SPB Mobile Shell
Version 3.5.5 du 08 Juin 2010
![[SOFT] SPB MOBILE SHELL 3.5.5 - Environement graphique [Payant] Descri10](https://i.servimg.com/u/f11/13/31/83/09/descri10.png)
SPB Mobile Shell introduit la prochaine génération d'interface utilisateur tout en conservant tous les avantages des périphériques Windows Mobile. Continuez à apprécier votre Pocket PC !
![[SOFT] SPB MOBILE SHELL 3.5.5 - Environement graphique [Payant] Screen10](https://i.servimg.com/u/f11/13/31/83/09/screen10.png)
![[SOFT] SPB MOBILE SHELL 3.5.5 - Environement graphique [Payant] 100](https://2img.net/h/www.spbsoftwarehouse.com/uploads/images/mobileshell/Screenshots/3.5/100.png)
![[SOFT] SPB MOBILE SHELL 3.5.5 - Environement graphique [Payant] 200](https://2img.net/h/www.spbsoftwarehouse.com/uploads/images/mobileshell/Screenshots/3.5/200.png)
![[SOFT] SPB MOBILE SHELL 3.5.5 - Environement graphique [Payant] 300](https://2img.net/h/www.spbsoftwarehouse.com/uploads/images/mobileshell/Screenshots/3.5/300.png)
![[SOFT] SPB MOBILE SHELL 3.5.5 - Environement graphique [Payant] 400](https://2img.net/h/www.spbsoftwarehouse.com/uploads/images/mobileshell/Screenshots/3.5/400.png)
![[SOFT] SPB MOBILE SHELL 3.5.5 - Environement graphique [Payant] 500](https://2img.net/h/www.spbsoftwarehouse.com/uploads/images/mobileshell/Screenshots/3.5/500.png)
![[SOFT] SPB MOBILE SHELL 3.5.5 - Environement graphique [Payant] 102](https://2img.net/h/www.spbsoftwarehouse.com/uploads/images/mobileshell/Screenshots/3.5/102.png)
![[SOFT] SPB MOBILE SHELL 3.5.5 - Environement graphique [Payant] Change10](https://i.servimg.com/u/f11/13/31/83/09/change10.png)
Version 3.5.5 (June 08, 2010):
* 320x480 resolution supported
* Fix: sometimes filtering and sorting in the Task widget didn't work
* Fix: it wasn't possible to restore settings from a file larger than 96K
* Other miscellaneous bug fixes and optimizations
Version 3.5.4 (May 14, 2010):
* Changes in the Internet search widget
* Fixed a couple of issues around logging into Facebook and Twitter
* Backlight support for new devices
* Other bug fixes and optimizations
What's new in Spb Mobile Shell 3.5.3:
· OpenGL ES 2.0 support in SPB Carousel
· Windows Mobile 6.5 icons support
· Miscellaneous bug fixes and optimizations
What's new in Spb Mobile Shell 3.5.2:
· Fixed issue with SMS opening on HTC HD2
· Fixed issue with alarms on HTC HD2
· Fixed issue with settings opening on HTC Windows Mobile 6.5 devices
· Backlight support for new devices
· Added a possibility to send MMS from an unnamed calllog entry
What's new in Spb Mobile Shell 3.5.1:
· Fix: SPB Pocket Plus close button makes Shell unresponsive
· Fix: Set Ringtone doesn't work for Contacts
· Fix: Added current conditions threshold for weather widget
· Fix: Agenda: One day is shown twice, 25 осt date is the transition to \"winter\" time
· Fix: 3D SMS viewer: First word disappears after enter
· Fix: Twitter issues fixes
· Fix: Kinetic scrolling doesn't stop on Asus P565
· Fix: 3D SMS viewer: Picture is absent
· Fix: 3D viewer: Date isn't shown for SMS and Email
· Fix: 3D email viewer: First account always shows
· Fix: Birthday widget doesn't update itself when contact info is changed
· Fix: New filter category is available only after MS restart
· Fix: Task widget makes task synchronization with Outlook longer
· Fix: Appointment list can become empty
· Feature: introduced default action for weather widget (now choose between \"Open forecast\" and \"Open conditions\")
What's new in Spb Mobile Shell 3.5:
New widgets:
· Tasks
· Picture frame (widget and fullscreen slideshow)
· Facebook status
· Twitter status
· Birthdays reminders
· Four instant wireless switches (WiFi, Bluetooth, Flight Mode, and Phone Switch)
· Internet search
· Operator's name
· Date
· Alarm
Updated widgets:
· Contact: ability to choose the default action
· Wireless manager: icon shows current states, and popup shows current states
· Weather: support for more advanced skins with detailed forecast and current weather conditions
· 3D email and SMS viewer
· Access to online catalog in the \"Change Background\" dialog box
· Streamlined background change (with cropping and easy to view local gallery)
· Current weather conditions (in addition to forecast)
· Gravity sensor support in the 3D carousel
· Improved 3D carousel design (e. g. added reflections)
· New \"Add Widget\" dialog
· Widget skin selection with preview
· New skins for most widgets
· Widget-based Professional home
· Option to have only one home screen (lifestyle or professional)
· Option to change the number of screens in lifestyle or professional layouts
· Weather in Agenda
· Tactile feedback on tap-and-hold
· Option to choose the default tab for Contacts and Launcher
· Improved design of most dialogs (popup menus, settings, etc.)
