[MOD][GT-N7100] Note 3 Mod Project V3.5 [ML3/ML4] [31.12.2013]
Message par Mendicant Bias le Jeu 21 Nov 2013 - 23:42
Note 3 Mod Project
Le mot du créateur du Mod "Tamirda" :
"Je vous présente le Note 3 Mod Project pour le Note 3 N7100."
Ce qui fonctionne :
Note 3 Launcher
Note 3 Multiwindow
Note 3 Fully Working Aircommand
Note 3 One Handed Option Fot all screens
Note 3 Keyboard - Thanks avivalder
Note 3 SNote
Note 3 My Files
Note 3 Contacts and Phone (with option for popup incoming notifications)
Note 3 Browser
Note 3 S Planner
Note 3 S Finder, Pen Window, Scrapbooker
Note 3 Apps like SketchBook, Evernote and more
Note 3 Gallery
Note 3 Writing Buddy
Note 3 My Magazine
And much more!
Images et Vidéos
Installation
Pré-requis :
- Stock XXUEMK4 Deodexed (Might Work On Custom Roms Based On XXUEMK4. PhoeniX ROM Already have this built in)
- Root & Recovery
Installation :
1) Démarrez dans le CWM Recovery en maintenant les touches "Volume +", "Power" et "Home".
2) Faîtes un NANDROID Backup avant via le Recovery.
3) Faites un "Wipe Cache Partition" et dans "Advanced" "Wipe Dalvik Cache".
4) Flashez le Mod.
5) Amusez-vous  Very Happy
Changelog
31 décembre 2013 - v3.5 :
- Fixed Contacts FC
- Fixed Story Album FC
- Fixed Other FCs
- Added Sview Cover Support(Experimental)
- Fixed Soft Buttons Light Always ON
Anciennes versions :
03 décembre 2013 - v2.0 :
  • New Note 3 Settings with Search Options and more! (Do not ask why touch with gloves doesn't work or other note 3 stuff - the answer is simple, you don't have Note 3 HW)
  • New Note 3 Multiwindow with amazing features:
    - Quad screen: you can split multiwindow up to 4 different apps!
    - Floating windows: Like Pen Window, just with the finger(One click on the app in multiwindow will open it as floating window) smile
    - Abillity to open same app from this list(If you need any more app please make a list so I can add in the next release) :
    [left]com.sec.chaton
    com.sec.android.app.myfiles
    com.google.android.talk
    com.google.android.youtube
    com.infraware.polarisviewer4
    com.infraware.polarisoffice4
    com.whatsapp
    com.kakao.talk
    com.sec.android.app.sbrowser
    com.android.email
    com.android.mms
    com.android.chrome
    com.facebook.katana
    com.google.android.gm
    com.google.android.videos
    com.twitter.android
    com.quoord.tapatalkpro.activity
    com.sec.android.app.videoplayer
    com.estrongs.android.pop[/left]
  • New black themed Note 3 Keyboard with the following fixes(Thank you dr.ketan!) :
    - No more big smilies!!!
    - No more missing icons!!
  • New Note 3 Signature Lock! Oh I love it!
  • New Lockscreen effect - Watercolor effect! Now you have 3 options:
    - Watercolor Effect
    - Ripple Effect
    - Flare Effect
  • New Note 3 Story Album app + widget
  • New Smart Scroll & Smart Pause Options!
  • New Quick Glance option (In order to use it you must activate Air Gesture, Motions and Palm Motions)
  • New SPen Features(In order to understand better go into Settins -> Air Command and use tutorials there) :
    - Air Click on a picture in gallry will open new Air Menu
    - Air Click on Attact/Contact in SMS will open new Air Menu
    Fixed:
  • Fixed Camera/Favorite apps in Lockscreen
  • FIxed SNS FC
  • Fixed App FC when using Emojis in keyboard
21 novembre 2013 - v1.0 :
- Initial Release
Téléchargements
Note 3 Mod Project v3.5
[Comment uploader et partager un fichier?] - [Vous êtes développeur ou cuisto?][/center]
ROMs : Rom Stock
: : X-Note v10
Re: [MOD][GT-N7100] Note 3 Mod Project V3.5 [ML3/ML4] [31.12.2013]
ROMs : Rom Stock
: : X-Note v10
ROMs : Rom Stock
: : X-Note v10
Message par djgregs62 le Ven 22 Nov 2013 - 1:10
Nouvelle mise à jour au 21/11
Oups j'avais pas vu que le post été à jour ...lol
djgregs62
Appareil principal : Galaxy Note 2
ROMs : DN4 Rom
Message par Mendicant Bias le Ven 22 Nov 2013 - 23:58
Post 1 mis à jour
ROMs : Rom Stock
: : X-Note v10
Message par Mendicant Bias le Mar 3 Déc 2013 - 20:53
Topic mis à jour : Mise à jour du 03 décembre 2013 - Note 3 Mod Project V2.0
ROMs : Rom Stock
: : X-Note v10
Message par dave62 le Mer 11 Déc 2013 - 21:27
Hum pour moi scratch book, album et navigateur ne fonctionnent pas. ...
