[ROM ICS 4.0.3/NO SENSE] Domination - Taking Cyanogenmod to the next level [Build 8] [13.07.2012]
+8
lecobra
iciTeLLuRiaN
pirouli
jeanmarce
Tr4k3r
ElRey
thierry94120
12 participants
description[ROM ICS 4.0.3/NO SENSE] Domination - Taking Cyanogenmod to the next level [Build 8] [13.07.2012] Empty[ROM ICS 4.0.3/NO SENSE] Domination - Taking Cyanogenmod to the next level [Build 8] [13.07.2012]
Why is this ROM "taking CyanogenMod to the next level?
Cyanogenmod does not want to include many customisations like they did in cm7
But why not? we want to customize our phones!
This ROM adds more options and cherrys to CyanogenMod, cherry picked from the CM gerrit, Google gerrit, AOKP gerrit, many github pages that are around or made by me
This ROM also includes a lot of experimental changes like many NEON optimized code sets, better libraries like jpeg-turbo and tweaked surface flinger, skia and many more
Want to turn the recent panel in to a app killer?
Just select the option for a kill-all button!
You want to use this big awesome screen for tablet mode?
OK! just boot in tablet mode then!
You want to reboot but don't wait to long?
Just execute an hot reboot this is 50% - 70% faster then a normal reboot
You want a custom denisty?
got that covered!
Hate the default Roboto font?
Just change it to another font with the build in font changer!
Hate the stupid useless overflow menu button (onscreen menu button)?
Also got a option for that just hide it!
Hate the ugly Android Global Action (power menu) dialog?
Just change it to a nice 3 row picture view without text
In Android you can swipe from the top of the screen downwards to expands the status bar
Why only from the top of the screen?
In this rom you can define actions for
Swiping top edge
Swiping left edge
Swiping right edge
Swiping bottom edge
for example if you want the hide the status bar you can simply define a swipe action for it to an edge you like
And there is many more in this ROM!
Stock but still highly customizeable the way we like it
[ROM ICS 4.0.3/NO SENSE] Domination - Taking Cyanogenmod to the next level [Build 8] [13.07.2012] Owain
[ROM ICS 4.0.3/NO SENSE] Domination - Taking Cyanogenmod to the next level [Build 8] [13.07.2012] Screens
Installation
Ce qui est nécessaire :
-TUTO Préparer le HTC One X pour le débloquer, pour installer le recovery, le rooter et installer des roms customs [Windows] [10.04.2012]
Comment flasher :
-Téléchargez la ROM et copiez la sur votre SD card
-Démarrez votre appareil en mode recovery (vol down + power)
-Faîtes un Factory Reset(3 fois) / Wipe data(3 fois) / system/cache(3 fois) avant d'installer la Rom.
-Dans le menu principal, sélectionnez "install zip from sdcard"
-Sélectionnez "choose zip from sdcard" et allez où vous avez mis la Rom.
-Sélectionnez-la par "Power" et flashez-la.
-A la fin du flash, redémarrez l'appareil. (Reboot system now).
Procédure pour installer le fichier boot.img :
Spoiler :
13 juillet 2012 - Build 8 :
Odexed
Hybrid bar in JellyBean syle
Swipe gestures and key configuration for hybrid bar
A lot of fixes for the hybrid bar
A lot of Power Widget improvements
Camera burst shot
Camera ISO
Smart call option
Statusbar brightness sliding and longpress
Settings apk GPS toggle (right under WiFi and Bluetooth)
Settings Processor.java: Fixes and Cleanups
Mms: fixes battery drainage while receiving Mms with data connection off
Libjpeg-turbo is back
Externalize symbol picker options to resources
Mms: cleanup in locale
Fix a possible off-by-one in the dalvik verifier
Camera: ZSL (ZeroShutterLag)
Settings: Fix Notification light 'Always on' test
Battery light: Add ability to reset the colors to default
Camera: added continuous-picture focus mode
Dalvik: switched code to blx
Dalvik: hprof generation, not writing the first record
Improve HttpResponseCache performance
Option to let the ringone start with low volume and get louder.
