[ROM 4.0.3] ICS AOKP For Note! Build 27!
description[ROM 4.0.3]  ICS AOKP For Note! Build 27! Empty[ROM 4.0.3] ICS AOKP For Note! Build 27!
[ROM 4.0.3]  ICS AOKP For Note! Build 27! Aokptitleblue1
So I Took time out to Port AOKP (Build 27) For Galaxy Note Based On imilka's AOSP ICS v04 ! So The Bugs Will Be Same As It!
Credits to Team AOKP & imilka
Touchscreen & S-Pen Fix thanks to segunmichaelolu
Screen
[ROM 4.0.3]  ICS AOKP For Note! Build 27! Screenshot2012030419491
[ROM 4.0.3]  ICS AOKP For Note! Build 27! Screenshot2012030419492
[ROM 4.0.3]  ICS AOKP For Note! Build 27! Screenshot2012030419493
V2 : Updated to AOKP Milestone 4 Build !
Fixed Facelock!
Added CM9 Music!
Added Google Play Music (So that Market Play Update Triggers)
Changed default Lcd density to 200 Dpi
Auto Efs backup at boot !
Chrome Browser added!
Build.prop tweaks!
Default Tablet Mode Ui!
Spoiler :
ROM Control- Tons Of Features To Customize!
Android 4.0.3 -- IML74K
Unsecure boot.img (stock AOSP kernel)
Superuser & Busybox preinstalled
Deodexed
180 Degree rotation
Built in performance/init.d configuration (Thanks Kejar & company)
CM Launcher/ Power Menu
CM Brightness slider
Custom color for anything in RC
Clock Color/Location: Right, Center, Disable
Battery Icon/ Color Picker: CircleMod, Bar, Text Only, Icon Only, Icon+Text or None
Battery Bar in Status Bar or Nav Bar, Bar Thickness, Charging animation
Nav Bar Transparency
Nav Bar Button Reorder: Back-Home-Search-Menu
Nav Bar Color Picker
Nav Bar Button Glow Duration: Off, Fast, Slow
Nav Bar: Long press to Search button
Nav Bar Hide on Lockscreen
Toggles in Pull Down Menu: Auto rotate, Bluetooth, GPS, Wi-Fi, Aiplane mode, Vibrate, Silent, Sync, Data, 4G, Tethering, Torch, Brightness
LCD Density (Careful with this)
Menu Button location: Right, Left, both, Remove
Menu Button Visability: Always show, Always show Invisible Icons
Lockscreen Style: Quad, Octo, Stock
Lockscreen SMS customizable shortcut
Lockscreen Horizontal Option
Performance Menu: (Use With Caution) Max/ Min CPU, Scaling Governor
Unlock Sceen with Legacy Menu Icon
Volume Key to Wake Screen
Volume Key to Skip Tracks
Long-press back button to kill process
Disable CRT off animation
LED pulse settings (time on/off)
ICS ringtones/notification sounds
Customize carrier text to whatever.
Power Menu options: Boot to recovery/ Boot loader, Reboot, Screenshot
Facebook contact sync integration (must wipe to get this)
Disable Boot animation
Keyboard: Volume keys act as a cursor while typing
BUG
Toggles Dissappear Sometime
http://goo-inside.me/devs/eaglerazor123/AOKPNoteEag.zip
Si vous venez d'une ROM GB flashez d'abord ceci http://www.mirorii.com/fichier/3/501...EPACK-tar.html via MobilOdin et laissez redémarrer (il redémarrera sur le recovery) puis flashez la rom avec full wipes
Source : http://forum.xda-developers.com/showthread.php?t=1531367
description[ROM 4.0.3]  ICS AOKP For Note! Build 27! EmptyRe: [ROM 4.0.3] ICS AOKP For Note! Build 27!
Avis au testeur... j'attends des avis, le seul truc qui me freine c'est les 3 boutons la...
EDiT : aprés visionnage de la vidéo, on peut enlever les boutons du bas ! donc en cour de DL et test cheers
Merci pour le partage. Very Happy
Tu peux rajouter la source stp Wink
Merci du partage.
hello
j ai commence a tester depuis deux jours
pas mal
petit beug pas de logo de signal 3G ou 2G le logo reste muet
probleme d affichage sur la saisi des code pin l ecran disparait ou est fractionner
sur certain menus deroullant aussi
on peut suprimer les 3 bouton mais j y suis pas arrive......une vraie quiche
pas de montage usb il faut passer par droid exploreur
stable pas de force close
je la garde sous le coude.......
Merci pour ton retour
pas de quoi BigPat
Originally Posted by lewisteo
Hey, you should at least read thru the threads.
it's only 17 pages and I remember seeing someone posted screen shots as to how it is done a few pages back -
"how to get tablet mode on this rom *thanks fards*
boot your phone into 160/180/200/213 dpi whichever you choose to use.
go to Rom Controls
Navigation Bar
make sure "enable bar" is disabled.
change color to whatever you want *optional*
nav transparency 100%
nav bar height and width "default"
Power Menu Options
Show navigation bar toggle "enabled"
now hold power to bring up power menu options
disable navigation bar, enable navigation bar *power icon under navigation bar controls*
reboot
now hold power to get menu again and disable navigation bar
you should now have the tablet navigation bar up and running.
SCREENSHOT (http://yfrog.com/z/mti4zp)"
A good bro had already illustrated kindly to all.
source
http://forum.xda-developers.com/showthread.php?t=1531367&page=18
si une bonne ame pouvait traduire .............vraiment une quiche la aussi
cela sert a avoir les options tablette
@BigPat : je rajouterai la source
Ensuite faut que je rajoute également, si vous venez d'un ROM GB il faut installer un pack... je mettrai a jour le 1er post
v2 de sortie
en chargement..... bounce
Post 1 mis a jour
V2 en cour de DL mais que c'est long pour un poid si léger xD ! sinon j'espére que quelques bugs on disparut... style pour choisir les sonneries tout ca
je voulais vous demander si cette rom était assez stable pour pouvoir l'utiliser tous les jours.
Venant d'un Desire HD sous Ice Cold Sandwich, il est vrai que ICS me manque beaucoup, du coup je suis à la recherche de la meilleur Rom sous ICS.
Merci de votre réponse.
Cordialement.
Moi, je l'ai installée, les deux launchers plantent donc impossible d'aller plus loin que le démarrage.
Ah oui pas mal ça...Bon ben je vais attendre un peu alors.
Merci de l'info.
ca y esssssst
vraiment de la balle
les deux launcher plante c est vrai
j ai ADW est ca tourne
nova launcher tourne aussi
une vrai tablette
j ai des probleme avec le verrouillage
il faut l enlever sous la version B27 puis le remetre sous la v2
instalation
recovery------>abyss------>reboot recovery(rouge)------>flash----->LP1_KERNEL----------->reboot
cheers cheers
je garde pour l instant
Ah...y a pas de reseau....non toujours pas d icone 3G/2G
j ai ma tablette en plus petit Very Happy
Pour ceux qui trouvent que lien de la v2 rame:
Mirroir
Things To Do After Flashing!
Remove Apex Launcher As It Fc's!
Wierd! Both Launchers Seems To Be Fc's!
Install Nova Launcher Via ADB!
Here it is http://min.us/me2kzrO68
Donc c'est normal si les 2 launchers plantent.
Il faut installer Nova Launcher
@xMiixOmAtiiK: je te laisse faire les mises à jour de ton post.
Si tu veux un coup de main, n'hésites pas, on est là pour ça Wink .
Installer avec adb, c'est depuis le PC ?
ou tu decompresse ton fichier zip
tu va dans AOKPNoteM4\system\app tu suprime les deux autre lancher
tu met a la place nova launcher
tu zip
et tu installe
je vais essayer sans suprimer les deux autre
je vous tient au courrant
......bon ca marche mais j ai plus l afficage tablette
j ai change le dpi en meme temps 200---->240
je remet en 200 et j ai l affichage tablette
j ai vire Launcher2 pas trouve l autre "Wierd! Both Launchers Seems To Be Fc's! "
J'ai ajouté l'application directement dans l'archive sans décompresser et ça fonctionne.
Mais j'ai un problème de résolution qui a été changée dans la rom et nova ne prend pas toute la taille de l'écran.
edit : ça va mieux en augmentant le nombre de lignes et colonnes du bureau.
edit2 : on peut aussi changer la résolution des les paramètres.
V3
AOKP M4! AOSP V05 base + Fix's Galaxy Note Build3
Changelog:
-inverted some gapps *gmail, play market, talk, google+, email*
-fixed graphic glitch's *thanks fards for the help*
-reworked build.prop *thanks again fards!*
-Aosp v05 base
-external sdcard fix *now shows under /mnt/sdcard/external_sd
-more i cant think of right now.
http://www.mediafire.com/download.php?lqu8d718sewi282
moi ca fonctionne niquel
Ce que je trouver dommage , c'est qu’il n'y a pas les applications pour le stylet comme S mémo.
On peut pas tout avoir ......... o_O
Mais sinon, elle est ultra fluide comparé aux autres ROM que j'ai testées.
Il y a bien cette page sur XDA, mais le lien est mort [ROM 4.0.3]  ICS AOKP For Note! Build 27! 60586
EDIT : Mais en partant d'une ROM officielle (opérateur ou non) on peut extraire le'APK, il me semble Wink
J'ai déjà essayé mais l'application ne veut pas s'ouvrir.
Ah zut, c'est là dessus que je comptais pour ce W.E.
...après le flash de mon Gnote qui arrive vendredi ... Rolling Eyes
EDIT : Je ne ferais que le ROOTer alors ...
Reste plus qu'à attendre ICS officiel et re-ROOTage
