[SOFT][4+] BIFTOR SETTINGS : Redéfinissez le style de vos paramètres et de vos barres glissantes [Gratuit] [19.12.2013]
Message par Primokorn le Jeu 19 Déc 2013 - 14:59
BIFTOR SETTINGS
Je crois que dans ce cas, les images parlent d'elles-même. Regardez vos menus sous un autre angle Wink
Changelog
Biftor settings version 2.1 :
Fixed App Theming Problems
Added other languages Spanish,Russian and Dutch
Fixed other problems
Dont suport android less than 4 not working...
Biftor settings version 2.0 :
Added ability to switch between stock settings or my settings from launcher options menu settings or other settings same statusbar settings for all device should work
Added preference title text size picker switch able for enabled or disable
Added preference summary text size picker switch able for enabled or disable
Added preference category text size picker switch able for enabled or disable
Added android 2.1+ support
Biftor settings Version 1.0 :
fix some pbs
rewrote app
added Color Pickers (you can make your theme) for
preference text Title, summary, icon and bg all of them switchable cor enabke or disable
added category text color and bg color all of then switchable for enable or disable
new style with switchs
added welcome toast text switchable for show or hide
xda and pda-planet link added
New style setting/sliding bars
added all settings options if your device support
ability for swipe left or right to switch between bars
ability for change app theme
added sensors calibration
added Nfc, Sbeam and spen if your device support
added call settings
added power options
Main features of power options:
Ability for restart 6 important apps for example systemui,contacts and....
Ability for close or restart or kill all apps with android package this will give you more free Ram!
Ability for close or restart or kill all apps with com package this will give you more free Ram!
Ability for close or restart or kill all Android without any reboot or hot boot this will give you more free Ram!
Ability for close or restart or kill all Android +hotboot this will give you more free Ram!
Ability for Quick Hotboot
and more things I can't remember now...
Pré-requis
• Le root pour les options Menu
• Android 4.0+
Téléchargement v2.1
Bugs
• FC sur l'option Bluetooth sur le Samsung Galaxy i9500 - Android 4.3
Images
JE VEUX EN VOIR PLUS !:
Source - Aide à la traduction
Seigneur
Seigneur
Appareil secondaire : Nexus 5
: : AospExtended / MagiskSU
Re: [SOFT][4+] BIFTOR SETTINGS : Redéfinissez le style de vos paramètres et de vos barres glissantes [Gratuit] [19.12.2013]
RESERVE
Seigneur
Seigneur