Option for rotating while in call
Option to use the statusbar while in call
Option to fade touch keys while in call
Standardized keybord input
Removed lockscreen branding
Fixed WiFi and Bluetooth activating when opening settings.apk
Tethering fixed
Anciennes versions :
Spoiler :
endeavoru-Domination.zip - Lien 1
endeavoru-Domination.zip - Lien 2 (Miroir)
Spoiler :
description[ROM ICS 4.0.3/NO SENSE] Domination - Taking Cyanogenmod to the next level [Build 8] [13.07.2012] EmptyRe: [ROM ICS 4.0.3/NO SENSE] Domination - Taking Cyanogenmod to the next level [Build 8] [13.07.2012]
Add-ons
-gapps-ics-20120429-modified-for-custom-density
-gapps-ics-20120429-stock
(Si vous avez un problème avec le package modifié, flashez le stock package)
-gapps-ics-20120429-holo-black-addon
Kernels
-Repacked pour les roms SlimICS et CM9 Builds
-Stock kernel - Intrepresentation
-One-X Sense 4.0 (002 beta 6) - Faux123
-franco.Kernel-r9 - FranciscoFranco
Merci Colonel. Ca semble intéressant. Qui essaye? Moi j'en ai un peu marre de flasher du matin au soir... Wink
Bonjour Thierry,
Mais de rien, effectivement ça semble intéressant mais je n'ai pas le temps de tester pour le moment.
PS : La traduction en français arrivera un peu plus tard Wink
Ouais j'aurais bien tenté aussi, mais tous ces flash, devoir tout reinstaller, ça me gave.
Puis sur Cyanogen, tant qu'il n'y aura pas beats audio c'est mort ...
Salut à tous.
Elle a l'air sympas. smile Merci de partage Colonel Wink
Bonjour Tr4k3r,
Mais de rien Very Happy ,
Et bon test à tous.
ça va alors cette V3 ? smile
Je test ça plus tard je veux me poser sur la v.3 ce soir et y rester un peut. smile
Une excellente rom cette v3.0 de Dougi.
Il y a publié un correctif donc la v3.1 est sortit, je suis entrain de la télécharger.
salut a tous je vais me lancer vais la tester pour voir [ROM ICS 4.0.3/NO SENSE] Domination - Taking Cyanogenmod to the next level [Build 8] [13.07.2012] 69699
peut êtres une bonne surprise Wink
Je viens de l'installer. Pour l'instant, pas de bugs comme celle de Trip. Ca a effectivement l'air d'une bonne surprise, mais faut voir à l'usage.
Je la teste aussi on verra....
jeanmarce j'ai vu que le kermel r9 est en zip, tu le flashe comme la rom?????
lol moi pour l'instant j'arrive pas à la faire booter [ROM ICS 4.0.3/NO SENSE] Domination - Taking Cyanogenmod to the next level [Build 8] [13.07.2012] 69699
normalement faut extraire le boot.img du kernel pour l'installer en mode bootloader
J'ai pris le fichier stock-kernel.zip. J'ai extrait le boot.img flashé comme d'hab, et le stock-kernel.zip je l'ai flashé en recovery, comme les modules des autres kernels.
EDIT: 1er petit souci: je sais pas pourquoi, tout d'un coup tous mes APN avaient disparu, plus de signal. Un reboot et c'est revenu tout seul!
EDIT2: il y a des tweaks, mais j'ai du mal à comprendre ce qu'il font! Jeanmarce, toi qu'aime pas l'anglais, tu vas être gaté! [ROM ICS 4.0.3/NO SENSE] Domination - Taking Cyanogenmod to the next level [Build 8] [13.07.2012] 3571724197
ouf enfin réussi en plus de ma faute quel con maintenant ça boot Very Happy j'ai installer le kernel franco pour voir Wink
t'inquiète je vais y arriver [ROM ICS 4.0.3/NO SENSE] Domination - Taking Cyanogenmod to the next level [Build 8] [13.07.2012] 69699
pour l'instant j'installe toutes les option Wink
rom très fluide en plus je trouve la qualité de l'image sur l'écran plus jolie
Bonsoir tout le monde,
Merci pour vos retours.
@Pirouli : S'il-te-plais, peux-tu éviter les doubles posts, le bouton "Modifier" est la pour éditer tes messages.
Merci par avance.
@thierry94120 pour les tweaks rien trouvé de très intéressant je laisse tout par défaut Very Happy
excuse moi colonel59, j'ai pas fait expres, pour moi installée par dessus cm_endeavoru, sans full wipe, j'ai installé le kermelR9 de francisco, tout marche pour l'instant, a suivre.....
pour l'instant elle déchire cette version la meilleure cm9 que j'ai tester
vais voir si je peux installer Bricked-Kernel car j'aime de trop lol!
non marche pas Sad
Est ce que Beats Audio est integré dedans?
non pas de Beats Audio
Roh c'est chiant ça, il y a vraiment rien qui remplace ce truc, et ça améliore vraiment le son ...
franchement avec ou sans Beats Audio j'ai un bon son avec le casque je viens de tester sur cette rom le son très bon lol!