· Category filter in the contact list
· Improved widget edit mode (widget can be dragged to other pages, recycle bin for easy delete etc.)
· Color themes support on Windows Mobile 6.5
· Integration with SPB Weather and SPB Traveler via widgets
· Improved \"Choose Shortcut\" dialog box with similar look to SPB Menu
What's new in Spb Mobile Shell 3.0.1:
· Saving unknown phone numbers from the call log added
· Showing/hiding SIM contacts added
· “Show Today” widget implemented
· “Remove All” option in call log added
· Performance of portrait/landscape switching improved
· Some issues with “Edit Profile” dialog box on Treo devices fixed
· Contact matching in call log improved
· Performance of hardware accelerated carousel improved
· Other minor bug fixed
What's new in Spb Mobile Shell 3.0:
· Widgets (Lifestyle Home Screen)
· Facebook integration
· 3D carousel
· Widget-based photo contacts
· Finger friendly agenda view
· Call log
· Finger friendly profile editor
· Ringtone management
· Management of contact photos (crop, rotate etc.)
· Work as a home screen
· Media Player widget
· Wireless Manager
· New launcher
· 3x3 phone menu is back
· Finger friendly settings
· Kinetic scrolling everywhere
· Email indicators for individual email accounts
· Improved task manager
· Back/Restore settings
What's new in Spb Mobile Shell 2.1.5:
· Improved Weather Support
· Backlight support for some new devices
What's new in Spb Mobile Shell 2.1.4:
· Fixed an issue with calendar on HTC Touch HD and Samsung Omnia
What's new in Spb Mobile Shell 2.1.3:
· Fixed bug with drop down boxes on HTC Touch HD
What's new in Spb Mobile Shell 2.1.2:
· Option to show all day events
· Option to hide \"free\" events
· Fixed compatibiblity issues with some custom skins
· Fixed Palm Treo 800w compatibility issues
· Reduced sensivity of closing gestures
· Other minor bug fixes
![[SOFT] SPB MOBILE SHELL 3.5.5 - Environement graphique [Payant] Telech10](https://i.servimg.com/u/f11/13/31/83/09/telech10.png)
SPBMS 3.5.5
![[SOFT] SPB MOBILE SHELL 3.5.5 - Environement graphique [Payant] Autres10](https://i.servimg.com/u/f11/13/31/83/09/autres10.png)
Trucs & Astuces :
En FR (moins complet):
[UTILE] SPB Mobile Shell 3 : Trucs&Astuces, Thèmes, Plug
En UK (plus complet)
Trucs & Astuces :
[UTIL] SPB Mobile Shell 3.5 [Tricks, Widgets, Themes, Other, FAQ, Config]
Ce thread existe aussi pour la 3.0.1 (sait-on jamais)
[UTIL] SPB Mobile Shell 3.0.1 [Tricks, Widgets, Themes, Other, FAQ, Config]
Aussi disponible dans la
Sinon, uploadez le
Spoiler :
New widgets:
· Tasks
· Facebook status
· Twitter status
· Internet search
· Operator's name
· Date
· Alarm
Updated widgets:
· Weather in Agenda
· 3D carousel
· Call log
· Wireless Manager
· New launcher
SPBMS 3.5.5
Trucs & Astuces :
Trucs & Astuces :
