[ROM 6.0.1] Slim6 SlimRoms Marshmallow [Hammerhead]
5 participants
description[ROM 6.0.1] Slim6 SlimRoms Marshmallow [Hammerhead] Empty[ROM 6.0.1] Slim6 SlimRoms Marshmallow [Hammerhead]
Slim6
Slim6, bsé sur Marshmallow 6.0.1, commence ! Slim6 en est à ses débuts donc soyez patients pour voir vos fonctionnalités favorites arrivées
Fonctionnalités :
► DPI Changer
► SlimLauncher
► Root access
Liens importants
Site web
Téléchargement ROM
Support
Installation
Commencez par déverrouiller le bootloader et installer un recovery custom : Déverrouiller bootloader / Recovery / Root
  1. Placez la ROM et les GApps dans le dossier /sdcard
  2. Redémarrez dans le recovery
  3. Faites un NANDROID BACKUP
  4. Faites un FULL WIPE
  5. Flashez la ROM puis les GApps
  6. Redémarrez.
Images
[ROM 6.0.1] Slim6 SlimRoms Marshmallow [Hammerhead] SlimBeanOP2
description[ROM 6.0.1] Slim6 SlimRoms Marshmallow [Hammerhead] Emptyslimbean slim rom, rom custom n5, hammerhead rom, android kitkat rom nexus
description[ROM 6.0.1] Slim6 SlimRoms Marshmallow [Hammerhead] EmptyRe: [ROM 6.0.1] Slim6 SlimRoms Marshmallow [Hammerhead]
Mise à jour : Slim-hammerhead-4.4.alpha.1.1-UNOFFICIAL-20131113-1159
Changelog
advanced Auto brightness configuration
start music player when head set is connected
add back full blacklist support
add back increasing ring feature
add back call stats features
add back multiline notification for missed call
add back in call vibration
add back browser history page
add back advanced low battery indicator
add back notification shortcut feature
add back battery icon customization the new way
several fixes for sprint network apns
a lot small fixes again
Nouvelle build ce jour
- one for the guys which use accessability service and had fc on lockscreen targets
- as well when I was on it I added accessability instructions for ppl which need to use talkback...so that the phone tells you what to do on lockscreen...means it says...swipe to access a toggle......tells you the name of the shortcut you added etc.
- fix for the checkbox does not stick on longpress lockscreen shortcuts
- percentage battery turns now red when it is under 14%
- battery with percentage shows under 14% now text and not the "!"
Mise à jour et passage sous 4.4.1
Mise à jour bêta 1.6 sous Android 4.4.2... On va tester tout ça smile
Beta 1.9 dispo avec un beau changelog !
    BatteryService: fix FC on boot until battery stat is present
    National roaming info for yesss! in Austria
    PhoneWindowManager: fix navbar behaviour in expanded mode after 4.4.2 merge.
    systemUI: split the broadcast receiver in phonestatusbar
    GlobalActions: collapse all panels if global action is shown
    fb: small cleanup and fixes in navbar transitions
    WindowManagerService: fix application transitions in expanded mode.
    Base: Stylus Gestures
    Base: Toggle Stylus Pointer Icon
    fb: TRDS 3.0 and new theme engine preparation
    fb: add theme switch (TRDS) to navbar and navring
    QS: add theme switcher tile (TRDS)
    fb: add ticker entries only if we are not recreating statusbar
    Keyguard: disable statusbar clock for dashclock, lockclock and desclock
    SystemUI: Add double tap to sleep gesture
    Framework: Change stock Clock-Click Actions
    Keyguard: let the user drag the challenge down if widgets are disabled
    Add an option/category in Dev Set to customize the device hostname
    Framework: Fix QuietHours Vibrate
    Fix Immersive confirmation in expanded mode.
    Fix ResTable_config::CONFIG_* typo (MCC vs MNC)
    base: added national roaming info for Pepephone in Spain
    National roaming info for 3 in Ireland
    fb: lock statusbar recreation and release after ticker is done
    fb: use SlimActions for torch tile and send as qualified user
    Camera: don't display picture size unless supported
    Camera: Add ZSL support for Samsung/Qualcomm cameras
    Camera: Fixes Mako continues focus problem
    Camera: Fix Smart Capture label display
    Camera: TrueView Returns!
