row transparency; - PT-BR translations of crDroid custom features;
Build 1 - 24.01.2014 - Up to date with CyanogenMod until 24 january 2014 - New Halo; - Movable and re sizable Halo window; - Screenshot quick trash; - Power menu QS tile (simple press to go into power dialog or long press to go into reboot dialog); - Power menu added in navring targets; - Non intrusive call; - Navigation bar dimensions; - Enable or disable navigation bar; - Low battery warning options; - Lockscreen see through with blur effect; - Lockscreen PIN keypad shuffler; - Lock before unlock (Show sliders before secure unlock); - Extended QS options (3, 4 or 5 tiles per row + option to duplicate tiles in landscape mode); - Custom clear all recents button (place it in any corner of the screen); - RAM bar; - Option to hide app's status bar notification icons; - GPSTile from SlimRoms;
Changelog CyanogenMod par build
Images
AUTRES SCREENSHOTS :
privacy_tipPermission de ce forum:
