[ROM 4.0.3/XXLP5] [13-04-12] MIDNOTE 3.3 Codename "B&G" (LP5 ICS FULL Working and ITALIAN QUALITY)
+35
elfrager
laigle1968
doudou2106
ninotymi
yamrr1
brolee93
jejehtc
slinrob
guict
alexd83
lechat33
franzel
HTC EVO 3D
vinc62
sudoku
davfunk
enzo43162
djadja
Laxandre
Dikkenek
mike_du_51
Gizmodu74
cscscs
stynger
rvtt94
WhiTe-WiiDoW-FR
GUILLOTES
aloux72
mhsc
4n701n3
angelus141083
sebinfamous
39 participants
description[ROM 4.0.3/XXLP5] [13-04-12] MIDNOTE 3.3 Codename "B&G" (LP5 ICS FULL Working and ITALIAN QUALITY) Empty[ROM 4.0.3/XXLP5] [13-04-12] MIDNOTE 3.3 Codename "B&G" (LP5 ICS FULL Working and ITALIAN QUALITY)
[ROM 4.0.3/XXLP5] MIDNOTE 3.3 Codename "B&G" (LP5 ICS FULL Working and ITALIAN QUALITY)[13-04-12]
Images et Vidéos
Spoiler :
Derniers changements
CHANGELOG V3.3:
- ENTIRELY BASED ON NEW "LP6" SAMSUNG ROM
- KERNEL IS LP5 WITH ROOT (Thanks to Chainfire)
- ROM is FULL ROOT
- Full 1.4 Ghz POWER
- Google locations still not present in settings, but working fine with my "2.2 workaround"
- Latest Gapps included
- Latest Facebook app included with external zip and works fine
- Latest "Facelock" included
- Contacts deleting works fine now
- All apps of "MIDNOTE2.2" included
- All chinese stuff removed
- Battery % now works fine (set it in display settings)
- Toggles in status bar now are SIX
- Vertical scrolling now is FASTER, Contacts included..
- NO "Android is updating" on every reboot
- Fixed Wifi "hangs" during reconnection
- Fixed notifications sound issue (both vibration and sound)
- Fixed "no T9 text when using smartkeyboard in browser"
- Added "Voice2go"
- Native SIP call enable
- Native CALL RECORDING
- Native CALL and SMS BLOCKING
- Native "Auto silent" mode
Anciens Changelogs :
Installation
Installation V3.3 :
-COMING FROM ICS ROMS
(ALL VERSIONS MIDNOTE 3.0/3.1/3.2 INCLUDED) WITH LP5 KERNEL AND FULL ROOT GUIDE :
ADVISE : DON'T FLASH FILES TO YOUR PHONE IF YOU HAVE NOT CHECKED MD5 !
1. Download the MIDNOTE3.3 zip file WITH MD5 6e929c82208c0e810349ab246efaa2dd : MIDNOTE3.3.zip - 583.5 MB
2. Reboot in CWM recovery, do a WIPE DATA / FACTORY RESET, DON'T EXIT FROM RECOVERY but select "step 1" zip file and flash it. Now reboot.
3. Wait for cache rebuild, then when prompted select "SETUPWIZARD" (the second choice), check time option to "auto", then CHECK BOTH GOOGLE LOCATIONS options (keep attention to this step), DON'T ENTER YOUR GOOGLE ACCOUNT name and password in this step, finish your setup. Now select the launcher.
4. If you like STOCK SAMSUNG THEME, download this zip and flash it with CWM recovery : MIDNOTE3.3_STOCK_THEME.zip - 22.2 MB
5. Some users reported me that new "SNote" doesn't works for them, if this happens to you, please flash this zip from CWM recovery (Back to "OLD SMemo") : MIDNOTE3.3_SMEMO_BACK.zip - 34.7 MB
- COMING FROM GINGERBREAD WITH FULL ROOT GUIDE :
1. Download base rom (named 2.1, but not important, is THE RIGHT ONE) : https://docs.google.com/open?id=0BzR...VG45YU1TR04zUQ
MIRROR 1
MIRROR 2 (Thanks to "ashwin123") :
Part 1: http://www.mediafire.com/?2i48uqmk7u7vvpt
Part 2: http://www.mediafire.com/?wkj5dq2v1ev78ap
Part 3: http://www.mediafire.com/?25971artyvthc3b
2. Download the kernel : Kernel
MIRROR 1 : zImage - 8.0 MB
3. Download the MIDNOTE3.3 zip file WITH MD5 6e929c82208c0e810349ab246efaa2dd : MIDNOTE3.3.zip - 583.5 MB
4. Do a nandroid backup of your actual situation
5. Open mobile Odin and select "open file", then select "step 1" tar file. Now select "kernel", then select "step 2" file (this time is "zImage" without any extension), verify that ALL (enable everoot, inject superuser, inject mobile Odin) are checked, then check also "wipe data and cache". Now press "flash firmware" and answer "yes" on md5 verify.....
6. After the flash, you will be in CWM recovery, do a WIPE DATA / FACTORY RESET, DON'T EXIT FROM RECOVERY but select "step 3" zip file and flash it. Now reboot.