    Torch: Don't show variable brightness options when using the camera iface
    Torch: make torch to a real system app
    Torch: add better error handling and added fallback mechanism
    Settings: enable/disable lockscreenwidgets preferences
    Settings: One does not simply become a Developer
    Settings: add Device on Advanced Options for device-specific settings
    Settings: fix quickpulldown summary and clean up code
    Native: sensorservice: Fix init sequence for pre-1.1 API sensor HALs
    Native: libs/ui: Fix crash issue because of null pointer access
    Native: surfaceflinger: Set max acquired buffer count
    Native: GlES2: Add NULL check
    Native: sf: work around for no EGL_RENDERABLE_TYPE support
    Telephony: Fix NT_MODE case statements
    hungarian translations - Thanks to Zoltan
    spanish translations - Thanks to Carlos
    turkey translationgs - Thanks to docHD
    Tons of fixes and upstream on all devices
    and a lot lot more
Bêta 1.95 dispo
La bêta 2 est de sortie
    Settings: handle stylus options only on full language settings
    Settings: WiFi: Add forget all networks
    Settings: Wrong referring to the resource - id/android:id
    Settings: Fix switching running/cached apps with memory bar
    Framework: QuickRecord Tile (1/2)
    Framework: TRDS: Dark DocumentsUI
    Framework: Fix one and hide the other warnings from core/jni
    Framework: Don't try to set service.bootanim.exit
    Framework: Use java.util.Objects instead on internal API
    Framework: Fix to NullPointerException on move back in ActivityStack.
    Framework: Clean up native AlarmManagerService tabs/spaces and unused parameter warnings
    Framework: Don't pseudolocalize untranslatable strings.
    Framework: Fix improper declaration/use of pointer.
    Framework: Keydispatching timeout while finish Activity
    Framework: Framework: Chamber of Secrets (1/2) [WIP]
    Framework: Option to use volume keys to control media volume anytime [1/2]
    Framework: QS: Fix on tablets at first boot up wrong orientation detection if landscape
    Framework: BroadcastReceiver : Get sender of broadcasts
    Framework: Pick default interface for upstream.
    Framework: aapt: Support for mxmf file playback
    Framework: When DPM is updated while lock screen is inhibited, don't unconditionally ...
    Framework: Ringtones: Fix ANDROID_LOOP=true for ArgoNavis and Perseus ringtones
    Framework: Correct executable bit for source files
    Framework: wifi: Fix StringIndexOutOfBoundsException for incorrectly encoded SSIDs
    Framework: Remove unnecessary updateSurfaceScreenOn call.
    Framework: ServiceState: add support for DCHSPAP
    Framework: bootanimation: performance/speedup enhancements
    Framework: PackageManager: Restrict system packages to protected storage
    Framework: Wi-Fi: Ping the driver for wifi-only devices
    Framework: ActionBar: Compute required items prior to optional items
    Framework: GlobalActions: Fix possible race condition when showing dialog.
    Framework: fb: after fixing the root cause remove implemented lock
    Framework: wifi: Set the mode at native layer
    Framework: IPV6 tethering: Check info for null before removeUpstreamV6Interface
    Framework: base: IPV6 tethering support
    Framework: fb: TRDS some tweaks and fixes (1/2)
    Framework: Keyguard: do not show maximized on simpin and several fixes
    Framework: Media: Add quality levels for two 4k resolutions for camcorder
    Framework: Camera: Add support for QC camera features.
    Framework: input: Add workaround for broken hardware keyboard support
    Browser: Set slimroms.net as default home page for browser
    Browser: Add Website Settings as valid fragment
    Download: Open images with content://media/ instead of content://downloads/ URI.
    Download: Clear notifications for Deleted items from Download list
    vold: Extract UUID and label from inserted volumes.
    vold: Handle missing UUID/LABEL from blkid.
    vold: mount ext4 with forced SELinux context
    vold: force SELinux context only for sdcard
    vold: minivold: adjustments for vold in recovery
    vold: allow non-vfat devices to be used as ASEC
    vold: support more than 1 UMS share
    vold: pass selinux context to ext4 mount (remount ro)
    vold: Raise MAX_PARTITIONS to 32
    vold: Initialize flag variables
    vold: Clean up ASEC unmounting on physical storage.
    vold: Use correct minor device number to format SD card
    DashClock: fixed text color in advanced settings (trds off)
    Email: TRDS: Dark Slim File Manager
    Email: TRDS:[Email] Dark Email (1/2)
    Email: TRDS:[UnifiedEmail] Dark Email (2/2)
    Email: Add missing "Notify for every message"...
    Email: Add new check frequency options (2h, 4h & 1 day)
    libcore: Allow multiple gzip members in gzip streams.
    libcore: Replace "mips" with "mipmaps" since the MIPS gcc compiler defines mips to 1.
    libcore: Move DeleteOnExit to libcore.io.
    native: added null check and remove EGL fallback
    native: go back to default heap sizes
    native: Revert "SensorEventQueue: Allow setRate on sensor enable"
    SlimCenter: add reboot dialog to SlimDeleter
    Telephony: Could not enable data connection
    Telephony: DcTracker: Fix CDMA APN Data issues.
    Telephony: check if the provisioning apn is actually empty before
    telephony: Add Qualcomm42RIL
    Telephony: SMSDispatcher: Fix determining the defaultSmsApp for proxied messages
    Telephony: CdmaLte: Fix 3G reported as unknown on certain devices
    Telephony: Properly handle a null URI.
    Telephony: CdmaLte: call setDataRegState when using RilVoiceRadioTechnology for data
    Telephony: SamsungCDMAv6RIL: update to latest RIL
    Recovery: Support custom graphics.c.
    LatinIME: fix crash on voicetyping
    LatinIME: Bring back ALL the keys for QWERTZ
    LatinIME: Added smiles without noise to AOSP keyboard
    Mms: remove duplicate "send" option in menu
    Mms Bubbles
    Mms: Clean up delivery report dialog.
    Bluetooth: Allow sending apk files to remote device
    Camera2: starting camera from scratch based on AOSP 4.4.2 camera and partly the work from CodeAuroraForum to have better support across all devices and to get a lot ehancements compared to the stock one. Based on this following commits were added.
    Camera2: Revert "Camera: Propagate power mode selection from UI to lower layers."
    Camera2: Cleanup and compatibility fixes
    Camera2: Remove the luma-adaptation seekbar
    Camera2: Add all resolutions, focus modes, scene modes, and color effe…
    Camera2: Fix CameraRootView layout size on tablets
    Camera2: Disable wavelet denoise by default
    Camera2: Support for HTC's HDR mode
    Camera2: fix panorama preview on older devices
    Camera2: enable antibanding by default
    Camera2: check for video size available
    Camera2: Preview needs to be stopped when changing resolution
    Camera2: revert CodeAurora's panorama angle handling
    Camera2: fix preview for landscape devices
    Camera2: fix aapt warnings + correct strings.xml
    Camera2: roll back UI menu changes from CAF
    Camera2: add Smart capture
    Camera2: Add a GPS indicator
    Camera2: enable color effects Settings in UI
    Camera2: finish Settings in new google style
    Camera2: follow new 4.4 UI guidelines
    Camera2: add proper lable for screen capture on video mode
    Camera2: update to new 4.4 KitKat UI
    Camera2: added needsEarlyVideoSize
    Camera2: Add Samsung camcorder mode
    Camera2: fix scene mode crash
    Camera2: Add red-eye flash mode support
    Camera2: enable jpeg quality setting and add video jpeg quality
    Camera2: seperate color effect settings camera and video
    Camera2: don't display picture size unless supported
    Camera2: TrueView Returns!
    Camera2: set default video quality back to 5 and code style cleanup
    Camera2: enable focusmode settings UI
    Camera2: enable ISO mode settings to new UI
    Camera2: remove fine/normal/superfine jpegquality and use always int
    Camera: Avoid animating cature with decoded jpeg in long shot
    Camera: Overrides the focus mode for ZSL
    Camera2: set focusmode default always to auto
    Translations overall packages
    tons of device commits (see changelog in download folder for specific information)
    tons of small fixes here and there
Bêta 2.1 dispo
Beta 2.3
Vendor slim: relabel dalvik-cache and wpa_supplicant correctly
Vendor slim: get rid of compcache and zram
Vendor slim: push up xxhdpi dpi to 370
Vendor slim: Reorder FarEast APN
Vendor slim: Fix internet APN for Life:) provider.
Vendor slim: Fix Dialog Mobile Broadband MMS APN
Vendor slim: Fixed mmsproxy for Mobinil MMS
Vendor slim: Added APN entry for Etisalat Egypt
Vendor slim: Fix TIM Brasil APN
Vendor slim: Fix Giffgaff APN
Vendor slim: Add OVIVO APNs
Vendor slim: Fix Telenor DK MMS APN
Vendor slim: Add b-mobile APN
Dialer: Consistent white dialer
Dialer: trds: dialer update
In-Call: UI from blue to white
Mms: improved mms bubbles
Native: Update HWUI config for xxhdpi/2GB devices
Settings: recover last location state during on/off switch
Settings: Apn settings fixes / code maintainence (1/2)
Settings: Fix FC when trying to adjust radio band via *#*#4636#*#* dialer code.
