[ROM] Stocks du Desire S
+5
oussama123
etofun
flo59650
durion62
9 participants
description[ROM] Stocks du Desire S Empty[ROM] Stocks du Desire S
Voilà je me suis pas embêté
j'ai repris le poste de XDA;)
source
RUU_Saga_HTC_Europe_1.28.401.1_Radio_20.28b.30.080 5U_38.03.02.11_M_release
http://www.filefactory.com/file/ca1f...977_signed.exe
RUU_Saga_Orange_UK_1.31.61.1_Radio_20.28b.30.0805U _38.03.02.11_M_release
http://www.filefactory.com/file/ca31...918_signed.exe
RUU_Saga_Virgin_Mobile_1.31.351.1_Radio_20.28b.30. 0805U_38.03.02.15_M_release
http://www.filefactory.com/file/ca31...933_signed.exe
RUU_Saga_H3G_UK_1.31.771.1_Radio_20.28b.30.0805U_3 8.03.02.14_M_release
http://www.filefactory.com/file/ca31...937_signed.exe
RUU_Saga_TMO_DE_1.30.111.1_Radio_20.28b.30.0805U_3 8.03.02.11_M_release
http://www.filefactory.com/file/ca32...580_signed.exe
RUU_Saga_Bouygues_FR_1.31.1020.1_Radio_20.28c.30.0 805U_38.03.02.16_M_release
http://www.filefactory.com/file/ca32...948_signed.exe
RUU_Saga_O2_UK_1.31.206.1_Radio_20.28b.30.0805U_38 .03.02.14_M_release
http://www.filefactory.com/file/ca32...935_signed.exe
RUU_Saga_Vodafone_UK_1.32.161.1_Radio_20.28b.30.08 05U_38.03.02.15_M_release
http://www.filefactory.com/file/ca37...398_signed.exe
RUU_Saga_HTC_Thailand_1.35.1113.2_Radio_20.28d.30. 0805U_3805.04.02.01_M_release
http://www.filefactory.com/file/cbce...327_signed.exe
RUU_Saga_Telstra_WWE_1.36.841.3_Radio_20.28d.30.08 05U_3805.04.02.01_M_release_184558_signed
http://www.filefactory.com/file/cb2e...558_signed.exe
RUU_Saga_FET_TW_1.47.950.3_Radio_20.28I.30.085AU_3 805.06.02.03_M_release_197543_signed
http://www.filefactory.com/file/cc1c...543_signed.exe
RUU_Saga_HTCCN_CHS_1.46.1400.8_Radio_20.28f.30.085 AU_3805.04.02.28_M_release_200195_signed
http://www.filefactory.com/file/cc1c...195_signed.exe
RUU_Saga_HTC_Europe_1.47.401.4_Radio_20.28I.30.085 AU_3805.06.02.03_M_release_199410_signed
http://www.filefactory.com/file/cc7c...410_signed.exe
RUU_Saga_hTC_Asia_WWE_1.48.707.1_Radio_20.28I.30.0 85AU_3805.06.02.03_M_release_199476_signed
http://www.filefactory.com/file/cc72...476_signed.exe
RUU_Saga_HKCSL_CHT_1.47.832.1_Radio_20.28I.30.085A U_3805.06.02.03_M_release_199606_signed
http://www.filefactory.com/file/cc94...606_signed.exe
description[ROM] Stocks du Desire S EmptyRe: [ROM] Stocks du Desire S
J'ai une question je recherche la derniere rom officiel d'htc sans surcouche operateur... ici je vois 2 roms europe laquelle dois je prendre ? 1.28 ou 1.47?
j'ai entendu dire que la derniere version serai android 2.3.5 est ce quelle est deja dispo ?
Ps / sur un autre forum j'ai trouver cette rom RUU_Saga_S_HTC_Europe_2.10.401.8_Radio_20.4801.30.0822U_3822.10.08.04_M_release_225161_signed ?
Est ce la derrniere ?
