[THEME][SM-N900X] TWRP Holofied - Black / Dark / Light / Play / XDA [31.03.2014]
3 participants
description[THEME][SM-N900X] TWRP Holofied - Black / Dark / Light / Play / XDA [31.03.2014] Empty[THEME][SM-N900X] TWRP Holofied - Black / Dark / Light / Play / XDA [31.03.2014]
TWRP Holofied
Le mot du créateur du thème Z31s1g :
"Je vous présente le thème pour le Recovery TWRP TWRP Holofied - Black / Dark / Light / Play pour le Note 3 SM-N900X."
Détails :
- Recovery gone App.
- This is a heavily modified version of the theme by thecoby.
- Button labels on all pages are images (looks much nicer than the rendered fonts).
- Almost all images created new from vector source (will be released later on to support porting and allow for easy changes to appearance).
- Designed for 24h clock. To use AM/PM, edit variables in ui.xml, values are included as comment.
- The theme is compatible with TWRP versions up to 2.6.3.0, but encryption page is not functional on versions older than 2.6.0.0.
- Port the theme as much as you like. Second post will soon be updated with some info on this topic.
- You use this theme at your own risk.
Images et Vidéos
[THEME][SM-N900X] TWRP Holofied - Black / Dark / Light / Play / XDA [31.03.2014] OP4
Installation
Pré-requis :
1) Avoir installé le [RECOVERY][SM-N9005] TeamWin Recovery Project
Installation :
1) Téléchargez le fichier .Zip du thème souhaité et renommez-le en ui.zip
2) Dans "/sdcard/TWRP/" créez un dossier "theme" (respectez la casse).
3) Copiez le "ui.zip" dans ce nouveau dossier
4) Testez le thème custom en redémarrant dans le TWRP Recovery
5) Redémarrez et amusez-vous Very Happy
Changelog
31 mars 2014 :
All themes updated
  • Added bookmark function to filelists on "install" and "add zip to queue" pages - default path is set to \sdcard\Download for both lists (all)
  • Added "default settings" icon to actionbar on "settings" and "theme settings" pages (all)
  • Added confirmation dialog for resetting defaults and changing bookmarked folders (all)
  • Added "refresh storage" icon to actionbar on "backup" page (all)
  • Added setting to apply highlight color to progress bar (helps with visibility if highlight color is applied to actionbar/actionabr stripe) (all)
  • Added setting to use old progress bar (below console) (all)
  • Added setting to use light statusbar (matches overall backgroud color) (play)
  • Color of action bar labels changes to white when highlight color is applied to actionbar (light)
  • Color of action bar icons changes to light grey when highlight color is applied to actionbar (black, dark, light)
  • Fixed some dividers not showing on "advanced" page for certain devices (black, dark, light, xda)
  • Fixed some dividers not showing on multiple pages (multirom play)
Anciennes versions :
Spoiler :
Téléchargements
Spoiler :
description[THEME][SM-N900X] TWRP Holofied - Black / Dark / Light / Play / XDA [31.03.2014] EmptyTheme, Samsung, Galaxy, Note 3, SM-N900X, TWRP Holofied, Blac, Dark, Light, Play, XDA
description[THEME][SM-N900X] TWRP Holofied - Black / Dark / Light / Play / XDA [31.03.2014] EmptyRe: [THEME][SM-N900X] TWRP Holofied - Black / Dark / Light / Play / XDA [31.03.2014]
Je les ai déjà vu quelque part ceux là smile
Merci pour le partage.
En attendant d'avoir le Recovery TWRP compatible avec le Note 3, vous pouvez admirez ce thème Very Happy
Déjà testés sur Note 2 Wink
Cool mais nous on peut pas le tester pour le moment Wink
Merci de nous mettre un thème qui ne nous nous concerne pas Very Happy
Il ne serait pas sage de retirer les liens de téléchargement?
Tout comme le sujet du TWRP, ces 2 sujets mettent les membres en danger, j'ai du mal à te suivre.