Settings: Always show band 0
Settings: fix exception in BatterySipper.getQuickNameIconForUid
Settings: Dont show "Erase SD Card" when there is none
Settings: Address adb backup/restore denials.
Settings: Fix elapsed time formatting.
Settings: reorder app security to top
Settings: Bluetooth: Set alias name only through Rename option
Settings: Bluetooth: Don't set a null alias before unpairing
Settings: Fix null pointer exceptions in NetworkPolicyEditor
Nfc: Fix NPE in RegisteredAidCache
Camera2: notify the gallery that camera storage path was changed
Camera2: add ability to call needAutoFocusCall when using continuous picture
Camera2: fix power key shutter default behaviour
Camera2: move back out as privileged app
Gallery2: Storage configuration options gallery side (2/2)
Gallery2: Fix invalid private access.
Gallery2: jni: fix C99 inline linking
Art: Fix NewLocalRef, NewGlobalRef to handle cleared weak globals.
DownloadProvider: DownloadProvider: don't allow backups.
DashClock: Fix plurals on gmail and calendar selection
Browser: Remove Incognito mode from quick controls since it no longer exists in the ...
Bluetooth: Fix bluetooth phonebook sync problems on some car kits
DeskClock: Provide compatibility to existing AlarmClock shortcuts.
DeskClock: trds: fixed bottom bar color
Torch: move back out as privileged app
System core: healtd: Send messages to Android log, not the kernel log
Frameworks: services: don't clear wallpaper when SystemUI disconnects.
Frameworks: fix remaining blue dialog dividers
Frameworks: Sleep Screen Shortcut
Frameworks: QS: let's welcome LocationTile to 4.4
Frameworks: SystemUI: Add LongClick SwitchButton (1/2)
Frameworks: trds: consistent glow for menu dropdown and popup
Frameworks: privacyguard: Share privacy package name between activity stacks
Frameworks: Check for homeAsUp status when collapse actionbar widget
Frameworks: fix possible NPE on power key handling
Frameworks: Revert "Fix a bootloop problem when /data/system/usagestats/usage-history.xml...
Frameworks: Fix broken XML parsing idiom.
Frameworks: XmlUtils#readThisMapXml should handle null keys.
Frameworks: Fix appwidgets not updating
Frameworks: Fix blacklist support
Frameworks: Prevent nullPointerException by updateBondedBluetoothDevices
Frameworks: NPE in SearchManager.triggerSearch
Frameworks: Swap volume buttons when the screen is rotated by 90 or 180 degrees
Frameworks: Show confirmation for deleted screenshot.
Frameworks: Add same named operator configuration for some operators
Frameworks: Fix a variety of small publicly-reported bugs.
Frameworks: Prevent MediaScanner infinite loop with invalid path
Frameworks: Memory leak: parseObbFile.footer
Frameworks: fix possible buffer overrun and memory leak
Frameworks: CompoundButton: Let text can be changed by config
Frameworks: Re-initialize error after attach
Frameworks: WifiState: Don't aquire transitionwakelock in airplane mode
Frameworks: Revert "Fix for Concurrency issue reported in 525529"
Frameworks: Use highp precision for scaled coordination
Frameworks: NetworkPolicy: Validate policy templates before updating
Frameworks: Clear the scan list when an empty list is received
Frameworks: wlan: Error handling on PNO failure due to active P2P session.
Frameworks: Close sockets on wpa_supplicant termination.
Frameworks: add app launch timeline instrumentation
Frameworks: wlan: Fix for delay in PNO scan trigger after p2p disconnect.
Frameworks: get proper obb mountpoint based on user handle
Frameworks: Framework: Minimum Vibration Duration (1/2)
Frameworks: StatusBarWindow: Fix collapse using Back button
Frameworks: Keyguard: smooth background change derp fixes
Frameworks: Revert "SystemUI: update internal state right after hiding transient bars."
Frameworks: PhoneStatusBar: fix massive surface redraws due to animation race
Frameworks: UsbDebuggingManager: Fix multiple NPEs toggling USB debugging
Frameworks: Don't rely on gcc extensions
Frameworks: Fix memory leak in PatchCache
Frameworks: Add explicit close of Scanner input
Frameworks: fix multiuser bug in vibrator service
Frameworks: add config.xml option to permanently force permanent menu key
Frameworks: SystemUI: add permission.CHANGE_NETWORK_STATE.
Frameworks: Add Long-Click to Preference Tile
Frameworks: Custom Tiles
Frameworks: QS: no need to rebuild the complete QS on orientation change
Frameworks: SystemUI: Always show translucent decor on recents panel
Frameworks: make QS again rtl aware
Frameworks: QS: fix wrong measurement on 4 or 5 tiles per row on settings panelview
Frameworks: Fix fatal exception due to missing looper for current thread.