Pour info ca serais la derniere version RUU_Saga_S_HTC_Europe_2.10.401.8_Radio_20.4801.30.0822U_3822.10.08.04_M_release_225161_signed
Ce trouvant ici http://www.filefactory.com/file/cf238df/n/RUU_Saga_S_HTC_Europe_2.10.401.8_Radio_20.4801.30.0822U_3822.10.08.04_M_release_225161_signed.exe
Bonjour voici un lien que j'ai trouver sur le net ou toute les roms sont a jour http://www.filefactory.com/f/c64d333a2755a421/
bonjour je cherche une rom original ruu de l'operateur swisscom merci
htc desire s
***locked***
***security warning***
saga pvt ship s-on rl
hboot-2.00.0002
radio-3822.10.08.04_m
emmc-boot
aug 22 2011, 15:22:13
HTC Desire S
bonjour je cherche une rom original ruu cid: HTC__Y13
c est quoi ces liens qui nous mene nulle part ou alors sur un site ou il faut payer
bonjour à tous
je suis tombé sur ce post car je recherche une RUU VODAP 203 pour downgrader mon désire s qui est en version 2-10-401-9 et hboot 2.000002 j'ai éssayé la 1.28 et la 1.47 et j'ai un code 131
merci de vos réponses
As tu essayé les tuto sur XDA pour le downgrade du htc desire S
En effet, je ne trouve pas de trace de la rom que tu recherches
oui j'ai regardé mais rien de plus mais peut-on vérifier si la ruu correspond au cid avant de la télécharger?
oui tu peux tu ouvres le zip du Ruu avec 7zip et dedans tu ouvres le fichier android.txt dans lequel tu dois pouvoir trouver les Cid ...
bonjour et merci de ta réponse
j'ai éssayé avec 7ZIP mais il n'y a pas de fichier android.txt
il faut peut- etre lancer le RUU, si oui dans quel dossier il s'exécute?
C'est un Ruu en zip ou en exe?
c'est un fichier exe mais je souhaiterais le lancer via le bootloader en rebootant sinon ça ne marche pas si tu as une autre solution je suis preneur
Lorsque tu vas lancer l'exe il va créer dans un répertoire temporaire sur ton PC un zip qui va lui être flashé sur ton appareil , il faut donc trouver ce répertoire temporaire pour trouver le zip qu’il faudra ouvrir avec 7zip pour lire le fichier android.txt et vérifier les cid autorisés...
C'était expliqué dans un tuto quelque part sur le forum mais où? (c'était il y a longtemps Rolling Eyes )...
c'est vrai je comprends c'est vieux je vais rechercher une nouvelle fois
En fait quand tu lances le RUU il te pose plusieurs questions et je ne sais plus quand tu attends pour aller voir dans les fichiers temporaires ou se trouve le zip...
j'ai réussi à trouver le fichier et installer sur laracine en le renommant PB99IMG- zip et redémarrer mais aucun résultat il ne reboot pas sur la rom, faut-il être unlock?
Non pas d'unlock pour flasher ce type de fichier (Ruu en zip).
Tu n'as eu aucun message d'erreur?
non aucun message
Est-ce que tu peux essayer de le re-flasher et faire une capture de tout ce qui s'inscrit dans la fenêtre de commande?
oui je peux faire ça
Wait and see Wink
voilà la chose.
C:\downgrade>adb push zergRush /data/local/tmp
* daemon not running. starting it now on port 5037 *
* daemon started successfully *
562 KB/s (23060 bytes in 0.040s)
C:\downgrade>adb push misc_version /data/local/tmp
1227 KB/s (367096 bytes in 0.292s)
C:\downgrade>adb shell chmod 777 /data/local/tmp/zergRush /data/local/tmp/misc_v
ersion
$ cd /data/local/tmp
cd /data/local/tmp
$ ./zergRush
./zergRush
[**] Zerg rush - Android 2.2/2.3 local root
[**] (C) 2011 Revolutionary. All rights reserved.
[**] Parts of code from Gingerbreak, (C) 2010-2011 The Android Exploid Crew.
[-] Cannot copy boomsh.: Permission denied
$ adb shell
adb shell
adb: permission denied
$ chmod 755/data/local/tmp/zergRush
Usage: chmod
$ rm /data/local/tmp/boomsh
$ rm /data/local/tmp/sh
$ /data/local/tmp/zergRush
[+] Found a GingerBread ! 0x00000118
[*] Scooting ...
[*] Sending 149 zerglings ...
[+] Zerglings found a way to enter ! 0x10
[+] Overseer found a path ! 0x000171e0
[+] Zerglings caused crash (good news): 0x401219c4 0x0054
[*] Researching Metabolic Boost ...
[+] Speedlings on the go ! 0xafd19ddb 0xafd39ef7
[*] Popping 24 more zerglings
[*] Sending 173 zerglings ...
[+] Rush did it ! It's a GG, man !
[+] Killing ADB and restarting as root... enjoy!
# /data/local/tmp/misc_version -s 1.27.405.6
--set_version set. VERSION will be changed to: 1.27.405.6
Patching and backing up misc partition...
# exit
exit
C:\downgrade>