7. Wait for cache rebuild, then when prompted select "SETUPWIZARD" (the second choice), check time option to "auto", then CHECK BOTH GOOGLE LOCATIONS options (keep attention to this step), DON'T ENTER YOUR GOOGLE ACCOUNT name and password in this step, finish your setup. Now select the launcher.
8. If you like STOCK SAMSUNG THEME, download this zip and flash it with CWM recovery : MIDNOTE3.3_STOCK_THEME.zip - 22.2 MB
9. Some users reported me that new "SNote" doesn't works for them, if this happens to you, please flash this zip from CWM recovery (Back to "OLD SMemo") : MIDNOTE3.3_SMEMO_BACK.zip - 34.7 MB
Tuto d'installation
Installation versions précédentes :
Téléchargements
Liens de téléchargement de la Midnote 3.3 dans le Tuto d'installation
Téléchargement Midnote 2.0 :
description[ROM 4.0.3/XXLP5] [13-04-12] MIDNOTE 3.3 Codename "B&G" (LP5 ICS FULL Working and ITALIAN QUALITY) EmptyRe: [ROM 4.0.3/XXLP5] [13-04-12] MIDNOTE 3.3 Codename "B&G" (LP5 ICS FULL Working and ITALIAN QUALITY)
Faut vous mettre d'accord Very Happy
et l'installation de ça "Download link CF-LP1 kernel CWM flashable" On la fait quand?
Je ne le vois pas dans les instructions d'installation, donc tu ne le flashes pas.
C'est si tu veux changer de kernel.
Voilà l'explication: Very Happy
Please, keep attention...
First of all, thanks to all you guys for your support.....but I want to clarify an important thing...
I made available both abyss 3.9 kernel and CF-5.2 ICS kernel in first post, because :
If you want or need to do some stuff with your ICS Note (eg. do a nandroid, flash a zip file, RESTORE a previous backup), you MUST :
1. Go to recovery
2. Flash Abyss 3.9 kernel (or an Abyss kernel with NO touch redpill recovery)
3. Reboot recovery
4. Do what you want (nandroid, flash a zip, restore)
5. Flash back CF-5.2 kernel (CWM flashable)
6. Reboot
That's all, thanks for your attention....
Edit : Procédure d'installation mise à jour en Post 1
Installation de la rom terminée (avec Abyss), pas de problèmes pour le moment sauf pour les apn de free que j'ai du faire à la mano l'appli mobileconfig n'y arrivait pas toute seule.
ROM terrible pas de bug tres fluide
Donc on peut installer cette rom avec cwm directement de Gingerbread, rom ELEGANCE par exemple ??
Parce que je suis un peu perdu avec tout ce qui sort d'un seul coup, même si c'est génial Wink
@aloux72 :il faut que tu suive ce tuto pour l instalation de cette rom en venant de Gingerbread :
INSTALLATION INSTRUCTIONS (coming from other bases like Gingerbread or CWM flashable ICS roms) :
1. Reboot in recovery
2. Flash Abyss kernel
3. Select advanced/reboot recovery
4. Select wipe menu and wipe data/factory reset
5. Flash MIDNOTE2.0 rom and stay in recovery
6. Flash Gapps 7.1 and stay in recovery
7. Select wipe menu and do a wipe cache/dalvik
8. Reboot
regarde bien le post 1
ok merci Wink
Sad Je voulais me rabattre sur celle ci...... Lien ne fonctionne pas !
Oui il ne fonctionne pas, bizarre.
Essaye un peu plus tard.
J'en cherche un autre.
Very Happy Si cela fonctionne en passant par fichier à gauche et télécharger.....
Exact, j'avais pas vu.
Il faut sélectionner: File et tout en bas il y a download.
Merci Guillotes Very Happy
elle est bien cette ROM ? je vais ré-avoir un NOTE en fin d'aprem acheté neuf, et j'aimerai passé a iCS directement... aucun bug particulier ? tout fonctionne ? appel ? etc ?
[ROM 4.0.3/XXLP5] [13-04-12] MIDNOTE 3.3 Codename "B&G" (LP5 ICS FULL Working and ITALIAN QUALITY) 61393
Foncez les gars..... Que du bonheur cette Rom ! Application du tuto à la lettre : 0 souçi
Clavier QWERTY mais c'est tout...... Facilement modifiable !
[ROM 4.0.3/XXLP5] [13-04-12] MIDNOTE 3.3 Codename "B&G" (LP5 ICS FULL Working and ITALIAN QUALITY) 2325459160
Le seul bug que j'ai pu constaté est minime, un petit freeze dans la galerie mais en sortant et entrant de nouveau tout est rentré dans l'ordre. Sinon cette rom est super fluide!
quelqu’un un a teste le CF-5.2 ICS kernel ?
Comment on modifie le clavier Qwerty ??
en installant un autre clavier par le market
https://market.android.com/search?q=clavier&c=apps
oui mais on ne peut pas mettre le swype en français ??
est ce que obliger de garder le kernel 3.9 ??
Tu vas tester et tu nous diras Very Happy .