Frameworks: Cursor leakage due to cancellation signal
Frameworks: Fix visibility of multiple non-fullscreen activities.
Frameworks: Fix a JNI local reference leak in MediaDrm
Frameworks telephony: do only run setCellInfoListRate for RIL version >= 8 old ...
Frameworks telephony: Fix typo
Frameworks datetimepicker: trds: darker time picker
Build: qcom_utils: Update list of QCOM_BOARD_PLATFORMS
Build: Fix cflags for QC targets
Bionic: libc: Unbreak build for scorpion
Telephony/InCallUI/Dialer: Remove non intrusive incall ui
Telephony/InCallUI/Dialer: Add Incoming Call in Background
Telephony/InCallUI/Dialer: Flip to Mute/Reject Call
Telephony/InCallUI/Dialer:add decline and answer incoming call action on notifications
Frameworks AV: tons of upstream in caf branch for caf based devices
And as usual lots of device fixes, upstreams and ehancements on device and kernel level
beta 2.5 RC1 sortie
SlimKat 4.4.2 build.2.5.RC1
Hey guys,
We have finally removed the beta tag and Jenkins is in the process of building the new weekly builds. We are not far away from first stable release so this weekly will be tagged as RC1. Thanks to all of the users and testers that made this possible!!!!!!
This week we had 2 main aims. Firstly to iron out all of the small bugs which were present in preparation to go soon stable. Secondly to add back one of the important missing features that a lot of users have been requesting and asking why we hadn't merged yet when other ROMs had and that is Hardware key rebinding. The reason was very simple. The code and feature which we and all other ROMs have been using for about 2 years was nice but not that what we wanted to have with 4.4.2. So we decided to recode it completely in a more flexible, more centralized, less resource heavy way without affecting all of the non hardware key devices and with some nice enhancements of course.
DashClock also got some major updates mainly to tweak the UI even more.
ATTENTION: You need to update this week your gapps!!!!!!
Note: If you have no backup accounts visible in  "Settings -> Backup and Security" after a fresh install just reboot and it will show up. It is due to a problem with googles native GoogleBackupTransport.apk control.
bonsoir,
merci pour la maj(la suis de pres celle ci,c'est encore celle que JE preferes)
Pour moi c'est la plus complete en personalisation,aucun fc,fluide,en francais, en plus il est vrai que je la suis depuis un moment et la connait bien.
Pour ceux qui l'apprecie vous pouvez lui mettre des themes bien a elle avec xposed
vous prenez le module : https://skydrive.live.com/redir?resid=FA6983CE87583207!246&authkey=!AKP9V3zuCTHyvnw&ithint=file%2c.apk
et vous mettez les themes de votre choix : http://d-h.st/users/kroz/?fld_id=30798#files
tout sa compilé avec le kernel franco,c'est de la balle
Bonsoir je la prends et testerai sa demain Wink
@snach
tu as tester?
en tout cas si vous avez besoin d'infos sur cette rom ,n'hesitez pas
Bonsoir,oui mais pas fan !!!
je reste sur vanir et cataclysm (de coeur)
Beta 2.6 RC2 dispo Very Happy
bonsoir,
pour ceux qui veulent des themes et puisqu'il n'y a pas de theme chooser,vous pouvez avec le module xtheme engine et avec le framework xposed prendre tout pleins de theme ici: http://forum.xda-developers.com/showthread.php?t=2516001 ou la: http://d-h.st/users/proseray et biensur celui de primokorn http://forum.xda-developers.com/showthread.php?t=2427724
Le mien, ça fait un moment qu'il n'est plus à jour côté XTheme par contre. Wink
Mise à jour importante avant la stable smile
Il manque encore la gestion des thèmes sinon elle tourne très bien et elle porte bien son nom smile
Salut, si c'est la même base que celle de El liberator, la fonction thème n'est pas prêt d'être intégrer
Beaucoup de fonction on était enlever depuis les dernières maj, je dis ça, si on parle bien de la même version, sinon n'en tenais pas compte
C'est qui El liberator ?... Un membre de la team Slim ?
Je l'avais testée cette Slim il y a quelques semaines et les fonctionnalités se sont plutôt accrues smile
"El liberator" doit surtout prendre des sources Slim non ? Very Happy
Oui je pense, pour les sources, sur frandroid il partage Wink
Ah ok, j'ai vu. Ce n'est pas vraiment une SlimXXX ça smile