Peut-être à déplacer en section NOTE2 puisque Primo a testé [THEME][SM-N900X] TWRP Holofied - Black / Dark / Light / Play / XDA [31.03.2014] 60586
Le développeur a sûrement changé les résolutions sinon il n'a pas assez réfléchi smile
Et ils existent déjà dans la section du Note 2 Wink
Pour le TWRP par contre, ça serait bien effectivement.
Espérons que nous soyons entendus Wink
Pourquoi veux tu supprimer les liens de ce thread ?
Ce n'est qu'un thème pour le Recovery TWRP.
Quand au Recovery TWRP, le topic est toujours là mais il n'y a plus de lien, je les ai supprimés en attendant une version compatible avec le N9005.
Donc il n'y a aucun danger pour les utilisateurs.
Je ne veux pas le supprimer, je me demande ce que ça fait là, c'est tout, tout comme le sujet TWRP, étant donné que ça ne nous concerne pas.
Je défie quiconque de flasher ce thème sur le GN3.
Tu as enlevé les liens du recovery TWRP, c'est déjà un grand pas Very Happy  , qu'aurait-on dit à un membre qui aurait flashé le TWRP en le téléchargeant ici? On lui aurait expliqué que le sujet était ici juste pour le plaisir des yeux?
On va en rester là, on n'est pas d'accord, on ne va pas débattre ici. Et la décision te revient, c'est toi le chef.
Mi-temps du match de l'équipe de France:
Pub du GN3 et de la Gear, c'est pas la mi-temps du superbowl mais quand même cheers
Slogan:
Design Your Life
Le thème est dans cette section car il est pour le Note 3 tout simplement Wink
D'ailleurs ce thème se flash via le Recovery TWRP seuleument vu que c'est pour personnaliser le TWRP.
Le sujet TWRP est toujours là car ça ne sert à rien de le supprimer vu qu'une version sortira pour notre modèle donc autant le garder et les liens seront ajoutés quand il seront disponibles.
Le thème et le Recovery auront leurs utilités au moment voulu tu verras, les développeurs vont nous sortir une version pour notre modèle.
Fin du HS
Salut
Je vous confirme que si vous flashez un thème TWRP sans avoir TWRP il n'y a absolument aucun risque car s'installe sur la SD Interne.
De plus ce thème ne se flash pas.
En espérant vous avoir éclairé
Topic mis à jour : Mise à jour du 17 novembre 2013 - TWRP Holofied - Black / Dark / Light / Play / XDA
Ah le coquin ! Il compris pourquoi nous étions publié par XDA sur leur portal et pas lui ... Wink
[THEME][SM-N900X] TWRP Holofied - Black / Dark / Light / Play / XDA [31.03.2014] 180484 Very Happy
Topic mis à jour : Mise à jour du 18 novembre 2013 - TWRP Holofied - Black / Dark / Light / Play / XDA
Topic mis à jour : Mise à jour du 24 novembre 2013 - TWRP Holofied - Black / Dark / Light / Play / XDA
Bonsoir tout le monde,
J'ai voulu tester ce theme.
En l'etat il ne fonctionne pas, car pour l'instant seul un zip flashable fonctionne sur le Note 3
Impossible de coller un fichier dans le dossier theme.
Topic mis à jour : Mise à jour du 07 décembre 2013 - TWRP Holofied - Black / Dark / Light / Play / XDA
Ne fonctionnera toujours pas ...
Salut North,
Bizarre, as-tu remontée l'information au dev ?
Non je ne lui ai pas remonté.
Le problème est qu'il est impossible d'installer ( pour l'instant ? ) manuellement un thème pour TWRP sur le Note3.
Zip flashable obligatoire ...
Ok merci pour l'info, il n'y a pas de retour sur le thread depuis le 09 novembre, il ne le sait peut-être pas.
Je le contacterai demain pour lui remonter l'info.
Topic mis à jour : Mise à jour du 14 décembre 2013 - TWRP Holofied - Black / Dark / Light / Play / XDA
