[ROM 4.4.2][KOT49H] Calkulin's Nexus 5 - Optimisations + Script d'économie de batterie [18.01.2014]
Message par Primokorn le Sam 18 Jan 2014 - 19:14
Calkulin's Nexus 5
ROM includes:
Stock Google kernel w/ init.d support
Working ART runtime
Deodexed system
Superuser
Busybox
and more
MODs included:
Tweaked system (Very FAST)
Raised contact sync resolution (requires resyncing of contacts if you don't factory reset before installing)
Battery % on status bar (thanks to Erhany for the code) (disable zip in FAQ)
Exchange security bypass (thanks to Apascual89 for the code)
Enabled Multi-User support (rotate lockscreen to change users)
4 way reboot power menu (thanks to Kahvitahra for the code)
Enabled menu button to be always on (disable zip in FAQ)
Relaxed MMS compression ratio (Hangouts & Messaging)
Enabled access to App Ops in Settings/Security
Disabled alarm set icon (enable zip in FAQ)
Blocked annoying ads in programs
Enabled NFC while on lockscreen
APN settings for a lot of carriers
Colored notification icons
And other misc tweaks/mods
Installation
Commencez par déverrouiller le bootloader et installer un recovery custom (à jour) : Déverrouiller bootloader / Recovery / Root puis sauvegardez votre partition EFS.
  1. Placez la ROM dans le dossier /sdcard
  2. Redémarrez dans le recovery
  3. Faites un NANDROID BACKUP
  4. Faites un FULL WIPE
  5. Flashez la ROM
  6. Redémarrez.
Images
A propos du script
Can be used with any kernels that have init.d support
It completely eliminates the need for an application to set CPU speeds or profiles
Easily customizable - See FAQ for instructions
If Android Overclock, No-Frills CPU Control, Overclock Widget, QuickClock Advanced Overclock, SetCPU or System Tuner are detected, the script is ignored, so it will not affect them
Preset profiles are:
2.26GHz - 100-85%
1.95GHz - 84-36%
1.72GHz - 35-0%
And just an FYI, even at 1.72GHz, the phone still operates very well & smooth, it's the battery savings that are the real benefit
Changelog
v1.0.1
Initial Release
Tweaked battery saver script (v1.0.1)
Updated
Google Play Services v4.1.32 (978161-38) (v1.0.1)
• Nexus 5 ROM (v1.0.1) - Mirror
md5 - 4ae588202d1f8912cc4022f740d8c717
• Nexus 5 ROM Update (v1.0 to v1.0.1)
FAQ
How to modify the battery saver script?
(requires knowledge of how to run terminal or adb commands)
These are the available commands to set parameters. To check what the available commands are for each, type available after the command
For ex.
cpu available
To check what the current settings are
cpu status
To verify what the cpu is currently set to
cpu verify
To reset the script back to stock
cpu default
To disable the script
cpu off
cpu - Controls the script
cpu_bp - Enables or disables battery profiles feature
cpu_bp1_batt - Battery percent of when profile 1 ends
cpu_bp1_governor - Enables or disables battery profile 1 governor and sets governor
cpu_bp1_max - Max cpu speed for battery profile 1
cpu_bp1_min - Min cpu speed for battery profile 1
cpu_bp2_batt - Battery percent of when profile 2 starts
cpu_bp2_governor - Enables or disables battery profile 2 governor and sets governor
cpu_bp2_max - Max cpu speed for battery profile 2
cpu_bp2_min - Min cpu speed for battery profile 2
cpu_delay - Delay before script cycles
cpu_governor - Main governor
cpu_max - Max cpu speed when profiles are off and in between battery profiles 1 & 2
cpu_min - Min cpu speed when profiles are off and in between battery profiles 1 & 2
cpu_uv - Controls undervolting for kernels like Franco's, 0-150mV in increments of 25
devlog - Enables or disables logging
NOTE: You need to wait the time set in cpu_delay before settings take effect
Want to disable the battery percent in the status bar and the menu button in the navigation bar?
Flash the Calkulin's_Disable_Battery_Percent_and_Menu_Button _for_Nexus_5_v* zip attached
Want to disable the menu button in the navigation bar?
Flash the Calkulin's_Disable_Menu_Button_for_Nexus_5_v* zip attached
Want to enable the alarm set icon in the status bar?
Flash the Calkulin's_Enable_Alarm_Icon_for_Nexus_5_v* zip attached
Having problems with included hosts file or want to see advertisements again?
Flash the Stock_Android_Hosts_for_Nexus_5 zip attached
Addons
Stock_Android_Hosts_for_Nexus_5.zip
Calkulin's_Disable_Battery_Percent_and_Menu_Button_for_Nexus_5_v1.0+.zip
Calkulin's_Disable_Menu_Button_for_Nexus_5_v1.0+.zip
Calkulin's_Enable_Alarm_Icon_for_Nexus_5_v1.0+.zip
Stock_Calkulin's_Nexus_5_ROM_v1.0+_Kernel.zip
franco.Kernel-nightly-r32-Calkulin.zip
Re: [ROM 4.4.2][KOT49H] Calkulin's Nexus 5 - Optimisations + Script d'économie de batterie [18.01.2014]
RESERVE
Message par snach21 le Sam 18 Jan 2014 - 22:30
Bonsoir tentente !!!!
je dl  Very Happy
Edit/
tu dis flasher les gapps dans le tuto d'instalation,ou sont ils ?
faut les trouver à par sur la section nexus5 ?? merci
edit/2
-Stock_Android_Hosts_for_Nexus_5.zip => c'est quoi?
-Calkulin's_Disable_Battery_Percent_and_Menu_Button_for_Nexus_5_v1.0+.zip
-Calkulin's_Disable_Menu_Button_for_Nexus_5_v1.0+.zip
-Calkulin's_Enable_Alarm_Icon_for_Nexus_5_v1.0+.zip=> pour activer l'alarme dans la taskbar ??
-Stock_Calkulin's_Nexus_5_ROM_v1.0+_Kernel.zip=> c'est quoi ??
-franco.Kernel-nightly-r32-Calkulin.zip=> c'est franco r32 modifié ??
Désolé des questions,mais je suis sur de rien !!
snach21
GenActif
GenActif
Appareil principal : Htc10*
ROMs : Viper ***
Appareil secondaire : Desire Hd A-Revolution
: : Stock
Message par Primokorn le Sam 18 Jan 2014 - 22:45
Message par snach21 le Sam 18 Jan 2014 - 23:07
Merci primo, tu est à fond ce soir , tu est partout !!!  cheers  Very Happy
snach21
GenActif
GenActif
ROMs : Viper ***
: : Stock
Message par Primokorn le Sam 18 Jan 2014 - 23:23
Ouais bah je stoppe par contre Very Happy
Bonne soirée Snach Wink
Message par snach21 le Sam 18 Jan 2014 - 23:27
Merci pour tout primokorn, bonne soirée à toi aussi Very Happy
snach21
GenActif
GenActif
ROMs : Viper ***
: : Stock
