[ROM][AOSP/KitKat 4.4.2/3.4Kernel]Non-Officiel Cyanogenmod 11 with ION_Liberty [15 Juin]
Page 1 sur 7 1, 2, 3, 4, 5, 6, 7  Suivant
Message par HTCBatMan le Mar 26 Nov - 6:29
[KERNEL 3.4] UNOFFICIAL CYANOGENMOD 11
Cette Rom est issue de la dernière version Android, kitKat.
Vous allez vivre une nouvelle expérience avec cette ROm.
Celle-ci se compose :
  • 3.4 JB KERNEL
  • RIL
  • Torch
  • Mobile Data
  • Mic
  • Audio
  • GPS
  • Vibration
  • Auto Brightness
  • SD Card
  • Airplane Mode
  • Daydream
  • WiFi
  • Auto Rotation
  • System Monitor
  • Tethering
  • Screenshots
    Jan 26, 2014:
  • Latest upstream CyanogenMod changes
  • Enabled full QCOM BSP
  • Enabled LPA (low-power audio)
  • Fixed notification LED
  • Enabled audio-visual enhancements
  • Increased speaker volume
  • Camera: Fixed all picture quality issues
  • Camera: Disabled focus for now (as it is more broken than Windows Vista)
  • Switched to scorpion CPU optimizations + bionic optimizations
  • Overall performance greatly increased
  • Other misc changes
    Kernel:
  • Re-mapped RAM to better suit AOSP ROMs and KitKat
  • Fixed 1080P video playback as a result of the RAM re-map
  • Updated WiFi drivers (bcmdhd) from Nexus 5 kernel (thanks to Flemmard)
  • Compiled with new January 2014 Linaro toolchain release from Christopher83
23rd January 2013
New update:
[*]SultanXDA :  Camera still Image Quality fixed. Credits: SultanXDA
[*]Ivanich  : Deep Sleep fixed. Some display related commits such as retire fence added Credits: Ivanich
[*]d_l : Thermal drivers r now from 3.0 and is fully kernel based [keeps phone cooler] Power-off fixed [no more reboots when power off phone]. Camera flash battery cap reduced to 1% which means now camera flash can be used till 1% battery. Battery drivers r now pyramid's own [testing purposes] write back panel is disabled since it seemed not to be working properly. credits: me
17th January2013
[*]DISPLAY - CAF And MEDIA-CAF
-Fully Fixed
-No more glitches
-Latest CM synced
Credits: Sulatanxda, ivanich and me
[*]New Adreno drivers and libs
-Browser problem solved
-Recent apps window fixed
Credits Sultanxda
[*]Audio fully fixed
-Both headphones are now louder
-overall loud speaker is now good as well
Credits: SebastianFM and me
[*]Camera fixes
- Focus Fixed
-Random crashes fixed
-Note: Use focal for better still images
Credits: SebastianFM and Me
[*]Bluetooth fixed
-Fully blutooth should be working now
Credits: Me
30th December 2013
  • All graphic glitches fixed
  • Camcorder fixed
  • Still Images fixed [still there r some quality issues]
30th November 2013
  • Fixed screenshot
  • Fixed recent apps switching
  • Fixed SD card
  • Fixed native USB OTG mounting
  • Fixed MDP clock rate (SebastianFM)
  • Ported newer GPU driver from CAF jb_2.5.5 branch
  • Added newer 4.2 Adreno libs
  • EGL: Use only Adreno rendering
  • Enabled QCOM_BSP
28th November 2013
  • Ion from CAF
  • Graphical Glitches fixed
  • Ril Fixed
24th November 2013
  • Initial Release
Qualité de la Camera
Encore des problèmes avec les images
HDMI
FULL ROM :
ROM :
MRROIR :
GAPPS:
[Vous devez être inscrit et connecté pour voir ce lien][/b]
[[Vous devez être inscrit et connecté pour voir ce lien]]
@[Vous devez être inscrit et connecté pour voir ce lien] (Pour être un ami humble et certains design)
@[Vous devez être inscrit et connecté pour voir ce lien] (Pour le code source du Kernel)
et moi ([Vous devez être inscrit et connecté pour voir ce lien])
Appareil principal: HTC ONE m7
ROMs: Stock 4.4.3-6.09.401.5-SENSE 6
Appareil secondaire: HTC SENSATION XE
:: HD2,DESIREHD,HD7
Cm11, KitKat, cyanogenmod, unofficial cyanogenmod, Kit kat 4.4, Android 4.4
:: HD2,DESIREHD,HD7
Re: [ROM][AOSP/KitKat 4.4.2/3.4Kernel]Non-Officiel Cyanogenmod 11 with ION_Liberty [15 Juin]
Message par [Legenda] le Mar 26 Nov - 11:03
Biiiennnn, je n'avais pas mis cette rom car le data ne fonctionne pas sur celle-là!