Pourtant je suis avec une mk4 et j'ai fais un wipe cache et dalwik. ...
dave62
ROMs : Custom obligatoire !
Message par Mendicant Bias le Mer 11 Déc 2013 - 23:48
Bonsoir Dave,
Tu es sur quelle rom exactement ?
Peux-tu compléter ton profil s'il-te-plait, ce sera plus simple pour t'aider.
ROMs : Rom Stock
: : X-Note v10
Message par johnmarcus11 le Sam 14 Déc 2013 - 11:12
Blufant ce Mod Note 3.
Parfaitement fonctionnel quand on a compris toutes les possibilités.
Et là,c'est pas si simple.
johnmarcus11
Appareil principal : Moto G
ROMs : stock 4.4.4
Message par Mendicant Bias le Sam 14 Déc 2013 - 11:19
Bonjour Johnmarcus,
Merci pour ton retour et content que ça fonctionne bien pour toi cheers
ROMs : Rom Stock
: : X-Note v10
Message par johnmarcus11 le Sam 14 Déc 2013 - 11:23
Salut Mendicant,
Je vois que tu es dans les starting block.
Action,réaction.
Bon w-end.
johnmarcus11
ROMs : stock 4.4.4
Message par Mendicant Bias le Sam 14 Déc 2013 - 11:36
 oui dans les starting block Very Happy
Bon week-end à toi aussi.
ROMs : Rom Stock
: : X-Note v10
Message par elfrager le Mer 18 Déc 2013 - 20:54
A votre avis compatible ou pas avec une deodexed mk9 ?
elfrager
Appareil principal : SAMSUNG GALAXY NOTE 2
ROMs : voir signature
Message par Mendicant Bias le Mer 18 Déc 2013 - 20:58
Bonsoir Elfrager,
Normalement oui le Mod est compatible avec la MK9.
Mais au cas où fais un Nandroid Backup avant, comme ça tu pourras restaurer facilement si il y a un problème
ROMs : Rom Stock
: : X-Note v10
Message par idavidok le Dim 29 Déc 2013 - 16:28
pour info ne fonctionne pas sur mon note 8 en 4.2.2 ...
idavidok
ROMs : change tout le temps
Message par Mendicant Bias le Dim 29 Déc 2013 - 16:29
Bonjour Idavidok,
Oui c'est normal ce mod n'est compatible que pour le N7100
ROMs : Rom Stock
: : X-Note v10
Message par idavidok le Dim 29 Déc 2013 - 17:42
Vraiment dommage
idavidok
Message par Mendicant Bias le Dim 29 Déc 2013 - 18:02
Il faudrait que tu ailles dans la section du Note 8 sur XDA pour voir si un tel Mod existe
ROMs : Rom Stock
: : X-Note v10
Message par Mendicant Bias le Mer 1 Jan 2014 - 23:15
Topic mis à jour : Mise à jour du 31 décembre 2013 - Note 3 Mod Project V3.5 [ML3/ML4]
ROMs : Rom Stock
: : X-Note v10
Message par spigaou le Jeu 9 Jan 2014 - 23:32
Décidément il y en a un qui va encore dire des trucs sur moi ......
car ce ne marche pas sous xperia-z-ized v2.1
ce coup là j'ai fait un nandroid backup,  nananere
spigaou
Appareil principal : SAMSUNG SGN4
ROMs : Emotion MMr23.1.official
Appareil secondaire : SGN3
Message par Mendicant Bias le Jeu 9 Jan 2014 - 23:45
 tu n'as vraiment pas de chance toi Very Happy
As-tu fais un wipe cache + wipe dalvik cache avant de flasher le Mod ?
ROMs : Rom Stock
: : X-Note v10
Message par spigaou le Ven 10 Jan 2014 - 0:01
hello Mendicant  , oui j'ai wiper de tout les cotés ! (je commence à avoir l'habitude, même si après j'oublie les nandroid backup de temps en temps.. :p
Mais rien n'y fait !
peut être le module xposed wanam ou autre LBE qui ont tout planté ?
enfin je vais pas me casser le bol, t’inquiète pas j'ai fait un restore
quand j'aurai un peu de temps , je referai une clean intall et dans la foulée le ModProject, et seulement apres ma config et applis tiers
bonne nuit
spigaou
Message par Mendicant Bias le Ven 10 Jan 2014 - 0:20
Ton Note 2 c'est vraiment un mystère Spigaou,
En effet peut-être Wanam Xposed, LBE ou autre chose qui crée des incompatibilités.
Tiens-nous au courant en espérant que tu trouveras d'où vient ton problème.
Bonne nuit à toi aussi.
ROMs : Rom Stock
: : X-Note v10
