[ROM 4.4.2] PLSX - Pure Light Speed X (Hammerhead) [AOSP][18.02.2014]
Message par Primokorn le Mar 18 Fév 2014 - 11:41
Features for PLSX:
Customizeable Auto Brightness (credits to Cyanogenmod)
Native Battery Percent
Customizeable Navigationbar Height
Customizeable Powermenu
Mute annoying Notification Sounds
Quiet Hours
Customizeable Charging LED
Customizeable Notification LED
Buildin Kernel Settings for Fastcharge (if supported by Kernel), Governor , Min and Max CPU Frequency
0,25x and 0,75x Animation speeds
Newest drivers for GPU from Qualcom
A big bunch of optimzations
Kill all recent apps button
Configureable Notification pulldown for QS
Option to disable Safe headset volume warning
Increasing Ringtone
Rotation tile
CM's Launcher 3 Edition
*NEW* Expandable Volume Panel
*NEW* Unlinkable Notification Sound Volume
Features of PSK:
Kernelbase = 3.4.79 (google factory Image = 3.4.0)
Compiled with sabermod gcc 4.8
Fastcharge support
InteractiveX governor
CPU Voltage Control
96MHz min Frequency
*NEW* Gamma Control
hundreds of additional commits for performance and battery optimizations or bugfixes
Welcome to Pure Speed X
PLSX is a fast, lightweight AOSP (4.4.2) Rom with an emphasis on speed and performance. Our goal is to provide unrivaled performance, stability, and a lightweight Rom with a real small and handpicked set of features. We are not, nor ever will be focused on adding every feature out there. We will always be searching for ways to make it faster, more stable, more secure, but PLSX will never be as feature rich as PSX.
Commencez par déverrouiller le bootloader et installer un recovery custom : Déverrouiller bootloader / Recovery / Root puis sauvegardez votre partition EFS.
  1. Placez les fichiers dans le dossier /sdcard
  2. Redémarrez dans le recovery
  3. Faites un NANDROID BACKUP
  4. Faites un FULL WIPE (data+system+cache+dalvik)
  5. Flashez la ROM puis les GApps puis SUperSU
  6. Redémarrez.
Téléchargement v1.0.8
Rom (Mirror @AFH: ICI)
BaNkS GApps (avec GEL-Launcher) ou PSX/PLSX-GApps (avec Launcher3 CM-Edition)
Si vous utilisez Hangouts et avez des problèmes, essayez les PA GApps pour le moment : PA GApps
Mako Only: Hopefully fixed miracast issues
Fixed homebutton issue with gappsless installation
Changed LatinIME from proprietary google version to CM compiled one
bases now on KVT49L with LatinIME Fix
fixed a textbug (rastakat in Build-Name)
added custom sepolicy-stuff that should help with some warning in log regarding permissions and also help with system apps accessing kernel userspace
hammerhead only:some new kernel commits that should fix some internal bugs (memory leaks, dmesg log spam etc.) also there is some fix for a possible kernel panic...
Nexus 5 only: Hopefully fixed the SOD Problems
Nexus 4 only: Added a Wifi patch that will bring more download/streaming speed for some users
Added Expandable Volume Panel
Added Unlink for Notification Volume
fixed a problem with Whatsapp freezing phone under some circumstances
fixed a problem with games like 8balls
(hopefully) fixed a problem with Copilot GPS
fixed wrong dialer icon, is now really KitKat style
Added camera2
Added gallery2
Added CM's version of Launcher3
Kernel is now 3.4.79
A big bunch of kernel tweaks and fixes
Added kernelside Gamma Control
VM Tweaks
added rotation tile
added increasing ringtone
kitkat dialer icon
Hammerhead only: Even more new kernel commits to still optimize it a little (this time it mainly are fixes for low notification sound in some situations)
Option for Disabling Safe Headset volume warning (psxXtras->User Interface)
Option to full disable or select side for Swipe of Notificatiobar to QuickSettings (psxXtras->Bars->Statusbar)
even more speed, more butter.... you know, everythings even smother
Statusbar right Pulldown for QS
A ton of small bugfixes (internal stuff)
Kernel optimized even more (sleeps like a new born baby, less wifi wakelocks, still smoth as fluid butter)
Kernelside memory leak removed (thanks to franciscofranco and cyanogenmod team)
finally the slow flash bug is history
Added kill all recents button
Added a commit that fixes something regarding wifi disconnect/reconnect, maybe it fixes the issue reported here regarding wifi reconnect
Added some commits to framework/base that should even press more extra juice out of battery
Removed the entry for notificationen LED pulse in Display settings
fixed short "blink" of charging led
Added a big bunch of commits to kernel regardings USB,Audio and some other subsystems
Initial Release
• Dirty flash depuis la PSX peut provoquer des problèmes donc full wipe conseillé
• Idem depuis la PSLX-Beta/RC
• Possibles FCs sur les services Play Store ou de localisation au premier démarrage. Ignorez.
ROMs : OmniROM 8.1.0
Re: [ROM 4.4.2] PLSX - Pure Light Speed X (Hammerhead) [AOSP][18.02.2014]