Le développeur à préciser qu'il fallait attendre la prochaine MàJ
[Legenda]
ROMs: ROM : Testeur
:: Kernel : Testeur aussi
Message par HTCBatMan le Mar 26 Nov - 13:23
En fait, j'ai remarqué surtout qu'aucun des portages Kitkat ne se fait sans bug.
A++ et bonne journée
:: HD2,DESIREHD,HD7
Message par [Legenda] le Mar 26 Nov - 13:41
A part la mise à jour de la rom with ION que j'ai posté ici...Et que j'ai un plaisir à utiliser depuis!. Effectivement que des bugs!
[Legenda]
ROMs: ROM : Testeur
Message par HTCBatMan le Mar 26 Nov - 14:07
:: HD2,DESIREHD,HD7
Message par HTCBatMan le Sam 30 Nov - 16:17
Mise à Jour :
[ROM/CM11/KitKat 4.4][28/11/2013] Unofficial Cyanogenmod 11
:: HD2,DESIREHD,HD7
Message par [Legenda] le Dim 1 Déc - 14:09
MàJ 30 Novembre smile
[Legenda]
ROMs: ROM : Testeur
Message par HTCBatMan le Dim 1 Déc - 15:37
Merci à toi LEGENDA et je profite pour te proposer de la tester.
Moi j'y retourne, j'étais passé faire un coucou a la ViperS2.0.0... Je m'y mets de suite.
:: HD2,DESIREHD,HD7
Message par HTCBatMan le Jeu 5 Déc - 17:32
Il y a tout de même une bonne nouvelle .
[Vous devez être inscrit et connecté pour voir ce lien] un développeur de chez XDA nous informe que [Vous devez être inscrit et connecté pour voir ce lien] le développeur de cette ROM est pour le moment en vacance et qu'il s'occupera du problème d'appareil photo d'ici son retour dans 2 semaines.
:: HD2,DESIREHD,HD7
Message par HTCBatMan le Ven 6 Déc - 14:10
Il est important de savoir que le Montage de la mémoire de stockage de masse via USB n'est pas fonctionnel (pour le moment)
Je le rajoute dans le post 1
:: HD2,DESIREHD,HD7
Message par HTCBatMan le Ven 27 Déc - 19:59
Mise à jour :
[ROM/CM11/KitKat 4.4][26/12/2013] Unofficial Cyanogenmod 11 [Cam Working]
Edit :
Toujours les même Bugs apportés par le KitKat avec en plus des bugs graphiques, l'appareil photo fonctionne mais une fois que l'on veut faire une photo directement Fermeture inattendue
:: HD2,DESIREHD,HD7
Message par [Legenda] le Sam 28 Déc - 20:32
ne parlons pas des lags Sad
franchement j'attends de meilleurs MàJ : là je reste sur Vipers 3.1.4 !!
[Legenda]
ROMs: ROM : Testeur
Message par HTCBatMan le Dim 29 Déc - 15:28
C'est une bonne idée, celle-ci est l'une des moins aboutit des KitKat qu'il m'est arrivé de tester.
:: HD2,DESIREHD,HD7
Message par HTCBatMan le Lun 30 Déc - 19:01
Mise à jour :
[29/12/2013] Unofficial Cyanogenmod 11 [Cam Working]
Post 1
:: HD2,DESIREHD,HD7
